View Full Version : Suspension & Brakes
- motor mounts ... do them now (22k mi) with exhaust? or do them later with K-Member?
- Just A Little Help!
- pics of my new brake setup.
- C5 conversion, Hawk HP Plus pads... HORRIBLE squeal under light braking pressure
- GM LS1 front, GM LT1 rear ceramic pad users?
- stock ride height?
- warped rotors cause vibration just cruising???
- How to adjust Koni 4/4's on car?
- Broke a Koni
- Suspension
- Anyone know what the front/ rear weight distribution is on a T/A?
- Torque arm advice on new setup
- What Springs?
- abs problems
- brake setup
- i need traction, help me out
- Front alignment adjustments (shade tree)?
- What should my pinion angle be?
- lowering question
- Should i get brackets for slp stage 1?
- Reporting on my 1.8in drop.
- Specs on a 10sec cage
- Rod/Rod suspension components
- Front Stabilizer bar
- Need help finding a BMR K-Member.
- Hotchkis vs. Strano springs
- 98-02 K member
- QA1 front spring question
- 02-04 Z06 brake pads for a 02 f-body
- Roll cage install
- I think I've got my plans figured out... insight?
- Identifying front QA1 springs
- Best springs?
- Duralast pads vs Hawk
- changed a arms, now i have a problem
- Lowering a 2000 ss camaro conv.
- Coil springs and unsprung weight
- Installing struts
- Squeeky front poly bushings?
- newb shock question
- V6 springs (specifically fronts) of any use at all on SS? Weight transfer any better?
- Good stiff springs?
- Coil Overs????
- Hawks Ceramic pads
- best place to buy coilovers? 97 z
- Dose this sound right? (suspension idea)
- lowering with 28" tires?
- What can Brown do for you?
- UMI vs. BMR SFC?
- im going to lower my car, how much should i lower it?
- Best springs to lower front of car?
- Qa1 questions?
- 3rd/4th gen FMSI brake line fittings
- Welding my BMR sfc's in on firday..
- UMI is great but takes to long to ship
- Vogtland Springs?
- BILSTEIN HD's WITH EIBACH PRO KIT?
- Question about bad calipers?
- ? for UMI sales people
- Need Suspension Advice
- WARRANTY ON BILSTEIN HD's?
- Steering Rack Removal?
- Should I Get These?
- Car is hard to keep in a strait line, very hard steering??
- Put new brakes on now they feel differnet.
- Torque Arm Weight
- Sportlines + Long Tubes = No More Speed Bumps
- building front end need input.
- Need input on HAL Shocks and Springs
- irs for an m6 for sale?
- caliper pin problems
- Spring Settlement Question
- New Rotor
- Need help with Springs/shocks
- Unsprung weight
- Brake line routing
- brake lights wont work
- Please give advice on Shocks/Springs for my Vert
- Made your own Subframe Connectors?
- Whats the BEST way to remove SFC's?
- poping? PISSIN ME OFF!
- Hotchkis vs Eibach LT1 Pro-kit vs Strano
- adj. torque arm with non adjustable lca's
- BMR springs 2" drop not 1"
- Is there a thread on brake replacement
- Rear brakes squeek on turn
- Ran dry on brake fluid!?! HELP
- Torque specs
- Koni SA Recommended Settings?
- can of worms
- Help with LS-1 Brake upgrade
- Finishing my suspension, suggestions please
- General Suspension Question!
- installed new parts, have Q's
- bolt length for umi t/a
- What the heck shocks/springs do I have?
- General Suspension Issues/Questions FAQ
- Problem getting enough caster in my car.
- What is Everyone's Opinion on KYB AGX Shocks and Springs?
- Front driver side BAD squeak. PLEASE HELP
- Bilstein HD Shocks
- Sterring
- what spring rate with QA1-R shocks
- Ride Height Question
- Used Bilsteins And Springs?
- QA-1 Coil over for my SS?
- How much for alignment?
- corvette irs in camaro
- Read end feels like it sways from left/right at highspeed
- suspension bushings
- Edelbrock Shocks
- 2 sets of front brake pads ??
- Pinion Angle - UMI torque arm HELP
- Ride height differance with 275and 315lb springs
- Upgrade Questions
- best slotted rotors?
- DMS springs
- What is a good price for roll cage install?
- painted rotor hats...need help
- Big brakes, brackets and unsprung weight
- these rotors....what ya think?
- Sam
- Want to convert my power steering lines over to -AN
- Chrome STB???
- caliper paint....opinions needed
- New rotors/pads problems..
- Eibach ass sag problem fixed???? maybe. see in here.
- C5 Calipers behind ZR-1s. Any pics?
- bilstein shocks and springs
- Need Opinions Badly!
- Gage Going In!!
- Vibration at idle
- Ball Joint or Tie Rod?
- [b][b] Please Help Out![/b][/b]
- slotted rotors for firebird opinions
- Street driven without ABS?
- Need to re-valve??
- Does Anyone Make Drop Spindles For Our Cars?
- UMI T-mounted TA. Bolt making contact w/ DS
- How to remove rear rotor
- I need your opinion
- drag radials with no SFC??
- Swapping out stock F-Body brakes?
- is it worth it???
- Need help/advice building street/strip T/A
- Brake Bleeder Screw Part numbers
- spacers for the LCA relocation bracket ??
- Lifting the car with SFC's on??
- ls1 brakes
- Bad Noise Suspension vs rearend
- knocking noise from drivers frt wheel
- front suspension arrived
- Those with DMS springs...COME IN!!!
- HELP!!!!! Can't get rear rotors off!!!
- Stock LCA axle mounts not even?
- squeak?
- good road racong shock??
- V6 F-body chassis and suspension
- koni adjustables vs. bilstein revalves
- How Can I Get More Front Wheel Travel?
- Got my drilled/slotted Rotors. from rotorsonline.com
- Subframes-Worth it?
- aligment
- Subframe Connectors
- Need Rotors what kind though?
- Changing Brakes
- Installing grease fittings in stock front control arms?
- Noise?
- Rear spring isolater squeek
- Odd braking at high speed or hard turn and brake, ABS related>
- Rear Axle Bumper
- Where to buy ebrake parts?
- F-body Spring/Shock install write up?
- brake fluid
- Just installed my suspension mods.
- Q on installing Adj. TA
- crank pully rubbing on sway bar
- will i still have 50/50 braking if i get rid of my ABS?
- Lowered Car.. Can't Be aligned..
- Photoshop please
- Prokits and aftermarket shock replacements - Can I get away with it?
- Alignment specs, best all round usage to use?
- Need softer suspension
- front shock/spring removal
- bilstien front shock ?
- What To Do! What To Do?
- poor brakes
- I have tried EVERYTHING!!
- Flex brake line to rearend
- What brands springs are red?
- severe vibration!
- Brake pad swap, brakes clicking during hard braking
- QA1 rebuild
- Power steering problems
- Wilwood Brakes, tell me about them
- anyone have a manuel rack that drives on the street?
- Coming Soon... 82-92 Tunnel Mounted Torque arm
- Stock WS6 ride height? ...and bump stop advice needed
- suspension install
- symptoms of torque arm being loose??
- Weird noise after sway bar install
- Hotchkis Springs. Before...After.........After
- rear lower control arms...worth it?
- Wheel hop! Help!
- brake lines
- Which TQ arm with a 9"???
- Loc-tite and nylon locking nuts?
- Who has the number to www.EngineeredVelocity.com
- wheel hop, from LCA bearings?
- Where to buy pete z bars?
- UMI LCAR Brackets...need some help
- HELP!!! installing sportline springs
- missing strut mounts?
- (Yet another) Strano Suspension is on.
- Do I really need to chance my shocks soon?
- bilstien's with stock springs ??
- Near stock ride-height springs
- Madman steering shaft??
- Please Help......
- Energy Suspenion
- eibachs vs. off brands??
- Sway bar or LCA
- UMI lca install
- Installed Earls SS lines but have question.
- i need some help with part names...
- Prokit + Koni SA... owners inside.?
- How important is it to get your rotors turned when doing the brakes?
- dimensional specs of 98-02 WS6 springs?
- BMR binding
- Anyone have pics or have QA1 front coil overs
- How to lower the front?Without springs?
- powersteering has to go
- Just intalled SLP bolt-in subframe connectors
- 2002 F-Body Frame Rail Width
- Best Koni Set Price?
- Suspension parts are on!
- Front brake rotor upgrade.
- c6 Zo6 brake bracket for f-body????
- Does ayone know what parts came with the SLP level 1 suspension?
- Ground control kit?
- lower control arm
- Brake Help
- Umi
- what's up with my parking brake?
- pain in the A$$ struts install
- i want i want i want. please help
- LCAR Brackets. . . Need some help
- want to know what difference to expect:UMI parts:D
- Anyone running Strange "Pro Race" brakes?
- Brake Fluid
