View Full Version : Suspension & Brakes
- Some DMS related questions...
- How Low do SLP SFC hang?
- important question about hotchkis lowering springs
- How many of you have this problem?
- russel bleeder valves
- SS brake line fitting size
- Steering wheel vibration??
- spohn ta w/ long tubes
- Wholesale Direct Rotors & Pads ???
- Changing Springs
- Tubular K-member
- Hawk HPS Pads??
- Power Sterring Cooler#
- sway bars from SLP on a hawk
- Caliper swap from V6 Camaoro to V8 F-bird
- need new suspension cause of duals
- SFC's Box or Tubular?
- remove endlink for front shock install?
- Pro Fab Tubular K-member is in!
- How long do they last?
- UMI Performance, Inc
- Wilwood brake kit
- HELP, BAD VIBRATION>>>>>>>>>>
- Why so much more?
- Suspension upgrade
- Adjustable Pinion Angle
- Maybe a stupid question...(suspension related)
- air shocks lowering help me PLZ???
- Question about cars stance
- wuts need to hook?
- Tunnel Brace Too?
- Having trouble
- Looking for new rear shocks, how are Tokico's?
- What kind of rear shocks do I have on my SS?
- brake pads question...
- Suspension tips for Drag Racing
- 1le swaybars
- Shocks, Swaybars, Springs???
- is an adj. torque arm worth it?
- Rattling from new BMR additions
- Decisions on shocks
- Question if I lower my Z28.
- Questions pertaining the powersteering cooler.
- brake rotors and pads ?
- New Street suspension setup - Strano Koni/Bilstien, plus some deviation from the norm
- Clunking/Rattling Poly/Poly Lower Control Arms?
- Upper panhard rod, whats its purpose and can it be removed?
- Rotors and handling questions...
- What mod will help in wet weather?
- QA1 shock rebuild.
- Z06 Caliper Question
- Madman LCA's
- Eradispeeds Rotors
- Torque for tie rod ends?
- Where can I get a brake bleeder screw - 10mm x 1.25?
- got in accident, i need some advice
- zL1 Springs?
- help rate my suspension thus far....
- Pro-Kit Vs. Hypercoils---Check it Out!!!
- Cutting torque arm for yank trans crossmember
- QA1 drag shocks with sportlines...Q's..
- which shocks??
- LS1 steering rack in LT1 car for conversion
- which springs
- Had a braking issue coming off the highway
- Help!!
- How Noticeable Will An STB and SFC's Be When Put On At Same Time?
- Panhard and LCA questions...
- rattle after lowering
- Having Problems With Handling
- How Low Can I Go....
- What manufacturer wants to step up?
- Opinions on Springs and Shocks
- Part #'s for Delco Rotors
- New pads on old rotors?
- Lowering Questions
- Spohn Torque Arm
- Can I fit rear Z06 calipers and rotors on 02 WS6?
- Car bottoms out
- Which TA will fit with true duals?
- When installing a new torque arm bushing?
- People with Z06 brake upgrade... come on in!!!
- **FYI** $31.00 Rotors @ Advanced Auto Parts
- Installing front springs/shocks
- ABS problem need wire diagram ASAP
- camber problem ?
- Rear pass. side wheel one inch closer to front
- Hypercoil Springs ... should they come with
- Please help with rotor problem!
- Setting rebound on Koni SA...
- Help banging noise after install!
- Need help chosing spring rates.
- Need some advice on lowering my car...
- Lowered with BMR Boxed SFCs???
- Rear shocks...... need advice...
- What should I do to make my car hook?
- painting my brakes, what paint and color
- Which lowering springs do i have?
- driver front wheel shakes when braking
- Lowering Spindles
- Rotor opinions
- PA or BMR k-member
- SS brake line install issue
- starting to rust!, Will stainless work?
- 4Th Gen Springs on 3RD Gen Car
- Cadi CTSv Brakes
- Are poly bushings really worth it.
- Bent BMR TQ bracket in Houston **Need Help***
- Spohn Pro Rear Drag Sway Bar users, help needed!
- Regular grease damages ploy bushings over time?
- Squeeky Front Willwoods..
- cars feelin a bit bouncy?
- Leaking Rear QA1
- When I go over a bump I hear a hollow high-pitched knock type sound.
- Performance brake fluid...
- Question on LCA relocaton brackets
- Pete Z Bar Pictures
- Will Billsteins help with wheel spin at launch?
- Front and rear Z06 calipers on 2002 Z28...
- launh
- Creakin noise on right front???
- How heavy are the IRotors compared to stock?
- Suspension guys.. need your help.
- If i wanted to lower my car what should i go with?
- Tranny mount question...
- Car Lowering
- major brake problem.. almost wrecked
- Removing the panhard bar?
- Turn down EBC rotors?
- spring isolators
- question about HAL
- Wheel hop??
- Parking Brake Boot
- weight distribution
- Brake install
- Help Adj. Panhard Rod!!!!
- what grease for poly lca bushings?
- Adj. Panhard rod, adj. question....
- Help!! New Linelock No Instructions!!
- Kenn brown subframe owners inside!
- will stock springs and struts work with BMR K-member and a-arms?
- Front LCA's
- Anyone have a tubular k-member care to opinionate?
- speedbleeders, same for F-Body and C5?
- Anyone used these Lakewood Lift Bars?
- Which Sub-Frame Connectors
- Sway Bar End Links
- suspension work
- Any downside to maxing out caster (+4.5ish, right?)
- Is it a Blown Rear Shock?
- Can my Trans take the pressure from my torque arm?
- What mods are required to run stock springs with Hal shocks?
- Relocation Brackets
- Driveshaft loop
- ABS inop, low trac lights...?
- Problem installing Lakewood DS Loop.........
- LG C5 Brake Adapter + Movit Brakes for the C5, would it work?
- Alignment issues after intsalling HAL's?
- Street, not Drag
- Best lowering springs for launching
- SFC+LCAs+Shocks and Springs
- Rubber hose to replace rear spring isolators..what to use?
- Double Diamond Style SFCS or BMR style?
- chunk of LCA bushing fell out!!!! what to do???
- good compromise shock?
- Recommend shop to install weldin BMR SFC??
- Firehawk...lowered? How much?
- IRotors Question
- 00 fbody brake upgrade that's worth the money?
- LCA's
- running stock susp....please help
- Problem with shock or something else?
- Using BMR T/A w/o using Trak Pak Crossmember
- hal qa1 shocks
- How much does it cost to....
- Shocks for lowering springs...
- Squeeky Brakes...How to fix?
- anyone cut there springs? need input fast.
- Bilstein Front Shocks
- Suspension is too stiff, what are my options?
- Welding Subframe Connectors Question?
- Best Lowering Springs??
- Shackles/spring clamps OK for small drop?
- traction problems
- Vibration when coming to a stop
- This guys article making me rethink poly motor mounts and my poly lca's...
- Need opinions/suggestions please!!
- poor handling at speed
- Anyone tried these rotors?
- Sway bar question
- Power Slot Rotors... Any Good?
- panhard & sway bars
- Has anybody used Metco relocation brackets with BMR LCA's?
- Check these rotors out...
- Where to get new brake caliper shim (not sure what they're called)?
- Opinions on Baer Eradispeed rotors
- BMR SFC/LCA/Nitto DR install
- Best Brkae up grade for the buck?
- SLP bilstein/pro kit problem
- Question about BMR T/A
- Bolt-in Relocation Brackets for Moser 12 bolt...
- BMR extreme rear sway bar on the street?
- UPPER panhard bar - aftermarkets?
- ok bought the Qa1/hal adjustable shocks
- LCA relocation bracket Q?
- just springs?
- Will I Have A Problem With MY SLP SFC's and L/T Headers?
- EBC Greenstuff pads?
- Is this wheel hop? concerned...
- Help with tire contact patch diagnosis
- Morse ceramic brake pads
- Best suspension setup!!!
- Need Techinical Help-Where do I go?
- ???BMR K-member & Solid Motor Mounts???
- SFC's ROCK!!!
- Wtf, No Brakes!!!,please Help.
- Gunna install SLP bolt on SFCs...
- Best Torque Arm for the buck??
- How you like you BMR SFC's?
- Rubber bushings in aftermarket LCAs and Panhard Rod
- Wilwood vendors?
- LG's LCAs + BMR relocation brackets
- Hothkis Adjustable Panhard Rod?
- Irotors?
- squeeking from rear end
- Having SFC welded in
- Willwood or Baer?
- Is my suspension good for drag racing......
- Want to lower my car. HELP!!
- Best springs for the track
- Brake Question
- C5 Conversion Bracket
- How to modify stock spring perch to use with hals
- Sway bar bushings...and others...
- Who is having problems with Eibach springs sagging in the rear?
- BMR Front Sway Bar Install Question?
- PHB install?
- Question about rear stabilizer bolt specs??
- Question about SFC?
- Which spring BMR or Eibach Pro Kit?
- New Brakes squeaking?
- weird brakes
- Suspension: SS vs. 1LE
- flex on launch? pleae HELP!
- Calipers off of car for ~1 week, what to do with lines?
- LCA Question
- buying a prokit...will it ride rough?
- Brake Bleeding question
- Mustang guy transplanted...
- Any way to keep hal springs from being bouncy
