View Full Version : Carbureted LSX Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11
12]
13 14 15 16
- Out with LT1, in with LQ9
- Odd misfire
- Heat soak
- Testing New Combo today
- best carb for a stock ls1 ?
- Best tranny controller for carbed LS2/4L70E?
- Can't get outta the hole... Carb help needed
- carb/ cam only ls2 guys...
- Check my math please ?
- I'm Running a Q-jet on my 5.3 and Love it
- LQ4 Information Pleaes
- Pro Systems Carbs
- Valley Plate?
- Will a stock LS1 cam pull too much vacuum at idle? Swap cam for carb application?
- Does this look right?
- Could this pinched O-ring on the oil pump pick up have caused a spun rod bearing?
- 6.2 cam only 250 shot on a fogger**time slip added**
- Fuel pump location?
- 6.0 Blow Through
- LQ4 carb size
- 2001 mustang saleen need custom harness!
- 5.3 carb or fuel injection
- Can't get my LS2 to idle!
- fuel pressure issues
- 6010 - Battery disconnect
- Streetknight's Fox Build
- help with nitrous tuning
- Good news and bad news......
- Ls & lsx?
- Sealer needed on intake bolt threads?
- can a Super Victor work on LS3 heads?
- wtb carb'd intake and msd boxs for 5.3
- DMMizell LSx copy's
- Fuel Line Question
- Stock flexplate or SFI
- Cam sensor extension harness sucks
- ARP rod bolts & resizing the rods.
- holley dual carb intake
- Is my 2002 ls-1 1st design or second design?
- Yay, nay?: MSD controller for LS efi...
- LQ4 Questions
- Push Lock Hose
- i thought you carb guys might like this!
- Super Vic + Carb + hat under stock SS Hood?
- fuel pump issues
- ultra hp tuning
- Base Dyno Pull - Results
- On my way.........
- approx. Hp Tq
- New 408 tuning
- S-K Speed.....
- MSD question....
- Who has the Holley Modular Hi Ram?
- any gain switching to carb
- Is .030 alot to turn off the crank?
- MSD 6010 MAP setup?
- LQx with a carb look but EFI
- What engine assembly manual
- ls1 850 or 950
- wiring my f body alternator carb ls1
- who make summitracing carbs?
- Intake manifold help
- Stock LS6 dyno numbers....
- Damaged the RS today
- What caused a spun rod bearing?
- 98 camaro racer
- help with msd cable lol
- Air cleaner assembly help....
- Fuel pressure drop ??
- on the fence about going carb on my LQ4
- MSD 6010 wont rev passed 2200rpm
- 5500 car falls flat on face
- Wiring - EFI to Carb
- Question for guys running a 750 holley
- Custom Cam for Carb Setup
- Project 427 bagged daily driver
- ***FOR SALE THREAD for Carbureted applications *** NOTE: New Rules!
- msd 7531 and coil per cyl?
- Super Victor fuel distribution issues
- LS Carb for sale section??
- MSD 6010 No start...help.
- quick question bout 6010 and wiring with NO progressive for tach output
- Oil pressure sending unit adapter
- Carbed L33 jet size question
- Test drive
- A/C with a carbed LS setup
- its alive again!
- Mustang Coupe LY6 swap BRP mounts
- What size carb for stock LM7?
- 91 s10
- msd to computer cord
- going to wheel dyno tomorrow any guesses???
- Why are people putting their Carb on backwards?
- 1rst track results for the junkyard dog
- THIS close to driving...small prob with TV cable bracket?
- Fuel pump recommendation
- throttle cable are you using on f-body cars
- Little help with tuning...
- carbed 402 questions
- Hard starting when warmed up?
- MAP sensor?
- Carbed LS1 for the street....which carb?
- edelbrock 71187 intake
- 86 Blazer LS2 build
- Hard start
- Popping off the line?
- Black Black plugs....
- pushrod length help
- plugs?
- Dominator vs Ultra HP
- Best street LY6 carb intake?
- wideband question
- My LM7 build into a 1994 Silverado
- MSD 6010 and 4th Gen tach
- Need help!!!!
- Msd 6ls question
- Temperature
- stall speeds
- Need some help Carbed 4.8..
- Victor JR L92 Intake Question
- You are the weakest link....
- does msd 6012 come with this bracket?
- PCV help
- Would t-rex cam work?
- My next LS carbed swap, what do you think?
- LS3 intake rocker question
- Wiring help on fox carb swap
- anyone have a spare 6012 box?
- Try to talk me out of this
- What fuel setup?
- what do i need to buy for swap ?
- How to wire up Alternator
- Ok I searched, but wanted your opinions.
- Fuel Line Location
- Holley 850 dp too BIG?
- msd 6ls2 up in smoke
- New best
- proper carb
- Rocker Suggestion
- HP predictions of 6L
- a little carb advise
- 83 regal 6.0 swap. need wiring help with alternater????
- Dyno Testing the 346
- new best
- LS Combo
- Carb jets, accel. pump, power valve. HELP PLEASE
- Carb'd Fuel Injection Style LS7 Intakes
- Time to make the call!!!
- wtb - super vic intake
- Another wideband thread
- fouling plugs
- help: cam for carbed vs cam for EFI
- lq9 with 700r4
- Who's got the big cubes
- Tci 399753
- Carb hat/plenum vs air cleaner assembly
- 10.86
- Advice on baseline tune
- Need help, my 6.0 build just took a turn for the worse.
- New best for my cam only carbed lq9
- well it is going to happen now.
- 6ls help please
- best plugs for my setup
- Power Steering Pulley
- progress so far on 1st build
- LQ4 stock balancer?
- Blo thru on lq4
- E85 Carb on 2000 Z28, help please!
- 5.3 cam quest
- in car video at road race track
- any one using a ms4 or tsunami in carbed lq4
- MSD 6010 No start
- Whos using the BRP conversion kit for A-body, alternatives?
- anyone have any pics of ls in a
- Anyone running a cam only LQ9?
- Temporarily plugging outlets on a Holley dead head reg?
- Carb 6.0 chevelle Help
- blow through power valve issue
- big disapointment
- Holley HP750 DP Street
- 01 mustang with stock intank pump .. need some help!
- 2005 avalanche 5.3 into an 85 K5, What do I need?
- Super vic carb on a efi intake help
- 06 truck 5.3 carb questions? no p/s, no a/c.......
- Demon carburetors
- Porting my Victor Jr
- Oh no, another What size carb? thread!
- Ly6?
- Anyone using the Edelbrock MSD module?
- where should I set the rev limiter?
- 5.3 LS with Carburetor in 63 & 77 Nova - Hood Clearance ???
- Cost of going carbureted?
- carbed LQ9 video
- Carb'd LS build for dirt track (lots of pics)
- Best cam for ls 383 carb...HELP
- attempting to get 400rwhp out of a 5.3 in my '95 z28 without breaking the bank
- maryland emissions 98-02 F body
- Carb'd 6.0 MPG
- What will a stock LQ9 do? Here's what.
- Carb'd LM7 into 1994 OBS swap questions
- rpm manifold on truck motor, steempipe?
- couple of ?'s: what programmer, what cfm carb
- What tires are you guys running on your street rods?
- Mounting Holley pumps
- New PB
- 364 to 402
- what intake gasket l92 victor jr?
- What do you use for a water pump?
- Vacuum pump
- Potential Carbed Ls build, lots of questions...
- Help me Build my Carb Motor
- Fox body guys...how did you run fuel system?
- Efi vs carburetor .....who deliver more power?
- Is 2-1/4" exhaust too small for carbed 5.3 with cam?
- L92/LS3 guys, what gaskets?
- Thoughts?
- Jetting set ups?
- Aaaah! This damn noise.
- Losing fuel pressure after hot
- BMR or Wolfe engineering
- 383ls 425 rwhp but olny 365 lb/ft
- PCV location
- Intake Gasket ?'s....
- cam votes needed
- Looking for LS3 heads ?????
- Carb and manifold recommendations?
- knock sensors?
- Any of you run a carb spacer?
- ls motor in 86 Iroc coolant sensor/water temp
- another ls newb with questions
- changing balancers
- finally got er fired up!!!!!!
- turning up fuel pressure
- Nitrous on carbed LS3
- ls newb needin some help
- 5.3 swap into 85 Trans Am
- What thermostat are you running in your carbed LS swap
- pump gas comp. ratio w carb
- 10.99 or burn it
- another ? on LQ4 build
- Plugs for a LQ4!!
- LSx ~ old school gauges??
- DOD and cam questions
- How to find a good hooker?
- who is running 40+ low load total timing
- Msd box
- Hood clearance/ 4th Gen conversion
- New ZL-1 Camaro times!!!
- lq4 build carb size?
- Super Chevy april issue
