View Full Version : New LS1 Owners - Newbie Tech
  1. Best Head/cam Package For 02 Ws6
  2. Will 2004 Ls1 from a GTO fit my 02 Z28?
  3. license? no license
  4. exhaust question
  5. handheld tuner VS laptop
  6. cars off to the shop
  7. Stock m6 shifting
  8. chk engine
  9. Getting ready to do ls6 intake manifold swap need help!
  10. Which bellow do you guys use?
  11. Free Mods?
  12. muffler sponsor?
  13. Sorry just trying to figure this stuff out
  14. again...coated vs high temp paint
  15. just catback talk
  16. cat back or duals
  17. A little help please...
  18. New to the LS1? Here's what NOT to buy:
  19. dynomax bullets
  20. Lid clamps
  21. what intake is it
  22. Toggle on electric fans
  23. C6 Z06 cam
  24. Are 5.3L Truck throttle bodies the same as 5.7L TBs
  25. ls1 thermostat in a 5.3 truck???
  26. help me out
  27. What bolts for mounting to engine stand
  28. Is This A Real SS Or Not?
  29. how much hp does the stock bottom end hold?
  30. Is there such thing as an LS1 intake w/o EGR?
  31. Anyone ever replace turn signal stalk?
  32. difference b/w 98 and 99-00 fbody's
  33. First Mods That You Must Do(newbie)
  34. need help stall converter
  35. GU5 On door. Any idea?
  36. Code question?
  37. Where to find interior parts?
  38. suspension ??
  39. what thermostat
  40. 100 octane fuel
  41. Did I Get A Good Deal On My Camaro Z28
  42. First F-body!!
  43. factory freak or modded??
  44. Does less weight make a BIG difference?
  45. Just weighed nearly stock Z28 w/headers: 3380 lbs.
  46. m6 shifting issues, please help im stumped!!!!!!
  47. What do you guys think of this?
  48. Cold/forced air induction
  49. So I got it looked at on a lift...
  50. what is the stock rwhp for a 99 z28?
  51. how much hp from slp loudmouth for LS1
  52. Just wanted info on z/28 with ls1
  53. Cant do a brake stand?
  54. a few dumb exhaust questions
  55. tach not working
  56. Factory alarm question
  57. cam and supporting mods vs. full exhaust and gears
  58. a simple request
  59. Tsp Cat back
  60. Finally going to get an SS!!
  61. OEM Bolt Size
  62. Hooker
  63. Hey guys!!! Got some $$$$ TO spend!!
  64. Quick Question... Should be Simple to Answer:P
  65. First few mods were the easy ones...
  66. Hood ? with K&N FIPK
  67. T-REX cam
  68. how a A4 can beat a M6 from a roll???
  69. People with ftra, please help
  70. God damn orfice tube
  71. What do you guys think of this?
  72. How fast should it be
  73. Noobish suspension question
  74. Nitrous!!!
  75. Exhaust Question
  76. wiring
  77. Oil pressure sender
  78. Pacesetter ?
  79. 160* Duralast Thermostat...
  80. Tr224, AFR205, LS6 intake, dyno...???
  81. New 160Amp alternator -- now funky sound?
  82. Stall Converter or LT's First???
  83. exhaust question
  84. a4 dies..
  85. Newbie question re: lowering compression ratio?
  86. motor mount time
  87. Water vs. Antifreeze vs. Water+Water Wetter
  88. Looking for x-pipe exhaust
  89. GAP for NGK TR6
  90. slp cai owners help!
  91. power tune??? WTF?
  92. AIR mod
  93. Underdrive Pulley
  94. Help With 2000 Z/28
  95. pcv valve location
  96. Cam w/o longtubes and A4
  97. how does the traction control work? asr?
  98. Good Ls1 Modding advice........
  99. exhaust
  100. Y-Pipe Ground Clearance Issue
  101. 3.73 or 4.10
  102. what is good for the 1/8 times?
  103. Noob question on programer / monitor
  104. looking for a clutch
  105. Washing my ls1 motor
  106. Dyno needed for power tune?
  107. headlight vent things
  108. Street tire 60' times
  109. SLP exhaust question
  110. motor parts
  111. cutout questions... any help appreciated
  112. Concerning O2 Sims
  113. Threads on Maintenance & Repairs Belong in the GENERAL MAINTENANCE & REPAIRS SECTION
  114. cutout with stock headers
  115. Some n00b questions.
  116. Cutout before catalytic converter
  117. header install car wont run
  118. what is the ls1 suppose to idle at... ???
  119. What had the stock LS1 block been know to hold?
  120. possible ls1 owner
  121. my first ls1
  122. AEM wideband? stuck?
  123. Full bolt ons/cam/100 shot too much for stock LS1?
  124. New here... opinions on motor please
  125. Proud '02 SS owner
  126. ls1 engine
  127. gto intake
  128. Black, on black, on black, on black...Pic inside
  129. bosch 13111 o2 install
  130. Need help finding a dyno...Christiansburg, VA (near VT)
  131. Any negatives for porting throttle body?
  132. Valentine One.. Bad Encounter DONOT BUY FROM THEM
  133. SLP H-Pipe for stock headers
  134. header bolts
  135. Should I buy this 2001 Sunset Orange WS6 for $9000????
  136. Little red wire
  137. 6.0l
  138. Opinion's on polyurethane bushings?
  139. Help - Coil Packs on 98 TA
  140. 98 traction control
  141. Thunder Racing Performance Packages...
  142. Engine Replacement Question
  143. stock sizes of MAF and TB
  144. taking my car to speed
  145. how do u know if its a real ss???
  146. Tach and shift light problem
  147. C5 Z06 center caps
  148. Headlight alignment
  149. newbie 6L accessorie swap question
  150. stock cam
  151. all bolt ons vs. upgrade tranny!!
  152. My car seems slow compared to others!
  153. Next Mod!
  154. I am back!!
  155. Whats next??
  156. NEW LS1 Sweet Deal $5,650
  157. 4th GEN tail lights
  158. Which is cheaper?
  159. Floor Mats?
  160. 3.42 gears worth swapping on a A4 with 2.73?
  161. broken bolts
  162. possible race setup
  163. Starter Help!!!
  164. Major car question!
  165. maf stuck
  166. Plug in block above the oil filter?
  167. Mass Air Flow Question
  168. Lookin' 4 a cam, need some help
  169. Wich LS1 F-Body has the best aerodynamik?
  170. Should I buy a C5 C6 or TransAM
  171. Airlids and fuel economy
  172. A/C block off plates?
  173. what kind of transmission?
  174. MAF upgrade?
  175. 02 sims .Help
  176. Direction of LS1 rotatoin?
  177. white smoke
  178. 420-450whp H/C/I package support?
  179. Where should stock idle be on a 2000 Z28??
  180. What is this thing?
  181. Installing LS6 intake on '00 Firehawk
  182. Defective windshield?
  183. TA LS6 intake on '00 Vette?
  184. Should I change over to 6spd?
  185. change oil light after 1/4 mile run...
  186. Car wont start, blowing starter fuse??
  187. LS1 Mods--whats next?
  188. How Much $$ to install LT's and ORY
  189. launching with stall?
  190. is my gas gauge right?
  191. Pinging with 91 octane...
  192. new adjustable clutch?
  193. How accurate are the factory gauges?
  194. Proper Shifting
  195. Which octane to use?
  196. Sensor?
  197. A4 or M6
  198. Exhaust
  199. next mod
  200. Window Motor
  201. installed my slp lid??? WTF
  202. Motor Life question
  203. Hi my car pic :)
  204. looking for a new ramair hood?
  205. looking for a new ramair hood?
  206. heads & cam + 125 shot OR procharger for 02 SS???
  207. ORY, SLP or other? Or have one made?
  208. Driving !air-filter mod!!
  209. A New Noise: Whining!
  210. Tach question
  211. SS functional hood
  212. Question
  213. sorry another noob question
  214. typhoon intake install went wrong
  215. Lifetime Air Conditioner Warranties?
  216. Knock knock?
  217. underdrive pulley or beefy alternator?
  218. Research
  219. Camaro mod ideas?
  220. Simple question regarding header fitment
  221. General Thoughts - New Owner
  222. Carfax help!
  223. Best Upgrade for a Stock 98 LS1
  224. well she just turned 250k
  225. Oil Pressure Reading
  226. choosing a cam
  227. Power band?...
  228. Cam, compression & intake
  229. 114 0c.
  230. just purchased some ngk tr55's
  231. air lid question
  232. Sluggish performance after first mods.
  233. MAF/ SLP or OEM?
  234. Battery
  235. Ms4
  236. Ls1 T/a
  237. so i have a problem
  238. little knocking when i turn off car normal?
  239. SS Hood
  240. New LS1 Owner!!!!
  241. Is my rear end going!!?
  242. the new z
  243. Went to the track
  244. Help Asap
  245. Lowering a 01 SS!!!
  246. Foglight Alignment
  247. headers question
  248. Switch for Fans
  249. Stall converter
  250. Front Bumper
