View Full Version : Suspension & Brakes
  1. Brake pedal feels funny after line lock install
  2. rear suspension basics
  3. new brakes
  4. Launching Questions
  5. Brembo rotors of Ebay Seller IRotors
  6. QA1 rear shock help!
  7. Koni DA & Hotchkis Springs finished build
  8. need rotors and pads
  9. Car have to be on jacks to remove panhard bar or can i use ramps??
  10. Help!!!help!!!!help!!!
  11. Braking issues
  12. What benefits - sub frames?
  13. Nascar spring rates?
  14. Busted sway bar link
  15. Removing nut from rusty shock threads
  16. Help: need wheel alignment specs
  17. Tried To Install The BMR Torque Arm This Weekend
  18. Are rotors interchangeable?
  19. Shock mounting bolts for rear QA1's, what dimensions?
  20. Strano Bars
  21. QA1 Generation F Coil-Over Kit
  22. Spohn Torque Arm Install Question
  23. WDP INC. Rotors Feedback
  24. Shock bounce
  25. Torque arm + relocation crossmember vs torque arm + LCAs
  26. ordering Hal QA1 but got some Qs
  27. where can i get manual rack for my stock k member
  28. Body Roll?
  29. Somebody Help!!!
  30. Ok so I put the stock springs back on and...
  31. Adjustable vs non-adjustable torque arms
  32. Hal rear shock install questions
  33. sub frame connectors.
  34. Brakes...Disc Removal on an 02 Z28
  35. Did you have any problems installing your Spohn trans-mounted torque arm?
  36. Best 3 point subframe connectors
  37. time for suspension
  38. Will a trans-mounted aftermarket torque arm set @ 0 degrees still reduce wheel hop?
  39. what should i do ?
  40. Help!!! Virbration~!!!!
  41. Springs & shocks for street/strip
  42. Better pedal feel...INSIDE
  43. Vibration when braking
  44. Is my car lowered or are shocks just shot
  45. brake pad removal/re-install
  46. corvette line lock install
  47. Bleeding 6 pistons
  48. hawk pads & brembo blanks combo?
  49. couple of questions
  50. what size bolts
  51. adj vs non adj vs dbl adj
  52. LCA Relocation Bracket Question! Help!
  53. Which Angle For MADMAN'S Torque Arm?
  54. Installed Corvette rotors now steering wheel shakes?
  55. Brake problem
  56. Best SFC's??
  57. Loud scretch
  58. Adjustable lower control arm question
  59. Bang for buck brake upgrade? What rotors to go with hawk pads?
  60. yikes....I think I found my cause of vibration at 70mph+...pinion angle related
  61. car sits 3/4 inch lower on pass. front ( help?)
  62. Good Choice
  63. How difficult is a pad and rotor swap?
  64. out of alignment?
  65. Panhard Bar Installation
  66. Does a 9" need new, longer torque arm mounting bolts?
  67. How large are the rear brake pads supposed to be?
  68. Car is back together.....Something WRONG
  69. Anyone ever thought of this?
  70. new rotors any suggestions?
  71. Another question (can anyone help?)
  72. torque arm or not?
  73. 4 link kinda style suspension??
  74. Brake job question
  75. Brake Line Size?
  76. One side dusts mroe than the other?
  77. Brake Line Size?
  78. Koni SA rear
  79. rotors and brakes question
  80. Lowering Basics?
  81. help on which shocks to get?
  82. Do verts use same struts/shocks?
  83. diff between 3 channel and 4 channel ABS?
  84. Turn One pump
  85. abs inop light
  86. new rotor needed?
  87. where do i start?
  88. SJM Line Lock Kit: How hard to install?
  89. Panhard rod and Lower control arm blowout in sale section
  90. Bilstein Heavy Duty Shocks, how good?
  91. Bilstein HD's with BMR springs?
  92. panhard bar install
  93. How Long Before OEM Brakes Need Replaced
  94. Thank you Victor & Precision Brakes for my upgrade!!!
  95. anyone know the name/part number for the e-brake cable stop on the rear end?
  96. Lowered Cars with 315's
  97. Cracked my stock torque arm should I get a after market?
  98. BMR lowering springs
  99. Cutting rear springs?
  100. What's the weight diff. between Strano's 35/22mm sway bars & the '02 Z28 sway bars?
  101. New UMI tourque arm, lca's and panhard bar
  102. WELD IN re location brackets
  103. suspension... wut ???
  104. slp dssl
  105. installed my umi 3 point bolt in sfc's and spohn adjustable lca's.
  106. Need rear spring recommendation
  107. Brake noise
  108. SLP SFC's - instructions
  109. A couple of questions about removing rear isolators
  110. WHY an alignment after lowering?
  111. BMR Xtreme Torque Arm
  112. abs light and brake light
  113. Rear Springs ?
  114. Cutting 1/2 Coil on SLP Eibach Springs = What?
  115. adjustable STB?
  116. My Car Is A Turnin Turd
  117. steering column questions
  118. anyone make custom springs??
  119. After installing eibach lowering springs
  120. Right front has a metallic tap everytime I go over uneven road
  121. disconnecting front swaybar..(I'm a dork)
  122. Setting Spohn TA?
  123. Rocks eating away my rotor??
  124. need help with torque arm bolt!
  125. 325lb springs too much for drag racing?
  126. Wheel hop after hitting second...
  127. Fabrication?
  128. Difference from T/A to WS6?
  129. need opinion about lowering car after motor install.
  130. Camaro Brake leak
  131. specs for hypercoil rear springs
  132. What shocks for daily driving comfort?
  133. Upgrading to LS1 brakes?
  134. Where to get Brembo rotors locally?
  135. flapping sound
  136. power steering leaking and not working well what do i do?
  137. hit curb, need help
  138. Spring Rate Question
  139. Rear brake(left side) squeekes loud after brake job
  140. LG SFCs not meant for off road use
  141. Car sags in the Rear! Help!!
  142. PA Racing FitmentQuestion
  143. BMR Panhard rod relocation kit
  144. I know, I know
  145. Panhard Rod.. Which one?
  146. Air ride
  147. quick question about springs
  148. SFC Question??
  149. Wrecked my WS6
  150. anyone ever heard of A&W race cars?
  151. 04 GTO tie rod
  152. do 93-97 trans am springs fit on a 3rd generacion camaro or even 2nd gen trans am???
  153. P/N for front swayber endlinks?
  154. LS1 Rear Disk Setup on 8.5" 10 Bolt
  155. Subframe connectors. Bolt or weld?
  156. Koni help: Can't get the allen wrench in there.
  157. question about cutting springs.
  158. Rotors from WS6 store?
  159. will 02 T/A springs/shocks fit in a 94?
  160. !Front Swaybar
  161. A "Thunking" that is driving me bananas!!
  162. Help how do i get the calipers off??
  163. SFC Pictures
  164. play in steering
  165. Sping compressor for Strange shock assembly
  166. Brake crises
  167. Is an alignment necessary after spring/shock install?
  168. Removing ABS
  169. Jacking points for Tubular SFC
  170. will eibach springs for 2002 ls1 fit 1995 lt1 camaro?
  171. Aftermarket Torque Arm Necessary?
  172. Are my wheel bearings bad?????
  173. Umi LCA's, which ones?
  174. Heated Springs
  175. torque arm?
  176. 2pc rotors for the Fbody?
  177. raising back up wat to do wit relocation bracket
  178. Want to raise Pro-Kit rear
  179. Looking for a good SFC
  180. Spohn Torque Arm Installed *pics*
  181. whats for handling and whats for stiffening?
  182. abs inop and e-break
  183. Question on Brakes.
  184. What kit??
  185. BMR Lowering Springs
  186. Wtf No Brakes
  187. Ball joint starting to go out, how long do I have?
  188. Where To Buy BMR Lowering Springs?
  189. What DS loop
  190. How long does shipping take for springs?
  191. What do I need to hook my Spohn T/A to my 12 bolt?
  192. Rear air bag
  193. anyone know where I can get....
  194. Spindle arm/ball joint stud are kicking my ass...
  195. Wilwood 6 piston brakes
  196. One more Strano fan.
  197. Brake booster interchangeablility
  198. Help with front Caliper Bolts...they just keep spinning
  199. Shock tower nuts
  200. Is this normal for a chassis mounted TA?
  201. Help Swapping out Front Control Arm
  202. Need help with brakes for tire and wheel size.
  203. Adding safety loop to chassis mount torque arm?
  204. New Koni SA's in, what settings?
  205. Hotchkis or Pro kit???
  206. true duals + chassis mounted tq. arm?
  207. Any opinions on these slotted/drilled rotors from Ebay
  208. hawk HPS vs Ceramic
  209. what setup for street use?
  210. Heater hose mod done...now alot of squeking...any ideas?
  211. stb
  212. Something making a banging noise
  213. Help steering play problem
  214. HorsepowerTV Camaro airbag
  215. My ABS Inop light comes on...
  216. Next Mod?????????
  217. Koni Guys:
  218. Weld in relo brackets
  219. coil-over advantages
  220. adjustable coil overs maybe??
  221. Are there any benifits to having..
  222. Lower control arm question:
  223. New Spohn Torque arm in, new problem!
  224. LSx in what platform for road racing?
  225. lowering trans am
  226. Shock Set-up?
  227. twisted chassis
  228. Supension upgrades: Koni hose mod
  229. Koni / Hotchkis setup from Strano
  230. Brake fluid?'s
  231. Just get GM rotors and pads?
  232. Traction Bars
  233. Shock & spring swap completed - my story
  234. Exhaust hitting new subframe connectors
  235. has anybody had to change their tie rods?
  236. In the market for new rotors
  237. How to disable ABS?
  238. Suspension Help ! ! !
  239. can anyone help me wiith suspension parts?
  240. Pulling ABS fuse
  241. got my bilstein shocks, can some one -
  242. looking for a link.......slotted rotors, but not what you think
  243. A whole new animal after suspension upgrades!
  244. which ones?
  245. Shock question
  246. cheap angle finder!
  247. K-member
  248. lowering springs
  249. Vibration - bad strut?
  250. adjusting a non adjustable panhard rod??
