View Full Version : Carbureted LSX Forum
Pages : 1 2 3 4 5 6 7 8
9]
10 11 12 13 14 15 16 17
- MSD 6010 6LS Ignition Box $275 Shipped - 2 Week Sale
- Time to tweak n tune.. Where to start???
- Mallory fuel log
- custom timing curve
- Need a timing curve...
- Carb'd 5.3 build...cam question
- 6.2l
- msd 6010
- fuel delivery
- Ls swap
- Edelbrock vs. Holley LS2 dual quad intake
- Pics Of my Junk....
- fuel pressure question.
- newLunati Voodoo LSX kit
- pushrod question
- Help @ thoughts on LQ9, 408, Vic jr, CNC LS3 head combo
- thoughts on my 408 LQ9 carb cam combo
- anyone willing to chat carb with me...
- Going Lq4 and need advice
- Finally started have electrical gremlins
- Base tune?
- 79 ls bu ... It's alive !!! VID
- Timing pills ???
- Msd 6010 grounds ???
- edelbrock pills
- Dyno numbers..
- New guy needs help with computers
- MSD 6010 problems..again! READ and HELP lol
- what thermostat are you guys running ???
- Build my 5.7 or go 6.0??
- msd 6010 ???
- Carb'd LSx into '64 Corvette Roadster (Build Thread)
- Need to get a reluctor installed in Western NY
- burnout competition winner! New competition new vid!
- new fox combo
- ls2 with 6010
- Finally completed my heads/cam swap
- MSD 6010 2-step question
- Dallas/FTW area 7-28/8-2
- Carbed lq9 cam only
- Help me set my MSD timing/MAP table
- Bent reluctor
- Looking for the right carb for your setup?
- Carbed 4th gen cowl
- valve springs
- lq4 build
- 5.3 carb intake questions
- good day at track
- run a return or no return
- Engine height question.....
- Red cam shaft drive spacer
- better gas mileage
- Holly Red fuel pump ???
- First passes...video. Need some advice where to go next.
- Finally in the 9s!
- What distributor gear with GMPP front drive kit?
- Holley red fuel pump ???
- Bigger secondary jets??
- Finally made some dragstrip runs
- Needing ls swap advice!
- carbd sprayed lq9 cam recommendations...
- Carb + stock ECM?
- Track results
- Extension harness needed?
- 1988 Camaro IROC-Z 5.3/4l60e swap
- Need some input on build
- First Gen LS conversion from 500ci BBC questions Lq4/408
- loose bolt
- LQ9 H/C = 10.85 @ 125mph 5000ft DA
- MPG estimate needed
- thinking of swtiching to carb
- Someone please tell me I'm being ridiculous
- L-33 carb'd build up (lots of pics inside)
- 408 specs and start up HP#'s???
- Ditching EFI for victor and carb? Ls3 camaro
- 4L70E controller ?
- Cam Break in.
- Wegner water pump questions
- are you carb guys using MAP sensors?
- l4q carb conversion setup suggestions
- 5.3 s10
- How many cranking amps do you need!!! Msd 6010
- 6010 info
- carbed 6.0 lq9 vs c6 z06
- New to Carbs Need input please
- L92/LS3 Dual Plane
- Map sensor
- Cam opinions. Lq9 build
- Quick carb conversion question. Price
- Proform 650 race carb
- Crankcase pressure....
- wtb quickfuel 850 carb
- gz motorsports has anyone heard of them
- at what point is a vac pump necessary
- Blew mufflers open?
- Carbed L92 engine-which front and rear covers
- Throttle cable
- PCV for my carb setup
- LQ408 First start up
- Budget build reccomendations
- spark plug help
- What fuel pump are you using?
- More left to do...
- Ms3
- MSD box....
- Problem fixed!!!!!! VID ADDED
- Gmmp intake gaskets? Part #?
- Do I need to re-stall convertor going from ls-1 to a 408?
- 1st outing
- First nitrous passes
- 6.0 lq4. eddy 2215 what kinda hp?
- Need some input
- high compression 370
- DOWN goes a Mustang!!!
- msd box wiring question
- Left bank going lean with Edelbrock Performer RPM LS1 manifold?
- Alternator charging question
- 5.3 to 5.7L LS1
- lq4/lq9
- GMPP Dual Plain Picture
- edelbrock box vs. msd
- ok to mount street/strip fuel pump upside down?
- New PB
- ls1 heads cam ls1 carb th350
- carb tuning issues HELP PLEASE
- Tuning help
- External Fuel Setup
- Carb and Cam Selection Help
- Anyone have a nitrous carb plate they'd part with?
- what intank fuel pump to use
- Track trip coming soon. Estimates?
- New engine for our CP car
- U carb guys ???
- New best for the ole mustang
- Edelbrock 7118 on 06 TBSS LS2 HELP
- 408 build
- holley hi rise intake
- Warning!!! MSD 6012 owners
- Damn MSD 6010....no spark!
- 1980 Zephyr Wagon!
- Carb and ac?
- 408 carb suggestions
- Going carb... No more plans of boost
- Fuel Pressure gauge accuracy?
- Warm start problems
- Dynoed my truck today!
- idle engine speed
- 85 iroc ls2 t56 swap
- Carbed LS swap guys, a few cooling system questions.
- First trip to the track
- 86 c10 5.3 build
- TEA stage 1.5 heads (862) casting on a stroker
- Building a Stroker 383 or 408 ?
- looking for people running with e85
- Thermostat and fan temp setting questions
- what carb and headers size?
- what carb intakes are available for l92 / ls3 heads?
- lsx 454 cam in 6.0?
- Help me choose my N2O
- sprayed for the first time.
- Edelbrock 7118 ignition box tach signal
- blow through s480/370ci which intake and timing box?
- Help ls1 carb tuning
- Cam suggestions
- Who is runing an oil cooler?
- MSD 6LS-2 failure
- Is an 850 too much carb for 5.3?
- LY6 with Z06 cam and carb questions
- intake bolts ???
- Cranking compression?
- Help figure out what knocking noise is
- TA 1/8th mile results
- rods for stroked lq9
- Help Troubleshoot my Fuel System Problem
- Holley carb and 700r4 TV adjustment question
- Going carbed 5.3 in a 91 Mustang??wiring and fuel lines?
- Stainless collector bolts?
- What are these heads worth?
- looking for a company to spec cam
- well i left the carb setup to be
- LQ9 Mustang On Spray Results!
- MSD 6010 timing with Carb'd LQ4
- Pan drop for a cam swap?
- lm7 fan same as 4.3?
- Porting the vic jr.
- Combo decided !!
- Spark plug gap
- Need MSD 6010 tuning disc
- DFW area Carb & Timing tune needed
- tuning insight
- Gauge Help
- EPS 222/226 in a carbed lq9?
- Little bit of smoke?
- LY6 Build - VVT with Carb?
- exhaust is on vid
- AHHHH! What to do?
- carbed lm7 no spark
- Please assist carb tune.
- wideband questions
- Injector plugs
- cam behavior, carb vs efi?
- what horse power?
- Popping through intake while revving
- LQ9 Mustang Track Results......
- backfire/ pop thru carb or exhaust, mostly exhaust
- LS7 rocker arms
- carburated lsx mpgs
- Blow through carb help
- what gear to run?
- Expert Carburetor Advice needed
- 04 5.3??'s
- Test ride....
- What kind of RWHP should I expect this combo to make?
- What carb..CFM....make and model???
- LY6 Carb engine HELP!
- Carb conversion?
- Afr / jetting
- Header Question
- valve spring help!!????
- First time with it at the track!..
- The long awaited....first ride
- first fire trouble...
- Need help....
- track time equal bad driver!
- New best
- Carb'd lsx 434 build.
- Carb'd crate options
- 6.2 stock bottom end new best all motor
- dual plane with spray
- do you think this is going to beat a diesel?
- Ive been thinking bigger cam
- I'm going carbed, what am I getting into, need?
- 6.0 Carbed cam Needed!~
- Super Victor Guys
- newbe...not sure where to look now!
- Add tail pipes, added 4 mph
- 1993 Mustang Coupe, 6.0+Nos. Looking for 9's (video added)
- Speedtigger wins True Street.
- my 6010 tune
- LM7 w/carb'd intake and Edelbrock carb/700R4; throttle bracket WTF's?
- 1952 Dodge Truck Street/Rat Rod Build
- cam what u guys think of this cam ???
- milling choke horns
- gen IV carb question
- Quick plumbing question
- Engine diesels after shut off..help!
- 5.3's only...
- 2 questions plugs/carb
- Mix emotions on Pump shot sizes.
