PDA
View Full Version : Carbureted LSX Forum
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. busted ls
  2. Recommended compression for 91 octane LS1?
  3. ls3 heads/rockers
  4. Cam selection for my lq4 build
  5. stock 5.3 msd 6010 tune??
  6. TEST: Aeromotive S/S VS. Holley HP 150
  7. Sheetmetal Intake Design
  8. ECU removal
  9. MSD 6012 coil selection
  10. New carb ls7 intake
  11. which timing curve?
  12. 5.3 blow thru turbo setup
  13. 6.0 rebuilt long block with 317 heads
  14. Manifold casting
  15. Daytona Smart Spark LS
  16. LQ9 with 799's.... Super Vic or Jr.?
  17. PWM Fuel Pump Pressure Regulation
  18. Anyone ever try the Stinger plate system ?
  19. 2007-09 GMC Sierra 3500 6.0/4L80
  20. Need carb tuning help please
  21. help with new build
  22. Msd 6010 and factory tach
  23. Question for Nitrous E85 Carb guys
  24. Using a GM PCM On Your Carbureted LSX Swap
  25. what heads/intake
  26. Cylinder head mill question
  27. 6010 guys with nitrous
  28. what to do with my 5.3
  29. Carburetor for LM7 cammed
  30. Camshafts made just for use carb neanderthals
  31. Nitrous/Fuel plumbing,looking for ideas
  32. Looking for timing ideas 12.5:1 6.0
  33. I am having a few issues with my carb'ed ls.
  34. Rotorcraft 2150 Rebuild
  35. 2000 Camaro 3.8 to lsx
  36. 69 Nova 408 build
  37. Dual dominators, tunnel ram 408
  38. Road Race Ls1 Dry sump Carbureted
  39. Does this belong to my lq9?
  40. LQ4/4L80 build
  41. Fuel pump size to run carb and nitrous?
  42. E85 Carb jetting. opinions?
  43. ls2 carb
  44. LSX block
  45. Bosch 044 + Carburetor
  46. How well should it run?
  47. 66 elco throttle linkage.
  48. What box and intake for 5.3
  49. New carbed LS 5.3 getting started
  50. I want your opinions and experiences
  51. I could use a hand planning a 4.8 build for my truck
  52. Msd 6010-Blow thru tuning
  53. Carb/intake swap
  54. Dieseling on shut down?
  55. holley carb lean spot advice
  56. Spark Plugs
  57. First time to track
  58. Lm7 carbed
  59. Stroking a 6.0 is it worth it?
  60. 6.2 build debate SBE cathedral vs rectangle compression vs flow
  61. looking for a different carb, thoughts?
  62. intake power
  63. Here it is. The article on my 408" stroker is done.
  64. Fuel pressure regulator.
  65. LS1 Carb swap recommendations on 41 Chevy Pickup?
  66. Need help with tach to control trans
  67. Buddies nasty 420ci ls3
  68. Power valve restrictors
  69. What kind of power can I expect?
  70. Carb'ed 5.3L cuts out/bogs under heavy throttle
  71. going to carb my lq4
  72. carb tuning questions.
  73. MSD 6010 Random Missing / Hesitation Thread
  74. Holley HP or Dominator ECU with Carb Nitrous Motor?
  75. carb 5.3 build for strip
  76. PSA for Edelbrock intakes
  77. "Budget" Build Carbed 5.3
  78. nitrous 5.3 fuel pump
  79. 6010 possible issue
  80. Help on the LQ4 build!!
  81. MSD 6012 Coil Selection - Truck Coils - Select LS1 or LS2?
  82. The next swap.
  83. Surprised results with only 28 degrees timing
  84. Cooling question on a new 1st build
  85. N/A Camaro vs 600awhp subie
  86. 4.8 cam advise.
  87. not an ls but not injected any more
  88. Please post how you did your PCV setup.
  89. First time out on new build 11.22 @119
  90. Video of my car from NMCA True Street
  91. New Heads, guess my ET
  92. Miss firing
  93. Victor jr VS Supervictor
  94. New Best in Mustang
  95. Trick flow LS3 intake?
  96. Runs rough
  97. 1971 impala ls1
  98. torquer v2 with carb?
  99. SN95 Blowthrough Forged 370/S480 Build UPDATE: Its Alive! Vid added
  100. Fuel issue or Carb issue?
  101. Help with parts needed for make carb this engine
  102. Drag racing w/ moroso 20143 oil pan?????
  103. Ls next 390 cube solid roller
  104. How about a 1230 CFM Holley 4150?
  105. Still this left............
  106. Carb'd 5.3 Breaking up at 5k rpm under heavy load
  107. exhaust hotter on one side??
  108. Staging temp
  109. new race engine advice
  110. Finally back up and running
  111. GM 1 bar MAP voltage/pressures
  112. 650 HP setups? Help my father out...
  113. 500 crank HP on LQ9?
  114. Help with ignition on 5.3 6010 msd
  115. Nice E-Bay cam on 106° LCA
  116. 12.5 Comp Ration on pump gas or E85?
  117. LS1 finally running video
  118. Cam for blow through setup.???
  119. 82 C10 build
  120. Update
  121. Carb'd LS1 spark plug recommendations
  122. Spark plugs for alcahol
  123. 418 LS3, 237cc Cathedral, dizzy and a carb heads to dyno
  124. Hotrod Carbed Intake Dyno Test
  125. New, few questions about carbs.
  126. 5.3 head options
  127. Cam for this 5.3 set up ???
  128. Questions about an intake for my 408 build
  129. Front mount distributor setup (timing)
  130. Just got my carb done up, lookin sexy!!
  131. Msd 6ls need tach
  132. Lm7 in 66 nova. Carb vs efi
  133. Starting of my first LS build.
  134. randome carb question
  135. e85 carby?? what cfm
  136. Very bad vibration! HELP
  137. A/F graph with timeslip
  138. A Nice Street Strip Carb Combo On The Dyno For You Guys
  139. Aeromotive 13101 to dead head carb setup
  140. Switching to fuel injectors to Carb
  141. Carb ls2 pcv system
  142. on my 3rd 6012 msd. box
  143. First start what pill
  144. 700r4 to LS
  145. Want to put ls carb on my car
  146. Smart Spark LS Pre Loaded Timing Tables
  147. Zones (and other TX guys/gals)
  148. blown top pan gasket! help plese
  149. Performer RPM Square Port Press Release
  150. Daytona Sensor Smart Spark LS
  151. Timing Help Please!!!!!
  152. My run vs a 14 stang 5.0 on radials
  153. Camshaft for carbed 6.0 LQ9
  154. 24x/58x
  155. Who's the best of the best E85 tuner??
  156. The tuning chronicles: emulsion/driveability
  157. MSD 6010 with windows 8.1 easy fix.
  158. Map Me a timing curve!
  159. Questions on truck build...
  160. Anyone running a Holley dual plane. 30-130
  161. Have to quit racing............
  162. Lsx 434
  163. Rpm
  164. 414ci nova results
  165. Lq4 cam help
  166. lh8 oil pan
  167. Horsepower guess on my Carb'd LS1
  168. Gm ASA ICL specs?
  169. Converter Company advice ...
  170. Carb tuning recommendations
  171. buying a used LS mileage
  172. LQ4, LQ9 or LY6?
  173. stumble down low and no power - 5.3l h/c
  174. MSD startup problems
  175. carb tuning question
  176. 03 2.2L lsx swap
  177. 5/6/15 TNT disappointment
  178. Secondary fueling question
  179. Another Personal Best with the Mustang...
  180. I am beginning to think E85 sucks....
  181. first time out with the new setup
  182. I need help please motor won't stay running
  183. fuel pump suggestions and size help please?
  184. Heavy Car cam selection - 5.3 + Carb + TH400 + 650CFM ?
  185. Carb help please
  186. PCV problem or something else?
  187. Daytona Sensor Box
  188. possible msd 6010 problems or something else help!
  189. V6 Camaro to Carbed 5.3L
  190. Broken LS1Edelbrock Performer RPM intake manifold
  191. 6010 box on daily driver
  192. Innovate AFR MTX-L help ?
  193. MSD 6010 421 "Hits rev-limiter early"
  194. Where should my compression be at ?
  195. Data Logging for Carb Guys - Knowledge Is Horsepower
  196. Swapping to new motor
  197. Frankenstein Racing Heads Do Manifolds?
  198. single exhaust sizing
  199. 6.0 l92 carb what cam???
  200. 5.3 in a 71 monte carlo.
  201. Which Edelbrock Intake Manifold? 408 LS
  202. help me tune my metering block
  203. The truth about the MSD 6010 & 6012
  204. Finally made some passes on the new motor
  205. Finally getting somewhere with the Mustang. New Best
  206. Corvette alternator wiring ?
  207. spark plug gap
  208. Carb lsx fuel system.
  209. Please critique my next build
  210. Carb LSX in a 01 Ram 1500
  211. Holley carb newb qustions
  212. what should I expect?
  213. Fuel filters
  214. PTV clearence issues
  215. Anyone need a carb cam? BNIB
  216. Finally! Shes on the road.
  217. E85 Carb on stock LS1 question
  218. quick question..msd 6012
  219. Anyone Wanna Sell?
  220. Carbureted LS it is !
  221. 5.0 stang being a nuisance
  222. You can't take the ricer out....
  223. Help with DCR on Edelbrock 2216 cam
  224. Mud Motor lq4
  225. Thanks guys
  226. Th400 with a 99-2000 long crank
  227. Power levels, where do you think i'm at
  228. My first LSX **VIDEO**
  229. back in the carbed ls world
  230. new guy needing help
  231. -7 plug
  232. Fuel pump.
  233. LSX 383 help!!
  234. Who would have this carb. intake manifold in stock ???
  235. Single vs Dual carbs?
  236. Split Carbs on an LS/LQ?
  237. need mad info / thoughts....
  238. Holley 300-132: crappy looking casting from china?
  239. Carbed LY6 cam selection
  240. Single 4500 Tunnel Ram Top
  241. Another LQ4 cam question
  242. Should I buy or build it?
  243. Another how much power will I make thread
  244. Cam suggestions??
  245. Quick fuel 680 vs help !!!
  246. Single or dual plane manifold?
  247. Anyone using a mil-spec connector to pass MSD harness through firewall?
  248. cam?
  249. My cammed carbed ls1
  250. Who's running a msd 6010 with an ls2 cam sensor?
