PDA
View Full Version : Carbureted LSX Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17
  1. Jetting set ups?
  2. Aaaah! This damn noise.
  3. Losing fuel pressure after hot
  4. BMR or Wolfe engineering
  5. 383ls 425 rwhp but olny 365 lb/ft
  6. PCV location
  7. Intake Gasket ?'s....
  8. cam votes needed
  9. Looking for LS3 heads ?????
  10. Carb and manifold recommendations?
  11. knock sensors?
  12. Any of you run a carb spacer?
  13. ls motor in 86 Iroc coolant sensor/water temp
  14. another ls newb with questions
  15. changing balancers
  16. finally got er fired up!!!!!!
  17. turning up fuel pressure
  18. Nitrous on carbed LS3
  19. ls newb needin some help
  20. 5.3 swap into 85 Trans Am
  21. What thermostat are you running in your carbed LS swap
  22. pump gas comp. ratio w carb
  23. 10.99 or burn it
  24. another ? on LQ4 build
  25. Plugs for a LQ4!!
  26. LSx ~ old school gauges??
  27. DOD and cam questions
  28. How to find a good hooker?
  29. who is running 40+ low load total timing
  30. Msd box
  31. Hood clearance/ 4th Gen conversion
  32. New ZL-1 Camaro times!!!
  33. lq4 build carb size?
  34. Super Chevy april issue
  35. msd6010
  36. opinions on my cam choice?
  37. help
  38. valve lash
  39. Old school 406...
  40. How would this Cam Perform..
  41. what color ???
  42. Perf. Induction Intake w/Dominator carb
  43. Fox Body guys....any engine bay pics?
  44. throttle cable
  45. Cam choice for 5.3/g-body
  46. ptv clearence
  47. Street/Strip LS Coupe
  48. :-) just home from the engine dyno.....
  49. lq9 cam???
  50. help!
  51. Hello Everydoby.
  52. Swapped the 1 chambers for bullets
  53. 500bhp
  54. Where can I find the specs on the timing pills?
  55. Anybody running the GM Hot Cam???
  56. LS1 in a boat- cam selection
  57. Remember to check everything...
  58. please validate my PCV hookup for a carbureted motor!
  59. Fuel pump recommendation
  60. Howards Cams
  61. HP estimate? I hate asking but I'm tired of not knowing
  62. what to keep from the main harness on a 4th gen?
  63. Fuel system
  64. Nitrous carb'd 5.3 cam question
  65. Blower Cam Questions
  66. Anyone interested in switching from carb to fi?
  67. Another LS1 moisture question
  68. Does anyone know about TEA heads?
  69. Thoughts on 111 LSA on carb APP.
  70. Tdc before startup?
  71. 5.3 hp with 317 heads
  72. Carbed LS1 + 4L60E possible?
  73. HP guess
  74. GMPP single plane intake manifold LS1/LS2
  75. What to do with my 99SS
  76. GMPP intake and MSD 6010 for sale
  77. Build plan help ???
  78. Ls1 or lq4
  79. Wiring questions ls1 to ls2 swap
  80. Filter
  81. Carb and timing on LQ9
  82. Carb'd LS1 timing issues
  83. Q-jet?
  84. Manifold
  85. Carb suggestions
  86. Back Pressure
  87. TRex
  88. Call EPS for Carb Cam??
  89. best new carb for under $550
  90. Ice drags video
  91. msd6ls2 58x
  92. ls3 heads
  93. 65 chevelle hood clearence
  94. Which intake and controller?
  95. Why do efi guys have so much trouble?
  96. MSD questions?
  97. ~3000lb Gbody + LQ9 + CAM/Trickflows= 10.5x???ET
  98. 7531
  99. Victor jr or super victor ?
  100. zex anyone????
  101. Paralysis from analysis: ugh!!!!!!
  102. Help with engine choice.
  103. fuel pump?
  104. Another hood clearance issue
  105. E-85 horsepower?
  106. Fuel system and return line ?
  107. listed parts for sale in parts classified
  108. 5.3 HP Estimates?
  109. who makes intake mailfolds
  110. fuel pump for n20.
  111. Nitrous Express Throttle Body info?
  112. problem with 5.3
  113. Electric fuel pumps? also plug wires?
  114. 1989 Chevy Silverado w/ 71' El Camino motor
  115. carbed 370 boost
  116. anybody tried a two four intake yet?
  117. Why wont my 6010 run.
  118. Help ????
  119. What stall speed do you think?
  120. Anyone here with a blow thru carburator?
  121. New dyno pulls
  122. 830hp
  123. PLEASE HELP! LS1 still missing!!!
  124. got a cam coming for my 370 build.
  125. Wiring fuel pump + oil pressure safety switch help?
  126. Cam choice...complete build and purpose within
  127. Intake gaskets or O-Rings?
  128. Happy new year!!!!
  129. 85 mustang throttle cable to ???
  130. 69 gto ls2
  131. LS1 Coil Harness help
  132. Quick help on drivers side breather...what size??
  133. LSx Carb'd Swap Q's
  134. The difference between a Holley 950HP vs a 750HP
  135. 6.0 carb help (need cam setup)
  136. gmpp carb intake
  137. What would you do?
  138. Happy holidays to my carb forum friends.
  139. sheet metel carbed ls1 intake
  140. who uses wideband o2 setup on their carb motor?
  141. L-92 Dual plane intakes
  142. Damper options with dist cover>?
  143. Carb'd 5.3 with issues...
  144. Carbed 6.0 cam question for a full size 4x4 toy...
  145. Seeking opinions between a LQ4 and 502 bbc
  146. Roots blower?
  147. how much gain from
  148. Top 10 reasons I ditched EFI
  149. 6LS for 24x reluctor...hook up to any coil pack?
  150. anyone????? TRIED IT YET
  151. Project EFI to Carb in my 2007 Silverado
  152. Vic Jr. or Performer for budget 5.3 w/ 4.8 pistons. 11.5:1+ comp
  153. GMPP L92 vs GMPP cath port intake height
  154. Can my 65 make it to the 6s/10s on the motor?
  155. In tank fuel pump
  156. carbed ls3 problem,.help
  157. Water pump issues.. Broken water neck
  158. map sensor find
  159. 5.3 cam help
  160. Figured I'd post this here...
  161. hood clearance
  162. 6.0 carb conversion help!
  163. Carbing a 09 5.3, What tranny?
  164. 89 mustang 6.0 10.63 on motor VIDEO
  165. ls1 s10
  166. milling 243s
  167. new best time
  168. HELP coil harness problems.
  169. ported iron 6.0 heads a good choice???
  170. Timing !!
  171. 241s or 243s
  172. Anybody know anything about Demon carbs
  173. Gutting out my Tahoe for my El Camino
  174. MSD 6LS mounted inside???
  175. Porting heads on a budget motor
  176. Cam for a carbed 5.3...light car
  177. Hood clearance...SBC vs LS
  178. Edelbrock to msd
  179. 408 lq4,l92,build for 92 corvette.
  180. What is the real cost & performance gain of stroking an ls-1?
  181. e-bay rotating assembly
  182. Carb baseline setting help
  183. new school72 walk around vid !
  184. is this about right
  185. carb advice
  186. pics coming tomorrow
  187. LQ4 plan....
  188. Goal: 6.50's 1/8 with carb...what do I need.
  189. some thoughts
  190. happy thanksgiving
  191. Intake needed
  192. Will I be better off with LS1 or LQ4?
  193. l92 vs 317's
  194. Extremely rich on a cruise. Tuning help please.
  195. stock 2002 throttle cable to 4150 carb
  196. LY6 & LQ4...will same intake work?
  197. cam companies...
  198. E85 anybody use it?
  199. LSX recommended clearances
  200. Idle timing
  201. carb 347 n2o options
  202. new to LS...is carb the way to go on conversion drag car?
  203. What should I expect hp f.I to carb 6spd to th400
  204. need cam ideas...ls2 w/carb
  205. LS3 foxbody video
  206. Got a new carb for the TA
  207. Carbed lq4 intake/cam question
  208. Carbed 2008 4.8, 6010 msd box
  209. my ly6 on 150 shot
  210. New best
  211. My carbed L92 headed 6.0 "video"
  212. Using 6.0 in our Port City circle track car
  213. 5.3 carb setup for ski boat...
  214. Drag racing only need 600+ hp.
  215. stock lq4 best chip 6010
  216. Carbed LQ4 Smoke at Idle-Carb Issue?
  217. Stock rods w/ arp bolts or forged on a 418 w/ nos
  218. Carb for LQ4/317, then LQ4/L92 Combo??
  219. Best carb choice for LY6 (6.0 w/ L92 heads) stock cam
  220. E-85 questions
  221. Gm intakes
  222. anyone need a new msd 6010 cable?
  223. Building temp carb motor, need input relating to cam/intake choice
  224. G6X3 cam or something else?
  225. Fuel bowl plug question.
  226. Looking for input on proven carb'd LY6 combinations
  227. Data logging a carb'd LS motor
  228. shakedown runs - got some questions.
  229. Bad lifter cause backfire through carb?
  230. First Passes 383 Carb & Dist.
  231. New Mallorey FireStorm ignition?
  232. Nightstalker 90 chevy 1500 5.3 carbed
  233. LS3/L92/243 heads and intake ?s
  234. Part throttle misfire? help!
  235. Carb setup on ls1... Help
  236. In need of advice
  237. Motor mount ??
  238. Electric Fuel Pump/ Electric Water Pump ???
  239. Just ordered a new custom carb cam.
  240. got a new toy
  241. carbd lq9 with 799s compression fear?
  242. first time out with lq4 powered mustang
  243. Finally done chasing lean tip in problem!
  244. 64 GTO Road Race Car with LS3 416 Carb Motor
  245. Custom coil cover for carbed Ls1
  246. convert carb to fuel injected?
  247. Winter Muscle Up
  248. Carb question but not for my LS1
  249. What Spark Plug 6.0 carbed
  250. Custom grind cam for my carb'd 5.3 arrived
