View Full Version : Drag Racing Tech
  1. Anyone making a 10point cage to FIT?
  2. what to do?...Gear choice for 385
  3. Driveshaft Loop for True Duals
  4. M/T DR 275/60/15 Vs. ET Drag 26x10x15 size for size?
  5. need to gain a tenth
  6. Put your screen name in your back window at N vs. S!
  7. my new best times tonight cam only almost 10's
  8. PSJ,can you enter my new 12 sec. pass?
  9. Improved a little bit more
  10. 11.08@125.47, 1.63 60' - TReX cam/stock heads
  11. Going to Lebannon Valley tonight
  12. Any ET/MPH guesses fo LS1 RX7
  13. Good list of stuff to bring to the track.
  14. Question about wiring a "race" car.....
  15. S+W 6 point pics anybody got them?
  16. Custom dash setups... I gotz q's
  17. What do you think I will run?
  18. Quick easy question
  19. New race set-up
  20. Slomaro is back
  21. results with my grand-am cup cam
  22. To cam or not to cam
  23. This weeks(6-12-04) race report NEW BEST!
  24. cheap trick for the heat
  25. How to launch an A4 with Nitto DR's?
  26. Saturday Nights at Rockingham
  27. Need some info??
  28. Good weekend of racing, netted 6's in the 1/8th
  29. mickey thompson or nitto dot tire ???????
  30. Anyone with Midwest 2800 stalls get in here!
  31. does this sound right?
  32. Twisted frame? can it be fixed?
  33. Need Help Now!!!!!
  34. Track times from 6/11
  35. Gotta love drag racing :-)
  36. FMS 346 SR- Shake Down Runs Complete
  37. Will SFC's help my 1/4 time?
  38. Roll bar question........??
  39. FASTEST LS1/LS6 (No C5R, AFR, or Iron block)??
  40. 231/237 PP"ls6" track times
  41. TEA 1.5 guys.. whatcha running???
  42. BMR vs PA k member: exact weights?
  43. So, lets get this straight. Whats better for a 1/4? AT or MT?
  44. Anyone have pics of Speed Inc.'s lightweight carpet installed?
  45. Will Front Skinnies Help with ET's?
  46. tubes or not with ET drags
  47. New best and some observations
  48. Lightest adj. torque arm?
  49. Rollbar Modification
  50. are et streets for me
  51. New Best!
  52. Finally hit 11s..woohoo
  53. if you crash on the strip...
  54. BFG G-force TA drag radial in the 265/40/18 size anyone runnung?
  55. What should it run???
  56. First time at the track, Best time i've had in a long time!
  57. First pass ever
  58. Guys running 10's, post your RWHP numbers and raceweight
  59. Will tracks allow me to run a 1350 carbon fiber driveshaft w/o a loop?
  60. A/C Removal?
  61. Looking for pics of swing out door bars
  62. 440ci with a 600 shot @3900lbs = ? ET
  63. Anyone running a gear higher than a 4.10 in an auto.?
  64. First time at the strip tomorrow!
  65. Shitty times for my first visit to the track.
  66. 10's Galore
  67. anyone ever weighed an aluminum seat?
  68. What the Hell is Madman Up To Now??
  69. Times on road surface
  70. Some Q's about Harness with 8 pt rollbar
  71. 1/4 mile strip in western WA?
  72. New times.
  73. Some 8sec videos
  74. ??Where can I get T-handle pins for my swingouts??
  75. 245-45-16 to 275-50-15 drag radials...
  76. mph improvement?
  77. Can the upper panhard be removed, if so, how many of you have removed it?
  78. Anyone have pics of the brace needed for race seats?
  79. Can the powersteering cooler be removed and if so, what are the weight savings?
  80. Lightweight carpet and seats.
  81. Tire Pressure for BFG DR's ?
  82. S&W 8 Point Rollbar
  83. My stock ls1 times at Milan dragway in Mich.
  84. Finally in the 12's on street tires...
  85. Our 1/4 results from NFME in Indy
  86. Gotta love drag racing
  87. New PB on street tires
  88. Summit Part number for Convo Pro skinnies?
  89. S & W racecars cages quality & fit?
  90. New best, but still not happy.
  91. Race Track says i need a roll bar. which one.
  92. help! my track times suck
  93. "Stick-on" dial in numbers............
  94. horrible ls1 times at track last nite
  95. 8000foot DA, does anyone
  96. help!! my LS1 running 14's all night!!
  97. Does this sound right?
  98. Barometer?
  99. My two 11.7 runs/ I can see where i went wrong
  100. Short time
  101. Not Happy! Any Ideas?
  102. Track day New Bests! (Video Inside)
  103. x-pipe to 3" dual bullets= how much HP&TQ?
  104. last video of my 11.5 pass--new best comming soon
  105. Would a gear change give me more mph or less? 3.46 to 4.10's
  106. 1/4 mile guesstament on my car?
  107. ET Guesstaments on my car?
  108. Line Lock Question....
  109. Launching
  110. Rim/Tire suggestions??
  111. Had a good night at Irwindale tonight! =)
  112. short belt part number
  113. Drag Shocks Hals or Strange?
  114. fastest ls6 cam f body
  115. PSJ can you add my time slip to the data base
  116. Trailer Brakes really necessary??
  117. What's the lightest/best working rear drag bar?
  118. front alignment specs for drag racing?
  119. M6 vs. A4 cars, which is heavier from the factory?
  120. Another hood post...
  121. What do you think of these for a daily driver front skinny tire?
  122. Does ride height drastically effect launch traction?
  123. Front tire pressure.
  124. Check out what is going to make me HOOK!
  125. Got a new best tonight 11.704@118.34
  126. North vs. South progress thread... just about 2 weeks to go!
  127. 1/4 mile speed
  128. drag slicks et streets or the new m/h
  129. Pic! Icon Z28 Rotating the EARTH!!
  130. Hal rears with + & -, what direction to soften up
  131. A recent underdog pic :)
  132. Coil overs on the rear?
  133. Gearing reccomendation for my setup
  134. What does it take to go 8's?
  135. how fast are 300zx twin turbos
  136. Does removing the air filter really help?
  137. Best gear and tire combo for 200-4R naturally aspirated?
  138. was wondering why my timeslip isnt posted
  139. Any problems fitting a kirky,summit or jegs racing seat in our F bodies?
  140. Guessing contest - how fast was this vehicle at US41?
  141. Help Picking 1/8th mile gears
  142. Why wont my car sixty foot???
  143. Project "Something Wicked"- Update 6-1-04
  144. Some Pics of My BatteryBox/External Switch Install
  145. what do you think my new set up will run
  146. What front ride height for drag racing?
  147. Upper panhard rod support
  148. Baro/humidity past Friday May 28th NJ or nearby ?
  149. 02z in the 1/8 mile
  150. EFA 4th gen Shootout results
  151. Anyone done lightweight carpet recently?
  152. Post your cam only best.
  153. Aussie quarter pounder video 10.53@131 NA M6
  154. My Results From Sturgis Drag Way!!!
  155. New best and tach question
  156. Has this ever happened to anyone?
  157. Are tubes hurting my 60' times?
  158. 11.26@117 1.48 60' NA Stock Internals
  159. 12 bolt and low 10s
  160. TR224 A4 cam only - track for 1st time
  161. mounted up some of the m/t drag radials today.
  162. New LS1 6sspd N/A record :)
  163. Not pleased with track numbers
  164. Mufflers straight off the headers?
  165. Panhard upgrade needed for the strip?
  166. Drag Shock Question
  167. Weather questions...
  168. First runs ever
  169. After 6 years finally broke a 10 bolt
  170. New Best 10.08@136.7 !!!
  171. Roman's gittin' faster ...sweeet! first pass 10.74 @ 129 mph!
  172. What psi to DRIVE on MT ET Drags?
  173. How is Everyone's North vs. South To Do List??
  174. Anyone close to MIR(EFA shootout tomorrow-29th)
  175. info needed on drag racing
  176. Too Much Tire?
  177. Question about rear swaybar
  178. Guess who's getting M/T ET Radials tomorrow.
  179. How to determine whether you need 1 or a pair of airbags?
  180. Stock Internal P/A car steps it up at PSN...
  181. Need draggin tips/techniques
  182. are my times correct?
  183. Adjustable or nonadjustable LCA's?
  184. Proper burnout with A4
  185. On average how much 60' gained with adj. TA?
  186. Some recent pics of my car 5.25.04
  187. Guys with 1.4X 60 fts I need help
  188. Probably shouldnt post this but.............
  189. 26x10.5 et drags on a 7 inch rim. how much will it effect my gear ratio?
  190. Burnout ?
  191. M&H 17" 275-50 --28" tall-will it fit?
  192. Need Help!
  193. 13.98 with no 3rd gear!!!
  194. Anyone running NX150 wet and TCI3500?
  195. Will my et's drop w/ new mods?
  196. Cut rear springs = still the same spring rate?
  197. Fit 29x13.5x15 Hoosier QTP DOT without minitub?
  198. Drag springs?
  199. racing a BIGblock
  200. Weather ?
  201. 346 + single power adder + 9 sec ETs???
  202. How much power to trap 116
  203. 3.73's or 4.10's
  204. don't know what to think??
  205. Let the WIFE drive the Hot Rod this weekend.
  206. 9's in an LS1 M6?
  207. Are there any LS6 Cam Track Results Posted yet ?
  208. Questions about airbags? (suspension)
  209. Has anyone used these Lakewood lift bars?
  210. New MT Drag Radial info
  211. Rear sway bar for drag racing.
  212. Camaro project front suspension pics.
  213. A New Member to the 10 DOH CLUB
  214. Stock Z28 numbers
  215. lexan glass?? who has it installed??
  216. Can my Trans take the pressure from my torque arm?
  217. Damned heat-only ran a 11.97@117.84 today
  218. Can heat cause this much?
  219. 231/237 cam only times
  220. TH400 vs M6 part 3 (results)
  221. Need some help/opinions
  222. Pin on hood. what kind of fasteners?
  223. Track time with our "Street Beast" Project
  224. Video by PhamtomTA of me at Hot Rod pump gas drags.
  225. Do I have a chance at 11's?
  226. My second time to the strip
  227. A few questions?
  228. First nitrous times.
  229. Changing diff ratio for mph trap.
  230. Launching w/aluminum flywheel
  231. Track times from tonight
  232. HELP: Slower Times after adding Mods???
  233. bad times
  234. PSJ, why does it take forever, for time slip?
  235. Questions about suspension setup.
  236. Bogart wheel pics
  237. New times for the z
  238. Al Corda #7 in Joliet Ill
  239. New 1/8 mile best
  240. Guess my ET............
  241. New best at Irwindale Speedway!!
  242. What does it take to hit 11s on stock internals?
  243. anybody broken the stock flexplate?
  244. 99z-28 Vs. 04 Cayenne Turbo
  245. Take your guess!
  246. Question regarding tubes and rim screws
  247. Anyone go to the SGMP or the Silver Dollar?
  248. Why am I so slow?
  249. question about 1/8 mph and 1/4 mph
  250. Anyone headed out to Irwindale Speedway tonight?
