View Full Version : Drag Racing Tech
  1. Header primary sizing and questions....
  2. Wieght Diff. of Front Runner vs. street skinny??
  3. Anyone else can't wait for spring (pics of new Bogart RT's)
  4. What size jet for 150 dry hit?
  5. !monsoon
  6. Those with aerospace brakes- COME IN!!!
  7. Help me out with my math!
  8. Made some changes to the car...tires/gears/weight/etc
  9. Strange front brakes
  10. Quickest full weight bolt on M6 ?
  11. A3 guys, I need help wiring up the NSS
  12. Travel limiter info
  13. What will I run...
  14. Speed Inc. lightweight carpet
  15. 408 or 540?
  16. Do I have an 11 sec car ?
  17. RPM not reading!!!
  18. anyone do back to back track testing on light weight k-member and a-arms?
  19. how to remove the A/C completely?
  20. need help on desideing what i need next
  21. Any negative drawbacks to running a motorplate??
  22. Solid motor mounts Part 2
  23. Former Nitro driver Bruce Sarver takes his own life
  24. Bmr Torque arm
  25. help on tow vehicle
  26. 13.1 1/4! slave cylinder or nitrous problem?
  27. What would in Run through the 1/4
  28. Spohn Driveshaft safety loop and stock torque arm
  29. 700+rwhp cars, what main caps?????????
  30. coated main bearings
  31. More progress pics
  32. Qa1 ???
  33. bullets after collectors????
  34. What is this connector & wires?
  35. harlan 2 step how to??
  36. MADMAN's #
  37. Hardcore Racing Announces the Warhawk LS7X Block by World Products!
  38. Need some pointers on traction...
  39. Is this a good 1/8 e.t.
  40. Launch RPM's?
  41. Is my trap speed okay?
  42. how much weight will this save?
  43. Please stock suspention guys
  44. where am i losing power?
  45. Hitting 11's with bolt ons?
  46. such thing as too much LCA angle?
  47. Any bolt on cars running a 90mm intake?
  48. hooked up my shift light but its on constant
  49. Torque arm Front Mounts, Slip Yoke vs Solid mounts
  50. Rim Screws on Weld Aluma-Stars?
  51. 2 step on a vette
  52. madman manual rack need one
  53. Frank Hawley Drag Racing School?
  54. why is it
  55. For those that are mini tubbed
  56. Skinnies
  57. Installed my TH350 and loving it....kind of
  58. What gauge wire to go from alternator to kill switch?
  59. What size tires for skinnies?
  60. woble down the track
  61. whats the fastest full weight LT1,stock cubes,4L60 on spray?
  62. harlan 2 step list
  63. kirkey seat mounts
  64. Difference between madman and RT TA's?
  65. Launching an M6 with Mt steets
  66. Madman is the shit!!!!!!!!!
  67. Practice Tree?
  68. DIY rollbar camera mount, for less than $2.00
  69. Wiring diagrams?
  70. Dzus Pictures Needed
  71. 2 Step users/potential users - Need input...
  72. Eibach Drag Launch Kit... Worth It?
  73. which is better th350 or 400/does speedo work
  74. My launch problems
  75. Flat On M/t Drag
  76. Vibration during deceleration
  77. what psi u guys run
  78. Anyone have tips on how to improve my 60'?
  79. anyone running 18 bfg dr's
  80. Offset Spacers?
  81. What degree are our brake lines flared?
  82. Removing my strut tower brace
  83. What should I be trapping with my power level?
  84. Front runner tire or radial tire for skinny
  85. Launching Dilemna
  86. Ls1 M6 Or Ls1 A4?
  87. Which torque arm for high hp cars?
  88. PVC ? please come in and help if you can
  89. !Front bumper support with fog lights???
  90. Tires 26's vs. 28's
  91. El cheapo tires for skinnies?
  92. Which tyres for drag racing?
  93. When to shift???
  94. How to heat up slicks?
  95. Whitey update
  96. Fuel cell or sumped tank??
  97. Those w/ grinded calipers, do you have a linelock?
  98. Help with my ET / DA Loss...
  99. PA Racing K-member
  100. Race Weight! Gutting A Fbody!
  101. how do i shave off a 3rd of second
  102. Fuel Cell in Trunk Area, Rear Bulkhead Needed?
  103. Broke spohn torque arm this w/e
  104. how much time u think i will drop
  105. take a look at my slip, seems weird for power levels im at.
  106. Horsepower or Torque, what makes the car accelerate?
  107. what size DR's to get?
  108. What PSI for ET Streets??
  109. TH-350 305 1st gear
  110. burnout in 1st or 2nd?
  111. race weight
  112. Pre-loading rear sway bar
  113. Drive shaft reccomendations please
  114. How can i delete my ASR ??
  115. burnout with a stalled a4
  116. How do you have your ram air system set up on your drag car?
  117. What's the best thing to do with the PCV system on a drag car?
  118. What am I doing wrong??
  119. car pulls/drifts to the left out of the hole
  120. Whats the best suspension for drag
  121. good to 7.50's!!
  122. Freaky Friday
  123. general tire size question...
  124. How can i adjust the lca's ???
  125. Safety question - tires
  126. 9.99 or 10.99 for a 10 point cage?
  127. made my appointment. parachute baby!
  128. highest shift rpm?
  129. SPAL LW Fan, what Dia and CFM?
  130. 60ft question
  131. What Aftermarket WS6 hood weighs the least??
  132. Should I stay in 3rd or shift to 4th....
  133. Gateway (IL) 2005 Photos Now ONLINE!
  134. Weighed my car today!!!
  135. If you had to pick?
  136. I need help!
  137. 28x9 - et drag or hooser?
  138. Pinion angle effect nose dive?
  139. tire vs mph link?
  140. 6 Pt. Roll Cage?
  141. Harness Bar
  142. Racing harnesses
  143. Which Hal Springs for a 408 Iron 300# or 325#
  144. Will any 2.5" coilover springs work?
  145. Which gears to go with
  146. racing seats
  147. Weight vs 60ft question.
  148. Best times seen out of a v6?
  149. First TIme to the Track??????????????
  150. I FINALLY have a running race car again!!!! Dick Harrell Widebody is complete..
  151. First Trip to Dragstrip??????????????
  152. What will these mods be worth in the 1/4?
  153. lowering the rear end
  154. ignition wire on pcm for shift light?
  155. Mcleod SFI bellhousing
  156. Cooling down the car?
  157. Help me make my car faster
  158. Here's How a 28" ET drag should look in the wheel well
  159. Bracket Racing
  160. What do you think of my times?
  161. anyone running the Wolfe lower spring perches?
  162. Luanch the car with a 75 shot ???
  163. Brake fluid resevior leaks out the top on hard launches
  164. Hardcore drag racers, 10s and faster, please come in.
  165. Strange Shock Assembly
  166. Wheel hop
  167. icing LSx intakes
  168. Removing the bumper supports??
  169. Questions after dash removal
  170. What else to do to improve cam only setup?
  171. What is the best way to launch?
  172. Directions for Removal of Seat Belts...
  173. Stenod Performance Chromoly Cage Complete (Pic's)
  174. Check out my breather set up.
  175. little help here
  176. Weight Transfer (drag/launching)
  177. Weight Reductions
  178. Gauges - How is everyone setup
  179. Spinning will add mph?
  180. Powerstroke or Duramax?
  181. Couple of pics for the hell of it
  182. Couple drag racing ??'s for an A4
  183. ET Streets 26? or 28? x10 too much for bolt ons + 10 bolt?
  184. Ride height vs. 60ft...
  185. ???'s about tire size vs MPH
  186. Boltons+Traction-DS Strength=...
  187. ET Streets
  188. would this burn up a clutch
  189. Trailer
  190. finished up my Mcleoud bellhousing today
  191. Building Z28 into drag car, order of buildup question
  192. vfn fiberglass body kit
  193. Explain Brakestands 6-spd!
  194. Need some more info on A3 swap...
  195. !ACing right now
  196. Need some expert tire help
  197. Darting All The Way Down The Track When Power Applied
  198. With a 4" narrowed rear
  199. can you launch with a line lock
  200. anyone running a th400 and high rpm with stock crank?
  201. what shift points should I race?
  202. wheel and tire combo problum
  203. installed adj. torque arm and new drive shaft loop and car dosent feel right
  204. what are good 60' times for a m6
  205. pulled front sway bar and putting v6 springs in
  206. Front bar, how much does it hurt your times.
  207. 25mm rear swaybar question
  208. Could my new mods slow me down??? Please give some feedback.
  209. Opinions needed, tire too far under fender?
  210. Quarter mile time difference = car lengths?
  211. Madman reason to KEEP the front swaybar?
  212. Quick transbrake question...
  213. Slow track times!!!
  214. should i get a line lock for my m6?
  215. suspention setups
  216. Front Spring Rates
  217. Launch pic, any suggestions?
  218. how do i launch with a 6 speed at the track please help
  219. Info for future !abs peeps...
  220. air bag ?
  221. what kind of 60' should this cut
  222. How much does weight effect 1/4 mile et?
  223. How much can a stock TA handle?
  224. What is a two step?
  225. 60' ? Tuning issue ?
  226. Need advice about pin on hoods
  227. Getting ready to upgrade rearend, suspension pieces...
  228. what kind of light weight batteries??
  229. San Antonio Race - might be cancelled
  230. SLP Line Lock
  231. How much will these parts help me in the 1/4?
  232. front swaybar
  233. "Darting" on launch
  234. V6 Camaro Springs?
  235. Weight Reduction Now..
  236. how to remove the front sway bar??
  237. get slicks...better get new rear???
  238. Why do M6s turn in crap results at the strip, cam only?
  239. how do you luanch an AUTO?
  240. 1/8 to 1/4 mile conversion chart
  241. Torque arm question?
  242. First time at the track - very disappointed
  243. lowering 60ft times
  244. Finally made it to the track, but have some issues that I need help figuring out.
  245. Wolfe Roll Bar, jig notching worth it...Chrome Moldy or steel?
  246. SFI Rules for floor mount 5 Point Harness
  247. Which Line Lock, any difference ??
  248. Camaro RS 10 pt cage
  249. UMI Torque arm, 10 bolt-12 bolt ??
  250. Fixed racing seats... ok for a DD?
