PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 [136] 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152
  1. CG height
  2. New brakes
  3. Random Tech.
  4. Tire pressure
  5. What would a dead shock sound like? Bad Noise under car
  6. Convertible subframe install... remove stock SFC?
  7. What front springs to run with HAL shocks?
  8. Potentially stupid question.
  9. Alston Torqure Arm
  10. Dms Products?
  11. Alston Torque Arm
  12. what dsl with lowered car?
  13. Does anyone have adjustable schocks?
  14. Steering wheel cocked right, wobbly wheel..help!
  15. ABS INOP light coming on .......
  16. Gotta fix my car but found out I OWE money on my tax return...suggestions plz
  17. Grade 8 bolts good enough for LCA relocation bracket?
  18. Will 98-02 k-member fit on 97s?
  19. rear thumping noise
  20. Line Lock?
  21. Air Shocks- Call me Crazy!
  22. Can I still turn my stock rear rotors?
  23. Lowering 2inches any problems?
  24. Anyone having issues with their tq-arm w/
  25. Sure Stop Rotor Specail
  26. panhard bar.....good idea?
  27. new CHEAP SFC company!!!
  28. Ok, I was out cleaning the car and noticed this *pics*
  29. creaking sound coming from the passenger side rear
  30. Has anyone hear cracked their windshield because of too much torque?
  31. street strip shocks tech
  32. any difference between poly/rod vs polypoly suspension
  33. Brake Pads
  34. Sway Bar or Adj. PHB??
  35. What shocks w/ BMR 1" lowering springs
  36. Opinions on Jegster Bolt On SFC's please
  37. drag racing susp.
  38. Which Springs to use w/Hotchkis SwayBars?
  39. Minimal Brake Dust. Which pad?
  40. Airbag suspension
  41. Need reloc. brackets for LCA... FAST !!!
  42. How bad would it scrape???
  43. Pictures of installed SFCs please
  44. headers dragging
  45. another shock Q muahaha . search? wahts that
  46. Sam Strano, revalve price?
  47. Help! Stuck while installing front strut!!!
  48. Installed Moser 9" what Swaybar to get?
  49. Which replacement shock for daily driver?
  50. How to decrease F-Body weight?
  51. Torque Arm...help
  52. Spohn torque arm
  53. Experts comment on my setup
  54. Is the very 1st setting (all the way to the left) considered 1 or 0?
  55. Tie Rod Replacement
  56. Convertible rear shocks - access?
  57. PA K-Member even lower
  58. Spring/shock swap - Front strut pieces?
  59. I need traction !!!!!!!!!!!!
  60. Help, what is this?
  61. suspension newbie needs spring recommendations (yes, i tried the search)...
  62. Crossbrace, TQ Arm, and true duals...who's got it
  63. Eibach/Sway bars
  64. Jack up car with BMR boxed SFC's
  65. Who's having a sale?
  66. Creaky noises normal with poly bushings?
  67. SLP Sub Frame Connectors...
  68. if you have DMS and BILSTEIN HD NON-REVALVED please come in
  69. need alignment help
  70. Cures for crooked launches?
  71. Installed Bilsteins.....Car now sits up higher on the DRIVER's side...
  72. Sub frames
  73. Baer Brake systems
  74. which springs go good w/HD Billsteins?
  75. 1LE or BMR....Please read....
  76. People with Hotchkis springs....
  77. need some very average shock/spring advice
  78. what else do i need??
  79. BMR or PA
  80. 17's or 18's Help???
  81. Swaybars
  82. PA K-Member Special
  83. Installing Bilstein HD's and BMR springs help?
  84. LCA Help
  85. riding high in the back?????
  86. Addco 35mm Front Hollow Bar !!!
  87. Anybody notice raised height w/ Bilstein HD shocks?
  88. What DSL with FLP's
  89. just got my car lowered........
  90. Explanation needed regarding swaybar balance.
  91. Hal f and r series
  92. Installing LCA relocation brackets, what height/holes?
  93. Will I have to roll the fender lips with this combo?
  94. Painted cailpers...in progress...pics
  95. Right suspension setup?
  96. Left side of car jacked up??
  97. Rear sway bar for drag racing!
  98. Manual Steering Rack
  99. Best Shock/Spring combo for a 1" drop?
  100. spring installation question
  101. Good poly trans mount? Which
  102. Eibach Pro Kit
  103. Intrax Springs w/LT's?
  104. Hub bearing noise?
  105. Best Sub-Frame Connectors?
  106. Sway bars on WS6
  107. solid end lca advantage????
  108. sway bar size on 99ss????
  109. STB at the track
  110. Pinion angle?
  111. Factory installed STB
  112. Those with Hals, what are you setting the ride height to?
  113. Custom SFC's
  114. sprint springs?
  115. Panhard bar clunking
  116. Installed LCA reloc. brackets, LCA's, and PHB today.
  117. ABS noisey and violent??!!
  118. anyone using the new coilovers for the rear?
  119. Steering rack clunk
  120. Getting rotors turned
  121. Brake Problem
  122. wheel spin fix
  123. Body Twist?
  124. Rear springs rubbing in an odd place - help
  125. New Guy Mods
  126. Installin Bilstein HD's/1LE rear sway bar/Performance align....
  127. Dms or pro kit springs?
  128. Installation/maintenance questions?
  129. are KBDDs necessary?
  130. what setup???
  131. Strut Tower Brace
  132. What shocks should I get?
  133. Will LS1 STB fit LT1?
  134. Stock Slalom Speed and modified
  135. kyb's and ground control
  136. How are rod LCA's and PHB suposed to feal?
  137. need help finding k-member and a-arms
  138. Anyone have experience w/ cutting off old SFC's?
  139. Tips on removing stock a-arm ball joint?
  140. Need help installing the front R series Hals.
  141. Suspension help-recommendations
  142. I-Rotors!!
  143. Any Prospeed Porsche brake kits left?
  144. Tell me about lowering
  145. benifits of a panhard bar
  146. springs & shocks?
  147. Need help installing rear Hals.
  148. Do I need an aftermarket torque arm?
  149. Alignment help needed.
  150. Need websites that explain spring/shock install.
  151. whATs a good shock and struts for dms spring
  152. Ugh another spring thread.
  153. Wheel hop HELL! HELP!
  154. How much to cut the rear bump stops for Eibach Pro-Kit springs?
  155. SSBC Force 10 Tri-Power Braking System??
  156. Competition Engineering Sub-Frame Connectors
  157. Susp. experts lets talk
  158. 2.0 60' All Day. Need Help!
  159. Help Me Hook Guys!
  160. Need help selecting springs and shocks.
  161. 99 SS suspension upgrade-- Any Advice?
  162. 2pt.stb's who's got them.
  163. Has anyone tried these SFCs?
  164. Illustration of where the rear bump stops and rubber spring isolators are?
  165. Any opinions?
  166. Sb 350 in a 99 z28?
  167. Installed Koni Shocks and SFC's today! Some ?'s
  168. Is this normal?
  169. How much better will my 60' be with a good TQ arm?
  170. Optional Bilstein Vs. Bilstein HD
  171. Bump steer?
  172. porsche brakes
  173. spring rates
  174. Anyone running this rear swaybar?
  175. Switching Brakes ?????
  176. Front end problem. Need help please.
  177. Size of tunnel brace bolts
  178. alternatives to the TA
  179. Removing welded SFC's
  180. Anybody running a 21mm 1LE rear swaybar?
  181. Installing Front Shocks
  182. ABS on the Side or Top of Pumpkin?
  183. Has anyone found a Driveshaft Loop that fits
  184. Best SFC's?
  185. Poly front upper and lower a arm bushings??
  186. Hal questions.
  187. ASR or TCS whatever I nned help
  188. Do any of the aftermarket swaybars (front, rear, or both) have any affect on drag use
  189. bmr sfc tubular ?
  190. Difficulty steering. Please help.
  191. I Need a shop in So Cal for SFC install.
  192. what SPRINGS for front and back....
  193. swaybar or not?
  194. Jegster torque arm
  195. ST swaybars
  196. traling arms
  197. How are the HAL QA1's on the street?
  198. sliding and fishtailing
  199. Tourque settings for the following?
  200. droping the car! few questions!
  201. Torque arm with true dual exhaust, Trans or Crossmember Mounted?
  202. need some shock advice
  203. Manual brakes and steering on street?
  204. BRAKE and ABS INOP light came on last night, any ideas?
  205. How many miles did your rear rotors last?
  206. need new tires.....
  207. painting brakes
  208. slp subframe connectors
  209. What Swaybars for this set up?
  210. STB - noticeable difference??
  211. Line Lock Install question
  212. K-member, BMR vs. PA?
  213. about mac springs
  214. Steering thunks...
  215. IF you had to build your suspention one piece at a time...
  216. Traction>subframe,panrod,controlarm, what?
  217. Stupid to not get subframe connectors?
  218. $25.00 drop
  219. Should I change Master Cylinder?
  220. Bad News..or Good...depends?
  221. Replacement Front Rotors
  222. major wheel hop question.
  223. Spring Thread, what to gow tih for a 1" drop?
  224. My thoughts on POLY bushings
  225. Useful life of stock suspension?
  226. Help! Rear alignment issues
  227. ABS Standard on all LS1's?
  228. Amazing handling WS6!
  229. Alignment now or after?
  230. Line Lock
  231. Loud Noise when Nailing it!
  232. Need Torque Specs for BMR LCA's....
  233. Lube for Heim joints?
  234. need help with earls stainless brake lines
  235. swaybar sizes
  236. Why???
  237. looking for rotors
  238. Noise and aftermarket LCAs
  239. Ground Control setup
  240. G2 front lower control arms -- wow
  241. Will LCA's help traction on a drag car w/ no wheelhop?
  242. 'Camaro' caliper decals???
  243. Winter Suspension Upgrade project..please help
  244. what can i do with my brake lines?
  245. rear springs for moser height increase
  246. Just installed adj phb for anyone who needs info
  247. What Front Brakes do you suggest
  248. Are bump steer tie rod ends necessary for lowered cars?
  249. C5 Rotors...?
  250. Got my BMR LCA's, Question about the Grease Nipples
