PDA
View Full Version : Drag Racing Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
  1. why does it bogg
  2. Lightweight Battery help?!?!?!?!?
  3. Lakewood Trac-bars
  4. Is beadliner spray heavy?
  5. Rear Sway Bar
  6. corrected timeslips VS corrected dyno #'s
  7. m/t e.t.street 26x10.5x15 vs 28x10.5x15
  8. Buy My Rolling Chassis :)
  9. harlan 2-step relay wiring question
  10. 15x10" Welds with 26x11.5" ET streets?
  11. Who makes braces for wheel stands to save the oil pan?
  12. Nitto Drag slicks
  13. Quick Help.. What lite weight brakes??
  14. Q. about timing sets for serious power
  15. AJE Front end
  16. Launching a4 with drag radials
  17. Where can I find 15x6 rims with a 4 on 9.4 bolt pattern for my trailer?
  18. shifter Q
  19. ExperiencesWith ETstreets. On 16x8s?
  20. How hard can you Launch!!
  21. Pin on hood, yay or nay.
  22. Is Snell Rating 95 out-dated for 06?
  23. is it the ASR or the cruise control?
  24. 28" tire too much for me?
  25. Manual Rack?
  26. My set up
  27. A-1 technologies bolts/studs
  28. Meziere Race pump guys....
  29. bumper support
  30. Liftin' em with Bolt Ons
  31. more HP with a ypipe and a cut-out .... OR 2 bullits comming off the hdrs
  32. stay with fast 90 /90 or
  33. PC680...How do I connect the batt.terminals???
  34. Search is down: What is an Edelbrock Victor Jr worth over a Fast 90/90?
  35. times after installing supercharger??
  36. Why cant the makers of the TA's make a end to fit the Moser rear?
  37. Ram Air Hoods at high speeds? 170+MPH
  38. SS Lift-Off Hood
  39. Got two size rims what setup to use?Help
  40. Pro's and Con's to Trans Break
  41. My solution for BMR torque arm with Moser 12 bolt
  42. Spohn Torque Arm
  43. Ultrabell, What else is needed??
  44. 15x8's or 15x10's for the track?
  45. Pics of custom gauge setups(I searched)
  46. ET Streets or BFG Drag Radials????
  47. Weather Station ??
  48. New setup seems to be running fine...
  49. Anyone know where to get an inline thermostat?
  50. k-member, a-arm, shock, and manual rack choice help.
  51. weight loss and actuall time
  52. What do you guys think about this?
  53. ws6 losing weight
  54. What will it take to get 500 to 500+ RWHP?
  55. removing the front swaybar really worth it???
  56. Help with Tire Thread Size
  57. Attention W2W engine build customers
  58. Where can you get the bearing kit for QA1's
  59. 10 pt with removable door bars...I searched
  60. Spohn Torque Arm...Do I have to beat Floor board in??
  61. 2 step
  62. Burnout impared
  63. Weight reductions for the c5?
  64. removing AC?
  65. Line Lock?
  66. trying to start a aerospace gp take a look
  67. battery kill switch
  68. winterizing engine
  69. 28" tire too much?
  70. 1/8 mile times
  71. 255/50R16 MT or 275/17 NITTO???
  72. BMR torque arm with a Moser 12 bolt (few issues)
  73. Year One Battery Tiedown
  74. need help....!!!!!
  75. Driving on skinnies?
  76. 400 RWHP to hit 10.99999??
  77. ET Streets, Or MT Drag Radials?
  78. scatter shields... what are you using
  79. Rearend alignment = torque line issues! Need help!!
  80. Thanks, tech forum
  81. weight savings
  82. Aftermarket Steering wheel???
  83. 28 inch tall tire 15 by 8 or 15 by 10 wheel
  84. SFI 25.5 rollcage in late model F- Body
  85. Gains 3:42 to 3:73 in A4??
  86. SFI 18.1 Balancer. Who??
  87. Hawker/ Odyssey 680 users, question---
  88. QA1 Double Adjustables?
  89. mach 1 question...how fast???
  90. Whats the difference between QA1 Gen F and R's
  91. Has Anyone heard of/used these wheels?
  92. Ladder Bars?
  93. Will a 27" tire be enough when I spray
  94. mini tub and lca question?
  95. How much does my car weigh? (Estimates?)
  96. density altitude in chicago 9PM
  97. Anyone read Car Craft (Dec 05)... WTF???
  98. Front end
  99. wolfe 5 pt
  100. Whose car weighs in the 3000-3100lbs Range?
  101. 3rd gen manual steering
  102. 10pt wolfe
  103. QA1 height adjustment
  104. QA1 Gen F or R series
  105. Advice to set up 2002 T/A
  106. Does this weight sound right?
  107. Is there an easy way to remove spot welds?
  108. et fronts vs radial front runner
  109. Few questions for those who care
  110. Flywheel weight w/ auto tranny
  111. Weight vs Horsepower
  112. Tig welding chromoly cage?
  113. Line Lock?
  114. Help with big gear/stall shiftpoints.
  115. Manual Brake Setups
  116. why didn't I go faster?
  117. 15x7 third gen wheels with 195 tires... on the front of a 4th gen
  118. Formula weight?
  119. A little HELP
  120. MT DR's and no traction WTF???
  121. 2 step?
  122. Drag race procedure
  123. Performance Racing Industry 2005 Photos!
  124. 60' Question
  125. Breaking Point ...
  126. Power steering plug
  127. Track experts, please analyze & comment.
  128. Help with Rollbar, 6/5pt.???
  129. what tire
  130. Any suggestions on making car more consistant?
  131. anyone used spares for front runners??
  132. Gains 3 mph in the 1/8 but only 1 mph in the 1/4
  133. Help with Drag Suspension For Trucks
  134. QA1 insatll questions
  135. Pics of my bullets on long tubes.
  136. Can I run 1pc Magnums on the street?
  137. light weight battry? where to get one?
  138. 90Z28 v/s modding formula
  139. Pics of my homemade Subframe connectors
  140. Aluminum Center section on street?
  141. TCS with TH-400?
  142. Time Guesstimate for me?!
  143. Snell 90 or SFI 41.1A .......SFI 41.2A ??????
  144. Radiator recommendations
  145. dropping some weight! come in with more ideas
  146. Shell M2000 or SA2000?
  147. post your pics of your aftermarket shifter. i searched
  148. How much can you narrow without mini tubbing?
  149. Wolfe 6 Point RollBar ???'s
  150. Woohoo, motor is out! Need specifics for new motor.
  151. How'd you guys mount ur race seats?
  152. Which Grant wheel looks best in a Camaro?
  153. Weight of 98 V6 camaro??
  154. meziere race pump on weekend car?
  155. Photoshop Wheels?
  156. What parts to buy ??
  157. Estimate on vehicle weight???
  158. Stenod Performance Cage Complete (*PICS*)
  159. new about my light weight battery pc680 (pics inside!)
  160. Bogart Wheel GP?
  161. What about Summit Poly seats?
  162. Race weight
  163. i need help
  164. Quick ? about oil...
  165. plates for a/c and radio
  166. trans mounted or tunnel?
  167. Coil Relocation locations
  168. !air bag tricks? (driver/pax)
  169. cruise control removal
  170. z28 rear spring part number?
  171. Fastest 60' on street tires?
  172. ported tb
  173. Skinnies and Meats question....
  174. Torco race fuel concentrate?
  175. Anyone use a vacuum pump for their brakes???
  176. Expected HP and 1/4 times
  177. My attempt at minitubbing
  178. SME Conference & Expo. ??
  179. subframe connectors help ?
  180. The best springs and shocks ??
  181. What is the best sway bars ??
  182. Using nitrous?
  183. what tire size with 2700 pound cam only car
  184. Tire/60 foot questions...
  185. Vacuum pump problems--race car guys inside please...
  186. light SFCs
  187. rear end question
  188. S&W racecars roll bar
  189. M&H Drag Slicks
  190. Ported TB gains on H/C
  191. What to do to prevent from engine losing oil do to wheelies?
  192. cam only ls1 times
  193. Strang Shocks
  194. Kirkey seat???
  195. Madman Rack install question
  196. Everyone who wants to hook great and pull wheels needs qa1s and et street radials!!!
  197. LS1 Drag Racing gets boost from NHRA
  198. Will 3:73's blow drag radials off the line?
  199. Which headers? And other suggestions.
  200. Swiss cheesing Kirkeys?
  201. Kirkey Seat Brackets
  202. Door Panels
  203. Picking a specific torque arm based on setup ?
  204. Tcs/asr?
  205. What style suspension?
  206. question about trap speed
  207. Motor is toast, need ideas on what to build?
  208. Where can I get bearing for front QA1's
  209. Help my 60'
  210. light weight starters?
  211. spacers ok??
  212. Adj. vs. Non Adj Torque arms
  213. competition engineering 3-way drag shocks ???
  214. BMR Xtreme duty torque arm questions
  215. Upper ball joint bind?
  216. Strange double adjustable rear shocks question
  217. G2 harness bar install question
  218. Any performance difference going from oem to poly mounts?
  219. What Should 123mph 1/8 Traps Be Good For???
  220. drag race 1/2mile
  221. Corvette Challenge
  222. Need speedo help quick!
  223. shooting for 10's Cam Only??? THOUGHTS??
  224. TR6's cold enough or do I need TR8's?
  225. Line Lock
  226. summer v. fall
  227. Does Pete Z have a website?
  228. Launching with PY3600E ?
  229. 100 lbs off nose of car by changing brakes and suspesion
  230. what are the "best" tracks open year round in the US???
  231. Stenod Performance 25.2 / Outlaw 10.5 Update
  232. Header primary sizing and questions....
  233. Wieght Diff. of Front Runner vs. street skinny??
  234. Anyone else can't wait for spring (pics of new Bogart RT's)
  235. What size jet for 150 dry hit?
  236. !monsoon
  237. Those with aerospace brakes- COME IN!!!
  238. Help me out with my math!
  239. Made some changes to the car...tires/gears/weight/etc
  240. Strange front brakes
  241. Quickest full weight bolt on M6 ?
  242. A3 guys, I need help wiring up the NSS
  243. Travel limiter info
  244. What will I run...
  245. Speed Inc. lightweight carpet
  246. 408 or 540?
  247. Do I have an 11 sec car ?
  248. RPM not reading!!!
  249. anyone do back to back track testing on light weight k-member and a-arms?
  250. how to remove the A/C completely?
