View Full Version : Gears & Axles
  1. What kind of posi for a 9inch
  2. Moser 9 inch Al 3rd Member - Does it come with a steel spacer or crush sleeve?
  3. gear whine and grinding
  4. whats the cheaper way to go about a rear end?
  5. breaking wheel studs with my s60
  6. 3.73 rear end whine
  7. M9 and True duals?
  8. Aluminum or Iron Case to go with my MOSER 9"?
  9. Stock rear
  10. Horsepower loss more with Gear swap or rearend swap
  11. Dang, I Need To Know
  12. are these 3:08s????
  13. winding noise???
  14. So...need some opinions..
  15. Who's broken a Truetrac?
  16. what kind and how much rear end fluid?
  17. Do Dana 12 bolts have the option for a 3.23 gear or 3.08
  18. Can 4 channel components be put on a 3 Channel?
  19. Need help from rearend guru's
  20. Best Rear
  21. Built 10 bolt?!?!?!
  22. how many people have 3.42s???
  23. M9 hitting the gas tank?
  24. M9 Issue
  25. 9 inch vs 12 bolt
  26. where to get ford 9"
  27. Broke my driveshaft with a 3k launch, is this common?
  28. what gear ratio?
  29. Where to buy a new carrier and gears complete kit for ten bolt?? asap
  30. 3.42 or 3.73's
  31. Thanks Midwest Chassis & Performance!
  32. Need help on a KTRE rear end
  33. Rear end help
  34. Which driveshaft for my app???
  35. 9 inch assembly specs... Sponsor help?
  36. Best place to buy 9"
  37. my 98 z28 has a popping noise,maybe in u-joint or driveshift
  38. rearend noise ?
  39. torque specs on the torsen T-2R
  40. a super great deal!!!
  41. Moser 9in 3 channel abs problem
  42. rear end gear oil ?
  43. CONFUSED W/THIS POPPING> driveshift-U-JOINT?
  44. my 98' z28 w/ popping under seat near trant mount
  45. shipping on driveshaft?
  46. torque spec on moser nodual carrier caps.
  47. Who Sells The Cheapest Aftermarket Rear End??
  48. Do I have a 4 channel axle?
  49. Moser 12 Bolt Housing Question
  50. 373's for an m6
  51. Any m6 guys running 12 bolts?
  52. 68 firebird ... rear end seems off center ?
  53. Who has the best price in Houston Tx on a gear install?
  54. just got my summit gears in. what brand?
  55. 4 channel to 3 channel on a S60
  56. gear install question
  57. Howling stock rear end
  58. Rear End leak...
  59. Quoted $325 for labor to install 4.10s
  60. Stock Aluminum Driveshaft
  61. 9" wheel bearing O Rings
  62. true or not? setting rearend gears
  63. want a 9, but have 4ch abs. help please!
  64. Changing Axle Bearings?
  65. what gears are you th400 guys runing?
  66. Rear End Swap
  67. I need a new axle
  68. thinking about 373s
  69. 3.90 or 3.73 with 9" - 8th Mile Track
  70. what parts needed?
  71. Clunking
  72. c5 gears??
  73. Some Pics of New 12-bolt.
  74. Help me out everyone!
  75. ASR removal
  76. sway bar help
  77. Conversion Joint to 1350?
  78. going with a 12bolt
  79. BMR weld-in LCA brackets on 9"?
  80. 97 rear in a 99??
  81. 9" with stock drive shaft question?
  82. Burkhart housing pics.
  83. Carnage of a 10 bolt!!! PICS
  84. apparently I have a "loose" rear end
  85. MidWest Chassis Custom FAB Race Housing Pics
  86. need some help with my 10 bolt
  87. U-joint help
  88. 430 & 456 guys
  89. 12-bolt Break-in question
  90. quick question about 3.73s
  91. how to recenter my rear end?
  92. 10 bolt CARNAGE
  93. 9" Gurus: Need some help
  94. What gears?
  95. banging problem need advice
  96. Has Scott from Driveline Solutions Died?
  97. Moser 9"
  98. Where to buy Axles and internals?
  99. 1350 joints
  100. Newbie rearend Question???
  101. Moser 9" Clearance Problems
  102. Easiest way to remove carrier from housing???
  103. will a 98-02 f-body posi unit fit in a 00 gmc pickup rear end ?
  104. Crush Sleeve
  105. How much and What kind of oil needs to go in the stock 10 bolt.
  106. Bent Axle tubes
  107. looking for a r&r of the factory rear end!
  108. Special Tax Time Pricing on all MOSER ENGINEERING Rears @ Tick Performance!
  109. Think it'll go?
  110. Strange U1603 questions
  111. 9" Axle length for 99 F-Body?
  112. pros and cons of S60
  113. Moser axles...EPP
  114. just had 10b rebilt, now a new noise?
  115. What Torque Arm for the Strange S60
  116. Broken rear?
  117. Install 4.10 Motive Gears??????
  118. 10 bolt started whining!
  119. 3.42 gears for a 4 series carrier???
  120. Stock rearend leaking fluid even after I replaced pinion seal???
  121. moser 12bt. with hd eaton CLUNKING LOUD
  122. C clip eliminator?
  123. 1310 yoke on Moser 9"? U joint help PST DS
  124. Anyone run across this????
  125. 4.10 To 3.73
  126. Carrier bearing install ?
  127. 2-series carrier question - need help
  128. do stragne 12-bolts whine like mosers??
  129. Waste of money 3.73 10 bolt?
  130. ford 9"+big bearing ends +ls1 brakes????
  131. 12 bolt torque arm mount
  132. Anyone running M29 or M12/MN12 with 3.73's?
  133. Reluctor Rings?
  134. Brand New 9 Inch Problems
  135. Moser/Strange 9" Fitment
  136. Question about the 10 bolt.
  137. Midwest Chassis- Thanks!
  138. R.I.P. 10 bolt 2/10/08
  139. A few ?'s about my broken axle
  140. 3.90 in A4
  141. 130+ on moser 9
  142. FORD 9" on 2000 T/A
  143. Ford 9", M9 or Moser/Strange??
  144. WHAT ARE THE COSTS and differences between a ford 9" and a M9
  145. to the top
  146. Differential Help
  147. Is this a good Deal
  148. Who builds their own?..
  149. Need fast answers on 4:10s!!!!
  150. 9" & 12-Bolt
  151. stock driveshaft size ???
  152. Rear Diff Fluid Change?
  153. Broke my 10 bolt, where do I get an overhaul kit>?
  154. 4.10's??? need more gear 4.56's??? Input needed.
  155. Locker or True Trac for a mid 10 Sec. Car?
  156. To get gears or not.
  157. How much hp will a stock driveshaft handle?
  158. Need help deciding if a gear change will benefit me.
  159. 4.11's effect on speedo
  160. Midwest Chassis
  161. question about Moser 9"
  162. 10 bolt groaning while turning
  163. New M9 Rearend Install Pic :)
  164. NeEd SoMe ReAr EnD iDeAs!
  165. Swapped from 2.73 to 3.73
  166. Exhaust causing rear diff seal leak????
  167. Putting in 3.73's
  168. Does it really matter?
  169. Burkhart Chassis February specials.
  170. Can U use the M9 on the street?
  171. Gonna go with 4:10 is that good?
  172. Lingenfelter TA Cover Leak
  173. Leak...
  174. is this the right rear end for my car?
  175. Are Strange and Moser interchangable?
  176. 10 bolt posi
  177. Who's good for RearEnds?
  178. GM vs. Motive
  179. Any suggestions from guys about 9 inch diffs?
  180. What type of fluid and additive do I need?
  181. What gear for me?
  182. axle help
  183. When will my 10 bolt break Answer
  184. Likes and Dislikes...looking into buying a rear trying to figure out which one
  185. Im considering going from my 12bolt to a True fab 9! WHat options should I look for
  186. 3.05 to 3.90 et
  187. Need some help with part #'s for 9 inch.
  188. Damn 3.73 s Love and hate em!
  189. Auburn 542040 unit and my rear end
  190. how wide is the 7.5 10 bolt from a 99 z28
  191. whats the rear worth and will it fit?
  192. Anyone with True Duals w/ Moser 9" or M9?
  193. 4th Gen Posi in 3rd Gen Rear...
  194. First customer owned 3 channel 9"
  195. weight difference between 9in. and 12 bolt
  196. 3 Channel to 4 Channel
  197. Moser 9" options
  198. Where to buy rear ends?!
  199. my new MW axles
  200. Could I buy a 9 inch for the center and axles?
  201. Please check my 9" ring / pinion gear pattern...Ready to run?
  202. Do Gears affect smog
  203. 4.10 gears in m6
  204. Ford 9" posi problems
  205. Leaking TA cover
  206. MOser 9" with 4.11's or 4.33's...inside????
  207. steel vs aluminum driveshaft
  208. going back to 2.73s??
  209. 9 inch from joey at tick
  210. Yo
  211. From 2.73 to 3.73
  212. what gears to get?
  213. Need new gears
  214. i have a 2.73 gear, 3.73 question
  215. 3.90 in A4 opinions
  216. gas mileage with 4:10
  217. Need suggestions on gears?
  218. 433 gear in a A4 car
  219. ford 9 inch
  220. Power TV Video of Moser M9 Rear from Sema
  221. bent driveshaft
  222. What rear I searched
  223. 05 z71 gears??
  224. 3.73:1 gears going in tomorrow
  225. May be dumb
  226. Gear and Tire changes, Figuring out new MPH
  227. Rear Diff Fluid Change
  228. Paranoid or something to be thinking about?
  229. 373 versus 410......550 plus rwhp
  230. My 9" install, the good, the bad, and the ugly
  231. Opinions on 10 bolt gear failure
  232. need rear end help PLEASE!
  233. 8.5 10 Bolt vs. 7.5 10 Bolt
  234. Are these splines acceptable or do I need new axles?
  235. Pros and Cons, fbody rears
  236. Ford 9" + 3.5" alum. DS help
  237. moser 12 bolt with madman lca and relocation brackets
  238. Rearend going bad??
  239. rotational TQ for 9" pinion?
  240. 9" back brace ?
  241. Upgrades this weekend
  242. rearend suggestions
  243. Issue with my 9" and locker
  244. Driveshaft Help
  245. What center section to get
  246. No ABS after your rear? What about jumpering the wires?
  247. Need some help
  248. front u joint help please....
  249. best place to buy
  250. ford 9" pinion setup troubles......PLEASE HELP
