View Full Version : Suspension & Brakes
- ? on tires
- Should I put Pilot Sports in the back instead of Nittos?
- tailshaft vs tunnel brace for torque arms
- Please, I need pics of your weld-on reloc brackets, help
- Rear is squeaking.....
- Skinniest tire on stock rim
- Can I remove these? Any probs?
- LOWERING CONCERN
- Long T/A or Short T/A?? What was the verdict??
- 16x8 with E/T`s enough tire?
- manual steering rack and handling /and other weight loss related ideas
- Hows This Suspension Set-up?
- Where to buy Nitto 555 R2s?
- Drag radials
- LCA end question.
- Torque Arm
- EBC rotors - initial findings
- SUSPENSON PARTS ?'S
- Shocks, various makes, opinions?
- Traction mod
- spohn torque arm ok for 9-10 sec car?
- No Grease fittings on BMR front control arms???
- Polygraphite or Polyeurathane?
- Wolfe RaceCraft 6 point roll cage weight
- So I'm getting some chromemoly subframe connectors. Anyone got em?
- slp level 1 ??
- WTF is this squeeking noise???
- Wheel hop?
- Traction...17" vs. 16"
- good torque arm?
- Rebuild rear calipers (What's involved)
- Cold tires..beware
- Spohn Roll Cages - Anyone have one?
- A-Arm Replacement
- Which part for lowering?
- g2 lca and phb
- rear suspension ?????????
- Passanger side sits lower and hitting the rear wheel, please help
- need some traction and brake advice
- 98 ws6, warped rotors, 40K miles.
- What would I need to avoid loosing traction with street tires with an 8# ATI SC?
- Anyone tried PPC LCA's?
- suspension help
- Whats the diff. between these swaybars
- Help looking for Poly Kit for my Sway Bars
- rear slides over when doing a burnout?
- Need info on brake kits.
- Installing LCA relocation brackets
- Who sells Tokico Illumina 5 shocks F/R???
- Steering rack replaced... best way to bleed.
- Questions for those who cut their springs.....
- Pro-Kit Install
- My PS pump went out, hard to install a new one?
- Which One First
- LGM Rear Suspension Parts are In
- Which shocks TB on a Budget???
- BMR K Member: Does it lower the front of the car?
- Bad ABS sensor?
- Bleeding Power Steering
- Is this a good slick/skinny combo?
- Improving braking...best bang for buck?
- LCA poly/rod and rod/rod
- brake pads
- Question on tires.
- Changing Tire/Wheels help out wheel hop?
- BMR subs & strut tower bar
- BMR LCA Relocators with stock LCA's?
- K-member and Alignment
- Tires follow road ruts
- 335 street tires on rear and 295 on front, whatyathink?
- In need of better tires
- Question on greaing suspension??
- Delco Durastops
- Car hard to steer
- upgrading from poly bushing lca's to rod end lca's
- rear brake rotor measurements
- Other Springs?
- Will 18x10's fit on the front???
- Strut Tower
- Finding some middle ground
- Kumho MXs: good tire?
- How to remove front sway bar?
- Locking Lug Nuts
- HAL's w/ Eibach sportlines?
- Removing front sway bar
- How hard to remove front sway bar?
- Comp Engineering Shocks
- Did suspension go out
- Any experience with Wagner brake pads?
- Lakewood traction action lift bars?
- Another brake pad question
- BMR double adjustable LCAs
- drag racing/ BEST lca's? metco?
- The best lowering kit for Ls1?
- sway bar end links
- Dynamic Motorsports springs???
- Lightweight Wheels
- SLP 21mm rear sway bar
- adjustable Vrs. fixed LCA
- DMS SFC's
- Relocation brackets for LCA's?
- weight limits
- kyb gas-a-just !
- Got EBC Rotors, check in here
- What could cause a sudden increase in brake pedal firmness?
- DR's...which ones to buy??
- problem with bmr adj. torque arm!!
- Anyone with BMR tubular SFC's??
- "Wonder Bar" ?
- Braided steel brake lines & TCS?
- "Low trac" light comes on, but no TCS?
- sfc's and headers?
- 315/35/17's do work on 9.5" rims! Measured footprint of 275 vs. 315 on 9.5" rims!
- Weld Pro-Stars Sizing, Backspacing etc...
- Those with P315 35R17 in the Rear???
- Wheelhop help needed!!!
- Seriously pissed......
- Removing calipers question....
- anyone's steering wheel do this?
- SLP headers & Eibach springs, clearance issues??
- If stb do anything when...
- lowering car with SLP long tubes?
- SLP SFC pics
- QA1 HAL shocks??
- boxed stock LCA's?
- I need a good street brake pad
- LG brake kits
- Still Hops
- Different torque specs for Hotchkis LCA's??
- Weights of PPC LCAs, PHB & SFCs .....>>>
- Spring experts please!
- mod mark
- If any sponsor can tell me...
- Caliper differences
- Handling Pros/Cons w/Tubular K-member and A-Arms
- Doing a Brake Job at home??
- Best street tire for under $200?
- clunking noise under the car!!!
- Steering feels loose-- any ideas?
- When changing brake pads...?
- Getting ready to install HyperCoils ... need some info
- Need Procedure For Front Springs R&R...
- Need pics of Sportlines with 17x11's
- Ok...I boiled it down to these last few tires..help me decide!
- Do Hawk pads have good life?
- ? on slotted rotors
- 285 tires on stock wheels?
- Question about sway bars and my setup?
- Need fast, Koni Part #s
- ABS INOP Light
- granatelli suspension
- SLP level 1 suspension
- Just a Little Off The Top, Please
- Aluminum Panhard Rod?
- Slot the error (or maybe I'm wrong?)
- will z06 calipers fit on the rear?
- anything besides warped rotors?
- Autozone rotors
- G2 super springs
- Brakes ???
- Brakes ???
- fighting sterring wheel
- What is the knurl size?
- Stock F-body rotor dimensions
- Suspension shop in New York for Camaros?
- look @ these tires
- whats the biggest tire for my rims?
- G2 springs on a stock car
- Autozone (Aimco) rotors...so far, so good
- What Should I Charge For SLP Level 1 Install?
- What are the pre-cautions for weld-on relocation brakets installation?
- Bent K-Member??
- LG Motorsports brake kits
- Level 1 with 24 mm rear bar - too much?
- Directions for adjusting adjustable LCA and PHB
- I have wheel hop : (
- 17x11's on lowered vert ..... work?
- LCA Brackets (bolt-ons)
- Brake Line Size Question
- Ive got stock breaking system with Autozone peformance friction brake pads and..
- Lowering car
- cutting or grinding caliper for clearance?
- IRS for 4th Gen F-body
- web tutorial The Physics of Road Racing
- Does a strut tower brace do any good?
- How do you stop poly LCA bushings from squeaking?
- Spring confusion ...HELP!
- Ball Joint For ARE K member
- squeeking brakes
- Master cylinder
- Do I Need New Tires?
- Whats the best sticking and longest lasting tire out there?
- Tunnel Brace??
- g2 SFCs????
- lowering springs
- Edelbrock Boxed LCA's same as Hotchkis???
- noticeable difference with LCA's?
- Alingment Questions
- Looking for Subframe Connector Installer
- How well are BFG dr's in the corners?
- air pressure in yocahamma dr
- Easy spring question
- need help on putting 99 vette rims on a 98 Z28
- Factory Swaybar removal, what will happen?????
- Ground Effects - real effects?
- What tires to buy?
- Got my Hals today.
- Anyone running a single rate spring?
- SFC???
- ??BMR k member 4 manual rack needs WELDING?
- torque wrinch
- Who sells blue lowering springs?
- Bent Panhard rod any effects?
- Lowering Options?
- bmr springs?
- What advantages do you get by getting an aftermarket panhard bar???
- Baer Claw Systems?
- how to adjust a panhard rod ?
- roll bar question
- G2 Coil Over kit
- sub frame connectors
- Adjustable Panhard Question?
- 98+ Camaro front end aerodynamics?
- pics of a pro kit with 17x11's out back
- Any common mods make high-speed aerodynamics worse?
- Hal shocks/ front springs. which rear springs?
- Kumho Ecsta Supra 712
- Baer Alcon Extreme+ question
- G2 Race Adjustable LCA's
- Any pics of REAR shock-tower bracing?
- Floaty Front End At High Speed?
- what pds with Baer Eradispeed Rotors?
- Those who has different tires size Front/Rear
- getting a sportline kit. what else do i need
- TT2's and Big Brake Kits
- New Sponsor .. PPC ...F-Body Brakes & Suspension
- Front riding high
- Anyone using a 9-inch rear with LCA reloc. brackets?
- Energy vs. Prothane Bushings, any difference?
- Brake "floating"?
- Are LCA Reloc. Brackets hard to install?
- C5 coil over suspension Help!
- C5 To F body brake brackets
- What shocks come on SS
- Strut tower brace question
- what aftermarket springs do I have???
- need a torque arm
- BMR springs
- more brake pad questions
