View Full Version : Suspension & Brakes
- Do verts use same struts/shocks?
- diff between 3 channel and 4 channel ABS?
- Turn One pump
- abs inop light
- new rotor needed?
- where do i start?
- SJM Line Lock Kit: How hard to install?
- Panhard rod and Lower control arm blowout in sale section
- Bilstein Heavy Duty Shocks, how good?
- Bilstein HD's with BMR springs?
- panhard bar install
- How Long Before OEM Brakes Need Replaced
- Thank you Victor & Precision Brakes for my upgrade!!!
- anyone know the name/part number for the e-brake cable stop on the rear end?
- Lowered Cars with 315's
- Cracked my stock torque arm should I get a after market?
- BMR lowering springs
- Cutting rear springs?
- What's the weight diff. between Strano's 35/22mm sway bars & the '02 Z28 sway bars?
- New UMI tourque arm, lca's and panhard bar
- WELD IN re location brackets
- suspension... wut ???
- slp dssl
- installed my umi 3 point bolt in sfc's and spohn adjustable lca's.
- Need rear spring recommendation
- Brake noise
- SLP SFC's - instructions
- A couple of questions about removing rear isolators
- WHY an alignment after lowering?
- BMR Xtreme Torque Arm
- abs light and brake light
- Rear Springs ?
- Cutting 1/2 Coil on SLP Eibach Springs = What?
- adjustable STB?
- My Car Is A Turnin Turd
- steering column questions
- anyone make custom springs??
- After installing eibach lowering springs
- Right front has a metallic tap everytime I go over uneven road
- disconnecting front swaybar..(I'm a dork)
- Setting Spohn TA?
- Rocks eating away my rotor??
- need help with torque arm bolt!
- 325lb springs too much for drag racing?
- Wheel hop after hitting second...
- Fabrication?
- Difference from T/A to WS6?
- need opinion about lowering car after motor install.
- Camaro Brake leak
- specs for hypercoil rear springs
- What shocks for daily driving comfort?
- Upgrading to LS1 brakes?
- Where to get Brembo rotors locally?
- flapping sound
- power steering leaking and not working well what do i do?
- hit curb, need help
- Spring Rate Question
- Rear brake(left side) squeekes loud after brake job
- LG SFCs not meant for off road use
- Car sags in the Rear! Help!!
- PA Racing FitmentQuestion
- BMR Panhard rod relocation kit
- I know, I know
- Panhard Rod.. Which one?
- Air ride
- quick question about springs
- SFC Question??
- Wrecked my WS6
- anyone ever heard of A&W race cars?
- 04 GTO tie rod
- do 93-97 trans am springs fit on a 3rd generacion camaro or even 2nd gen trans am???
- P/N for front swayber endlinks?
- LS1 Rear Disk Setup on 8.5" 10 Bolt
- Subframe connectors. Bolt or weld?
- Koni help: Can't get the allen wrench in there.
- question about cutting springs.
- Rotors from WS6 store?
- will 02 T/A springs/shocks fit in a 94?
- !Front Swaybar
- A "Thunking" that is driving me bananas!!
- Help how do i get the calipers off??
- SFC Pictures
- play in steering
- Sping compressor for Strange shock assembly
- Brake crises
- Is an alignment necessary after spring/shock install?
- Removing ABS
- Jacking points for Tubular SFC
- will eibach springs for 2002 ls1 fit 1995 lt1 camaro?
- Aftermarket Torque Arm Necessary?
- Are my wheel bearings bad?????
- Umi LCA's, which ones?
- Heated Springs
- torque arm?
- 2pc rotors for the Fbody?
- raising back up wat to do wit relocation bracket
- Want to raise Pro-Kit rear
- Looking for a good SFC
- Spohn Torque Arm Installed *pics*
- whats for handling and whats for stiffening?
- abs inop and e-break
- Question on Brakes.
- What kit??
- BMR Lowering Springs
- Wtf No Brakes
- Ball joint starting to go out, how long do I have?
- Where To Buy BMR Lowering Springs?
- What DS loop
- How long does shipping take for springs?
- What do I need to hook my Spohn T/A to my 12 bolt?
- Rear air bag
- anyone know where I can get....
- Spindle arm/ball joint stud are kicking my ass...
- Wilwood 6 piston brakes
- One more Strano fan.
- Brake booster interchangeablility
- Help with front Caliper Bolts...they just keep spinning
- Shock tower nuts
- Is this normal for a chassis mounted TA?
- Help Swapping out Front Control Arm
- Need help with brakes for tire and wheel size.
- Adding safety loop to chassis mount torque arm?
- New Koni SA's in, what settings?
- Hotchkis or Pro kit???
- true duals + chassis mounted tq. arm?
- Any opinions on these slotted/drilled rotors from Ebay
- hawk HPS vs Ceramic
- what setup for street use?
- Heater hose mod done...now alot of squeking...any ideas?
- stb
- Something making a banging noise
- Help steering play problem
- HorsepowerTV Camaro airbag
- My ABS Inop light comes on...
- Next Mod?????????
- Koni Guys:
- Weld in relo brackets
- coil-over advantages
- adjustable coil overs maybe??
- Are there any benifits to having..
- Lower control arm question:
- New Spohn Torque arm in, new problem!
- LSx in what platform for road racing?
- lowering trans am
- Shock Set-up?
- twisted chassis
- Supension upgrades: Koni hose mod
- Koni / Hotchkis setup from Strano
- Brake fluid?'s
- Just get GM rotors and pads?
- Traction Bars
- Shock & spring swap completed - my story
- Exhaust hitting new subframe connectors
- has anybody had to change their tie rods?
- In the market for new rotors
- How to disable ABS?
- Suspension Help ! ! !
- can anyone help me wiith suspension parts?
- Pulling ABS fuse
- got my bilstein shocks, can some one -
- looking for a link.......slotted rotors, but not what you think
- A whole new animal after suspension upgrades!
- which ones?
- Shock question
- cheap angle finder!
- K-member
- lowering springs
- Vibration - bad strut?
- adjusting a non adjustable panhard rod??
- Noise when braking
- ceramic pads...
- Just got my UMI stuff
- What tq arm will work w/ 9" and td
- stock strut length
- Lowering shocks and springs
- Need Help. Car wonders at high speeds
- 2000 Yukon Denali Body Roll
- how do i adj panhard rod?
- poly bushing
- changed my brakes WOW!!!!!
- c5 upgrade and the spare tire
- Air ride? Anyone got pics or vids of Air bagging?
- LG motorsports C5 adapter brackets????
- Bleeding when installing EBCM module?
- adjusting koni DA's on 1LE
- subframe-gm knows best
- Torque arm question...
- Differences between stock Z28, SS, SLP Bilstein, and 1LE Suspensions
- Strange springs and shocks
- sportline kit installed now some issues?
- Moser 12 Bolt + BMR Panhard Bar = BANG
- Quick Handling Question
- Stock Shock and Suspension Travel Specs
- Edelbrock TA, worth it or not?
- Help Removing Lower Spring Perch
- Info on How to Lower?
- How good are the 1LE springs?
- What are the symptoms of warped rotors?
- Help, Hotchkis Hell!
- *Pics* Polished the brake calipers on my Firehawk.
- Differences between relocation bracket and w/o
- shocks and springs info needed
- LCAs/Brackets ?s
- Drag springs
- BMR whats the deal??
- Rear Brakes?
- Car makes noise when i hit bumps.
- Are adj. suspension pieces noisey?
- Steering Rack Part Number/ Replacement
- Question on UMI torque arm relocation mount, and duals
- Someone please explain skid pad #'s to me
- Help..I got ripped off on some hothkis springs..got ?? instead
- Bob's Brackets?
- Koni DA's yellow. Bought them couldn't resist, what do you think?
- KYB Gasadjust
- SS Brake Lines and ABS
- Back to stock springs
- c5 z06 front brakes on 99 WS6
- What are some componets I should stay away from
- Z06 Caliper install
- LCA Relocation Bracket Question?
- Can I run rear bilsteins only
- Dms springs- one side sits lower
- Upper control arm
- Just purchased, are these good?
- Sponsors, does anyone have stainless steel braided brake lines in stock?
- Cant decide on springs
- what springs and struts should i go with?
- lightest subframe connectors
- 4 link
- Best place for subframe connectors
- Spohn Torque Arm
- whats the best option?
- How do I center my Axle?
- correct way to weld in LCA relocation brackets?
- umi suspension?
- Lowering Tech Article
- good writeups for brake work?
- $160.00 for Cross Drilled/Slotted Brembo Rotors & $60.00 for PBR Pads... Good Deal??
- Tubular K member for DD
- Who knows their ABS system?
- Vibration through pedal/floorboard
- Torque arm noise, tubular mount vs. lipped stock style
- need to find some part numbers for suspension
- Koni SA's
- Springs
- need to drop 60'
- How to pull brake pads further from rotor?
- what sway bar setup for minimal body roll
- Will LCA'S and panhard STOP THE SQWEAK
