View Full Version : Drag Racing Tech
- Open ORY for the strip?
- Calling out Southern LS1's. Eunice Louisiana Aug 3rd
- Not happy with new track times with new mods
- Not on Drag radials
- taking out air bags help please
- Safe to remove heat shielding?
- Check out my video from this weekend :)
- Help Quick!! Best Tire Pressure For The Track (F1's)
- Post your summertime heat "et's, mph&60ft"
- What should my 60' times drop with Nitto's?
- Please post your best wheelz up pic!
- Race results for the weekend of July 13 & 14
- Why am I losing trap speed with each run?
- ET Fronts
- Quick help: Best first mods for 12s
- A lot of BS times in sigs these days?
- ATTENTION: GMHTP Looking For LS1 F-Body Feature Cars In NC, VA, & SC
- Harlan's Two Step works as advertised!!!
- 2003 cobra quarter mile times
- Altitude finder website
- This truck could have taken me out! (vid)
- New track times!
- How much ET reduction do you guys see with hotter weather?
- New Times with stage 2 heads and 227 cam... p.s..Rear didn't break either
- What trap speeds are you intake/headers A4 cars running?
- front bumper support need help ASAP
- Has anyone had tires that have been...
- Does anyone have pics of grinded calipers to fit 15x10 prostars???
- Do you need relocation brackets if....
- What should i be running
- What do you think about a 9inch slick?
- Should I race the Z28 or the truck?
- Harlan two step question
- 01 LS1 in 91 Z28: TRACK TIMES!!
- First pass on ET Streets
- Wisconsin bound
- Drag racing info needed---->HELP!!!
- What psi for even wear on 275/40 Nittos??
- go away rain!!
- Upstate NYers Please race me to quell the interest of many LS1ers
- Harlan Two Step device, anyone have one.
- 1/8 th mile times
- What should I be running in the 1/8????
- 5pt. harnesses
- pic of 15x10 pro stars w/ et streets
- How much can hot weather affect your times?
- Help out of weight reduction!
- VIDEO CARTEK c5 10.72@130
- Bumper Supports
- oredering skiinnies, some ?s
- From 10.9 to 9.9, how much more HP needed?
- I need a rollbar, but don't want one
- Exhaust recommendations
- crazy
- how to reduce a Z28 weight to under 3000 lb?
- First time using the TNT F-1 wet kit
- Z's stock #'s
- Crappy weather but new best. Video inside.
- What do you think? 30'tall tire and 5.13 gears
- Weekend Race Results
- So close but yet so far!
- need info on F-body nationals in Sept in ILLinois.
- Gearing (M6) and 1/8 mile times
- M6 Guys With 4.10's Inside Please
- Need advice for slicks
- Should I get 4.11's?
- best launching RPM?
- Finished my drag brake install
- 10.71 @ 130 mph - All Motor Corvette (Cartek)
- Why did the Mickey Thompsons Hurt my 60ft??
- 1/4 mile video
- Finally ordered a trailer!
- Torque converter recomendation
- It's 95 degrees and 90% humidity but I'm going to Midnight Madness anyway.
- When is nitto coming out with their slick?
- First time racing...
- Almost 10's on drag radials with first outing in Project SS
- Mike R. {AKA Stealth} "CARTEK 415CI" runs 10.71@130!!!
- I finally broke into the 12's
- new best again. still slow but making progress.
- Started installing front drag brakes...
- 4th of July Race Results
- i lost 6 mph!my et down 2 tens! help.
- What to get first?
- Whatever happened to Tom the Roofer?
- Is a right rear airbag and /or hals really nessisary?
- 5 point harness that is LEGAL to daily drive with...
- WHat times am i possible of running?
- What are the lightest Tires out there
- paging Raughammer : what did you do to reduce the weight of your Z28?
- 26" or 28" et streets for daily driver?
- Big Money Payout this weekend at TAD
- Bigger tire/Prostars/HAL's.....
- Is any one using this SLP Line Lock?
- fireball and others inside here.
- need help, will 28x 10 fit ?
- How do you do a Burnout w/ M6?
- Front runners
- I hate six speeds!!
- Who makes a high quality pin on hood for the 98+ firebirds?
- Need help with my Reaction Times?
- 99 z28 w/ a4
- What size tire to run for 15x3.5" weld prostar...
- Jegster roll cage
- anyone else hate hot weather when racing
- So I get to the Semi's, pull to the line and cut a .011 RT and then...WTF!?
- Likelihood of breaking the rear on ET streets
- installed Lightweight carpet
- do 16x8 ro 9prostars need grinding?
- Went racing, hood didn't fly off..
- Soft Touch Rev Limiter???
- "No" Racing this weekend!"RAIN"
- 10.972 @ 125.29 mph Bremerton Raceway
- help! what size et streets for 15x10 pro stars?
- Weight difference between chrome 16 x 8s, and painted 16 x 8s?
- Buying New Slicks for my 16x8s, stay with 11.5 or goto 10.5?
- A win with "The Other Car"!!!!!
- Show me some pictures of weld draglites and prostars.....
- Stealth runs 10's at the Cartek Corvette Challenge
- 2-Step and a 98
- The TP4400 is going to kill my old #7
- Lightweight carpet pics
- i HOPE it is my A/F that made me run like POOP!
- Lost 2 tenths and 3 mph going to ET Streets in better weather...
- Vette vs. Viper Shootout at River City Raceway????
- All dressed up and no where to go!!!
- 3:73 versus 3:90's or 4:10's
- Air bag pressure
- 15" NO SPACER?
- 4.10's vs 4.30 on the street from a roll. which would have the upper hand to 120'ish
- Make that 4 solid tenths with the cam....
- TNT 100 Wet shot times vs N/A WTF
- Rear
- Anyone tried true 28" slicks on a lowered car?
- ETs or Hoosiers, what sizes???
- Those of you that have broken rears, please vote...
- FINALLY! A good launch pic of my car
- What would cause Car A to run faster than Car B?
- Need driveshaft length,Anyone???
- Track Times With New H/C Combo!
- Who is running macs in here with cats,
- Is it better to build a superstock car or buy a rolling chassis?
- Milan 06/26/2002 Results/Videos
- Will the Spohn race T/A handle low 9 second launches?
- stock 98 z28 a4 time
- Please post your best 3.73 60' times (A4)
- Just released
- What was the shipping weight of your f-body?
- Bracket Racing rules for Footbrake or Modified
- Mark Williams CF 3.5 driveshaft?
- how do you remove wiper arms?
- Rivercity Raceway($1400.00 to win footbrake)
- Drag Radials...
- Saerching for 12's, need advice....
- ET Streets/Hoosiers and 10 bolts...
- Which will go first? Rear or trans?
- Front/rear drag brakes
- How about some "Drag racing weather station 101"?
- Question For Those With Wolfe Cage and Swing-Outs
- Wheel studs & lugs
- why not many FAST supercharged cars?
- What are the best Heads/Cam/Intake times with stock rear and stock 3.42s?
- Race results: Runner up and a Win!
- How many runs can you get out of a stock 10 bolt? I got about 140..
- Scatter shield?
- what kind of '60 should I expect?
- another weekend of racing!
- Pics of new hood and carpet
- What should my times be
- WOT shifts with 2 step......
- new bests. 11.97 @ 113.26
- I got my Glasstek hood installed
- Calculate your engine's true HP/Torque Curves
- Race Video 11.045 @ 124.96
- newcomer hi all
- Picture of new Hoosiers on the car (28x10x15)
- Big Thanks to Thunder Racing
- Removing entire belt at the track - question
- 11.5" tires on a 8" rim?
- well 2 step works very very well
- Increaseing trap speeds
- Lightweight seats with stock headrests?
- Best potential ET on a 125 MPH run?
- 6pt. roll bars
- Is a 7/16" spacer too much for a Draglite?
- my et last night>
- Favorite wheels for drag racing?
- Where Can I Get The Light Weight Carpet From
- Need lightweight hood info...
- REAL weight on AC-25.5#
- 516rwhp supra, How fast in 1/4?
- MMRA race in AL?
- best tire gear combo for my setup?
- G5 cam track times!
- LoL- I ran the SS tonight
- Harlan - Anyone - Help with the NOS - 2-step hook up
- FIPK Rival?
- "dynabatt" adapters impossible to find!!
- racing
- please post videos!
- racing
- Going to try the 2-step out Friday night
- Thinking of Spraying the Car.....
- Unbiased Cam Testing?
- 60FT. Time Help!! Never raced at the track!!
- First time ever doing real drag racing!
- Drag racing videos from Memphis - 5500 rpm clutch dumps :)
- Corbeau Forza seat weight vs. stock
- how much ET improvement with cam only?
- Newcomer Cindy Crawford
- Possible to hang the hoops w/o removing swaybar?
- What should I run?
- Memphis Results & Shifting Problems Resolved
- Cheeta SCS
- tires that will pull the wheels
- Anyone trimmed rear fender to clearance 28" Drag Tires?
- brake rotor questions??
- Crossed drilled rotors are or are not outlawed for drag racing???
- Gotta question about my converter
- 7.26 in the 1/8th @ 98 mph!!! Stock A4 w/no converter!
- Mack Your Calendar
- Racing wo/ a hood?
- Worthless Mods = NEW BEST!
- New best and I pulled a tire..WHEEEE
- Terry Burger ...... Wheels Up !!!
- Memphis F-Body.org results (new cam only best)
- Very strange vibration,Anyone?
- Car is twisting like a pretzel
- Remove front swaybar ?
- Since the topics up, Does anyone want to take a stab at my 1/4 time?
- Guess my 1/4 mile time?
- Has anybody ran at the powerhouse in Panama City...
- Anyone up for a little F*rd vs. GM feud?
- Weight reduction you can't see/feel?
- steering wheel pics?
- how to remove cruise control?
- ?'s about jackson SC drag strip
- Anyone racing this weekend?
- Hey Terry Burger
- 1/4 mile question
- relocation brackets?
- Question about the 165R-15 Skinny tires
- [EVENT] Raceway Park planning an F-Body vs. all other GM EFI cars "Cival War"
- informative staging "101" article
- FLP Longtubes w/cats 1/4 mile times inside
- Heads and Cam w TNT SS goes 10.16 Video!!
- Say it ain't so....Fireball is doing weight reduction
- bfg vs nitto drag radiaals
- How to take off the ABS & Traction Control?
- Mounted my 28x10x15 Hoosier QTPs
