PDA
View Full Version : Suspension & Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152
  1. please recommend me some bushings/shocks/suspension parts
  2. new shocks springs and bushings but still scrapin?
  3. strano springs w 18s questions
  4. can anyone vouch good for agx's?
  5. can i see pix of the SLP sfc installed to see how low they hang...
  6. Poly/poly lca question??
  7. Question on replacing an outer tie rod end
  8. Koni/Strano Install Video
  9. thinking about removing power steering...
  10. Heater Hose Mod Writeup
  11. BMR's front only
  12. Help H/C Car. What do I get First?
  13. Squeaking front suspension
  14. Strano spring ride height on TA?
  15. CTS-V Brake Install w/ Pics
  16. Rear SLP Bilsteins/Heater Hose mod done
  17. Rod end lube?
  18. Why are my rear wheels leaning in? Please Help!!
  19. Suspension?
  20. abs delete ?
  21. Squeak from the rear driver side
  22. Lowering: Will it bring my TA up?
  23. GM discontinued axle stopper bushing??
  24. Abs inop/trac light on--help??????
  25. BMR lower A-arms and AGX KYB shocks...what needs to be modified?
  26. Steering gear coupling shaft.
  27. What's the ABS module worth?
  28. Popping noise during cornering from rear suspension (Spohn Lower Control Arms?)
  29. Brake Problems
  30. what spanner wrench to buy
  31. Which setup is better?
  32. Can you weld in Sub Frame connectors on a regular lift?
  33. Bad Panhard bushings, opinions needed
  34. Ground Control Coil Over !! Link inside.
  35. Bad Breaks in an Impala 1970
  36. Bad front wheel bearings?
  37. Coilover ride height question
  38. Tire Rubbing
  39. Spohn Drive Shaft Safety Loop ?'s
  40. 3 point SFC's & Tunnel mount torque arm
  41. LG coilovers creaking on bumps?
  42. Are my tires causing my car to just go side to side on uneven roads??
  43. Which drag shock for me?
  44. Changing Brake pads... Brake calipers wont budge
  45. SLP subframe connectors and drive-shaft safety loop??
  46. What else should be modified after lowering the car? (Strano springs/Koni 4/4s)
  47. Panhard bar question
  48. weak brakes
  49. Koni DA, perch mod
  50. tryin to get the front lower
  51. LCA Bolts?
  52. Fitting 98 Z28 Brakes on 94 Trans am axle need info...
  53. Want to sell your 01-02 SS/Hawk SLP sway bars?
  54. Fron lower control arm bolts!! Help!
  55. 6Litereater Big Brake Upgrade
  56. QA1 what???
  57. Does this pic show a bushing problem?
  58. Going QA1
  59. AGX's out and Bilsteins in!!!
  60. What setup works better w/420 RWHP,then current Stock Torque Arm setup&poly bushings?
  61. Car swaying all over the road after moser 9" install
  62. Best street pad?
  63. Missing trq arm nut, what size is it?
  64. Question on LCA relocation brackets on a stock ride height car
  65. Rear lower than front with hotchkis springs
  66. How to tune Koni Adj shocks
  67. UMI adjustable control arms
  68. Shock question
  69. Flowmaster merge fits with UMI tunnel mount
  70. understeer q?
  71. Car bump steering a lot on 275s.
  72. Bilstein Strut Help!!!!!!!
  73. chrome moly LCAs worth it?
  74. Looking For A Brake Fitting...
  75. BMR not a sponsor anymore???
  76. Got my BMR 1.25 springs installed.
  77. ABS Thread Size???
  78. Tokico shocks...
  79. Do lower control arms wear out?
  80. Difference b/t base c6 and c5 z06 calipers?
  81. Help leveling car
  82. Ebay Panhard Bar...
  83. what should my konis be set to???
  84. Best handling setup
  85. Can you help identify these springs?
  86. Center The Car
  87. hal 275 springs question
  88. Good find?
  89. Aftermarket Rubber Bushing LCA's
  90. Q's about goin to a 1LE front sway bar
  91. cts-v upgrade??
  92. Clunking noise on deceleration after TA install
  93. What's your LCA Angle?
  94. stock torque arm with umi relocation crossmember
  95. Rod or Bushing End LCA's?
  96. g-body suspension into a-body
  97. Koni SA/Strano Springs at da track???
  98. Upper A arm Prob..Cant loosen ball joints
  99. Sway bar sizes stock/aftermarket
  100. Couldn't find much, SBC k-member?
  101. Adj panhard bar or not?
  102. Adjustable rear Strange shocks and sway bar too close for comfort
  103. Brakes shot, lil street upgrade?
  104. What plain blanks to mix with stock calipers?
  105. Help me figure out my suspension setup for street/strip
  106. brakes problem
  107. Strange clicking
  108. Upper shock mount replacment?
  109. Koni adj.
  110. What is best for drag setup. Stiff or soft??
  111. Wheel hop after springs?
  112. What pads can u buy at Advance/Autozone with LOWEST dust?
  113. broken torque arm mount - replaceable?
  114. What suspension next?
  115. QA1R Question?
  116. Parking brake is stuck! How do I fix?
  117. ?s About Shock Adjustment
  118. Question about spacer on top of springs
  119. Pics of Strange master install. Please.
  120. loud pop ?
  121. Just installed my SFCs today!
  122. Any aftermarket lightweight bumper support ?
  123. LS1 Brakes on an LT1
  124. Setting Pinion Angle on a slanted driveway
  125. F.S. Adj Torq Arm
  126. Poly trans mount
  127. serious brake upgrade needed!
  128. My Torque Arm Relocation Bracket is Warping the Sheetmetal
  129. Front Drum-to-Disc Brake Conversion Kits
  130. What High End" Coilovers options do we have?
  131. Are LT1 and LS1 control arms the same?
  132. Prokit
  133. rear end is making a noise
  134. NOOB to Suspn. and Brakes
  135. New, custom, tubular upper A-arms
  136. Rear Coil Axle Mount
  137. Line Lock Switch idea
  138. correct size thread on the rear brake lines
  139. line locks??
  140. Adjusting BMR Panhard bar...??
  141. Front: Edelbrock or Koni/1LE?
  142. Koni Sale & backorder status
  143. QUICK Brake & Caliper question
  144. Cutting Hotchkis Springs
  145. I cannot stnad Wilwoods anymore!!
  146. Drag Racing suspension
  147. BMR springs with pics
  148. Considering selling my BRAND NEW Koni's and strano springs
  149. 275 spring question
  150. Performance differnce beetween chassis & Trans mounted TQ-arms?
  151. drag brakes
  152. Discs & pads from a 96 TA fit a 2001 WS6?
  153. Radiator for better cooling, Road Race
  154. Suspension most bang for the buck for launching.
  155. Ordering QA1 Shocks on BMR website???
  156. brake lines on f body c5 z06 calipers
  157. Strange DA install ?'s
  158. clunking trans
  159. car is making creaking sound on the rear.
  160. Right rear height lower than left after new tires installed?
  161. Got a few suspension parts???
  162. stiff brake pedal
  163. Shock Install...Alignment
  164. Where to put poly bushings and mounts?
  165. replaced shocks, still getting a bang noise
  166. Finally got my watts link installed
  167. Brake Ducting, whos done it right?
  168. Alignment without wheel lip
  169. Well I'm Pissed.......
  170. Koni adj problems.
  171. Anyone between sa or da shocks. Good read....
  172. Front End Alignment Nightmare!
  173. Installing pro kit what kind of shocks
  174. madman torque arm question
  175. what kind of a drop in time did you get?
  176. Spohn Solid Motor Mounts with UMI K-Member ! .. is there any headers install issues?
  177. Koni Shocks????
  178. Brake Problem......
  179. front brakes sticking
  180. suspension for street/strip car
  181. Low Trac light after bushing replace?
  182. align specs with me in the car or not?
  183. What do I need to replace? I feel every tiny bump in the road
  184. UMI Adj. LCA's & Relocation Bracket Install (Pics)
  185. whats the life time for sportline springs???
  186. Brakes and Calipers
  187. moser 9 inch problem with sway bar
  188. KW Coilovers anyone???
  189. Steering Rack
  190. Why can my '97 V6 'bird out-handle my buddy's '96 Z28 ??
  191. installing suspension, encountered problem.
  192. Lowered 1.8 inch photo ?
  193. Strano/Koni Set-up AutoX results/ Review update
  194. Follow up to locked thread got the KYB GR2's installed
  195. Rear Brakes Squeaking
  196. what shocks with Eibach spring
  197. Hydrolics / air ride ??
  198. clock spring/clockspring part #
  199. Eibach pro-kit
  200. Braking Help
  201. best deal on bmr turbo k-member???
  202. need help with alignment specs
  203. Coils
  204. suspension advice
  205. quick question about strut bar
  206. Need pics of your koni 4/4's and strano springs
  207. abs and asr light
  208. How loud is the rod end lca's??
  209. Bushing Replace?
  210. Lowering springs up front/Stock in rear. OK???
  211. !ABS... light weight option for hubs?
  212. UMI TA and relocation trans crossmember???
  213. Advice and courtesy
  214. rubber bushings vs poly
  215. Suspension problems?
  216. how to replace tie rod end
  217. Single or Double?
  218. DD Shocks & Springs recomment please
  219. Got bored, made a big STB...
  220. Super Cheap Big Brake Kit - Link
  221. help, clunking noise
  222. Strano Springs Clearance Question ...
  223. Strano spring and koni install, now need to fix my F**K up.
  224. what rotors/pads do you have
  225. rear brake noise
  226. Wheres the write up?
  227. What is the factory specs for ride height?
  228. P/N's needed for rear E-brake inboard dust cover
  229. Rear brake rattling??
  230. Panhard bar - which ends?
  231. I trimmed my front springs.
  232. Lower it or stock ride height?
  233. Adj tq arm or subframe connectors???
  234. Sub frame connecter
  235. rotors
  236. Coilovers vs Koni's and Stranos
  237. Thinking of Replacing Strano's for Eibach's
  238. Strano Re-valves - eibach Pro in action
  239. Outer Tie Rod Boot Replacement?
  240. Pre-bent brake lines for a 95 Z28?
  241. springs for a comfortable ride.
  242. Brake gurus............ceramic or OEM
  243. good suspesion shop in San Jose, Ca?
  244. tokico illumina series struts
  245. pinion angle guage slightly off?
  246. Pinion angle vs. traction?
  247. rear suspension
  248. help what suspension mods to fit a 28'' tall tire on 17'' wheel
  249. My Custom Air Suspension Install - 99 Trans Am
  250. People with DMS/Koni Come in!!!
