View Full Version : Suspension & Brakes
- New brakes
- how are the spohn swaybars?
- sub frm connector Q
- C5 Coilover Project
- Lowering Car...
- Chassis Engineering
- f-body zerk fittings?
- Changing pads, using same rotors.
- Grooves in Rotors- what does it mean?
- Alignment and new tires?
- QA1's Hals F vs R series?
- H & R SPACERS
- Hotchkis LCA's vs BadZ LCA's
- power steering questions?
- Gravity flushing...
- BMR Panhard Rod
- SFC pics and Question
- Anyone using a AJRE K member?
- Front adjustable shocks? Stock rear shocks?
- Decent Brake Set Up?
- sfc's on x-pipe setup
- need suspension help to get into 11's
- softer bumpstops?? or shave them? remove??
- driving without the front sway bar?
- Please Help with a Suspension Problem
- Sagging and more!
- Horrible Sound..HELP PLZ
- SFC / Strut Tower Brace
- Swaybar/Endlink angle ?s
- Pic of SLP's SFCs needed
- HI jackers are in!! can i remove coils!????
- PLZ HELP!!! Need a bolt size for a TQ arm bracket on moser
- KYB AGX adjustables yes or no?
- Edelbrock LCA's YES or NO?
- Suspension guru help
- How to tell if I got 1LE stuff on my SS?
- Is an Adj. PHR Required for Lowered Cars?
- Went tog et alignment today and not happy
- what is a good suspension set up for top end?
- LG subframe connectors
- Lowering Springs w/ Stock Shocks = Bad?
- Need bigger brakes...What are my options?
- Need front and rear coil overs....who makes them?
- Help!! Massive Wheel hop
- creaking noise??
- I have go fast goodies, but stock suspension, HELP.
- cad plating on rotors
- Need Good Break Pads and Rotors
- Panhard bar Help
- Anybody here cut 1.2xx 60' times?
- question about LG lowering springs
- how to break in the brakes?
- Brake question
- Hotchkis suspension
- Sweet purpose built '69 Camaro
- Springs and Subframe combo
- Running air bags makes your car lighter?
- Who sells 1LE springs?
- How to change struts w/out having to grind off the nut
- suspension giving out?
- Question about brake dust?
- SFC's STB.... FINALLY!!
- Rear Drag Sway Bar
- BMR TQ arm broke!
- NEED HELP: Installing SubFrame Connectors
- Need some serious help!
- what next?
- Need a sway bar part number please
- Relocation brackets and LCA's?
- KYB AGX's
- Mushy brake pedal
- anyone w/ the lca's and phb from badz, i have a question.
- Squealing Brakes - Oh so annoying
- STB rubbing?
- Got my new LCA's and Panhard bar
- deCarbon help please
- deCarbon help please..
- what shocks and struts should I get?
- sub frame conectors
- Pro Fab K member owners....
- Why won't these shops install my line lock?
- Anybody with KYB AGX adj.shocks?
- Diagonal bar above panhard rod???
- BMR LCA Relocation Brackets
- Rear rotors - thickness of hat - Aimco?
- Car shakes at about 85-up, any ideas?
- Cutting springs panhard rod now or wait?
- BMR K-member broke!!
- How could my swatbar be hitting my engine pulley??
- Whats The Best Way To Level The Rear?
- Wolfe Sub Frames??
- high speed brake pulsing
- sportlines on camaros?
- BMR Weld In Directions:
- Confusion in the kinds of stock suspensions
- QA1 Hals - do they slam down after launch
- thinking about cutting off 1/2 coil on my BMR's
- Who makes the lca's that eliminate the need for a torque are?
- Installing eibach pro kit need help!!!
- LCA relocation bracket question
- Alignment question
- Questions regarding the belt with power steering removed.
- What's a good front sb to go with the 24mm rear sb?
- Ceramic pads take more pedal effort than stocker?
- Rear Speed Sensor Vibrating
- Which direction to install cross drilled and/or slotted rotors?
- Need Help With Front Springs
- PS cooler..? worth it?
- Do Crossdrilled/Slotted Rotors do anything?
- A few Torque Arm Questions...some pics?
- BMR Extreme Sway Bar Users...
- lowered with 3 in. y pipe
- What suspension setup
- 25mm Rear Swaybar
- Hal/Qa1 shocks for front help.
- Which Springs and Shocks for Drag only??
- BrokenTorque arm mount
- Shocks for BMR Springs?
- HELP Daily Driver suspension
- Rear End Feels... Loose or Disconnected
- Warning
- Mitch, Trackbird, you two may like this article!
- A friend's car having vibration issues
- strut pieces, i need part numbers
- help i need shocks what kind should i get
- flp says rosslers pinion angle page is wrong
- Take a turn hard, and brake pedal will go to floor
- Help braking specialists, my brakes are noisy as hell- why? They are recent.
- Need help....
- Improved Braking?
- thud and grinding
- Flat tire feeling while backing up....tire is fine tho???
- have BMR springs but want front lower
- Jegster adj.PHR and relocation brackets
- NEED ANSWER QUICK: Frame Rails?
- Question about spring compression?
- True duals on a lowered F-bod?????
- Where can I get dms springs?
- Removing my ABS.
- what do i need to lower my car 98z
- Which Springs For Wide Wheels?
- Hals or coil overs?
- Can C5 Rear Rotors Bolt on to a F-Body?
- a Kmember thread.
- A blade sway bar for the LS1?
- Air suspension Question
- My bilstein hd's did not come with a bumpstop should I use the stock one?
- Want to lower rear...
- HELP with ABS INOP and TCS
- lowering the car, help with parts selection
- Truth about SFC's / STB's
- which brake for this price
- Eibach pro kit bounce
- Lowering springs and body roll (mitch, please come in)
- Getting Rid of Wheel Hop
- K-member
- best Setup?
- Looking for input on lightweight street brakes
- Rod/Rod Lower Control Arm Impressions?
- Anyone use Hal Lee's new shocks..
- Adaptive Suspension
- crossmember mounted adjustable torque arm
- Lowered my car this weekend.
- Tq Arm Mount...
- ABS sensor mounted in rear axle..who sells them and what part#
- Why do my caliper bolts keep coming out??
- Pro's and con's on your purchased products (Suspension wise) Please have a look!!
- air bags for rear suspension?
- torque arm ?
- BMR extreme TA
- Can you take the upper ball joint boot off?
- Realign the front wheels after going from a 2inch drop
- Hypercoil Springs????
- no abs sensors, or exciter rings..what to expect?
- Mov It Brake Users - Any Updates?
- Powersteering removal. Instructions? Write-ups? How-to's?
- Need help removing ABS.
- Madman Racing!
- how do you remove caliper??
- Suspension question
- Grind "Corvette" off my z06 calipers
- Spring and shock question....
- Anyone know the name of this part ? ? ?
- dimpled rotors
- Brakes squealing while driving...dammit
- lower balljoint effected by lowering?
- rough ride
- Rollbar/cage questions.
- No more aimco rotors at autozone
- weird brake/wheel noise after new brakes/rotors
- General Question
- Color and markings of Raybestos Quiet Stops
- Help with break squeak (not squeal)
- Strut Tower Brace or Shock Tower Brace??
- STB w/ SFC's Needed?
- Please help diagnose popping noise while decelerating
- Weld-in SFCs....don't weld the rear?
- Brake pedal intermittently sinks as if a leak exists or the master cylinder is faulty
- I have a potentially stupid question...
- 1le swaybar question
- Random Technologies!!!
- Do cross drilled rotors improve wet braking?
- Installing Spohn torque arm
- Clunk from rear suspension
- Loud bang from rear
- Power Stop rotors?
- Bleeding the brakes
- Major wheel-hop after Tranny/SPEC 3 Swap
- Shock information
- Guys using QA1 (HAL) shocks.....
- performance shocks
- where to get brembo brakes??
- New pictures of our double adj lca's and phr's!!!
- bleading brake juice
- Aftermarket K-members - up to street abuse?
- what all will i need for prokit installation?
- 1LE 21mm rear sway bar
- Removing Welded On SFCs? A Shop in L.A.??
- Just ordered lowering springs.....
- Need help asap with tq specs, installing shocks now!
- Torque Arm rubbing driveshaft question...
- brake rotors
- ride height?
- PA Racing K-member-E-bay--$210.
- Pinion Angle Gauges - Home Depot
- Anyone use KYB shocks?
- Who sells the Alston rear suspension components?
- silly sub frame ????
- Upper control arms-not a lot of people change them-Why
- Moving the torque arm mount to the crossmember
- Noise from ground contol rear-right perch.
- Opinions on suspension setup purchase!
- Got LG control arms in the mail today
- Lowering advice please...
- ANyone using the CE rear adjustable drag shocks?
- To lower, yet still launch good
- Just bought a 2000 Z28!
- Problems...
- "popping" noise from front end?
- 1LE suspension Kits
- suspension techniques springs
- Brake System Nigtmare: Keep Hitting Dead Ends
- Front sway bar?
- Just Got a Roll Bar.....
- Edelbrock Torque Arm
- Why is there 2 sets of holes in BMR TA.
- Check out my custom torque arm!
- Lowering Springs
- Relocation bracket question...
- G2 Springs no more!? (+small rant on LG)
