- Shopping advice - things to look for
- 1999 camaro ss
- 1998 ls1 engine noise
- What are common problems with LS motors
- how's this look? miss anything?
- mechanical throttle vs electric throttle
- Chips
- lowering.....
- Ls2 or Ls7 which one?
- Big Scare....
- Head lights come on automatically
- Lids
- What to do next
- Cam overlap and exhaust smell
- new z28...
- Anything to do now besides cam/gears?
- 243's/6.0
- DIY wiring harness ???
- cross threaded header bolt
- Looking for advice on street build
- Will this alternator fit/work
- is my tranny doomed?
- Lose Column
- ls engine codes
- Installed exhaust. Too much scraping! What to do?
- 98 formula help
- cant identify noise *video*
- Occasional bad misfire on startup and after heavy throttle usage
- steam?
- Rpm's at 70mph
- Exhaust rattling
- o2 extetion help
- Preparing for More HP
- Gas Pedal sticking at wot.
- which y-pipe
- I think Ive maxed out where I am at.
- Gas tank?
- My 00 z28 has a couple probs. I have big plans for this car! Help?!
- Valve cover removal
- just bought my first ls1
- Cam ???
- will Z06 valve springs work on LM7 heads?
- Suggestions on new Heads????
- 160 thermostat
- keep wideband sensor?
- 1st run on 98 TA
- 4:10 gears 4:11 gears???
- Mod adivse
- LS2 Idle questions
- ARH header odds and ends
- Will Corvette Intake fit on Gen III LS1?
- dumping 6 banger to get an ls1
- Budget Build
- how to get a 98 ta to go 10s
- 1999 Firehawk all stock (help)
- Can I use LS1 wiring on an LM7?
- now having some issues.
- just a question
- Help Understanding stroking/boring
- High Oil Pressure?
- What do you think?
- High Flow cats
- 98 formula headers
- Help Please: Need to know!!
- got about 3500 bucks to work with
- Briefly Seeing Oil Change Light
- 243 heads
- Wiring problem, maf,tps,coolant temp
- 98 TA Broken
- Noob, Headers and AIR tubes
- Startup sound?
- '98 camaro 6spd I can't shift for crap!
- Stall with stock rear-end
- Does anyone know what this is?
- How to Find out 35th LE build #
- Ls6 intake
- Took off by mistake, AC Condenser
- Some advice on getting my TA ready to be sold
- Ls manifold
- MM size on your stock throttle body and MAF ls1 TA
- Intake question help!
- B4C alternator question?
- camaro ss 2001
- Owners Manual
- Difference between o2 sensors, L to R
- New Camaro...Looking for a few replacement OEM items
- True Duals, cats or no cats, headers or no headers?
- Which Gas?
- LS1 Camaro & Trans AM
- how to get a TA around 450rwhp?
- Hey there! noob question about rear gears/torque converters.
- Cam swap disaster
- Good exhaust setup?
- what size heads??
- stall and gears question?
- swapping parts
- need throttle body bolts
- TR cheater classic or tru torque
- C5 LS1 budget build or swap?
- LS1 freshen up?
- missfire problem
- gforce chip?
- Just Picked Up a 99 Z28 6-Speed
- K&N or Volant
- Your opinion would be greatly appreciated
- Steering Shaft Removal
- Next Mod?
- Should DRL be on same time as Headlamps
- Newbie looking for advice "L33""
- Bought an 00 camaro for a good deal! Monsoon?
- what do you need for a shiftlight?? and shiftlight opinon
- How does this setup sound
- texas trues and torque arms
- new toy 98 trans am(new pics added)
- The hunt for 30 mpg
- New to LS1, few questions...
- did a header install and need help
- camaro exhaust installed need tune?
- NEWBIE: Just picked up the Bird yesterday....help
- New LS engine. LS1 or LS6?
- Stoopid Newbie Question
- camshaft help
- Cleaning my MAF
- car redlining and not shifting help (auto)
- hot wire
- More Pony's
- Which head is which?
- vacuum lines in harness???
- muffler selection question
- Quick starter (wire) question on 00 Trans
- The making of a Z06 engine
- LS6 valve springs ?
- p0410 code and no ses light?
- cheap programer?
- whats the difference?
- o2 extensions question
- Need help with LS1
- How and should I remove ac?
- Buying a LM7 in the states
- Why not Fast LSX Intake, bigger TB & MAF?
- Truck 5.3 parts for my SS?
- injector question
- exhaust and cam question?
- 98 Camaro
- Cam & setup?
- question about tuning after cam
- Knock sensor problem
- long time gone,need some welcome home advice
- Shifter Dilemma
- Yes, its a cam question
- B1 cam?
- Ls1 temp?
- Check Gages Indicator - Going Crazy!!
- Warning for all those doing intake swap
- hesitation after spark plug change
- what y pipe
- Newbie with a project. Thoughts?
- Noob question on SLP Cold Air Intake
- Help with oil question
- Got a steal on my first ls1!! Piks and questions
- Cam Swap Dowels....
- Outboard Main stripped on my LS1. Suggestions?
- parts for cam swap
- need help picking a cam
- wanting to verify header research
- Noob brakes on 02 Z28 advice
- LS2 engine, 6 speed trans, ECU swap
- semi new car
- 2002 trans am jumps to 4k rpms at on start up
- Why can't I post in Classifieds?? Because I don't have 50 posts/6 months membership!
- Underdrive pulley
- Broken Pushrod
- NEW here! question about headers
- M6 question?
- Advice/Help on first time dyno
- LS1 Cam suggestions...? little overwhelmed...
- 98 Trans Am
- Car came with parts
- Weird Gas Gauge Problem
- texas speed?
- Needs help to find a Good Cam??
- LS6 intake install
- milling 243's
- Showing off my new ride, first LS1 ('99 Z28)
- Free mod list?
- Is there anyway i can drive in the snow?!?
- Rising From The Ashes...
- True duals, need help?
- Cam Parts/Tune Help
- Ls6 heads and Cam?
- First LS1 in the family....suggestions?
- D585 Truck coil swap ?
- VIDEO: Hate my Exhaust
- Cam upgrade
- LS1 temperature
- My first ls1
- Finally.....
- 500rwhp help
- worth the trouble
- ls1 vs ls6 intake mani
- LS1 Question
- New to LS car, just bought a basketcase..
- best o2 sensors?
- Stock Ws6. Ls6 intake or not???
- Oil change light??
- Lt1 question
- 6.0l blocks
- Best 02 Sensor for long tube headers??
- Good flowing heads for ls1
- Is an 05 LS2 and 02+ LS6 cam the same?
- is a 6l crank and ls1 crank the same? spacer?
- help me build my parts list
- New guy needs help! 99 Trans Am 5.7L
- door hinge jumps
- Instrument gauges.
- 85 mm MAF from Zo6 LS6
- Install went well this weekend. TSP True duals
- my 98 z28 ... oil type?
- fuel injectors
- Check engine light after LT's
- Slave cylinder/clutch kit...
- 2000 SLP SS camaro..did SLP paint fender bolts after hood install and realign fenders
- Simple Brake question from a newb
- Ls6 engine swap!!!!!
- New question about handheld tuner!
- Question on Gears
- oil consumption?
- Too Trade or not to trade
- Motor / Car Vin number
- Check gauges constantly comming on
- speedometer is broken
- Z06 heads over patriot heads???
- 5.3 harness question
- 98 WS6 Headlight Motor Wiring Issue
- Engine Help
- Transmission seal
- Hi, Need advice.....
- wheel?
- Rear end gears..tune required?
- 1.8 rockers
- 98 formula hard to start?
- Exhaust sound level..
- Lq4 ls1 performance parts list.
- Help w/locks l,windows
- dealer g8gt with lots of maintenance before sold
- Hows this for basic...Fan clutch
- Where to go from here??
- Winter driving
- Newbie seeking help with heater core
- Car not right after TB swap
