View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58
  1. what size injectors
  2. WS6 Fuel injector question
  3. Will this be all I need? LS1 fuel system in 97 car
  4. What do I need to make 39# cobra injectors work?
  5. Fuel System Pics
  6. is there any instructions on how to install a racetronic
  7. does bigger fuel pump need more juice?
  8. another question for Racetronix
  9. Are the 00+ fuel rails larger than
  10. Roughing in IFR for 60 lb Mototrons? (with fpr?)
  11. Stock Fuel Pressure?
  12. quick question about AN fuel line
  13. Difference in two injectors on websites?
  14. How big of a shot can I go???
  15. Anyone have any experience with these injectors
  16. Fuel pump wiring
  17. Maybe the fuel pump??
  18. External FP recomendations?
  19. Power capability of 43.5 multec II
  20. Is this Fuel-System related?
  21. Bosch 420 l/h inline questions
  22. Roughing in IFR for 60 lb Mototrons
  23. What injectors for 382
  24. What do Z06 28lbs. Injectors go for?
  25. need help with new fuel rail install
  26. Fuel system for FI
  27. Which is better? And why?
  28. Racetronix Fuel Pump was a smooth and easy install
  29. Weldon Pumps?
  30. what kind of injectors are these?
  31. V6 problems
  32. what size injectors, and which fuel pump???
  33. loud humming noise
  34. 100 octane ok to run?
  35. Exact fuel milage!?????????!
  36. help 95 3.4L raw fuel smell
  37. STS Fuel Injector Size
  38. Race fuel question
  39. Shrader valve question
  40. Camaro not running correctly
  41. Do I Need a Fuel Pressure Regulator at the Rail
  42. whats a good large low Z injector?
  43. fuel rails
  44. H/C Install, which injectors to upgrade to?
  45. Will the Racetronics PNP hold 650rwhp on juice?
  46. Boost Switch/Relay source?
  47. checking fuel pressure properly?
  48. 800 rwhp what to do
  49. actual rating for 2000 injectors
  50. how streetable? a1000 and controller?
  51. do I need injectors
  52. I want Race gas
  53. Opinions of fuel setup
  54. Fuel System Question?
  55. how to install injectors
  56. Walbro GSS392 versus GSL392
  57. What would I need for this set up?
  58. 98 tank into a 2000 = PITA
  59. What will I need
  60. TPI on a LT1?
  61. 450 rwhp, what to do to fuel system, what injectors?
  62. Sending unit is out.....
  63. What lb injectors to upgrade to????
  64. Anyone use Torco?
  65. Is thier such a thing as a high performance fuel filter?
  66. Which fuel pump is great for LS1?
  67. Does anyone offer a complete C5 fuel kit?
  68. Torco Octane Additive lab results inside
  69. What size is the stock feed and evap?
  70. Car died and won't start!
  71. I need a gas tank for a 98 Camaro Z28
  72. carb/ls1 tune port conversion
  73. Fuel injectors?
  74. ok I need instuctions on where to cut access panel on 01 Z
  75. programming
  76. car starting to over load
  77. Which brand of injector is best?
  78. Octane
  79. Where to get the 3M fuel injector cleaning kit?
  80. Fuel tank/cell install in bed
  81. Will Walbro GSL394 Inline 190lph Pump support 400 hp?
  82. C5 fuel pump---it is a Walbro
  83. External Aeromotive and Filter FOR SALE
  84. MSD Booster and racetronix harness
  85. help
  86. somebody with a 98 and intank pump
  87. Have a Walbro pump, not sure which one though, need help identifying
  88. Is this fuel system design any good?
  89. Summarize injector pro's/con's please?
  90. LS1 with no return line-Dead head pressure?
  91. Few fuel system questions
  92. Fuel pump questions... which one...
  93. Racetronix PnP question...
  94. Where can I get used Vette return style fuel rails?
  95. Return styl Vette fuel rail line sizes?
  96. Speed Density vs. Mass Air
  97. Injectors: need some help!
  98. NEED HELP-Injector install gone bad!
  99. Racetronix install ?
  100. Injector Impedance
  101. yes another inline walbro 255 question
  102. Whats wrong wiht my car. Video
  103. Best injector cleaners?
  104. racetronix
  105. forgot to cut the side of the fuel pump bucket out
  106. SVO vs Delphi injectors
  107. my new injectors dont match... help!
  108. 408 stroker? will 30lb injectors work good or not?
  109. Tried toulene. It worked great.
  110. Racetronix
  111. Racetronix Plug and play pump not doing the job!
  112. With Racetronix 99+ F-body fuel system, do you NEED to run the new harness as well?
  113. may as well go big or just big enough
  114. Do I NEED a bigger injector?
  115. What to do for fuel system, LT1/LS1
  116. External fuel pump question?
  117. Corvette fuel rail adj. FPR?
  118. How many of you guys have installed your own fuel pump?
  119. Racetronix No instuctions or diagrams?
  120. what aftermarket fuel rails are out there?
  121. Fuel Pressure Regulator Question
  122. What to do about my gas
  123. what fuel pump to use?
  124. Autometer AFR Gauge question
  125. Is this my fuel pump going bad?
  126. sumped factory metal tank and exhaust
  127. Need fuel pump for truck
  128. Racetronics questions
  129. Installed the Racetronix PnP C5 Fuel System...
  130. Racetronix ... have a question ?
  131. Have a few questions about a fuel pump and injectors....
  132. Does the t block have any restriction to it?
  133. HP limit of stock fuel lines?
  134. Fuel rails add HP?
  135. Please Help me with this fuel related problem
  136. Installing new Fuel Rails and lines, any good writeups anywhere?
  137. best fuel setup for..
  138. racetronix 270 lph is king
  139. Nasty Performance Gas Tank/Exhaust clearance/Safety
  140. Fuel system greamilins....
  141. I need a fuel pump. Which one and who sells them?
  142. Different 42lb injector
  143. Walbro GSS340 v. the GSS340M
  144. Does anyone use Cam II
  145. Racetronix ? from Customer
  146. Why dual feeds from sump?
  147. Would dual in-tank pumps out flow 1 in-tank and 1 in-line?
  148. No Fuel Pressure...WTF???
  149. Clear style fuel filter
  150. Fuel Pump Question?
  151. do-it-yourself dual pump 2.0
  152. Fuel System Questions
  153. Dual Fuel Pump and Controller
  154. Vortech T-rex question
  155. LS1 fuel tank for a hybrid conversion
  156. Do I need more injector 28.8's @ 470 rwhp
  157. Just fired up the new motor for the first time....
  158. RC Engineering 650cc injectors
  159. Fuel Pressure Regulator Problem??
  160. Inline vs. In tank fuel pumps?
  161. where can i find...
  162. New Shell V-power?
  163. Dual or single
  164. new supercharger - new injectors - have problems tuning - help??
  165. how much hp are 30# SVO injectors good too?
  166. 97 vett fuel regulator blew off help
  167. Fuel pump help
  168. fuel system failure causes boom!
  169. Stock fuel pump size?
  170. Will my old LT1 injectors work on a 99 v6?
  171. Fuel Pressure ?
  172. WOT Fuel Pressure??
  173. racetronix wiring harness
  174. tsp 231/237-heads-nos combo fuel sys
  175. Injector information needed
  176. multiple misfire code... fuel filter? fuel pressure? what could it be?
  177. Anyone use/using the Speed Inc fuel system kit?
  178. 440rwhp. Just upgraded to 30#SVO's. Now fuel pump?
  179. Racetronix 99+ installed
  180. Aeromotive Fuel pumps Who's using one?
  181. yellow top injectors? generally means...36lbs.??
  182. fuel problem or tuning problem?
  183. walbro installation on ls1 convertible help!!
  184. Fuel Pressure Drop! Help!!!!
  185. am i crazy on can this work?
  186. What connector for Fuel Rails?
  187. 98 vs 2000 pumps and evap
  188. 96 z28 hesitation
  189. Do these Ford 42# injectors plug right in?
  190. Anyone using external EFI pump instead of In-Tank?
  191. Race Gas (Wow)
  192. racetronix....got a question
  193. Sending unit off calibration!
  194. HELP!! Can't fill gas tank??
  195. would this fit an ls1?
  196. Racetronix 99+ Fuel Pump installed… First Impressions.
  197. Misfire after injector install?
  198. injectors for boost
  199. walbro inline
  200. Injector Size
  201. verification questions for 60lb mototrons?
  202. cross over line on custom rails, in the back vs in the front...
  203. Race Fuel users: fast question plz
  204. Question about aftermarket fuel rails...
  205. Injector Wiring Problem Please Help
  206. Fuel system needed for 700rwhp?
  207. Best fuel system setup for 427
  208. real quick fuel pump question
  209. Racetronix 98 Fuel Pump...no instructions
  210. Fuel pump install instructions?
  211. Delphi 32/37lb/hr Disc Injectors
  212. Electric Fuel Press Gauge
  213. Help-need pics of fuel return lines-getting ready for spray
  214. ? on carbureted ls1 setup
  215. Question for those with stand alone fuel systems.
  216. What fuel pumps are safe for use with E85?
  217. BAP Sensor
  218. Will a 2001 fuel pump work in a 1998?
  219. will i need new fuel rails?
  220. NastyPerformance Race Fuel Tank
  221. Fuel System Cleaners
  222. lost gas mileage
  223. fuel system in 03-04 Z06?
  224. fuel system for new cam and juice
  225. Tb Help
  226. what size injectors?
  227. How do I modify 94Z fuel system to 98+
  228. LS1 Injectors in LT1??
  229. inline walbro pump question
  230. fuel pressure guage question
  231. New 38 lb injectors installed: now B2 is lots richer than B1, what should I check?
  232. NeEd HeLp! Fuel pressure 20 psi
  233. Need help with Walbro inline wiring
  234. in tank hose??
  235. Injectors-When to upgrade?
  236. How hard is it to remove the fuel tank and what has to be done?
  237. Does running your car w/ less than 1/4 of a tank often, affect the life of the pump?
  238. Injector questions??
  239. Where to get an adapter for fuel pressure sender ??? Need today
  240. Locking gas cap question...
  241. 1000hp 1st gen Fueling help
  242. Need advice for 67 Camaro w/ 433
  243. How do I get and adjustable fuel psi reg for my walbro 340
  244. Maybe a tired question but.....
  245. Need help identifying an LS1(?) gas tank
  246. fuel pressure
  247. will these injectors work
  248. Gas Question.
  249. Powder coated fuel rail?
  250. Now more pressure!
