View Full Version : Carbureted LSX Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
16]
17
- Holley HP Upgrade Kit
- Did you degree the cam you installed?
- 1970 Camaro: Carbd LS1 Build Thread
- Newbie
- Cam Theory: 6.0 LY6/ 6.2 L92 with exhaust manifolds
- L92 Edelbrock Vic JR gasket
- Where I'm coming from
- percys adjust a jet
- L59/ flex fuel
- 1966 nova with stock 6.2 100hp nitrous 7.01 1/8 mille FOTOS
- 232/236 114, Work with SV?
- Distributor with electric WP, how to mount alternator?
- Another Fav Mag article
- ???POLL - Age of guys doing carb swap LS motors???
- Check out October 2010 Car Craft
- Performer RPM VS Victor JR Dyno test
- Why or why not carb intake w/elbow?
- Popular Hot Rodding Engine Shootout
- has anyone used the fast xim with a carb
- need your input timing
- New Intakes?
- 6.0 Litre, L92, Cam selection, Max Power
- Budget Carbed LS swap info
- An Interesting LS1 Dyno Comparison on Annular Discharge.
- Carbed 69 camaro eng/tans combo help!!!
- heres a quick run down of my carbed setup
- Big grind cam
- WTT MSD 6010 for 6012
- Do u know anything about the carb EFI manifolds? If so give me some answers pls .
- ls mustang suspension help
- oil pressure sending unit
- engine buildup suggestions please
- LS1 Front Drive Distributor Cover
- Aor fuel ratio talk
- MAP sensor part number - what are you running?
- Stock LQ4: 750 proform HP tune up needed
- Converter setup right for carbe 6.0l
- 71 Chevelle 5.3 Carb'd Build cam recommend
- carb ls1 help
- Coolant Crossover Tube - Can I Toss It?
- Fuel System-What are you guys using?
- i am looking for an intake for an LS1 motor
- sigle or dual plane
- 6.0 mustang budget build
- 6.0 mustang
- Identify This Carburetor
- What spark plugs are you L92 headed guys running?
- Are these the right bolts?
- what spark plug to run
- what do i need to know?
- How do cams differ for single plane vs stock style?
- MSD 6010 question
- 06 GMC Sierra 6.0 Carbed
- decals
- how much timing for 6.2 carb?
- tire suggestion
- 650 dp on a 346
- Cam selection????? 5.3l
- New NOS Cheater kit
- ls383 turbo 400 into a 91 mustang
- cold start carb problems?
- Which carb for me????
- newb question lol come on in
- Need New cam
- intake coating
- 6.0 lq4 carb block 243 head vs l92 head
- Carbed LSx in a 4th gen
- TKO-600 and 6.0 whos done it?
- Carbed LS setup suggestions plz...
- lq4 6.0 valve springs
- msd carbed 6.0
- Crank sensor voltage??
- Edelbrock carb cam?
- lq4 hp
- O2 sensor question
- Who uses the distributor conversion for LS motors
- Does anyone have any experience w/ this elbow?
- new numbers for my nova 66 stock 6.2
- what to do now? had a problem..
- rpm shift point for stock 6.2 carb
- how to wire ls1 fans with no ecm???
- Quench and compression
- What kinda power?
- What fuel pressure when going carb?
- help with gauges
- Something a little different
- F.S. Holley 1000 CFM HP carburetor/carb (can be 830cfm) LOWER PRICE ! SOLD !
- 383 boosted setup input please
- spark plug gap for 100 hp hitrous
- Need some help with lq4
- SV-1 with 2004R geometry corrector bracket
- Converting 2007 LH6 to carb.................
- how to make an electronic quadrajet work without computer
- Stewart/Wegner water pump heater hookup
- Useful Carb tuning books? Recommendations?
- intake question
- need help on my lq4
- Serious MAP tuning help needed...
- Predator Z w/ carb set up.
- Guaging interest on a potential product
- Intake stud bolt kit
- L92 heads+Trex=?
- venting questions PVC
- Carbed lm7 swap
- 66 nova stock 6.2 12.11,109 mph without tunning carb
- 4.8 or 6.0
- Has anybody ran this on thier car
- what to do
- need info about conversion gas to E85 fuel carburated
- carb selection 600 HP LS2 please help!
- Would you run this cam in your MOTOR???
- 86 Trans Am project
- What is the foam for in my intake gasket kit?
- Fan controller
- anyone trye with a 6.2 with a carb how it work on the track?
- Is an intake manifold gasket really $100?!?
- What's the best way to clean out my fuel system?
- Dominator on a LQ4
- Whos runnin the Super victor
- new best ET.
- Bogging off the launch
- cam for ls3 engine
- OH CRAP, I think a washer went into intake??
- 9.4 @ 140...carb/dist/pump gas/all motor
- What fuel pump
- 5.3 or 6.2
- Turbo Import vs NA LS.....
- L92 Victor Intake - Who's got them for sale?
- What exhaust are you running?
- MSD trouble shooting
- LS2 with MSD wont start - HELP
- Riddle me this? 6012 + 4x and 2x cam sprocket
- dist. housing
- 6.2 carburated
- I need a little tuning help.
- 6.0 carbed mpg
- Camshaft Tech Questions.
- vic jr or performer rpm
- Keep cam or change?
- 383 ls1 vs 402 lq9?
- Ct525
- Parts Classifieds
- what's the deal on pricing
- 5.3 buildup for lightweight autox car
- G.M L-92 dual planes
- lq4 alternator wiring
- FS: Edlebrock Vic jr carb intake/ MSD 6LS 6010
- Got called out last night...
- Yes, another cam and carb selection post!
- coverting to a carb
- from efi to carb
- 119mph TOP END VIDEO!!!!
- AFR, Trick Flow, or Texas Speed?
- trouble getting my demon to idle
- Front mount dist. question
- Pro-Street LS3 Power?
- New times with the 6.0!
- Back to the track with the LS3
- l76 to carb questions
- Guys who have 50cc accelerator pumps
- Msd 6010
- LQ4/L92 with Vic Jr/carb cam
- My carbed ls3 stroker
- Are you running a pvc system?
- Looks like my 65 Skylark is more Phat than Fat!
- What is a ballpark A/F ratio to shoot for?
- coil problems?
- Knock sensor?
- all set for saturday
- any carb'd LS's on alcohol?
- Holley carb intakes!!
- What kinda power is possible with this setup
- What Valve Springs to use with Trex
- last trip to the track
- what cam for lq4 with ls3 heads,vic,jr
- 2nd stage
- Street traction
- Some new bests today
- NO LUCK w/search or Sponsors about my intake set up, please help!
- cam for 5.3 and vic jr?
- What Cam to use with victor jr.
- billet water pump spacers
- msd 6010 issue?
- Victor junior VS g.m.p.p single plane
- carburetor problem
- EFI vs carbed timing
- Dual plane cam pick.
- To cam or not to cam...
- Map sensor
- Track tonight
- carb set up
- Any issues using a 2005 5.3?
- Daily boost driver eng.
- lq4 with ls3 heads.what ignition?
- carb success..just do it, u will be happy
- new times with cool air
- AED vs Holley vs Demon.
- LSX 376 HP increase help
- Taking the 89 for a spin...
- Tail of two carbs - Time will tell.
- psia vs vacuum chart
- LSX blow thru setup
- Carb and stall advice...
- carb ques.
- Got some track times for my carbed setup!
- DYNO Results are in!
- Carb stumble
- L-92 dual plane motor
- LQ9 Carb L92 Heads noise up top
- Fast list for Stock bottom end LS's
- Is There A Super Victor For L92 Heads?
- Comprehensive EFI to Carb list?
- carb on a 5.3 DOD engine,is it possible?
- 346 in car video
- Carb spacer
- no spark, no start, crank sensor? setup questions
- F.A.S.T. EFI TB??? 600max HP?
- Carb sizing for LS3
- Custom trans crossmember
- need a timing table msd 6010 users!
- LS3 track times
- is this Ford dist. good? or shuld I sell it??
- New best!!!
- Carb Intake
- *New personal best tonight*
- Help with winter build plans
- Carb vs FI Expense comparison
- MAP? Do you have to run one?
- Finally tuned and dyno'd
- carb set up taller then truck intake?
- Cowl Clearence + Carb
- engine dieseling when shuting down
- jetting help. lq9 holley 750.
- New top end set up! Thanks Mast & Texas Speed
- edelbrock controller
- sound bits with specs?
- High revving combos
- Carb Spacer
- Carbed 5.3L Build, what to do? NOOB needs help!!!
- Which cam to use??
- LQ4 Build
- Carbed lq9
- MSD 6012 hard starting???
- Anyone running an E85 carb?
- msd rebate !
- Carbed LS1tech rides
- Post your MSD timing curves!
- Fastest list!
- This feels like home
- Cam differance Efi vs carb
