View Full Version : General Maintenance & Repairs
  1. Reason for a 20:1 A/F Ratio??? HELP
  2. Squeakiest pulley EVER
  3. Starting Issue Help
  4. Speedo Not Working...
  5. not charging with brand new working alt.
  6. charging probelm
  7. Right front blinker won't work .
  8. Noise from the rear when driving at low RPMs
  9. Shutting off airbag light?
  10. Overheating Problem Please Help
  11. Argh... tranny problems...?
  12. Junk Headers..??
  13. A/C Leak?
  14. header bolt
  15. stock exh manifolds
  16. a/c air blower fan
  17. Coolant hose problems...weird
  18. Cant get gas into the tank
  19. Weird noise on start up
  20. Clicking/Clacking upon Acceleration
  21. Does anyone know how to tell what is draining my battery
  22. 94 Z28 Changed cap and rotor, now over heating?????
  23. running rich related to possible broken cat?
  24. steering column malfunctioning
  25. battery or alt.
  26. Power steering leak
  27. what is this?
  28. Fixing my driverside window
  29. Vibrating Drivers Mirror
  30. weird steering column stuff
  31. service engine soon light
  32. No spark at start up?????
  33. Help: 2 Noises Heard on Cold Startups
  34. PCV hose question
  35. formula wing reapair
  36. Quick seafoam question
  37. Question about resetting "Change Oil" light
  38. Belts!!!
  39. annoying problem
  40. Where to find interior trim screws?
  41. Throwing belt problems Help please.
  42. Slight problem
  43. misfire help
  44. Squeaky Clutch Pedal....
  45. rpm gauge short...
  46. CAN OBD vs OBD
  47. Car stalled in rain. Now won't start. A/C Comp. Relay Buzzing
  48. fuel tank leak
  49. How the hell do I fix this?? (window related)
  50. Headlight Motor Gear Cheap Fix.
  51. speedo not working
  52. Starting issue please help
  53. Help with a squeak
  54. Spare tire
  55. Window Help. ASAP!!!!
  56. Gurgling sound when pushing accelerator
  57. 97 z28 steering probs
  58. Need help fixing camaro headlights
  59. Help! Help! Help!
  60. Problem with head/fog lights
  61. New turn signal lever, not working right!
  62. Trip Odometer Resets Itself
  63. Binding in right rear/hub/axle
  64. does this happen to you???
  65. Loud high pitched beeeep. Fuel pump?
  66. 99 corvette air condition leak
  67. Weird Idle Problem...
  68. How to fix a faded taillight!!!
  69. Air pump removal
  70. Weird over heating problem
  71. Headlight isn't closing Fully
  72. How to change a fuel pump in a 99TA?
  73. door hindge pins/bushings
  74. Ls1 ruff idle (misfire)
  75. Headlamp Lens need to polished
  76. anybody ever use PX3 oil treatment?
  77. Real simple question about shocks/struts replacement.
  78. Help! My Car Is Stalling! Need Help Asap
  79. removing right exhaust manifold
  80. Brown Slime In Coolant!!!
  81. Oil Level Sensor('97 LT1)
  82. Oil Smoking
  83. throwing 02 codes. fix?
  84. Wiring issue with header install
  85. MPG drop
  86. Window motor clunk
  87. Car keeps boggin need help!!!
  88. slugish? clean the MAF!
  89. Help!!! water in the cargo area
  90. e-brake handle
  91. Fog lights wont work right
  92. engine squeak
  93. Fan direction dial
  94. Car won't start - Have scan of attempt
  95. Stock 99 SS pings at WOT
  96. Alternator Hookup Problems
  97. Rough idle only when first starting
  98. Thermostat Housing Bolt Striped.
  99. Need Help ASAP: What Sensor is this? And why is it Dragging Underneath my Car?
  100. shop time on motor mounts
  101. PLEASE fill this info for me...
  102. T/A lights coming up when car is started
  103. Help!!! I keep burning O2 sensors!!
  104. Are "Precision" spark plug wires GM brand?
  105. alternator dies quick help???
  106. MPG on E....
  107. Help Headlights Not Working
  108. Bleeding through the crossover tube question...
  109. Exhaust Rattle
  110. Just broke my triangular shaped shoulder belt support
  111. Which fuel pump??
  112. dying battery ??
  113. Fan motor wont come on
  114. Have a rod knock
  115. Just joined the Flew off t-top club tonight...help!!
  116. gmmg cat back?
  117. Ima blow it up!!
  118. have a whine in my rear
  119. need help these codes popped up..
  120. broken gas cap?
  121. Headlight Motor Concerns
  122. car cranks while connecting battery.... WTF??!
  123. Pass. window motor repl.
  124. drivers door wont lock or unlock
  125. TTop lock fell out
  126. Overheating with GFX
  127. Car has no power up top???
  128. Just bought a Formula, what things should I check?
  129. Oil breather cap smoking
  130. Cranks FOREVER Before it Starts
  131. Does this look like the light sockets going bad? (VID)
  132. Silicone Wipers
  133. Interior mirror lights?
  134. Air conditioner Question
  135. Remove Power Steering
  136. Causes of running rich
  137. How do you pass inspection?
  138. Steering noise?
  139. Hood cable broken. How do you open hood?
  140. AC compressor shuts off and will only restart by restarting the car.
  141. T-Top
  142. remove cat
  143. A/C not blowing cold air, clutch does not engage
  144. window switch or motor?
  145. Insufficient Switching Sensor 1 or Bank 1 Sensor 1
  146. Squeaky...something...When AC is on...
  147. Gears throw off Odometer?
  148. Does anyone know how to program keyless entry on a 2001 trans am
  149. Headlight motor is going bad...
  150. Idle Misfire
  151. 02 replacement... how do u do it? nebody have pics?
  152. 234,000 miles and Seafoam?
  153. Throttle body Cable
  154. C smokes a WOT..WTF!!!
  155. Stock Alternator + UD Pulley
  156. cam position sensor going bad
  157. Advice on plugs and oil needed
  158. AC Repair Questions?
  159. 1999 T/A Noise and vibrations above 55
  160. I feel retarded asking this, but I need help with my windshield wipers...
  161. Car wont start! Need Help ASAP!!
  162. My GRANDMOTHERS fans dont kick on her 96 T/A
  163. rear brake noise driving me crazy!
  164. sway bar bushing question
  165. throttle body gasket question
  166. New engine, coolant boiling, wtf????
  167. Slow 1/8th Mile times
  168. Metallic grinding/hissing noise from rear end
  169. Alternator / exciter wire / backfire / now this!
  170. So.... need some advice with a window seal thing
  171. low voltage problem
  172. need some help on a gmmg+ory+a4+ cme tip= rasp at certain rpm's?????
  173. transmission related? please help.
  174. just replaced my plugs for the first time
  175. window regulator spring?
  176. front 02 sensors replaced....
  177. Help Bad Egr?
  178. tough/hard blinker?
  179. Thermostat issue
  180. Transmission trouble
  181. help with power/manual window problem!
  182. what type of brakes disc or drum
  183. power seat... lumbar and bolster problem
  184. Getting A Clunk In Rear Suspension...Please Help!!!
  185. electrical problem on 2003 mustang v6
  186. bad window motor or regulator, or both
  187. Humbling request for help on "how to..."
  188. car will not rev up past 2k
  189. So is it bad to have...
  190. Leaky Acdelco Battery
  191. Condensation on Driver Rear Tail Light
  192. window motor problems fixed :)
  193. window problem
  194. bad squeak after alternator change
  195. Help me find me coolant leak!
  196. Weird Vibration
  197. P0122 TB Position Sensor
  198. Dented oil filter?
  199. ??? On fluid for rear diff and t56
  200. Big WEIRD Problem... help!!
  201. Vibration in 1st between 1100-1500rpms on M6 SS
  202. NGk TR55 or NGK TR55-IX
  203. small E-brake annoyance
  204. Headlights won't come on
  205. car wont start! need help
  206. A/c And Turn Signal Not Work. Checked Fuses But They Look Ok.. Ideas?
  207. Spark Plugs and LT's
  208. Head lights flip when car is locked and unlocked
  209. starting issue
  210. Yet another exciter wire issue
  211. aggravating vibration
  212. Oil change light on after T/A reloctation???
  213. loud noise on startup
  214. Question about TA fog lights
  215. Loud Cracking Noise
  216. NEED HELP ASAP!!!!!!!!!!!! car is freaking out
  217. Help! Stuck Speedometer!
  218. Did gear replacement in Headlight need help!
  219. Broken Seat Belt Buckle Plastic?
  220. Help On How To Remove Fog Lamp
  221. exhaust leak or plugs?
  222. slp manual fan switch install?
  223. Battery died: New battery, idle problems?!
  224. Power Steering Fluid Leak
  225. headlight control module
  226. ls1 runs like crap in the rain, sometimes before it rains.
  227. a/c and heat fan won't work
  228. noisy ride!
  229. has this happened to you?
  230. Air conditioning question...
  231. Motor mount size
  232. windshield wiper blades, trico #'s, opinions?
  233. Power Window Motor Problems?? Look Here!!!
  234. Sending unit bad?
  235. Turn signal not working...and it's something different than usual!!!
  236. Oil pan gasket leaking, have some questions
  237. Wheel speed sensor problems!
  238. loud sucking noise
  239. Voltage issue (SEARCHED)
  240. Window doesnt't go up all the way...Pics included
  241. Steering racK????real quik answer
  242. ***PLEASE HELP****...Cluster lights problem
  243. Pass Window problem
  244. A/C and vent selection problem. Need some help!
  245. code p0480
  246. HELP! cooling fans not working!
  247. SES = 3 codes
  248. knock sensor code
  249. Alternator
  250. Headlight/Electrical issues need help ASAP!
