View Full Version : Fueling & Injection
  1. Nylon fuel line safe distance from exhaust ??
  2. can you attach you filters to you fuel pump?
  3. Aeromotive 18673 | Fuel Pump, In-Tank, 2010 - 2011 Camaro, A1000
  4. Edelbrock Pro-flo XT intake questions
  5. Will these fuel injectors work?
  6. 4th Gen Fuel Cell ?s
  7. gas tank problem help
  8. 1600cc injector help ?
  9. Height difference swapping LS9 injectors for Shorty Siemens 60's on TVS kit
  10. LS3 injectors on a LS1 rail ?? yes, I searched
  11. What return line size recommended
  12. Fuel PSI go to Zero when shut off.
  13. LS2 intake
  14. fuel system interchangability ??
  15. Aero Stealth 11142 install question
  16. upgrading part of fuel line from -8 to -10
  17. Help with 02 sensors
  18. Best deal going for injectors for 1000hp on E85
  19. routing -8 fuel lines
  20. Injector scaling
  21. DIY Double pumpers in tank on GOATS
  22. Racetronix BLT1-FPA pump kit how to ??
  23. Granatelli 255 fuel pump install problems...
  24. Walbro at 40 psi, 25% LTFT's
  25. how to tell if i have a bad or leaking injector??
  26. fuel pump question
  27. NEED YOUR OPINION (Pic Attached)
  28. duty cycle 102%
  29. What throttle body is the best
  30. Recommended fuel pump and injector sizes?
  31. Good Idea to upgrade?
  32. Repercussions of a blown seal on the Fuel Rail Pulse Dampener?
  33. PTM Throttle Body - 180d
  34. Keeping fuel level gauge correct when swapping to '98 metal tank from '99+ plastic...
  35. fuel pressure problem need help now!!!!!
  36. Racetronix harness help
  37. Car dies when fuel level gets low?
  38. What is the size of fbody fuel lines?
  39. fuel rail crossover
  40. Help with fuel line ends
  41. which 255lph walbro do i have?
  42. 2001 LS1 fuel pressure regulator
  43. Still figuring out my V6 Swap...Fueling
  44. Which is better - FAST LS3 injector spacers, or LS1 injectors
  45. Truck intake and rails with ls1 injector????? help
  46. Install -8 feed and -6 return without dropping tank?
  47. Problem, please help: Fuel pump and filter location, and how to replace? 2000 C5
  48. Help With Fuel System
  49. Which Aeromotive system do I need?
  50. need help with fuel system mods for KY turbo header setup... and injector decision
  51. '84 Silverado with LQ9 swap.
  52. Walbro fuel pump sock
  53. update to problem
  54. when do you NEED to seperate fuel rail feed / return lines?
  55. Where did u mount your exturnal pump?
  56. E-85 worth it in my case?
  57. 60lb to 80lb upgrade
  58. vacuum reference on regulator
  59. E85 to 93 issue
  60. Fuel system help
  61. LT1- LS1 swap fuel line help!
  62. Is it possible to lower fuel pump (aeromotive) PSI by decreasing voltage to pump?
  63. parts help
  64. Car starts and revs jump to ~2k?
  65. Fuel pump power wire, what size should I be using?
  66. Anyone know where to find this connector?
  67. o-rings on Injetcors need help please
  68. Nasty Nate Tank and DIY Hot wire kit layout...
  69. Does 2nd pump need its own power supply?
  70. Fuelcell with outside fuel pump
  71. Fuel return line setup.
  72. Does this Evap delete look like it will work
  73. Not Enough Volts To Pump
  74. Any Idea on injector size for 410lt1
  75. Fuel tank pickup and modification help needed
  76. Bad misfire
  77. Post up Pics of your fuel line routing!
  78. Running a racetronix below 1/4 tank
  79. What kind of fuel system needed for 550rwhp
  80. Racetronix Pump Requires 3 or 4 Primes Before Start - help. (pics)
  81. Limited Price Reduction for DW Modern Muscle Injectors
  82. Connecting FAST fuel lines to stock lines
  83. Should i upgrade my fuel rails?
  84. what fittings do i need?
  85. Aeromotive 17136
  86. Injector o-ring sizes? LS3 injectors w/ ls1 rails and supervic
  87. Fuel pressure question
  88. 1987 R10 2wd. 1/2ton dual tank how to???
  89. Post up your fuel system setups
  90. Fuel pump holding back power?
  91. Need recommenation for non-bleeding FPR
  92. Racetronix fuel pump unreliable?
  93. Fuel pump set up
  94. need to order fuel rail fittings asap! please help
  95. Magnafuel problems
  96. l76 questions
  97. Broke schrader valve trying to remove it
  98. raise fuel pressure to flow more at injector?
  99. Fuel pressure = zero when dumping clutch
  100. aftermarket fuel pump vs oem
  101. need some help on external fuel pump placement
  102. Holley's New Dual Punp
  103. RT Hotwire kit hooked to battery?
  104. fuel pressure gauge HELP?!
  105. Need the correct FAST rail MOUNTS. (LSXr102)
  106. anybody know where i can get fuel rail hardware
  107. LS2 fuel rail spacers.
  108. LS1 tank question
  109. bad fuel pump cause idle issues?
  110. pro flo xt on 5.3
  111. bosch 42lb green injectors wont seal?
  112. injector help
  113. Fuel rail fits BBK SSI intake just fine, but not LS6 intake, why?
  114. Single plane intake and edelbrock fuel rails, a few questions about installation.
  115. ACES IV Gasoline Formula
  116. Tuning in hot conditions
  117. Disconnecting Filler Hose?
  118. vette fpr placement matter?
  119. 98 and 99+ fuel system differences....
  120. idle is everywhere
  121. e85
  122. Need help finding specs on fuel pump
  123. Question on twin 255s
  124. Murphy's law!
  125. C5 fuel sender...Can this be repaired?
  126. EV6 39 lb injectors
  127. I need a ls6 intake complete
  128. injector help
  129. 1994 firebird formula please help idling at 1700 and breaks up through some rpms
  130. Any one have their 60s made into 80s?
  131. Crazy fuel issues. looses fuel pressure
  132. Help trouble shooting fueling issue
  133. 460whp on stock LS2 injectors....
  134. Riddle me this: 2 98' LS1 Racetronix Fuel Pump failures
  135. installed new fuel pump and no pressue at the fuel rail
  136. GMPP L92 Intake (originally LS3 Injectors) upgrade for ProCharger - what can I use?
  137. injector cleaning
  138. What fuel pump\pumps for turbo ls
  139. what fuel injectors lt1 355 build
  140. are these 80lb ford injectors that i have?
  141. Can i simply increase my fuel pressure to increase injector output?
  142. Fuel system problem
  143. Need an upgraded fuel pump...98 fbody
  144. Lonnie's Magnacharger Rails clear the rear magnacharger cog?
  145. Low fuel pressure. Need help
  146. Fuel line conn?
  147. quick question on fuel pump sending unit
  148. If room isn't a problem, car or truck intake?
  149. When is a regulator needed?? (quick Q)
  150. Busted Injectors
  151. Anyone running an aftermarket fuel level sender with stock gauges
  152. New fuel rails
  153. Racetronix hotwire for 2nd fuel pump ??
  154. 3/8 Fuel line HP limit ? Stock LT1 Bottom end HP limit?
  155. Fuel System Ideas Anyone?
  156. belt driven fuel pump confirmation help needed
  157. Critique turbo LS6 fuel system
  158. whats needed
  159. anyone have pics of dual walbros on a 99 up with -8 line out
  160. do i need bigger injectors
  161. Help with avgas stoichiometric, facts only please
  162. lt1 wilbro 255 install- no fuel pressure
  163. 24lb injectors in stock 93 z28?
  164. Throttle Body question please help
  165. what causes air in the fuel lines?
  166. Using LS1 injectors on an LS2 style intake
  167. Do I need to a bigger fuel pump?
  168. 1lb Hobbs switch? regulator? Sponsors?
  169. Ls1 turbo fule pump Question....
  170. 420rwhp, what injector size
  171. Dual fuel lines?
  172. LS1 fuel system/lines
  173. Anyone make an aftermarket rails for LS3/LS7 Intakes that uses Bosch 60mm injectors?
  174. Need new fuel pump asap
  175. Intake manifold build up
  176. Gas Leak
  177. Fuel Smell in car after fill-up
  178. Ls3 fuel system?
  179. should i run bigger injectors?
  180. upgraded to Aeromotive fuel rails... do i need a regulator now???
  181. new part list... what injectors...if any?
  182. Anyone running two fuel/tunes?
  183. stock pump limits
  184. Help w/install Nasty Perf stage 3
  185. LS1 F.A.S.T Rails?
  186. Fuel pump regulator bullshi1
  187. Fuel Pump wont turn on
  188. Injector Ohm Testing
  189. Fuel rails
  190. 30lbs good for heads/cam
  191. Injectors won't clip in, lil worried
  192. Best 80lb injectors?
  193. secondary fuel pump wiring
  194. Vendors that sell HOLLEY injectors?
  195. Need Injectors (Cam only LS1)
  196. fuel rail covers on a fast 92mm
  197. LS1 fuel line question
  198. Injector size?
  199. Seriously need injector help, please!
  200. -8 hose and e-85
  201. will larger injectors blow my motor??
  202. Big injectors?
  203. Can the Racetronix Hotwire kit be used or modded for external pump use???
  204. tuning in 80# siemen dekas
  205. Starting problem...
  206. Will This Cracked Injector Work?
  207. RPM Activated Switch to Switch a Aeromotive FPSC
  208. p0200 whole passenger side shuts down
  209. Selector switch or "T"?
  210. Racetronix Fuel Pump install gone horribly wrong...
  211. what injectors for h/c/i LS1
  212. Preferred fuel filter?
  213. ID1600s, anyone run them?
  214. Aeromotive fuel pressure boost connector
  215. Fuel system upgrade?
  216. Will These 30# fuel injectors work for me?
  217. braided stainless fuel line?
  218. Reinstalling bucket w/o pump, installing inline but want tank level sender function.
  219. Need to find someone to drill and weld in fuel injector bungs on intake.
  220. injectors for cam only?
  221. C6 fuel Pump help
  222. fuel injector question...98 ls1
  223. 30lb or 34lb?
  224. Acceleronics box-which location did you wire the injectors?
  225. Magna fuel 4303 with fuel pump controller
  226. new problem
  227. Should I step down my injectors?
  228. fuel gauge stuck on full 97 firebird
  229. Would I save by doing an E85 swap?
  230. no injector pulse.. please help!
  231. New regulator for use with the Aeromotive 340
  232. What is this ?
  233. Stock Fuel Pressure
  234. Tach driver needed for Aeromotive FPSC?
  235. What length injectors do I need?
  236. KB Bap results w/walbro
  237. DeatschWerks Fuel Injectors and Fuel Pumps
  238. MPG's
  239. Who here is running stock lines with E85?
  240. Edelbrock rails
  241. base fuel pressure?
  242. 89% duty cycle on a bolt on car
  243. Aeromotive Stealth + Kenne Bell BAP=????
  244. Blew o-rings on fuel pump line...
  245. fuel system upgrade
  246. E85 in Mild NA Applications tuning
  247. sponsors I need injectors
  248. Fuel system - 68 psi ?
  249. E-85 question
  250. Fast fuel rail?
