View Full Version : Suspension & Brakes
- TQ Arm Angle ???
- Grinding noise.
- K member
- just lowered my car i have some questions
- Relocation brackets even when changing rear ends
- Rear coil conversion?
- Alignment issues
- Stuck on front rotor swap...
- Suspention with 9 inch rear
- Paging 1LE guys (kinda long)
- HAL's springs sag can I use an Afco spring
- weird prob w/ brakes/steering...please help!!!!!
- Best place to get Hypercoils
- Corvette C4 or C5 Calipers which to run?
- V6 spring owners step inside
- Slot Car Racing control arms?
- Help with wheel hop.
- Pictures of modified spring perches on HAL shocks??
- Cutting Springs????
- Anyone else have this problem with BMR k-member??
- k members?
- Control Arms and Strut Braces
- Question - Progressive Spring Install Orientation
- buying a spohn T/A which is best?
- Info on how to not have warped rotors
- iROTORS? or what...
- Has anyone installed Budzter coil spring height adjusters
- Has anyone installed budzter coil spring height adjusters
- Stupid question
- rear end squeaking??
- Questions About A Setup
- Checkout my new gear!
- No rice or flames, but best way to RAISE rear for "Camaro rake"?
- Need some good alignment specs....
- Best "race" springs?
- Passenger side rear sits lower than right side
- How did I bleed my brakes without bleeding em?
- drag suspension questions... help!
- eradispeed 2 piece rotors
- Right Lower Control Arm Bad Already???
- Rear Coil Spring Airbags?
- Help me pick a Torque arm please??
- Question on BMR relocation brackets
- Best HAL Settings for MAX 60ft?
- Bottoming out???
- Koni shocks! any downside at all?
- New QA1 "R" shocks vs. older version
- brakes locking up
- Reybestos Quiet stops/Brute Stops/Wagner
- SLP Optional Progressive Package?
- Steering wheel noise
- First Mod... Lower the Z28
- EBrake handle loose......?
- BMR adjust PHB- need info please
- What shock for both drag and autocross
- Lugnuts, torque settings, and wheel studs, Oh my!
- Help with Shocks
- Z06 calipers...
- Looking to stiffen up the ride
- Received Hals the other day, I have a couple of questions.
- BMR Drive Shaft Loop Installation Problem
- What is the difference between these Bilstein shocks?
- Eibach Drag Springs...
- Please help
- Shock Mount Part Number?
- Installed New Spohn Adjustable TA (LONG)
- Relocator brackets help
- Which is more important LCA or PHB
- KVR Rotors Warped/ Warped Hubs?
- so what destroys brakes...
- driveshaft loop for dual exhaust?
- Resurface drilled rotors?
- edelbrock TA hits floor board...
- I got my Spohn TA in...now I have some questions. Please Help
- Thoughts on Mov It brakes
- New SS Vert owner needs help improving handling
- Wheel Hop with Nitto Drs
- Need info on the new R series Hals and Hals in general.
- Eibach too low?
- rears warp?
- double caliper
- Rear suspension hitting real hard!!!
- SLP SFC or BMR SFC
- 35/21 swaybars
- Squeaking from passenger rear
- Irotors
- How to and how not to lift the front wheels?
- I need c5 brake torque specs. Know where I can get them?
- Lca Relocation Brackets On Stock
- Bump Steer & Alignment when Lowering
- Any comments on Granatelli Lowering Springs?
- shocks for cut springs?
- Relocation brackets needed or not?
- Anyone use the new Hal QA1-R front shocks (drag version)?
- Rlb
- Eibach Pro-Kit owners in here (or others with a small drop)
- Where are the Sub Frame Connecters?
- Did the 99 Camaro SS come with BIlstein shocks
- BMR question?
- roadracers, help me with suspension setup
- any larger rear rotor?
- C5 Rotor......left and right?
- Will I really need new shocks?
- kmember install
- 1998 firebird 1LE brakes???
- 17 X 9 Front and 18 X 10.5 rear, handling effects?
- BMR Performance Sway Bar Set?
- Need instructions on rear shock removal
- Lowering Car HELP ME
- Anyone have any first hand experience with the new R series Hals?
- torque arm bushing?
- Relocation bracket installation?
- How much do BMR Boxed SFC weigh?
- coil overs
- Rear suspension questions..
- Thinking of lowering the SS.....
- Need help with brakes, please
- Ne1 know why brakes are rubbing
- Is Chrome Moly Really Better?
- Noise when turning?
- Drag racers, what shocks do you recommend?
- Adjustable LCAs
- Hyperco's and Bilstein's installed!!
- Suspension Rx - want smoother, more controlled ride. Possible?
- Leaky braided stainless lines HELP QUICK
- Christmas Sale LG Motorsports- G2 suspension
- bmr lowering springs
- bmr or edlebrock
- About to rebuild my front calipers...have a few questions about beeding and removal
- More suspension help for the newbie! (trailing arms and panhard bar)
- A little help for the newbie! (shocks)
- Squeaks
- Question about Baer Eradispeed rotors
- Any info on light weight breaks!!!
- BMR LCA's: Poly/Poly or Poly/Rubber?!?!
- Holy Squeaky LCA's!
- Front Wheel Camber Off??
- Whch Lowering Springs Are BEST??
- do a-arms or no
- Help Please, Thud sound when I take off
- Spohn Torque Arm Problems
- lowering car, do i need adj. panhard?
- decarbon,Delphi,bilstein WTF
- What is the best upgrade to reduce wheel spin?
- Best poly/rod components?
- How long do the stock dampers last?
- Has anyone cut their stock springs, come on in
- dif slipping...
- what does everyone think of the new Spohn torque arm?
- Need help on choosing what do on the suspension?
- Sophn Or BMR
- Bilstein info please!
- The f-bod front spring/shock how-to
- MAC torque arm installation???
- Hyperco springs rock!!!!
- How much 60 ft et is a torque arm worth on 6m?
- Issue installing LG Motorsports adjustable PHB
- BMR lower control arm question
- Lowering Springs - Any Good?
- autox's inside please....
- lookin to get larger Swaybars, what size and what company
- What size are my sway bars????
- few BMR related suspension questions...
- Mega-Bite Torque Arm
- What are the pros and cons of poly bushings??
- 93-97 V6 spring appearance
- aftermarket brake system
- Brake brackets w/lca brackets
- torque Arm
- Cost of front rotor and brake pad install
- Who carries polyurethane motor mounts?
- Anyone have a wolf race craft roll bar?
- Callin Mitch & Trackbird !!!!
- how much for lowering kit install!!??
- Tire Wear
- G2 Subframe Connectors and G2 Chassis X-Brace
- Brake Pads
- removing ABS...how?
- Advice on SFC's? (Chrome Moly Tubular vs. Double Diamond?)
- Taking longer to brake?
- I found out why no front sway-bar is bad
- Broke my Torque Arm and Driveshaft...which do i get with a 12 bolt?
- Suspension Question?
- SFC and LCA worth it??
- Blisten, Eiback, Konis, Ohh my!
- what are some good tires for road racing
- Are my slotted/cross-drilled rotors on the wrong way?pic inside
- Torque Arm Problems
- I had my alignment checked today because
- Help with new brakes!
- LCA angles how much?
- iRotor pads squealing
- front suspension squeaking
- can't hook up from a dig
- Ceramic pads for an FBody...
- Time for a brake upgrade/job?
- Better Handling
- anyone ever buy used shocks from SLP?
- LG vs. SLP
- Wilwoods 6 pistons
- Removing the upper Panhard rod or drag racing?
- What roters?
- Brakes
- Will this work in getting rid of the torque arm completly
- Taking off the strut tower brace,,, better launching??
- Differences between coil springs??
- Alignment
- Removed KBDD SFCs, installed SLP SFCs (info/comparison)
- Need Help!!
- Please help. drivetrain noise.
- SFC pics?
- SLP's convertible subframe connectors are now available!
- eibach pro-kit
- Front Sway bar problems
- Modified spring perch needed for Hal struts/springs?
- Need help with eibach pro-kit
- suspension
- New Spohn Torque Arm
- edelbrock shocks?
- Hal Gen. F vs. Hal Stocker Star R
- C5 13" Brake Upgrade on my 2000 SS - PICS!!
- A few rear suspension questions..
- mysterious clunking
- How to stop the clinking from my LCAs?
- What to to Launch 6sp SS?
- "01 WS6 suspension...any upgrades from stock T/A?
- best stock shock replacement
- Any expereance with random tech. TA
- stock rotors suck with 16 inch wheels???
- factory style torque arm vs. bolted to crossmember
- Front swaybar removal, is it worth it? :discuss:
- Hotchkiss SFC's
- Need help (i think broke something)
- Sfc?
- Any experience with these rotors off e-bay?
- Fabulous Brakes, Much Less than Baer, etc.
- Anyone Try Wilwood's setup?
- All parts needed for lowering
- Several questions regarding suspension components...
- Stipped a nut on my shock!
- Newbie to the LS1's Power
- whats the best way to solve on power understeer in the corners?
- Koni DA vs. QA1 and "r"
- Sequence of installation
- After how many miles should I change my stock shocks?
- suspension mods?
- Any expereance with these rotors off e-bay?
- 01 M6 SS,How do you turn off TCS?
- is the supposed to be?
- Pro-Kit or Sportlines
