View Full Version : Suspension & Brakes
- QA1 coilover strut question
- QA1coilover strut question
- Are brand new in-box Koni 4/4s supposed to...
- Is this considered excessive clearance? (K-member mounting slot / BMR A-arm rod end)
- ?Simple question, will a umi/bmr tq arm relo bracket clear tsp duals
- Umi body mount T/A
- So whats up with my handling?
- Lower a-arm removal (front) - Need help
- BMR koni shock/springs
- need new lowing springs and shocks
- Can you drive without the torque arm.
- What are the best combination of parts for best handling at stock ride height?
- New On-Car Adjustable Poly/Poly Lower Control Arms
- How to replace brake shoes on E-brake?
- Umi Panhard Relocation Kit Issue
- How to get a lower 60ft without sticky tires?
- Adding to the Stickies/FAQ
- car sits 1inch higher on driver side
- Keeping torque arm bushing in place. Help.
- strano/bilstein question
- Does UMI tq arm reloc. bracket + adj tq arm have to = awful ride?
- Found a torn bushing...
- SLP Bilsteins and BMR Springs
- Lets Talk Brake Kits
- Is this what I want???
- What pad material with Baer rotors?
- Brembo's on 4th Gen
- Big cam? Car stops like garbage?
- bmr ta001 rod end size, broken
- Critique my suspension mods!
- OEM style Torque Arm Bushing - where the heck do you find them??
- 18 sets of Koni's on the way to me...
- Strano Springs... just arrived and in stock
- Thunder racing lca brackets
- Stock calipers froze up on me, can u buy just the outside brackets?
- *Long* Bilstein HD review and questions about how to improve daily driver comfort
- Is it really worth it!
- What brake rotors to use with C5 conversion?
- Squeak squeak squeak....
- Whats the must have First suspension mod
- UMI and BMR help
- New suspension parts. Question.
- Long or short t/a with 4l80e?
- Rear disk brakes on A body?
- Stranos and Bilsteins = bouncy.
- Bouncy frontand suspension
- Want to finally replace stock springs/shocks..
- lowering springs
- Anyone Using A Jack Bolt Setup??
- 4th gen brakes/suspension on 3rd gen?
- Driving me nuts!!!
- hotchkis and general questions
- Lowered cars with true duals (pics)
- J&M Products/HotPart Suspension "Street" LCAs w/ Poly Bushings, Adjustable (82-02)
- Front not sitting properly.
- Now have wheelhop after full rear suspension rebuild
- Shocks for a lowered car
- How Tall Are The Stock Rear Springs???
- Will 36mm36mm rather than 1 7/16 sway bar bushing
- How to connect steering linkage?
- Suspension setup for true dual cars
- SFC bolt on or weld?
- Before And After Lowering Springs
- How to adjust E-Brake-01 Z28
- BMR adjustable LCA's grease fittings?
- 2003 Z06 End Links
- rear end off
- k-member
- Didn't have wheel hop...Now I do
- How did this happen? MWC tunnel mount w/ DSL
- Is it normal for the car to follow ruts in the street?
- hub assembly from ebay?
- Let's celebrate America right with a 4th of July discount code!!!
- I think I Ruined My Car's Suspension
- CTS-V vs Willwood brakes
- Ebay springs experience?
- Best Drag Race Brake Pads?
- soo brake lines need replaced...
- Aerospace Brakes
- Are Rear Lower Control arms worth it if I want to track my car???
- Suspension bind concern
- slp line lock help!
- Ditching the ABS
- BMR lowering springs.
- Anyone has repair/service manual with alignment procedure?
- Alignment Specs for Lowered WS6
- still looking for cts v calipers? Look here
- Hotchkis Springs- 93-97 vs 98-02
- SLP Drive Shaft Loop and 3.5" Drive Shaft
- Strange Engineering Front Shock S5269 Install Questions
- sub frame connectors
- PSA on Alignment from BMR
- how much is too much difference?? suspension gurus come in!
- What rotors for me ?
- Question about 4th gen ABS,TCS Lights
- Looking for a higher quality 35mm swaybar bushing
- Trans Mount Torque Arm and Y-Pipe Won't Get Along (PICS ADDED!)
- 00 T/A v6 to ls1 steering rack
- Help...pop/clicking noise at rr wheel
- Any reason to NOT just get new factory motor mounts......
- Subframe connectors causing vibrations?
- Front Swaybar Install gone bad .
- Lower rear control arms to clear wide tires 93 bird
- c5 brakes fit?
- ZL1 wins Top Ride Shootout at Chevy High Performance Nationals
- 03 C5Z06 Endlinks
- Strut Tower Brace worth it?
- Something bent?
- Brake Fluid Level Sensor
- Rubbing Sound / Adjust E-Brake??
- Leaning car???
- Coil Spring Compressor OOPS
- Dropping Stock WS6 on Stock Wheels....How low to go?
- roll cage and car seat....
- Lowering a 01 Camaro SS
- c5 big brake kit- not performing
- caster
- Brake Booster O-Ring
- pkwdercoating brakes question
- WS6, what suspension F41, FE2, FE4, FE7
- Who has ordered Spring spacers from TSP?? Pair or individual?
- hotchkis stb work with fast 102
- Tq arm/ working angle question
- E brake headache
- burkhart chassis Manual Steering problem
- Formula Hawk lowered before/after
- Leaning Trans Am
- Rear coilovers on 1994 fbody
- Hmmm..Weird stance.
- Sway bar endlinks for an 02 Z28
- Couple questions about my set up
- tubular k member and rear suspension advice
- Rear end feels unstable
- 275/40 18 rear fender rub
- ZR1 Calipers on 99 Z-28
- MWC Watts LINK isntall, NEED SOME HELP!!!
- New brakes
- Pics of BMR spring spacers installed?
- Few pics finally of Strano/Koni set up
- ABS Delete...now no lights!
- anyone have have spohn torque arm and 9" rear?
- Suspension Advice
- f body strut tower brace fits fast 102 mainfold
- f body strut tower fits over fast 102 mainfold
- Konis SUCK! High performance, but junk Quality
- Mixed brake fluids
- Custom Built Gload Brace with Driveshaft Saftey Loop
- Time to upgrade some suspension..
- new founders panhard + relocation
- gto camber problems???
- My plans for 02 Formula
- Outer Tie Rod
- Bump steer? Anyone else get that?
- 4l80E Swap Crossmember w/ TA Relocation
- Need Some Suspension mod advice
- What else should I replace while installing new shocks/springs?
- ABS/Active handling light is on in my C5Z... got a couple questions? got a C1214 code
- subframe connector question
- Problem: Brake issue
- Panhard Rod????
- adjusting koni yellow fronts????
- big difference between F and R QA1 front shocks?
- Broken strut mount
- Installed 5th gen Brembo's on my '02 Camaro
- Bilstein and SLP question
- Edelbrock 5290 subframe connectors
- Koni shocks and dana 60
- Sway bar for street/strip
- traction issues
- Mini ladder bar, suspension help
- poly/roto LCA vs Stock LCA with 1LE bushings
- Wheel alignment for 4th gen IRS swap
- Differences in R&P from 98 to 02?
- alignment specs for different uses
- Koni SA rear shock problem?
- Broken sway bar bracket...
- cts-v brake install pics
- Need help with suspension questions!!!
- Align best specs 1999 trans am
- C6 BBK(DBA slotted rotors/Hawk metallic pads), strano bars/koni/DMS springs, UMI susp
- BMR anti roll with MWC 9
- Help! Sick of my Suspension!!!
- Thinking about doing the heater hose mod
- I need to replace my WS6's shocks
- Hotckis Boxed LCA Bushings
- Complete Midwest Chassis suspension installation (lots of pix)
- Question about camber and alignment specs
- Gt GT In need of struts.
- UMI Adjustable torque arm noises?
- Rear caliper dust boot question.
- founders phb
- install time on bmr sub frame connectors
- Torque arm or TA with relocation bracket?
- Pinion Angle- TA and DS Measurments with PICS- Where to Adjust TA?
- Strano Adjustable Rear Sway Bar Installation Questions
- Drag bar set-up?
- What do you think about this setup?
- where to find caliper rebuild kits
- SLP Bilstein/Eibach install at UMI
- BMR Xtreme Anti-Roll Bar Rates
- How does this alignment spec look?
- Tunnel mounted TA?
- Rough ride needs some help
- who has best deal on shocks and springs for drag setup
- URGENT! Rear Brake Removal
- Solid Motor Mounts Install
- Recommend me a PHB
- Lowering Spindle or Springs?
- Stock bushings?
- Camaro feels loose while under throttle Newb needs ideas
- Tubular Suspension Pulled Out of Alignment?
- Strano Performance Parts CLOSED 5/22 -> 5/30, 6/7 -> 6/12 and 6/15-> 6/19:RACING TIME
- Help me choose a rotor and caliper color combo
- Loud squealing noise after changing brakes/rotors...
- Quick Torque arm install question
- Best brake options 16" wheels
- Torque arm question
- strange shocks question
- Fed Up!!!
- Info Please
- LCA Parts?
- quick brake conversion question
- Cut my springs
- Koni SA shock with ground-control coilover
- Hit pothole durning autocross now steering is bad.
- Upgrading Suspension Whats best?
- How low can you go before bad things happen
- Stanos and TSP catted Y?
- Rear brakes? If you do cts-v mod
- Upper Ball Joint Question
- Im making a panhard bar, torqe arm and control arms/traction bars from scratch
- Wheel squeek after rear brake install...
- Vibration while braking
- Bleeding brakes help!!
- How do I make my convertible ta safest
- Strangest sound
- Stock brake caliper fitting question??
- Memorial Day Sale 15% OFF!!!
- Double adjustable pan hard bar keeps coming loose
- rear adjustment help
- Qa1's help!
- Slp/eibach 70009 springs pictures after install
- Question on suspension
- Koni install question!!
- Best lowering springs?
- front shock boots
- Question about Koni SA up front and DA in the rear?
- Best and strongest subframe connectors ?
- 95z, Kicking tires over brake setup -LS or c5 brakes.??
