PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 [139] 140 141 142 143 144 145 146 147 148 149 150 151 152
  1. braking problem
  2. Brake experts come on in...long
  3. right rear sags more than the left
  4. Does torque arm affect nose dive/squat?
  5. Which springs would offer the least DROP?
  6. Everyone .... if you have BMR poly ends on ANYTHING ...
  7. Lower Control Arms
  8. LCA and PH bar
  9. bmr adj phr update
  10. Which would be easier to install springs or cut them?
  11. Who is running LG swaybars??????????
  12. Granatelli lowering springs?
  13. Who has broken a suspension part? Whos part and what was it?
  14. How difficult is it to install K.B. weld in Frame stiffiner
  15. bmr rear control arms
  16. Brakes are squealing
  17. Power Slot rotors????
  18. Installation of subframe connectors without loading the susp
  19. Need help...bad vibration at 65-75 mph...checked everything?
  20. How to tighten E Brake?
  21. A4 / M6 torque arm mount the same? doesnt look like it...
  22. What rear anti-sway bar should I buy?
  23. Question replacing rotors
  24. Do I really need a scan tool to bleed my brakes?
  25. Idea to Improve BMR Boxed SFC's, please look
  26. Best LCA and PHB...
  27. stock torque arm/ 6spd trans mount part #s?
  28. Power Steering going out.
  29. People running EBC brakes: Do yours still make noise?
  30. tips and suggestion on suspension parts..
  31. very dissappointed - review and questions inside
  32. power steering on my ss
  33. Can SLP Bolt-In SFC's be lightened?
  34. Need pics of BMR extreme torque arm installed
  35. how to set pinon angle
  36. Sway Bar Compatibility - years?
  37. Bilstein HD and Bilstein Heavy Duty???????????
  38. LG G2 LCA's
  39. Those that have rebuilt your calipers....
  40. brake decals???
  41. building an invincible monster!!!
  42. anyone with aerospace brakes?
  43. car not sitting level, sometimes?
  44. Hotchkiss spring users - stock DeCarbons OK, or ???
  45. pros/cons of LT1 brakes vs LS1 brakes?
  46. Brake help please!!!!
  47. Strut Tower Brace
  48. Car pulls left when hitting the brakes hard!!
  49. Part # stock trans/torque arm mount? Poly worth it?
  50. torque arm help and suggestions
  51. Koni Drag Shock Shocks
  52. QA1s with Eibach Pro-Kit
  53. SFC: BMR boxed vs KBDD or SLP
  54. SLP line lock vs Hurst/thunder lock? which one is better?
  55. rear suspension warranty ???
  56. Will FLP headers fit with SLP sub frame connectors?
  57. MAC torque arm?
  58. No more 4X4 and handles great!
  59. nwebie question re: SFC
  60. LCA brackets; bolt-on vs weld-in, differences?
  61. do we need the atermarket shock for aftermarket spring
  62. E-Brake is REALLY loose
  63. Creaking noise fixed... Would never have believed this.
  64. BMR parts: chrome-moly worth the extra $$$?
  65. Relocation bracket drawings
  66. question about bigger front brakes and the spare tire
  67. AIRLIFT AIR BAG
  68. Are BMR Tubular K-members a worthwhile mod?
  69. air bags in rear suspension?
  70. best springs for autoX (not coil overs)
  71. strut tower braces
  72. F**k!!! E-Brake is rubbing the inside of the rotors!!!
  73. Which 1LE sway bar?
  74. Edelbrock Suspension Components
  75. Not much of a difference with SFCs?
  76. Bent Torque Arm?
  77. Idiot lights coming on
  78. Are BMR TUBULAR A-ARMS a good mod?
  79. Are QA1-HAL SHOCKS worth it?
  80. Sophen Torque Arm (rough ride?)
  81. Brake pads
  82. September suspension sale. 15% off Chassis and suspension
  83. Need part number for 24 mm rear anti-sway bar
  84. Sure Stop Rotors
  85. Hypercoils
  86. Front Rotors?
  87. left front spring problem
  88. what exactly is a revalved shock?
  89. rear hals only is it ok???
  90. Cutting eibachs? and removing rear spacer...
  91. right front made 2 pops, spring boot is off...related, fix??
  92. How to Bleed the brakes?
  93. Eradispeeds cracking apart!?!?!?!
  94. drive shaft safty loop
  95. Cheapest place to get some Revalved Bilsteins?
  96. Selling G2 LCAs, how much?
  97. What to torque rear sway bar end links too?
  98. BMR stuff is crap ... now I have proof!
  99. Need spring recomendation.
  100. Anyone make 14" solid (non-drilled or slotted) rotors?
  101. springs and shocks question
  102. Need Help BMR Drive shaft Hoop
  103. lower control arms
  104. Upper Panhard Bar Mount - Need to know size of the 3 bolts
  105. got some new shocks, intalling the fronts?
  106. SLP SFCs vs BMR Boxed SFCs. Which to get?
  107. Installing new front struts > Will I need another alignment?
  108. Measurement Question
  109. Brake Options
  110. EBay "Mastergrade" crossdrilled / slotted rotors
  111. COIL OVER HELP
  112. Steel Braided Brake lines
  113. tie rod ends
  114. Dealer done right!
  115. Whats better 2001 WS6 or 2001 SS springs
  116. Did your air bag come with instructions?
  117. Hawk HPS vs Hawk HP Plus
  118. So HAL shocks won't work with eibach springs?
  119. Metco LCA's
  120. suspension
  121. What came stock on our cars?
  122. Redoing the brake lines...
  123. caliper mounting bracket
  124. Keep ABS or ditch it??
  125. Which way do the stock LCAs go?
  126. Photos - Added red Z06 calipers to the SS
  127. Strange problem with Hal/Qa1 shocks
  128. how much to weld SFC's
  129. Installed BMR tubular LCAs and still have wheelhop WTF!?!?!
  130. Need a new torque arm, Edelbrock respectable?
  131. What springs/shocks to get???
  132. Springs
  133. Where can I get new HEIM joints for my LG Tubular LCAs?
  134. Car feels loose on the street.
  135. Bleeding brake system on 2000 SS with Traction Control?
  136. Why wont my right rear rotor come off?
  137. Hal QA1 switch to Bilstein?
  138. suspension noise
  139. stress fractures on the eradispeeds, now what?
  140. Hal install complete
  141. Will 340 tread wear last long?
  142. Horrible squeaking problem.
  143. is this a Torq arm issue?
  144. Do BMR relocation brackets only fit BMR lower control arms?
  145. Motor is done, now i need to know where to start on the sus.
  146. Spohn Torque Arm road noise.
  147. Still getting too much float/roll in a straight line.
  148. RIP OFF or NOT
  149. 1LE springs
  150. Let's talk LINE LOCKS...
  151. Torching the SPRINGS
  152. How to unfreeze the brake caliper bracket (the bolt in it)
  153. BMR springs
  154. pics of roll cages
  155. anyone running a global west torque arm??
  156. Yank 4L60E/T-56 Transmission crossmember TA relocation mount
  157. Caliper upgrade w/ stock rotors?
  158. BMR K-Member and A-Arm question
  159. HAL shocks/springs....need help.
  160. dimensions of stock shocks/struts?
  161. Front caliper slider seized up...replacement options?
  162. Need quick help on removing steering shaft
  163. installing springs, LCA's,and panhard rod tomorrow any tips
  164. Wow! Looky at what broke!! (pic)
  165. Rear shock/LCA clearance issue
  166. New SLP torque arm
  167. LCAs on ebay
  168. Sloppy steering
  169. eibach drag launch kit, any pros/cons?
  170. anybody got carbon rotors w/ carbon pads
  171. good suspension set-up ??
  172. Does a TA need a rod end as a PHB and LCAs do?
  173. Help with torque arm adjustment?
  174. can i run stock rear/front springs with the HAl's?
  175. Brake chatter...
  176. Can [synthetic] ATF be used in the power steering...?
  177. can you help?
  178. Rear Sway bar size??
  179. Bought some new stuff today!!
  180. Cross drilled and slotted rotors!!!
  181. Well I ordered a few things. What do you think?
  182. crossmember to clear Hooker ORP
  183. problems with removing front sway bar?
  184. How much to install?
  185. Do QA1 shocks need to break in?
  186. What causes this and how/what can I upgrade to fix it?
  187. Just can't decide.
  188. Has anybody ever broken bolt-on lca relocation brackets?
  189. What look for when diagnosing poly and heim joints for wear?
  190. sideways on 1-2 shift
  191. Subframes? So many differnt kinds?
  192. Traction Issues!!
  193. Front Sway Bushings Question...
  194. Anti-roll bar....do I need a APHR too?
  195. Should I get the LG double adj or single adj PHB?
  196. Need advice now!!!
  197. ABS Module?
  198. Suspension
  199. tubular k-member
  200. G2 Torque arm install?
  201. Searching for bushings.
  202. Best place to buy a complete set of Hal's?
  203. Nose dive
  204. Problem w/Hotchkis STB
  205. SwayBar End Links....
  206. Lowering the SS 1"
  207. SLP Bilsteins
  208. Photos - Before/After lowering springs
  209. what the h*ll is up with my track times?
  210. EBC rotors, one year later
  211. How much does the bushings on a torque arm matter? (Spohn)
  212. When are LCA relocation brackets needed and what do they do?
  213. Poly. Trans Bushing?
  214. Cross Brace Help
  215. 3pt stb? need help!
  216. Need help bleeding brakes
  217. uhh???
  218. What springs are you running in the rear w/ HAL's?
  219. Lowering My Car Question
  220. 1 year durability update on BMR suspension parts
  221. Setting pinion angle
  222. swapping brake calipers - general question
  223. Brake Fluid, need help
  224. Eibach or Hotchkis
  225. Cut my stock springs today
  226. what size is hotchkis front bar?
  227. When is wheel alignment needed?
  228. Anyone Have Don Goetz's SFC's?
  229. Do I need relocation brackets?
  230. Am I missing a frame brace???? Pic
  231. Torque Arm bushing?
  232. SLP Driveshaft Loop
  233. Coilover question
  234. Would Anyone buy a Tunnel Brace?
  235. Do the Tubular Panhards clear aftermarket girdle covers?
  236. Look what santa ( a.k.a. the ups man ) brought today!!
  237. SFC Help
  238. is a low-speed "groan" normal???
  239. How hard is it to install a Brake Master and brake Booster?
  240. I know how to weld, should I weld in my own SFC's?
  241. What brake pads for Wilwood Superlite 6-piston calipers?
  242. Paging lowered cars with high hp (Over 400RWHP)
  243. strange leak
  244. New rotors arrived! iRotors!
  245. how quick before you need a cage?
  246. Best brake rotors and pads ??
  247. Got my torque arm in today, I gotta question though?
  248. a little help please....
  249. Help with warped rotors.need new ones.
  250. Take off shocks and Hotchkis springs?
