View Full Version : Carbureted LSX Forum
Pages : 1 2 3 4 5 6 7
8]
9 10 11 12 13 14 15 16
- Katech rod bolts VS ARP rod bolts
- Long tube headers vs manifolds
- Air cleaners - high flow top vs conventional flat top - fast 4 barrel
- went to 650dp with proform body...
- What chassis ???
- My Malibu wagon build
- we'll too much fuel pressure ?
- Mustang is coming along..
- LS3/L92 Victor jr throttle bracket????
- lq9 with 243 heads
- new personal best 6.0 Fox
- s10 needs a diet
- Got my 383 running with 6010 and e85 got timing questions
- Rip 6.0
- Metering blocks
- Some video from the FL2K13 Street Car Shootout.
- Timing chain and gasket question.
- Pinesol as carb dip works awesome!! - PICS INSIDE!
- Stall
- JEGS lifters......?
- where is jet (Holley)?
- carb terms for noobs
- 5.3 s10 cooling
- carb and th400
- Need some help designing basic daily driver fuel system
- ARP 340 Fuel Pump
- Need drop base aircleaner 14"
- holley dual four intake
- LS Pinging
- Dyno'd the LQ9 Saturday.
- A/F ratio
- Another cam & intake recommendation thread
- Small update
- info e85 plugs
- Next track outting...
- Edelbrock victor junior or efi
- for sale
- Carb spacer
- Best plugs for my LS3?
- first start up tune
- throttle is sticking some ???
- Crank wear??
- I'm getting too old for this...
- Some amusing reading for you all.
- performer rpm material removal? update, pics added!!
- what power valve ???
- Msd 6010 vs edelbrock
- Sunday track videos
- Anyone know of a triple deuce setup for LS motors?
- MSD 6010 timing questions
- Project mini "Full Pull"
- Carb tuning question
- A/F help for n/a,and for bottle..lq4 fox
- Proform main bodys ???
- Spray on the fox
- 2 stage nitrous
- s10 carb 5.3 wiring
- Well I'm an idiot... I think I solved my problem.
- Trying a new carb insulator
- fuel system help!
- Pro comp
- My carburated 5.3 with naaaawwwwwsssssss
- what Holley Carb to get?
- what oil stabilizer ???
- considering carb swap on 02z28
- msd 6012 cam sensor plug will not work
- Finally finished my carb swap project...for now
- LSX Cam Bearing Clearances: What bearings are everyone using?
- 408 lq9, s480 turbo blow thru build advice.
- Foxbody carb 5.3 stock fuel system??
- edelbrock victory jr vs. gmpp single plane
- 671 blower
- Finally sprayed the Mustang
- iridium plugs
- Outlaw vs dom, vs DP?
- Does the MSD 6010 box have a tach output?
- MSD 6LS wiring too short
- Msd map table ?????
- new radiator new 160 thermostat ???
- msd 6010 cam sensor will not plug in
- Not too impressed with my times.. Need a little advice (VIDEO)
- Oil cooler?
- Finally got to the track with the new motor
- 408 vs ls1 on 150 shot
- Bleeding Cooling system..
- Testing
- What timing for drag only Carb LS1
- Tuning help
- Carb Issues please help
- Good timing curve for msd 6012?
- Wtt ls1 performer rpm for victor jr
- L92 or AFR 230's on LS2?
- Nitrous spark plug help.
- Hurst billet plus shifter?
- Test drove malibu tonite !
- Carb'd 5.3 with trick flow cam desperate need help!!!
- Stepping up to a 50cc Fr.
- Advance cam?
- what oill and weight ???
- Any zex perimeter plate guys in here?
- Got some new meat.
- Wideband time
- LS3 heads or not???
- Help!! 6010 pops in first gear at wot,stumble,pulls good again?
- carbed ls1 first start
- asked for a cam spec and wound up totally confused
- What exhaust ???
- A lil funny gas for the 75 LS Nova LOL
- Blowthrough 6.0 S480 5speed combo
- Analog gauge for the NGK AFX
- thank you Zone!
- Carburetor Recommendation
- Wheel question?
- Aussie drag combo, e85 carb/dizzy/mech fuel pump 10.1@132
- ***Carbed FAQ/what you need to know***
- Speedometer option
- my new ride for next year
- 5.3 build choices,
- New best but still short of my goal
- Wanna go for a Nitrous Blast with me?
- Ran the truck! Vids added!
- edelbrok vs NOS nitrous jetting
- 8s or bust!
- Edelbrock 28457 September Sale! $299.99 Shipped at SK Speed!
- Edelbrock to MSD 6010 swap...misfires at WOT..Help!!!
- MAP Timing with Speedtigger :p
- Anyone try the holley hi ram with a single dominator on top?
- Front 2 cylinders?
- anyone running different set of heads on same motor?
- Dads 75 nova got a new name
- Rear end Dilemma
- got ? what u guys think
- 0 timing ????
- Need new radiator
- hooking up nitrous with step retard on ls6 box ???
- At ls fest Car pops at 6800 to 7000 in 2nd gear
- MSD Bankrupt
- anyone running a 4L60E with a carbed LS?
- map settings
- need help selecting cam and carb
- need recommendations for a drag application lsx 443ci carbed no power adders
- 10 second combos..3500 lbs..NA
- Time for new parts,track soon
- Help please with scat crank rod combo.
- First time out
- Help !!!
- Msd 6012 newbie help
- new to ls1 world. a little help plz
- RIP my lil 6.2 stock short block
- Visit to the track
- Holley Flooding - Question on Needle Valve Assembly
- Zones89rs
- How much power from jet changes
- fusible link ???
- Carbed lq9 spark plugs?
- Msd 6010 vs edelbrock version
- Dad's 7 day 75 nova build
- Add a resistor when crossing cam sensor plug wires in MSD 6010?
- Your thoughts....
- The Stumper
- LSX 454 carb PVC connections
- carb question
- Plug gap ???
- mech fuel pump mounted correctly on front drive?
- carb jet sizes
- msd 6010 box problems
- My new 408 diesels a little when I shut it down.
- what braided fuel lines to use
- Gunna run at the track
- Va. Street Outlaws, Colonial Beach VA.
- S-10 witha 5.3 long term build
- Solid horse power recipes for LS1
- info on balancer
- Junkyard Carbed LQ408 Ran 10.920@124.82 on Motor
- Finally 5s!
- Need a favor. front drive distributor wire lengths
- Anyone have carb'd G Body with stock Hood
- fuel pump for motor and nitrous
- What does it take????
- opinions or best cam for ls2?
- New best with tighter converter in the 5's!!!
- bought this carb
- New best tonight
- Holley vs Quick Fuel
- 68 Camaro Lq4 build list, experts please comment
- got cam and head questions
- Tuning issues.... Vacuum???
- Little update
- Why is EFI Super Vic $100+ less than the carb version?
- What kind of #'s should i see with my settup ?
- 408 LS6 Cnc head on methanol 13-14:1
- EFI to carb...regulator? And possible nitrous later?
- new build
- Nirtous with the msd 6010
- turbo 6.0 blowthru on alk
- vic jr VS super vic jr
- 800 double pumper too much
- 3rd attempt to build 5.3...lol
- 2004 alternator how do I wire it up ???
- Msd pills
- 5.3 LM7 Longblock
- Max compression ratio
- Can you get ARP 12 point bolts for GM PP single plane?
- msd 6010 problem
- 5.3 Carburator
- Slow 6.0
- carbed lm7 carb issues? timing?
- Dyno results in!! 408 %video added!
- removing oil pressure sensor from top of block?
- 0 ing vac. advance ???
- Chrome Yellow '95 5.3 mustang convertable
- turbo 4.8 blow carb jetting help
- First time start. Absolutley no OIL PRESSURE
- 4th gen metal tank fitment
- QF SS 830 Tuning Help LQ9/243 ASA
- mounted my map sensor
- MSD 6010 6LS Ignition Box $275 Shipped - 2 Week Sale
- Time to tweak n tune.. Where to start???
- Mallory fuel log
- custom timing curve
- Need a timing curve...
- Carb'd 5.3 build...cam question
- 6.2l
- msd 6010
- fuel delivery
- Ls swap
- Edelbrock vs. Holley LS2 dual quad intake
- Pics Of my Junk....
- fuel pressure question.
- newLunati Voodoo LSX kit
- pushrod question
- Help @ thoughts on LQ9, 408, Vic jr, CNC LS3 head combo
- thoughts on my 408 LQ9 carb cam combo
- anyone willing to chat carb with me...
- Going Lq4 and need advice
- Finally started have electrical gremlins
- Base tune?
- 79 ls bu ... It's alive !!! VID
- Timing pills ???
- Msd 6010 grounds ???
- edelbrock pills
- Dyno numbers..
- New guy needs help with computers
- MSD 6010 problems..again! READ and HELP lol
- what thermostat are you guys running ???
- Build my 5.7 or go 6.0??
- msd 6010 ???
- Carb'd LSx into '64 Corvette Roadster (Build Thread)
- Need to get a reluctor installed in Western NY
- burnout competition winner! New competition new vid!
