View Full Version : Suspension & Brakes
- Questions about a proper suspension setup for my car
- Whats the best way to center
- My first Auto-X
- Strano Springs
- Making Delrin Bushings
- I've got an Idea!
- QA1 Shocks hitting Ford 9 in Need Help!!
- My torque arm question/theory
- My torque arm queston/theory
- I need some more suspension mods... UMI hear i come.
- Whats next?
- Dakota break problems (sorry)
- problem after c5 brake upgrade
- lowered!!!! (w/ pics)
- I'm dumb with brakes
- Does banjo bolt need alignment? Need an expert on this!
- 69 Camaro brake conversion...
- 2 pont Vs 3 piont SFC
- Brembo Blanks..
- Brake Light problem
- PROKIT & BILSTEIN HD Owners ENTER!!!
- PA Performance K-members
- 02 Camaro Lowered: Canuck Motorsports Springs
- lt1 and ls1 steering rack
- Stranos bars
- Anyone running the WS6 store rotors?
- What is the ideal compressed and extended length of rear shocks
- Dms Springs
- trans build help
- rebuilding calipers seals fronts and rears?
- Best all around setup?
- need some advice on a suspension set-up
- Chromemoly worth it?
- PA Racing k-member w/a-arms,anyone using them?
- $450.00 left to go.
- poly bushings
- how does this tqe arm compair
- what brand k member does this look like?
- Caliper mounting bracket?...help please
- Massive rear end sway
- BFH and adj. PHR, but still rubbing
- Rear coil spring isolators
- Anyone against KYB's....
- QA1 with Nice ride height?
- Opinions
- New pads, rotors, and wheels, won't rotate??
- Strut tower brace torque setting
- replacement part #'s for aftermarket control arms / pan hard rods
- pics of umi SFC!!
- Tweaked ES trans mount. How do I keep from happening again? *Pic*
- stock LCA length from out edge of bolt hole to bolt hole
- Welding SFC's- remove pcm or neg. cable
- J&M triangular design SFC's
- Starting Suspension..???'s
- People Help Me Out On A Question !!
- Help with Horrendous squeek please.
- BMR LCA Relocation Brackets - Bolts?
- feedback on this setup please?
- Shaky car
- tube a-arms a must with tube k-member?
- QA1 Where does the Thrust bearing go in the setup?
- Which shocks on stock springs?
- HOUSTON: do we have a problem...? (strut replacment!)
- jumps to the right!?!
- Alignment after Kmember install
- strut question
- someone help !!!
- Lowered my 00 black WS6 with some Eibach lowering springs pics inside
- ? for those that did their own frt. shruts/springs...
- Hooking up a vacuum reservoir for the brakes
- rotors/pads
- Powerslot rotor keeps warping
- brakes! (brembo big brake kit)
- New photoshoot w/ Strano springs/Koni DA's
- Lowering Spindles
- Question about brake fluid?
- 408 iron and alignment
- Full length or Short Torque arm
- groaning/grinding from rear
- Whats wrong with my brakes?
- help with front springs
- Koni 4/3 vs. Revalves for my application - Please chime in.
- Suspension Problems
- Brake question
- LCA relocation brackets with BMR Trac Pac??
- which rear sway bar?
- where to find an f body abs delete block??
- Recommendations Please
- EBC green stuff or Hawk HPS Plus racing pads?
- Eibach Sportline Kit Question
- Normal for solid rod ends?
- Qa1 12 way adjustable rear shock settings...
- Is there a big diffrence between manufacturers?
- F-body Traction Bars
- Alignment has been done but the car still pulls to the left...
- coil spring spacers/ isolaters
- STREET brakes for 15x10 prostar
- Stoptech Big Brake Kit Fitment
- Am I blind? LCA Relocation brackets on BMR?
- UMI torque arm front adjustment?
- Paging RooRnZ28
- Leaky reservoir?
- swapping springs
- ABS Probelem with with C6 wheels.
- Improving handling after new shocks/tires?
- Custom Torque Arm
- help this noob. shocks and springs
- I have LT1 brakes... what can I do?
- Strano Springs
- c5 caliper vs ls1 calipers Difference?
- What kind of shocks?
- Line Lock / ABS
- bilstein/strano revalves
- Front ball joint question
- affordable shocks
- C6 brakes on fbody
- need help! why is my right rear sqeaking at certain speeds when braking
- 98 z28 a4 front brakes squeal! HELP!!
- 2000 Camaro SS E-Brake Parts
- Rear end feels squirly...
- Is it Wheel Hop?
- slp springs?
- QA1 shocks
- best / easiest way to go about doing a stock torque arm mount?
- Which type of torque arm for high horsepower?
- Yay for Moog outer tie-rod ends
- Brakes will not hold my car to do a decent burnout "help"
- will the torque arm fit??
- Road coarse, drag, street setup?
- how do i preload my suspension
- Just Bent My Torque Arm
- Need brakes
- Who sells poly ends for PHR?
- How much Potential am I loosing?
- will a stock torque arm damage my 9" diff because its dropped?
- Passenger Rear Squeak driving me insane!
- Possible to delete ASR? Brake module problem.
- QA1 rod ends?
- What suspension bit?
- Spring rate questions along with set-up questions
- NEED HELP ASAP......SJM ABS DELETE....please
- How much?
- Rear Comp Engineering drag shocks streetable for DD??
- Springs hitting panhard bar....
- rebuilding koni's?
- Help....Torque Arm Dilema
- Passenger side sitting lower than driver side?
- c5 brake conversion
- Is the Moly worth it?
- Rotors and Pads..right for me?
- between these two SFCs which would you get and WHY?
- UMI Double Adjustable Panhard review after several months.
- Eibach drag springs
- what brake lines with c5 brake upgrade?
- torque arm?
- Spring rates
- Strano springs w/stock shocks?
- new rotors for 03 z06
- Torque arm question
- possible rotor problems
- What is the best spring to go with stock shocks?
- Could you guess from this picture? Help!!!
- Spring ?'s
- sway bar
- wheels up?
- Shock/Springs in a Vert
- anybody with Koni shocks and strano springs and TSP true duals
- Broken bleeders please help!
- caliper sticking uneven brake pad use on front driver side
- Best Subframe connectors
- help me pick my auto X suspension mods
- Need help with wheel hop!
- broken rod end
- Rear C5 brakes
- Ag springs????
- rear end adjustment
- Sway bar bushings, worth it to change them out.
- Lowering springs with a full car?
- Proper brake bleed procedure
- Who has 1/2" bolts in their LCAs?
- Brake fluid question?
- new suspension
- Bump Steer
- Horrible Squeak
- what is this bar?
- Sway Bars and Lowering Springs?
- Lowering Spring Compatability Question
- Pics of installed Torque arm relocation?
- madman style shock mount and shortened lcas
- camaro rotor size
- brake problem, maybe bad ABS? help
- c6 zo0 rear brakes
- How to replace rotors and pads?
- no brakes
- BMR trak pak?
- How to properly adjust torque aarm and panhard bar.
- UMI K member
- sub-frame connecters
- popping noise
- Strut tower Brace?
- Lowerd with prostars?
- KONI DA rear install instructions
- Please help me ID this shock absorber part number
- Car Wont Hook With 150 Shoot
- wheel hop....I think
- Removal of lower A arms
- Brembo blank rotors part numbers
- tq arm
- Springs?
- Rotor question
- new mods ?
- Sam! We need to talk.
- Racing Video Clips - with Strano setup
- Rear sway kit for 12-bolt?
- springs/shocks
- Setting up a 4 link?
- Quick and easy brake caliper question??
- New Item- Front Upper A-Arms
- top shock bushings won't stay put
- car is leaning to the right...
- Where Should I Buy My New Shocks?
- Installing SFCs... problem
- LCA relocation brackets?
- Roadrace shocks ok for drag racing??
- front will not stay in turns
- KYB AGX Adjustables with Eibach Pro kit....good combo???
- Rotors for 98 Camaro
- 1st mod to suspension ??
- Unbearable vibration over 60mph after install of new parts
- TA hitting tunnel area under car with my tourque arm, need advice
- changed control arm angle...do I need to check my pinion angle
- 1998 1LE versus WS6 front bushings?
- Koni DA: what settings to start with?
- alignment problem: pulls right, got it aligned, still pulls to the right...
- k-member
- Installed BMR CM PHB and car is offset still!!!!
- front drag shock (qa1) shock and spring
- TSL true DUal setup with SFC
- tie rods?
- Shocks for a daily driver with LG G2 springs..
- Strano 35mm Sway Installed! OMG!
- Caliper Rebuild
- Strano springs pic
- Need new outer tie rods. Which ones?
- Problem Installing BMR Torque arm
- lca 1LE bushings help!
- umi adjustble torque arm are adjustable lca needed
- Squeek of death, sometimes a clunk.
- front end question
- shaking
