- How to calculate difference in .004 to .006 Adv Dur in a cam specs
- Port size vs. Flow Potential???
- I Beam vs H Beam
- Morel lifters and preload?
- Nitrous on engine that uses Alcohol
- Compressor back-pressure from twins?
- Help me with a oiling system
- Optimal Ring Package
- If you have an engine that is compression limited(low) can you still make good power?
- boost as a linear equation
- What's the rationale behind this?
- air distribution
- diffrence between??
- TSP SR 408 helped needed
- How DA affects Compression?
- What are the advantages/disadvantages of longer connecting rods?
- Valve spring locators, to use or not to use?
- Multiple TB questions
- mechanical vs hydraulic clutch physics
- compression test question
- Detailed Cam Spec Determination ?'s
- Knife Edging Cranks?
- Valve Spring Life vs. Lift
- How to make torque at higher RPM...
- Combustion Chamber Size Versus Piston Dish Volume for a Fixed CR
- BMW Direct Injection Engine
- New GM Hydra-Matic 6 speed RWD Planetary Manual transmission
- Strokers and Oil Consumption
- fast 90 mm intake question
- When does the bore of a 5.3 liter vortec start to hurt headflow?
- Toluene
- peak rpm
- Aluminum VS Steel Frame
- Designing optimum runners and plenum?
- Pump gas cam vs: Compression, Cylinder Pressure, Timing, etc.
- possible to change the firing order?
- Water temp w/ flow restrictor instead of thermostat
- BIG Power Questions: Small/Big CID? NA/FI Setups?
- Why hasn't VTEC been adapted to pushrod engines?
- Using boost pressure to increase exhaust velocity.
- How Boom tubes work?
- Gasoline VS Diesel Engines....
- Cryogenics
- "CFM vs Horsepower"
- How little quench with Aluminum block & heads
- Piston speed, Displacment vs HP?
- Miller Cycle engine
- New Gun Engine, real or no?
- How does 94 Octane gas with 10% methanol affect your performance?
- What happens on in gear decceleration?
- Running surface - Lifter / Cam
- Fast intake improvement
- Whats the leanest one of these LS1 can physically start/hold idle?
- Intake Manifold info needed...
- Effects of preloading frame during SFC install
- How does pinion angle adjustments help in terms of traction?
- Valve Material Question For 2.200"+ Valves
- downside for extra stroke
- Effect of Lifter Diameter on Ramp Rates
- How do YOU explain "area under the curve" ?
- Port flow and velocity questions
- Bruce Crower's 6 stroke engine
- Line of action & torqe arm mounting location
- Lightest Rotating Weight 4" stroker combo?
- What determines engine redline?
- Cam gurus inside
- direct injection
- convert from water to mercury.
- Phenolic Carb Spacers for Victor LS1 EFI
- turbo idea
- Header Primary Size Mathcing w/ Cam and Heads
- Ls1 specs for mathematical engine model
- Need octane? At a moments notice?
- How bout an Advanced Head/Cam type guide?
- Volumetric Efficienty
- #7 Piston Failure FIX !!!
- Help!
- Fluorescent Wet Flow Testing (cylinder head)
- vic Jr versus Standard intake question....
- F1 style transmission?
- Reversion and turbocharging
- Air volume:intake vs. exhaust
- Exhaust Sound - What are you hearing?
- Header Modifiaction to Reduce "Choke"
- Intercooling taken to the next level
- drivetrain loss in relation to rwhp?
- Do Belt Cam Drives Add Horsepower?
- Bricklin-Turner Rotary Engine
- LS1 Oil Pump Pressure Relief Study
- Milling Heads Versus Air Flow
- Rocker Arm Geometry
- Piston Rings and Their Placement
- Oversized valve stems?
- Valve idea
- valve spring pressure discussion
- Offset Pin Pistons and On-Center Rods
- How much, if any, of the combustion chamber should be in the piston?
- How to figure optimum DCR?
- Fuel Vaporizers and Super Carbs...
- Anyone Entering the Engine Masters Challenge?
- LSX Cad Model
- 5 questions rattling around in my head....
- Valve seal Material
- water assisted engine!
- Piston material
- 105mm TB and 90lb injectors
- Injector timing relative to cam angle
- Mikronite gears
- Figuring out if a cam is twisted
- Ram effect
- Manifold test on AFR 225
- Stoichiometric question
- Connecting Rods- On center?
- ET Splayed / Canted LSx Heads
- Question About Tuning ITB Manifolds
- Tapering the exhaust piping to keep exhaust pressure up
- LS1 engine builders/assemblers: Installing cam bearing question...
- Intake TB combo for high revving 347
- Interesting Crankshaft Technology Article
- Aerodynamics
- Vehicle dimensions?
- Question About Solid Roller Valve Springs
- Bore & Stroke Limitations (forced induction)
- Exhaust gas temp's influence on turbine speed
- Why is negative crankcase pressure hard on rod bearings?
- Boost as it relates to relates to port air-flow characteristics
- ceramic coating of the combustion chambers
- Knock Sensors....
- Teach me about Fast Burn Combustion Chambers
- Reversion
- SAE technical paper on how mass air flow sensor/meter works
- Fastener Selection
- Power from Forced Induction
- What accelerates an engine?
- how brakes work
- What kind of testing would you like to see?
- Valve Spring Retainer Fitment/Tolerances
- Proper way to test compression?
- Was is the advantage of a 1.7 intake rocker and 1.6 exhaust rocker?
- LS1 dry sump help
- main bearing clearance hmm
- Advertised duration v. .050 duration
- Reverse split cams
- question abou exhaust port shape
- Effects of piston speed.
- Benefits of a 32 valve heads
- Can you build a 8,000 rpm LS7?
- Dcr-scr Compression For Cams Help
- Importance of high lift flow vs mid lift flow for power
- Engine Braking
- Vacuum build up on start.
- Aftermarket Casting VS Stock Casting
- Trying to learn more about my old setup.
- Piston thermal barrier coating
- Short vs long air intakes... a few q's...
- Can someone explain this to me?
- The Little Power Gains
- How much exhaust pressure is there behind the muffler?
- Fantastic Magazine (A MUST read with lots of Advanced tech content)
- Lilfter Preload vs. Pump Up
- Three angle valve cut - Where does seal actually occur
- Need Exhaust Flow
- instantaneous piston speed?
- Optimal Clearances for Different Setups
- Intake design
- What's better for FI LS1, Hi CC Low DCR or Low CC Hi DCR?
- Combustion Chamber Width
- My 1st post in Hcore. Using 2 Lunati grinds as examples, help analyze (springwear).
- Converting to Methanol
- Valve OAL Question..
- optimising fueling vs timing
- Valve shrouding
- question about gasoline direct injection theory
- "Advanced write up" request
- How do you calculate how much seat pressure you need?
- Effects of different cam centerlines on performance
- Desired Compression ratio for nitrous??
- Nitriding Valve Springs - Daily Driver
- Anyone have LS1 file for Dynomation advanced?
- Valve train Q>
- Measuring Bearing Clearances - Help
- Displacement vs BSFC range
- Help with Dynamic Compression Ratio
- Engine Rotation Direction
- Advanced Book Selections
- Official: Volumetric Efficiency
- Converting CC to ML?
- How does the intake manifold "work"
- Ping, detonation vs. engine load, GenIII motors
- Flycutting Mayhem
- Another "Does anyone still use this old hotrod trick?"
- Does this old hot rod trick work or is it just a myth?
- Internal Combustion Engine basics, mainly airflow vs TQ&HP
- LS1 Reverse Cooling
- cylinder pressure
- Dynamic Effective Compression Ratio
- Piston "side play" question???
- Valve Spring Component's
- Weight over the lifter verses weight over the valve?
- Pistons with Lateral Gas Ports?
- Difference in horsepower production and cylinder pressure...
- Miller Cycle Cam with big twin screw blower?
- Crank Snouts
- Figuring Cam Overlap
- Head EI vs. Cam Duration
- Advanced Reader Poll
- Dynamic compression..
- Valve Tech
- HP gains from blueprinting alone.
- What about these clearances??
- Displacement formuals
- Carbon Fiber Driveshafts
- CR, Squish and Octane
- What is reversion?
- Cam Lobe Question
- How important is Exhaust diameter
- need help with car
- piston-wall clearance
- Is there an Optimal timing for overlap?
- Rod/Stroke ratio and other questions
- combustion in chamber or piston?
- Air: Fuel, Emissions and spark timing.
- Size Variance in Exhaust Ports?
- Ok, how about electromagnetic valvetrain
- technical power differences from 4* ext. duration
- One + inch of tire diameter = ratio?
- Desmodromic?
- Questions on Reversion
- Bore materials: Steel vs Nikasil (or chrome)
- Overlap, how much do you need?
- Cylinder Head Degreeing Question...
- Taper in cylinder bores
- Cast Iron Versus Aluminum Torque Plate
- Port volumes vs port cross section area
- How do NASCAR engines make 750+HP?
- Two must reads for advanced engine heads
- I got a good question for you cam guys
- Software Packages
- Material Selection
- short deck
- How ICL effects power on cams
- Heads... Intake and Exhaust Port Surface Texture
- What is this forum for? PLEASE READ BEFORE POSTING!
- A new way to check P/V clearance?
- Rocker Arm Round-up
- What Runner cc for stock cubed ls1
- How the MAF really works
- Cubic Inch / Nitrous ratio...
- Tuning Docs, VE/MAF, SES Lights, FAQS + more!
- How does increasing exhaust duration and lift affect the torque and hp curves?
