View Full Version : Suspension & Brakes
- panhard bar?
- Should you need to turn new rotors?
- Update on moving battery to the back
- springs
- mod mark
- What does it take for a 2001 F-body to 1G on the skidpad
- Would 26" or 28" slicks?
- How much of a difference will aftermarket sway bars make?
- PLease Help....
- Spring Q
- Steering wheel play
- Ceramic brake Pads vs others
- Qustion On Slicks
- Budget handling package....help me out
- 15in options............
- what do i need?
- Opinions on what I want..
- Comp engineering shocks... need the info
- Relocation bracket install?
- rear shock install
- Teach me something about brake rotors
- mod mark
- anyone have roto-tech rotors?
- How to take off ABS and Traction Control?
- Brake Question - - Soft Pedal
- How much could I get for my Bilsteins w/eibach's setup???
- 18" Wheel and Tires for my SS
- Fried Brakes
- best all around tires
- Anyone got a Thunder Racing linelock kit?
- What suspension mod to get next?
- how long do these shocks last? mileage wise
- Rear-End pushed back
- I need this question answered.. I asked b4..
- Clunking noise when I repeatedly engage and disengage the gas pedal at low rpms?
- Which tires, i need help
- Installed Bilstein HD Revalves!
- best 315...
- Looking for tires.
- Just installed my new LCAs
- question.....
- Best Tires for racing? stock rims!
- Eradispeed Rotors
- SLP Suspension Kit 70001A
- can you guys explain tires to me again.
- Pics of my SS with 315's
- Grease poly endlinks?
- BFGs in the rain?
- Torque Arm Blues.... 12 bolt + Lowered Car = Trouble
- should I just have my rotors turned?
- ??? 2001 WS6 SPRINGS Question Please ???
- Going to dealer about front rotors...any advice.
- Caliper mounting bracket bolts
- Wilwood Brakes and ABS? Need Help.
- REALLY bad powersteering problem
- Suspension troubles
- Widest rear tire I can put on my 17" WS6 rim?
- recommended tire pressure for Z28 :)
- Intrax or Sportlines
- Question about shocks?
- installing subframe connectors
- Clunking and rattling suspension
- Weight difference between SLP SFC and tubular's style sfc's
- 2002 SS HANDLES TERRIBLE!
- LG Motorsports ....good to go!
- Question for those w/ Eradispeeds & stock pads
- Brake Pads - Durastops or Hawk HPS? Non-drilled/slotted rotors
- cant connect to site by jmx for shock and spring install
- Tire Recommendations...
- How to install g2 three-point strut tower brace
- help problem w/ brakes/calipers
- People with GC coilovers!
- Who makes the best "bang for buck" rotors?
- What's the best rear springs to use with Hal Shocks for drag racing?
- Brake Pads - Which are best?
- Why does my bone-stock Z28 sit higher than other bone-stock LS1 f-bodies?
- "Subframe connectors" for convertible?
- Which torque arm
- sportlines w/Mufflex 4"?
- ive narrowed it down to these 2
- Front Caliper part numbers?
- BFG KD needed
- What is the best all around tire for the money?
- 12bolts, what handling mods?
- Rear suspention mods..
- Sportlines on my WS6...w/ pics
- Is thicker swaybar in the rear better?
- Drag Tires & Rims
- Kumho's on 17"'s anyone?
- Do you need a special tool to change out the coils in rear?
- mod mark
- suspension for open road racing
- Rear wheels get squirrely on a stock engine/suspension...
- Are there any springs that drop the car the advertised height?
- are SS springs single rate? Question on cutting springs
- Just did HAL/Eibach and I don't like it
- Ok deside what suspension for me
- Lug pattern for 3rd & 4th Gen the same?
- will kbdd sfc interfear with hooker long tubes?
- Got the ok to redo all my suspension
- Which Coilovers?
- Line Lock Question?
- Anyone Using Aerospace Light Brakes
- How does this sound for a budget suspension set-up....
- mod mark
- Lift bars
- Opinions on best bitin' street tire?
- QA1s....
- brackets don't fit
- Eibach Spring Sag
- intrax springs w/ stock shocks....good or bad idea???
- 1LE Shock Adjustment Stuck!
- Where to buy some polyurethane bushings?
- F'ed up front end = HELP!!!!!!!
- autozone/pepboys brakes???
- Exactly how much weight to Baer Eradispeeds save...
- anyone running eibach sport lines??
- Best shock to go with Intrax Springs
- Camaro SS Bilstein Spring?
- Changing HAL shocks
- mod mark
- Koni shock questions...
- Could use a little relocation bracket advice.
- BMR Boxed SFC's with a lowered car=scrape!!!!
- Edelbrock Suspension Upgrades
- Lowering with 18"
- Would it be safe to turn my rotors again?
- Steering wheel "shimmy" when braking
- Fenders hitting tires. HELP
- Who makes a torque arm thats lighter than stock?
- vibration after et street install.
- Adjustable shocks?
- What's the Max Aligment settings you got???
- Ok, I'm thinking of lowering......
- does anyone have airbag suspension?
- Who sell's the Hawk HPS Brake Pads??
- Anyone know anything about Drag launch kit?
- trying to find the right rack & pinion
- AN P/S rack fitting - i've seen them, anyone know what size to use?
- What size is the brake line tube nut on the master cyl
- AutoZone Rotor Users Inside
- Sway bar bushing brackets
- So how do YOU change wheel studs?
- mod mark
- SFC question...
- Easy question about INTRAX springs
- relocation brackets
- Help! Front end noise
- SFC's which is a better one Global West, Kenny Brown, or BMR
- suspension help/opions please
- BMR Lowering springs
- Braided SS Brake Line Question
- bilstein hardwear question
- What is the use of an adjustable panhard bar??
- are LCA's really worth it?
- Has anyone heard of this company
- Hal shock settings for driving and racing..what do you have them at?
- Hellllllllp me please....
- Opinion: Used 1LE springs or new Z28 springs?
- Who makes the best tubular K-member???
- HELP! torque arm angle right?
- HELP!!Brake Trouble
- Pros & cons of poly endlinks & bushings?
- SEVERE WHEELHOP on nittos NEED HELP
- I get wheel hop when the tires spin slowly.
- I finally got my Strange Front Brakes installed
- Need some ideas, what tires fit?
- How to break in new pads?
- SLP linelock Help please ...
- Where can I get some Intrax Springs? ASAP
- Why are we locking down posts here?
- Will Russell 3rd gen brake lines work on a 4th gen?
- mod mark
- My right rear sags sometimes and clunks when I hit bumps...
- Partial brake failure at the track..what's wrong?!
- line lock/brake control solenoid?
- What Brake Pads To Get?
- Watch that curb...
- Will 315/35/17 fit
- tire choices
- Anyone running Sportlines with 18's?
- V6 springs questions??
- HELP! toque arm angle off? please look>
- Double Diamond Subframe Connectors
- Need instruction on how to install lowering springs
- rotors warped =(
- How to deal with severe wheel hop?
- Why Does the Spring Clutch Kept Breaking?
- TQ arms for handling
- HALS -- which way to adjust
- Rear end gettin way too loose for comfort
- Weight Transfer & Ride Heght with HAL's
- Eradispeed rotor squeeking....
- tq arms from
- Poor finish: G2 Sway Bars
- pics of a camaro with G2 springs
- Where to buy Pete Z traction bars?
- Fulda EXTREMO tires? I am hearing good things about these, anyone have info?
- How much unsprung weight does going from factory 16in rims to factory 17in rims add?
- Nitto drag radials?
- Pro kit + Hal shocks will it work?
- Nitto drag radials 17" or 16"?
- Stainless Steel Brakelines and Synth Fluid in
- Upper panhard bar
- Madman TQ Arm ?
- ok getting suspension stuff
- Getting some powerslot rotors.... A couple questions!!
- 3 point shock tower brace ?
- How do I change the rear center brake line?
- Does the SS have larger front AND rear sway bars?
- New panhard rod needed?
- What's the best brake pads?
- how big on stock vette rims?
- lowering cars???plz help
- Ok, I am at my wits end with these *&$^ @ brakes
- Can I use LT1Eibach Pro Kit Springs on my LS1???
- G2 super springs??? PLEASE HELP
- 16x8 vs 17X9 rims weight difference?
- mod mark
- How much do SLP 17x9's weigh
- how to set pinion angle for spohn torque arm?
- Powerslots weigh more than stock?
- lowering a ram air w/ 17x11 rear
- stiffer stock height springs
- Help, wanna lower my car, need some advises
- Clicking Noise... Need HELP!!!
- GW Torque arm and Y pipe
- Please answer once and for all about Hals and handling
- Which spring rates for use with Koni DA's?
- Slotcar Racing SFC
- Hal Shocks and G2 Springs??
- vibration while braking
- BMR Boxed SFC?
- Wilwood rear brakes & C-Clip Eliminators please help.
- Recommendation on shop to install 'Vette IRS in a 4th gen ?
- torque specs for rear suspension....
- Question about Adjustable LCA's
- Do I need Double Diamond Subframes w/6 pt weld cage?
- G2 "race" LCA and PHB install ?
- Help me identify this sound....PLEASE!
- Need Help With SLP SCF Bolt-on Install!
- Question about BAER eradispeeds....
- Anyone have to reset their emergency brake? I'm getting friction sound.
- LG Motorsports - Wilwood Brake Kit
- How can I make the Intrax's ride better????
- How can I tell the diff. Between a ABS Rear end and a ABS/TCS rear???
- Lowering a 99 SS with 17x11 inch wheels
- INTRAX are on! Comparison's inside.........
- SLP Line Lock... Problems Come in :(.
- New Shocks and Struts
