View Full Version : Carbureted LSX Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14
15]
16 17
- old school tuning (no wideband)
- Looking to build carbed 6.0 please help.
- Vacuum leak- cause my problems?
- ls1 mustang brackets
- LS wins on the dirt!
- BRAND NEW Vic jr ls1 carb and 6ls ls1 ign module
- Intake Gasket Swelling
- Gaskets?
- blow thru carb jet selection?
- Secondary Butterflies fully shut at idle?
- Any news on L-92 dual plane intakes??
- To steam or not to steam.
- Pics please??!!
- LQ4/L92 Carb Cam Question
- Fuel line
- H Pipe vs X Pipe
- LS-3 Combo
- EFI to carb.....
- LQ4 help
- fuel pick up problem?
- FS:Edelbrock Super Victor / MSD 6012
- Carbed LS1 diesels when shut off
- Coverter Stall Selection
- tea stage 3 5.3 heads on lq4, Few questions
- GM Intake?????
- Carb'd break-in???
- z28 1991 my first project.
- 6010 Wiring questions.
- Carbed Ls Monte
- methanol
- Wanting A Carbed Vortec
- Fel Pro Gasket # L92 carbed
- cam/timing chain/degreeing questons Lq9 L92. E85
- conversion help 87 mc
- Coolant crossover, front and rear.
- throttle rod on 69 nova
- Sticky Throttle Plates
- carb ls1 na on ethanol vs 5.3 chinese turbo on ethanol
- Short video of my Carb'd LS1
- valve clearance
- Frustrated with my converters
- Help with TCI EZ-TCU controller
- Two Step, Retard Connector
- LQ9 change of plans... cam question..
- LS build ???
- What timing chain tensioner are you running with your double roller chain?
- freeze plugs????? help!!
- Hot Rod & Car Craft 3 year subscription for $30 ??
- Float level
- Pro systems carb
- Compare my two rides: Which one will win?
- RPM Limits 58x Reluctor wheel
- Gaskets for carb Intake
- coolant cross over pipe
- Trying to make 950+HP?
- LSX Heads
- Shaker hood?
- Blow thru Setups & Numbers
- Steam Tube Gaskets
- budget carb setup suggestions Holley 650dp
- LQ4 meets FAST EZ EFI
- MSD 6012 factory mis wired
- choosing a cam
- No money for an intake, so I'm making one.
- anyone use this?
- 7200 rpm 5.3
- Picked up a slightly used carb for my LS1. Hope I made the right choice
- Which water pump
- wanted msd 6012 and harness
- Is my cam 'ideal' for a carbed intake setup?
- MSD 6010 & Demon 650 idle stuck at 3,000 RPM
- Timing curve for Hotcam??
- LS1 base tune questions
- Tach signal
- Can I add PCV to
- What size carb...
- Heads 317 or 243
- 66 nova 6.2 ran 11.58 118 mph without bottle
- Track pass
- LS1 Oil Pressure Question?
- Carb'd 4th Gen Camaro build thread< with video of results>
- Return line?
- Timing Spikes
- timing day
- MSD 6010 Harness
- Which 5.3?
- LS2 Dilema
- crank sensor ??
- engine cooling question
- Timing on a LQ4.
- Here comes another 2nd Gen Build...
- Autometer Fuel gauge
- LS 2x4 Dual Plane Mid–Rise – EFI Dual Plane Mid-Rise EFI LS Intake Manifold
- Carb Porn
- ignition on carbed 6.0 fox mustang
- New Pro-system carb, but Black plugs :(
- Carbed LSx suitable for a tow vehicle?
- 6010 Tech
- carb tops efi
- Wrenched on my first 1,000 + horsepower motor today
- Get stock starter/alternator to work without the computer?
- Is my 850 DP too big
- another 5.3 performance question
- Carbed victor jr work on these heads?
- MSD 6012 Cam Sensor Harness v. GM Cam Sensor - won't plug in?!
- Alternator Wiring.
- Alternator
- so what kinda PVC setup are you guys using?
- The Engine is in! - Video added.
- air fuel ratio
- Updated stock 5.3 results
- Carb 5.3 questions cams/stall
- Just need a little advise
- Data logging with an AEM Uego?
- Where did you guys mount your MSD 6010?
- Need a big favour.. someone to measure carb height
- Vic Jr VS Super Vic
- Carb boosters compared on dyno coming up
- What stall to use? Carbed 5.3/th400
- cam set up ???????
- Victor Jr. with a 5.3?
- Coolant bleeder pipe
- 6010 rev limit
- MSD question....
- 6010/avenger670 prob
- Any one good at carb tuning?
- A short ride.
- 5.3 and 6.0 cam upgrade choice
- my msd 6010 & intake for sale
- Hp estimate?
- 6010 no spark
- Carbed with 6010
- Engine run on after key off
- acc. drive setup
- Patriot cam and 5.3
- single or dualplane w fast EZ efi
- intake gasket question
- head gaskets
- Don key's engine masters motor.
- msd 6010 or msd 6012
- Pace Carbed LS2 Crate motor
- cam,intake and carb ideas?
- dual quad ls1
- 3rd gen camaro hedders
- Help Balancer Needed (SFI)
- Low end load up
- Snow stage 3 water/meth injection
- Stock carbed 5.3 results!!!
- What carb would be best for my setup?
- Hope to be running this week
- HOOD - is all hope lost?
- Mechanical for vacuum secondaries? 5 speed, 5.3L, 2900lbs
- Anyone want to sell an Edelbrock ignition box?
- new gmpp dual plane intake
- LS build and internet ideas
- valve covers fit??
- Swap my Dual Plane for a Single Plane
- Drag Radials
- question on improving current 650 carb
- Car is banging out 500rpm too soon
- question about a headers
- Carb conversion difficulty
- Electric Choke
- camshaft selection help
- 1997 Camaro Z28...turbo 400 tranny..wana go with LS motor.
- new wisdom
- Why won't my Th350 converter fit my 6.0L?
- Machine shop doesn't know......Vic Jr. ???
- wanting to buy intake, box and harness for LS
- Grocery Gettin' Gbody: 5.3 Malibu swap
- carbed 91 mustang
- I want to carb my LS1
- 5.3 build questions Please if you'd be so kind
- What carb guys are spraying Nitrous?
- HP guestimates of new combo
- Anybody running an edelbrock carb
- need help for mods to my stock 317 heads!
- 5.3 in 85 c-10
- 6012 timing help!!!
- G.M.P.P Dual plane for L-92"s
- intake gaskets question
- yes another carb selection thread (boat)
- Wheels up^
- Dirt track LS
- lq9 combo QUESTIONS
- wiring a RPM accessory to MSD 6012
- What upgrade would you do next?
- how about vic jr w fast ez efi ?
- 5.3 cam help.
- noob 5.3 setup question
- 6010 issue
- New Holley Square Port Intakes- Update
- Did I make the wrong choice
- 6.0 carb and distributor
- heads and cam combo for stock lq4
- Edelbrock Ignition Controller
- Can you guys help me design a budget race engine
- 5.3l cam question
- LS376 515 Anyone have one?
- Carbureting L92/ LS3 Questions
- Lq4 build
- Barry Grant Closed the Doors
- Hood clearance/68 Camaro
- Don key engines
- Plug gap ??
- Ls2,lq9,ly6,ls3 ???
- 6.0 fox
- 317's vs 853's
- 95 Z28 6.0 swap
- Comp Cams 273 LSR 5.3
- Anyone using eps single plane cam 236/248
- Feedback On My LS Carb Build
- Map plug msd 6012
- What carbs you all running on your LSx?
- FAST XIM Controller?
- stock hood
- eldebrock vic jr l92
- lq4 combo for track
- Lq4 402 stroker build
- Edelbrock box, What pill for stock lq4?
- MSD 6010 What ignition timing chip should i be running?
- Max 5.3 power
- Lq4 Carb questions
- surge tank
- Nitrous Motor Combination
- what to do for breathers or pcv system
- new to carbs and need some help
- What's all involved in building a carbed la engine?
- What exactly comes in the package when buying an MSD 6010?
- Carb or EFI? Still can't make up my mind...
- lq4 no start
- gmpp vs. victor jr. single planes cathedral port
- Testing the waters, looking for a little advice
- Intake bolts
- New and Courious
- junk yard 6.0 with cam
- Show me how you mounted your alternator.
- Another new best
- Wideband for Carb setups?
- what to do?
- Will 3/8 fuel line supply a healthy 6.0L?
- Fitting for power brake vacuum line in the manifold?
- Ordered these, what do you all think?
- Carb cam question...
- 2 Cams 1 Choice
- l92 edelbrock carb intake?
- gmpp intake # 88958675
- Carbs on Edlebrock Intake
- swap headers for a 89 mustang 6.0
- controller wiring.
