View Full Version : Suspension & Brakes
- Damned computers--2/29/12 edition: Website/email Strano Performance Parts
- trying to get the end nut off the front shocks...
- brake pedal hard?
- UMI and BMR rear "Drag" sway bar ???
- Rear Brake Squeaking sound Fbody4thgen
- Founder Performance
- Quite a few suspension upgrades and really don't notice a difference..
- 94 trans am suspension
- Anybody DD a Tunnel Mounted TQ Arm?
- how do i remove the boot from the front shock/springs
- shocks didnt help ... need help any ideas??
- OK TAX MONEY: lowering with duals, do i need a new Torque Arm?
- brake line size??
- Need Some Decent Brakes
- comfort help....
- Need to raise suspension for true duals
- ES End Link Questions
- Need brake help ASAP!
- hotchkis or eibach
- Another satisfied Stagg shocks owner
- C5 caliper problem
- Ac delco brake booster
- Stock Height
- LCA relocation bracket ?
- Parking brake parts?
- BMR adjustable lower a-arms...
- Wife wiped out the V into a curb...pics of damage
- New Hardware?
- Need help with a master cylinder. ls1 brake conversion
- rear sway bar and rear end
- need help with brake problem
- Alignment with adjustable PHB?
- Doing Targa top conversion, need a TRUE subframe connector.
- Steering Rack or Tie Rod??
- Greetings & Questions about Strano
- Rear shock compatibility
- strut mount
- Stiff brake pedal, bad braking
- UMI Torque Arm Knocking?
- LT1 to LS1 Rear Brakes Swap???
- Desired ride height/fitment mock up
- Brakes: "...out of the realm of common problems..."
- Poorman suspension set up as far as springs/shocks
- Tires scrubbling/worn out shocks - Recomendations?
- Shock adjustment
- bmr adjustable bar,and lca
- A arm question
- Shocks and Spring recommendations for 99 Z28
- B&G lowering springs
- New setup Pinion angle info needed
- traction
- Front lower control arm options
- SJM abs delete/line lock kit with leaky line
- Suspension Mods
- Reinstall ABS (Remove poorly done ABS delete)
- Brake Line Concerns
- good alignments in the dfw area
- Drag Suspension Questions
- have a 2* pinion angle, vibration at high speeds.. going to drag strip for first time
- suspension advice needed
- Another bump stop mod.
- so why did my 98 z28 have a stiffer brake pedal than my 2000 ss?
- Front Shock Top Nut Removal ??????
- Anyone using the Strano or Hotchkis hollow adjustable rear sway bar set up?
- Handle like a 911???
- Problem with rear brakes
- Share BRAKEMOTIVE Long term use review...I want to know
- stripped bolt on torque arm-transmission attachment, solutions?
- How does my parts list look? Anything you'd add/change?
- Installed new on car adjustable trailing arms.
- Lower control arms
- What size fittting on the stock master cylinder for rear brake line.
- brake rotor diameter tolerance question
- Suspension install problem
- Rear compression travel
- Help with lowered ss
- Aerospace Rear brake rotor hat?
- Strano Parts
- Ceramic brake pads squealing
- which stainless brake lines?
- trouble with brake pad install?
- so tired of the manual rack.
- My suspension plan: second opinions please...
- LG Coilovers setup
- Highway/Pothole "Float"
- All 4 brakes stuck?
- camaro lowering springs
- aftermarket spindle?
- tire rubbing on fenderwell...help!
- Founders Performance Panhard Relocation Bar Reviews?
- best shocks for the buck?????
- LCA angle
- who has actually had both solid and poly mounts?
- panhard bar
- Shock and Spring Question
- Need spring info
- Street driven 4th gen F-body with 275 front springs?
- Brembo calipers?
- Best way to lower my Trans Am WS6 2002
- Abs inop,abs,tcs light?
- Cheap Lowering Springs?
- OEM Disc Brakes for 15 inch Wheels
- need pictures of stock rear brakes
- Who has the best pricing on rear drag bars
- Rear end V6 to V8 brake line question*PICS*
- Problems with K member
- stagg shocks
- Lower control arm Help
- Strano
- Full suspension on 02 SS
- Can I do a poly tranny mount without doing motor mounts?
- Copper/Bronze painted brake calipers
- Dangerous handling - please help! - SOLVED (kinda)
- life expentancy of bilsteins
- Measurements Please!
- Suspension List
- I cannot figure out where these bolts home are..
- Trustworthy Suspension Tech Inland Empire, Ca
- anyone know strano auto parts hours of operation?
- PA Racing K-Member
- free suspension mods
- who makes a decent line lock ?
- Overkill on a DD?
- Adjustable or non-adjustable panhard rod?
- anyone running a Strano 22mm or 1" hollow adjustable rear sway bar?
- eibach
- Rear drag shocks
- Torque Arm mounting bracket bolt?
- inner tire wear on lowered car
- Need help with set up......
- Getting an air bag lift kit on a '98?
- Axle to "frame" clearance
- Brake caliper change
- LCA relocation brackets
- Painting Calipers Red
- Brakemotive Vented Rotors
- Did all 4th gen SSs come with 35/22 sway bars?
- Lowering using Granatelli springs, stock shocks, and non-adjustable panhard rod?
- Loud bang under car with UMI relocation tranny bracket kit and torque arm
- rear suspension issues, Need help!
- Lowering Req. Adjustable A-Arms?
- intermediate shaft rattles
- Updating my brakes (Pics)
- Control Arm Bushing Question
- is this a problem?
- Home made harness bar?
- Stock Spring removal issue
- Front & rear strut spring swap. eibach pro kit
- Help after ball joint install
- Anyone know what brakes fit these?
- Lowering spring problem
- Good Suspension Setup
- need info on drag brakes
- Bmr rear sway bay
- Undecided Suspension Setup
- Car feels very unstable
- Rear Coilover Shock Length
- boss brake rotors
- Are my UMI sfc's welded wrong???
- anybody running raybestos brake pads?
- whats the best cheaper shocks?
- Since the last time I been to the track I've added some upgrades.
- UMI Subframe Connector options
- Run new rear shocks only?
- C5 IRS/trans and tube in fbody?
- lowering
- I want to go left! then Right! Suspension help!
- steering knuckle
- Best power steering upgrade?
- Subframe connectors
- Finally got my bilsteins in the car!
- Rear springs wont come out
- Getting a roll bar/cage put in my car, Please post pictures of yours.
- does anybody make a "lighter weight" spindle that will handle street use?
- No Stopping Power
- How to tell if wheel bearings are bad?
- What is your ride height?
- Umi sfc
- My budget suspension build up
- Tired of my car bottoming out....
- Help with sway bar link
- HELP.... strut mount bolts FUBAR...
- Spring Question
- Single Rear Brake and Rotor with Spooled S60
- Full suspension research.
- Sway bar endlinks seem to be seized...
- De-coupled torque arm. Any experience out there?
- Stranos & height
- Interior gut with SFC's?
- Brake noise, creaking when coming to full stop
- Black rotors anybody? (PICS PLZ!)
- Fair price for shop to weld in sfc's
- strut tower torx head bolts?
- Vertical lower a arm bolt woes
- Need PHB for hose mod
- 2011 Camaro Brembo Brake pics
- Those that know brake systems! Help!!!!
- UMI K member, arms, would you do this first?
- Best place to get stainless brake lines?
- Front suspension clunking after Bilsteins...
- Wheel speed sensor
- Soft brakes after eBay Slotted/ Drilled Rotors & Pads
- How important is a Torque arm for TSP TDs?
- Next suspension mod.
- brake booster?
- tire hitting fender in rear... need advice quick
- which type/brand of brake pads to buy
- Considering lowering springs
- strano springs on stock shocks dd
- What springs are these?
- opinions on springs with bilstein shocks (pics requested)
- Finished adding used suspension parts
- UMI Upper and Lower rod end A-Arms
- LCA questions
- Will This Work (Pics)
- proven performance!!!!!!
- want to swap my hypercoil springs help!
- brake conversion
- Raise car Emergency :(
- Is anyone using lowering A-arms??
- Painting springs??
- What should I do?
- Replacing/Freshening the front end - need parts/install advice and should I paint?
- ? on manual brakes
- Springs/shocks
- Brakes problem
- variable and constant...
- agresive handling from a DD??
- Driveline vibe/strange drone?
- where to start out at with suspension mods
- post deployment suspension upgrade
- Help! Threads stripped... What to do?
- What size are the front/rear sway bars on a '98 SS?
- Hypercoils-what are they worth?
- Sway bar hitting 9inch rear end. Advice?
- Need softer suspension
- LT1 Sportlines on An LS1
- What size spacer to run for the cts-v brake kit?
- what happened to the z-link kits?
- Caliper pin dust boots?
- Moog LCA Bushings from Stock- What did you notice?
- Strut tower brace
- almost ready to start buying suspension. but what?
- fishtailing excessively
- Strano or Tom Henry RS Project
- Sub Frame Connectors "UMI" bolt kit.
- Torque arm removing and bushing replacement help.
- Crazy not to get? Redoing Suspension..
- BEST Suspension?
