View Full Version : Suspension & Brakes
- is my panhard brace supposed to be bent on the passenger side?
- Missing Stock Shock Bushing
- Junkyard luck
- Best spring for 1.5" drop?
- Strano springs sagging?
- First suspension upgrade. Thoughts?
- heater hose mod along with my suspension overhaul??
- Are these 1LE shocks?
- Shout out
- Brake motive brake question??
- loud bang when going over bumps
- biggest rotors that will fit under skinny front drag tires
- C5 rotors on my 01 Z28???
- can you buy parking brake hardware?
- What rotors and pads do you recommend?
- Rear shock bushings
- Blown Front Konis
- Are there aftermarket DIRECT bolt-in Upper and Lower Control arms.........
- Installed exhaust. Too much scraping! What to do?
- umi shocks and springs which ones?
- headache when adjusting PHB...@*^%&$
- Alignment any different with BMR k-frame and a-arms?
- Relocation brackets
- Considering an entire suspension upgrade, umi good products?
- Broken trans mount, Help on choice POLY/RUBBER
- Slp Bilstiens vs Bilstien HD's
- car pulls hard when i get in grooves on the road.
- need help deciding springs for my Konis
- Need suspension advice
- Need suspension school
- Stock control am and pan hard length?
- Considering purchasing Strano's Bars: SWAY ME!
- 1998 Trans Am Suspension Overhaul!! 10-28-11 updates and question
- need alignment shop
- SS suspension upgrades
- Should my times improve
- strano suspension kit
- Conflicting parts?
- My car rides like a covered wagon!
- How to raise ride height on front adjustable QA1 shocks?
- Lowered car with hose mod vs stock Isolater??
- heater hose mod and grip
- rear suspension concerns
- Cal-trac question
- need to improve the 60ft
- Phb or lca clunk?
- k-member
- midwest chassis sway bar VS wolfe sway bar
- Adjusting koni's to stop wheel hop with s60
- Panhard Bar FAIL!!!
- WTT QA1 300 lb springs for QA1 325 lb springs or BMR springs ASAP!
- Heater Hose Mod
- c5 brake conversion
- Guys with procharged cars or QA1 coilovers, what front springs do you run?
- going to be getting coil overs soon, need imput
- Best Replacement Rack & Pinion?
- UMI QA1 Front Suspension Question
- ABS INOP/BRAKE/SERVICE VEHICLE SOON fixed!
- New suspension installed!!
- 4-Link rear suspension. Need a little help
- Steering Rack AND column
- sub frame connectors
- Trying to improve my 60'
- '99 Z28 - Panhard Bar/Trailing Arm Replacement
- help!! strut/shock removal
- Not Fbody but need help please
- Help out with rear suspension
- SLP Bilsteins, question.
- Need better brakes
- Strut Tower Brace Bar?
- Rear suspension (best for m6)
- Will it hook?
- Noise When Going Over Bump
- Spacer for rear springs
- difference between TA relocation and tunnel mount?
- need help
- where can i get this part?
- bmr vs umi.....is there a difference?
- sick of my car being lowered
- Best/Most Versatile Suspension for a Street/Road Race/Drag Car?
- E-brake Shoe - Simple Question
- LSX 445ci IS NEXT .. What suspension mods for the added weight
- Brake pedal loses pressure when started
- Ordered brakemotive brakes :)
- Join Team BMR at LSX Shootout!!
- Comp. Engineering drag shocks harsh....
- Part # for steel brake lines for LS1 front brakes?
- Possible new suspension setup, need help!
- Getting ready to change shocks any advice?
- Squeaky brakes??
- questions please help
- Any good rear brake upgrades not drag specific?
- Lowering an F-Body, what to expect?
- Grumble!! Can't find part for sell anywhere. Help!!
- Airlift bag maximum load capacity....
- Help from umi
- BMR Suspension Congratulates Shawn Calabrese on his Holley LS Fest 5th Gen Camaro Run
- Strano Performance Hollow Sway Bars are in stock
- Some new Autocross video: C5 Z06
- Disc problem; overheat and spots..ceramic pads
- help on new suspension
- Strano Stage 2 Kit?
- Possible solution to roto joint thud.
- Rear end floats with new moser 9 and stock sway bar.
- f41 equiped cars
- help with thrust angle
- Dtc p1637 ecm/abs control module circuit network!!
- What Alignment Settings For Koni/Strano Setup???
- looking for more bite....more aggressive pad?
- Lower car, tire clearance issues?
- Centering rear wheels in wheel well
- J&M 3-Point Subframe Connectors, Double Diamond Style (1993-2002 F-BODY) ARE BACK!!!
- Rattling while driving
- Has anybody had fitment issues with an aftermarket K member?
- random technology torque arm bushing
- Best K member?
- Do brands matter?
- NEW-J&M Panhard Bar Rod w/ Polyurethane Bushings, "On-Car" Adjustable (82-02 F-BODY)
- Full suspension??
- ideas how to get my car to sit right??
- Mounting Brake Lines on Stock Rear - Question
- Which brakes to upgrade to?
- Is this right?
- BMR Suspension Congratulates Ed Timmerman for LS Fest Speed Stop Challenge Victory
- good alignment specs for a street/strip car
- Need Rear End to not kick out!
- Dual Caliper question
- Ordered Strano Lowering Springs and Bilstein HD's
- How to bring car back to stock height
- Lightweight Brakes DD???
- Strano Stainless Steel Brake Line Set for LS1 brakes question
- cheap LCAs and PH
- best rear lowering springs for moser?
- Pan bar?
- QA1, Clockwise or Counter Clockwise???
- $25 to whoever diagnoses my brake problem
- road race/hard cornering street Camaro setups
- Brake light stays on
- Wheel hopping like crazy
- LCA Install
- Cheap acceptable rubber bushing set?
- need new front calipers.. fuggg help
- Convert BMR Extreme Rear Sway Back to Stock - HELP
- BMR Suspension Congratulates Paul Falcon on his Holley LS Fest Real Street Runner Up
- Need tips 4 installing Front Shocks/Springs
- Hydraboost Brake Setup
- UMI New Product- Front Lower A-Arms for the 82-92 Camaro/Firebird
- front shock swap issue
- Electric power steering conversion (w/pics)
- Floating rear end
- BMR manual rack issues
- lower control arm measurement
- Eibach drag launch spring for 98 up?
- removing e-brake??
- Rear of my car picks up when i launch?
- I want to lower my TA w/ Stranos...
- My crappy alignment results
- ABS module, explain the difference...I hope I didn't get screwed over....
- Low and broke
- Metric brake lines help
- venders
- BMR Suspension Congratulates Judson Massingill for LS Fest All Motor Class Victory
- Noob just got Brake Motive sloted/drilled brakes, howto break in?
- Fbody caliper rebuild kit?
- Brake pedal stiff
- Oem shocks ?
- spring spacers?
- heavy duty springs
- Anyone measured the height after Stranos/Konis??
- How to "bench" bleed MC on car
- lowering springs suggestions
- torque specs
- Wheelie bars or suspension
- 1998 Trans Am Spring Question
- sometimes i look forward to breaking things
- C5 brake conversion vs rotor & pad upgrade
- Need help identifying a Caliper
- Watts link for 1998 z28
- spring rates
- Will Motive Power Bleeder get air out of master cylinder?
- Clunking when reversing and braking????
- lower steering shaft bearing
- 10 bolt UBolts
- what's the best setting for kyb agx with pro kit
- A-arm differences?
- eibach sportlines to stock springs question
- Noob parking brake adjustment question
- Lowered/Bolt on T/A, what do I need?
- UMI Performance New Product- Convertible 3-Point Subframe Connectors
- BMR Suspension Congratulates Anthony Manna on his Holley LS Fest Drag Radial Victory
- Brake question
- 94Z28 springs fit 99 T/A
- why is my car shaking??
- 60+ mph shake
- BMR Suspension Congratulates Dave Childress on his Holley LS Fest True Street Victory
- Which drag bar?
- People with lca's/lca relocation brackets come in!
- squeaks after eibach springs installed
- abs inop, asr off and red brake light on
- Stock Torque Arm Install Help
- new breaks?
- Hawk Pads?
- Best Springs for OEM C6 Wheels?
- Good pads that aren't Hawk?
- motor mounts
- Which springs for best stance
- Wheel bearing?
- Suspension set up
- UMI torque or relocation kit fittment problems
- Madman Suspension
- 5th alignment in 4 months and still not right.
- lca measurement
- driver side lca wont line up?
- has anyone used 92 camaro struts on a 98 camaro
- what size allen bit for front caliper
- Bump stop and dust boot necessary?
- Sportline Springs
- Wheel hopping
- Adjusting/setting Koni shocks for the 1st time
- Founders Performance, LCA's and Panhard
- bump stop
- New Koni SA rear shocks and Lower control arms... Squeak?
- Your favorite "hooking" mods?
- Relocation bracket bolts?
- lowering springs and alignment
- lowering springs question
- Do I need to remove entire sway bar to replace bushings?
- Dont know where to begin
- outer tie rod ends, best replacement?
- Do you ever have to replace your bump stops?
- Experience with SLP Bilsteins?
- what company sells red springs?
- Lowering my car tomorrow looking for tips
- Shock nut has some serious rust.
- Tightening End Links
- Question about lowered cars and bumps
- 94 formula suspension question
- want to drop some weight out of my 98 z28 camaro
- Rear Braided/Stainless Brakeline Help.
- Trying to get a smooth drive
- manual brakes
- stranos on stock shocks? anyone done it?
- 1995 Z28 Power Steering or Aircon leak? Please help
- What suspsension setupid do i need???
- Performance Friction Big Brake Kit
- Subframe Connectors (SFC questions)
- bad rear axle hop??
- BMR Lower Torque Arm Relocation Bracket/ Excessive Vibration.
- How do you lowered boys do it?
