View Full Version : Suspension & Brakes
- Plated plain rotors??
- Those who have done the C5 brake conversion.....
- Subframe connectors for a convertible?
- Break In for EBC Green Stuff Pads w/ New Rotors
- porsche brakes
- Wilwood brakes?
- installation of 2 point SFC
- Is it bad?
- Edelbrock Shocks
- New brake pads installed....
- Hotchkis springs, Koni SA's are amazing!
- Real loud grind noise... (slightly long post)
- Rotorpros?
- LCA and panhard rod choice?
- Contemplating Goldline lowering springs...
- Frustated with brake drag (wife's car)
- Suspension Question - Suggestions please!!
- RF Groaning
- Squeak Squeak
- brake problem??
- Rear Caliper ?
- stud replacement
- alignment question
- pinion angles, camber, etc...
- Shocks/Struts??
- ******Should i lower it???******
- 2 Piece or 3 Piece SFC
- BMR drag race rear sway bar
- Which SFC are these?
- line lock
- Panhard bar: poly/poly, poly/rod or rod/rod
- Trying to learn to do brake rotor and pad change
- how and why is suspension adjusted? need help.
- Lower control arms
- Will these c4 corvette calipers work on my stock lt1 brakes?
- SLP Line Lock Question
- Will these corvette calipers work with my stock brakes?
- Safest way to work on rear suspension?
- quick review of brakes
- Suspension Problem???
- ABS INOP Light is on!
- Ordering from Strano
- Adjustable or Non-Adjustable TA?
- Wholesale Brake Parts
- front and rear brake dust question
- Torque specs(ft pd) for sphon TA bolts
- Brake Pads..
- suspension popping
- Torque Arm Doesnt Fit..
- wierd noises from rear
- UMI LCA and PHR review, B+G Springs SLP SHocks
- Front suspension Q?
- Do I need a better torque arm?
- What Pump to get
- Window Wierd!
- Lug nut and cap question.
- couple suspension ?'s
- Rear Rotors
- Suspension Parts Compatibility
- got brakes in mail...have question
- Energy
- Looking for budget brake upgrade
- best brand for cornering
- Removing the Brake Booster...
- power steering pump?
- I need new rear springs..but its not that easy..
- Were you happy with your REMAN Rack&Pinion?
- Stock Springs with Bilstein and BMR suspension parts is it ok?
- shock help
- GM rotor warning...
- anyone using Eibach swaybars?
- anybody ave s&w race cars frame connectors with pics
- coilover kit in rear anybody have it
- Caliper Brake line washer?
- raiseing rear end
- LCA quick question?
- I need some help guys...
- front brake line?
- Drilled and Slotted
- Abs Inop
- Pics of your brakes please........
- question about brake
- Anybody Used Intrax Springs
- Installed Hurst line lock and only the passenger side front locks up?
- What else do I need? (Brakes)
- Global West Trac Link ?s
- Best price for Hawk or other comparable pads?
- which one should i order from strano?
- where is the best place to get bilstein shocks?
- Hotchkis spring pn ?
- Tie Rod Grease Fitting
- Dilemma: Lower or not?
- Which shocks would give a smoother ride?
- installed some LCA relo brackets
- HD vs revalves on stock springs
- Did a search, still need pics... Konis on ls1 sitting on lower perch w/o isolator mod
- SJM manufacturing
- Anyone considered V6 shocks on a LS1 fbody?
- Wrong Shocks Or A Cheap Ass
- Hollow sway bar?
- stock calipers
- best shocks/strut combo
- Experience with UMI or LG Motorsports Caliper Extension Brackets?
- Will these calipers fit??
- just put in a BMR STB
- Finally Got the Car Lowered :D
- Any resale value to used Bilsteins/eibachs?
- Does this seem like a good set???? PLease need opinions.
- need a diagram please, and possible part#
- Posted on FAOA...question on LCA's(what's stock)
- Braking Problems..Need Help
- 68 camaro rear suspension swap
- Install advice
- Pics of Hose Mod
- car has jumpy/jerky feeling? WTF guys!!
- Goodridge SS Brake Lines? Install
- Messed up suspension
- I just changed rear brake pads.. now its making a scraping noise?
- Would I regret getting 1" drop springs?
- Strut cushion???
- So lowwwww
- Need urgent help with LCA install...
- bilstien shocks
- i just installed a strut bar
- Eibach LT1 Springs on LS1
- How Low do i go ??
- looking for dms springs
- Shock guys in here
- Weird suspension noise
- sway bars not making any sence to me
- Rules of thumb for how much spring and how much sway?
- Panhard Bar
- Proper grease for poly bushings?
- Question on Earls Stainless steel Lines....with pics.......please help!
- Powdercoating spring.....Bad Idea???????
- Need new shocks/springs! Any kits?***
- Weekend driver guys
- Squeaking
- Thinking of going back to stock springs to soften the ride?
- need some answers on suspension...help me out
- Earl's Hyperfirm Brake Line kit
- Rear control arm bushing question
- Redneck Puck Resetter
- Brakes project this week...please lend your advice
- grind and popping noise over bumps
- Problem with BMR 32 mm Sway Bar
- Nonadjustable TAs and lowered vehicles
- Prothane Mount Installed...
- linelock install???
- Steering wheel shakes-not rotors
- LCA and TA improvements?
- Lowering Spring Advice
- hal springs?
- Spring help Please
- DMS Springs With True Duals
- Bilstein HD review (and past impressions of other mods)
- buying new calipers. cost?
- Car Pulls hard to the Right when racing from a roll.
- What dose this go to on the caliper?
- brake calipers with camaro logo
- Squeaky Noise
- hawk ceramic or hps pads?
- I got screwed.
- Normal wear maintenance
- 1" drop opinions/lca brackets
- A few ?? on my bolt-in SFC
- Did i toast my hub/bearing?
- What brand of shocks is everyone using?
- Strano Front Sway Bar Install
- Question about LCA's & PHB's.
- Harness bar???
- Rotors and brake pads?
- Very low brake line pressure
- need tech info on brakes!
- I need some opinions...
- Stb
- Goldline Lowering Springs
- air suspension
- Duralast vs. Wagner
- Can Koni DA's double as a drag shock?
- Is there something wrong with my caliper?
- Help!!
- 49.95 for cross drilled rotors
- wohoo so i just found out no abs..
- Does anyone see a problem with this?
- diagnose this problem! please??
- rattles and squeeks driving me nuts
- Install front Koni's or pay shop?
- adjustable trq arm ?
- need help with a 12 bolt
- adjustable rear springs???
- BMR LCA question
- lakewood/mr.gasket lift bars for camaro's anybody have them ?
- Eibach install
- Soft/Hard brake pedal
- Alignment predicament
- are LCA relocation brackets a must?
- Q. UMI Parts combination
- Thinkin about dropping it
- someone with upgraded LT1 rotors/pads/lines chime in!!
- hotchkis stb
- abs diagnosis
- Shocks/springs installation costs ??
- What springs for DA's?
- Will rear spring sag cause pinion angle changes?
- coilover kit with any shocks?
- Cross drilled 2006 GTO rotors
- Anyone Ran Stock Shocks with Eibach Pro-Kit?
- Torque arm bushing bolt thread?
- Want to improve my handling w/ a 12 bolt.
- steering wheel opinions
- Which way to drilled/slotted rotors face?
- qa-1's
- STB worth it?
- Best first mod for handling/ride?
- Best shock/strut combo for Eibach Pro Kit
- Thinking about Bilstein Shocks with Eibach Pro Springs
- Rotors
- Spohn/tubular suspension help
- Spring Rates?? (z28, SS, 1LE)
- tire Sound
- Emergency Brake Adjustment C-5!!!
- F-body front end - shocks or struts?
- brake problem!!
- Spring in backing plate for E-Brake
- Who makes this Strut bar?
- Wilwood brake upgrade question...
- will the 1le rear springs help?
- Brake Booster Gone Bad?
- subframe connectors, would they help in a bad car accident
- subframe connectors - would they help in a bad car accident?
- Lowered Cars and Swaybar end Link Questions
- Questions about Air suspension...
- I wanna upgrade my brakes
- anymore group purchases comin up?
- Wheel hop...
- 80+mph brake fade
- 3 point sfc vs 2 point
- help please. revalve shocks? or...?
- Power bleeding brakes on 01 Camaro
- chirping 1,2 and 3rd why
- Something Broke????
- Autozone Brake pads & Rotors?
- GUYS with LOWERED CARS come in !!!!
- brake rotors with zinc finish?
- Am i screwed??? help
- Sway removal
- Cheap Rotors?
- lowering spring question
