View Full Version : Drag Racing Tech
- 15" ProStar grinding question
- How to run the Hals?
- 9 Second Club Member and New LS1 M6 Record
- ET Streets or ET Drags, Diameter?
- Wow, a new best for me!!!!!
- E/T Streets: how much wear is too much?
- One Mile High Speed Shoot Out at a retired Air Base in Texas
- To all running Mezeire race water pump....
- 10.99-Faster GMHTP Southern Shootout
- I'd rather be drag racing..
- Anyone run V6 springs in the rear?
- 320 horses???
- Requesting some pics of carb'd 4th-gen racecars
- Video BeaSSt 9.69 vs Jay Johnson
- What wheel studs and valve stems to run 10's?
- Which wheel studs (NHRA) for Bogarts?
- New England Dragway results
- Fastest bolt on w/out headers with or without nitrous???
- Need idea of possible times with changes...
- Any pics of Dynabatt hold downs, pre-made or other......
- How is the DA calculated?
- anyone have pics of BMR extreme T/A installed
- Classes/Divisions and Rules for 1Mile Shoot Out
- Where should i be with these mods?
- Major launch problems. Help please
- Best alignment specs for drag racing?
- Kinda disappointing day at the track
- Please keep in your prayers
- Et Streets, Need size help!!
- 255/50-16 or 295/35-18 BFG drag radials?
- 168 MPH
- help with a suspension setup on a 4k yank car
- 9's are getting closer
- External Kill Switch???
- SAM The BeaSSt goes 9.69 @ 141.22 NA
- LS1=good back-up bracket racer!
- New best at New England Dragway
- Possibly looking to race....
- launchin
- First Time
- Good night of racing, and a mild heartbreaker at the end
- Patriot Head ETs
- Help guys, My car is still slow............
- what would -Tq arm and lca angles do to street driving?
- Camaro Weight Reduction Shop?
- 120 octane unleaded ?
- Cinematography Skills as demonstrated by some of our members
- True duals with torque arm other than stock........
- lightweight carpet install
- Weld Magnum Drag one peice front skinnies
- 1/8th track results with Cam
- Finally got some track times
- Optima dry cell in the hatch w/o sealed box - Safe?
- Going to the track Saturday. Quick ?
- Now im NHRA/IHRA legal(roll bar came today)
- Raptor shift light, What to set it @?
- Just got rid of 4* of false knock. How much will I pick up?
- ET Database not working??
- 10.94@125.51 N/A
- What does a stock stripper SS weigh?
- Worlds Fastest Supercharged LS1
- GETEM BIG DOG PUPPIES DONT BITE *DELETED*
- Do I have enough exhaust?
- I said SuperCharged not NOS *DELETED*
- First Time to Track
- 1185 HP LS1 *DELETED*
- Who has C5R heads on their car?
- 7300 rpm safe with arp rod bolts and forged pistons?
- Painting weld in roll bars
- Burning Out Makes Launching Hard?
- Quick answer needed...Will 26 x 10 x 15 MT ET Drags fit...
- When do I need a roll cage?
- WHICH K MEMBER AND A ARMS ARE YOU USING?
- Anyone going to Pittsburgh Raceway for test and tune tonight
- 98 C5R Drag Camaro Update
- Pro Shifted T56
- !Washer fluid tank?
- alot more road noise with lightweigt carpet?
- brake stall ? please help
- Hoosier drags vs. MT ET drags
- Driving On Et Streets?
- Anyone need a Wolfe rollbar or rollcage?
- Dyno and track times
- What kind of 5 pt harness are you using?
- Wolfe rollbar people.....
- New dyno #'s
- When to shift?
- Launching a M6
- Racing a A4, what gear to start in???????
- in what gear at 1/4 mile mark?
- Will crappy weather and track prep make me loose 4-6 MPH
- what should i expect at the track..
- Dragged a 2003 cobra conv with a 2001 SS conv.
- First time at the track.
- Final Ruling on Stock Suspension
- M6 cars with drag radials please come in???
- Hoosier 26x10x15 better than Et drags?
- 11's so close
- New Best with low dollar heads/cam M6
- Hit the track with FMS 348 solid roller ....10s NA!!!!!!!
- Lastest Drivetrain Setback! Twin Disc!
- Pics of my LG custom rollbar, dyno graphs
- Big Dog race
- Removing ABS with a line lock.......
- Big 10.5 race in Huntsville Al. September 20-21
- First time out with .231/.237
- New best, but still no 9 sec club member
- Fastest h/c 6 speeds with POS stock 7.5"- is there a list?
- New Times on little tires
- Owned in the final by Limp Home Mode.
- Fastest TEA Stage 1.5 in the country???
- Burnout Problems, and Linelock Question?
- DERTY goes 9.88@138!!
- went to the track
- Rear suspension rules clarification for Southern Shootout
- Possibly the worlds slowest ls1???
- anyone have mad mans number?
- Rapid / ARE Rule N/A 9.735 @ 138.74!!!
- Wtf, Car is really slow, Need Help
- 5,000 dollar grudge match????
- A.R.E In Car Video 8.60's
- Yes, yet another guess my time.... C1 cammed SS
- DRAG SLICK POLL - 9 SEC .CARS
- A.R.E 8.54@167.33 VIDEO!!!
- Stock Bottom End 10.04 Last night (video inside)
- weight of a stock 2000 WS6???
- Why is no one running BFG DRs? (9-11sec ETs)
- Harlan - 2-step/nitrous question
- Paint cracking with !bumper support
- How much did you lose by?
- Instructions for installing an air bag.
- I'm looking for my rear end...
- Gearing ?, how fast are you REALLY going through the traps?
- Paging TOPLESSTA
- Traction woes
- Need some help removing dash. PLEASE!
- vacuum pump?
- need to archive this for others to use: battery relocation
- What to do with heater core send/return lines ?
- SAD DAY, car is for sale.....
- cam only class 10/4 at Maryland International Raceway
- roll bar questions
- will this tire hook 425rwhp ???
- who is interested in a FIREHAWK fiberglass hood from VFN
- M6 guys with 4.10 or higher gears...
- looks like you all owe the NHRA an appology
- 12 bolt+1.4 60's+ spacers?
- Is this wheelhop?
- Does F-Body stand for Fat-Body
- Hopefully I'm on my way to some 6.9s (1/8)
- What to get next ?
- To those who cut the bumper cover to fit tires....
- Anyone get rid of the plastic/foam on firewall?
- stock time?
- What should I run at the track with these mods?
- would relocation brackets make a diff on adjustable lca's?
- King of the 1/8 mile burn out.
- Much differance between manual brakes and abs?
- first time at the track with my new TA..????????
- 10's finally!!!!
- 28x10.5x15 ET Drag?
- 8.54@167.3 MPH !!!! ARE SITTING PRETTY! WOOF!!
- 8.56 @ 167 MPH!!!!!! 1.31 60!! ARE RAISES THE BAR!
- Cage Question
- ARE's Silver Z 8.67@160 1.32 60' !!!!!!!!!!!!!
- '02 SS vs '02 WS6 (stock for stock)?
- 10.750 @ 128! also have quick question....
- First time ever down the 1/4
- Weather and 1/4 Times...
- who has a TA and !bumper supports
- Tires rub after LCA reloction brackets
- Does anyone else make a two step that works on LS1?
- Power shifting
- Gain going to 4.10's from 3.42's?
- Spohn Torque Arm road noise.
- Will these hood pins work (HUMOR)
- Tom the roofer was flyin tonight.
- Light battery up front or regular battery in back??
- 4th Gen Fbody Shootout in Md Oct 4th
- stronger torque arm needed???
- what size fittings go in the PS pump??
- 11.60 at 116.9, with room for improvment
- See? Im not dyin, took new TA to the track last night
- Interesting time slip from last night
- "Breaking in" a new set of QTPs
- What's the worst DA you've seen on a track day?
- Oldtimers who are MIA, what are they up to?
- OC or US41?
- E/T Drags rubber removal
- modding a VR-4 to beat a saleen
- WHAT NEXT?
- Need to drop .3 to get 12s. help
- Long Distance Driving on Skinnies??
- Roll cage with swing outs?
- Hal contact info ?
- Taller tires = more or less RPM in shift points?
- Few FI videos from Sat morning
- Vid of 10.9 pass
- Bracket racing this weekend
- Car feels lose up top at the track
- 60's- ported vs stock heasds
- Went to HRP tonight, VERY happy with the results
- just ran the 1/8 for the first time, need imput!
- Reliable mid 11sec daily driven car for $2500?
- Anyone running suspension limiters?
- does anyone make a fixed rate strut?
- Pop's 02 Z06 Runs
- Cam only: 12.101 @ 116.81 on Nittos with new clutch!
- Would anyone here recommend Hal's?
- HAL shocks/front spring height question.
- Another New Best
- Thoughts on Removable Roof Panel cars and Racing. (T-Top)
- Where to buy a trailer from?
- New best at PRP today with stock tune
- Can I remove my cruise control and if so how
- Back from the TFBM/ARE Drag event!!!
- The Rollbar/Cage/T-top rule... The Future of Drag Racing...
- proper tire size needed please???
- Failed my chassis certifcation today....
- WTF is my problem?
- Who's going to PRP today?
- 1st Time to the track and good results
- Help with Torque Arm Decision
- Which Relocation bracket hole with -2 degrees pinion angle?
- Fire jacket question
- Bigger bang for the buck, LCA's or Torque Arm?
- The NHRA is NOT changing the Rollbar rule for 2004.
- PCV mod regain HP?
- Going to the track for the first time...............
- Gutting all underhood wires??
- 28x9 ET drags VS 27x10.5 QTP
- Okay I need a Guess on my weight.
- How much rear wheel HP to gain 1 mph in 1/4.
- Decomissioned: Turbocharged 3rd Camaro
- What should i be able to run?
- 13.1 ET ?? Need your suggestions
- Weighed the Firehawk tonight......
- Lightweight carpet...
- How much ET are skinnies worth?
- where in NHRA rules says spacers are illegal?
- Tommorrow's my last track day
- Attention all T-Top cars
- QA1 Hals in the rear
- pittsburgh raceway tomorrow anyone? *DELETED*
- QA1 really rock!
- Short belt keeps walking. Any advice?
- Light weight hood ??????
- What short belt does everybody run??
- what kind of times should my car run NA and juiced 100 to 75
