View Full Version : Gears & Axles
- What to do to not blow up 10 bolt
- rear question
- Stock C5 Axle Shafts
- From 2.73s to 3.42s
- someone point me in the right direction
- Parking Brake Shoe Assembly Sheared off! How to Replace?
- 9" swap questions
- need help
- halibrand rear end
- 4:10 A4 DR tire will they break
- 7.5 upgrade, with a twist...
- Are Precision Gears any good for an S60?
- Will this work?
- Anyone got a 9in narrowed 2.5in on each side????
- Need some advice
- How much abuse can a stock ford 9 take?
- S60 cost and weight advantages to a spool?
- 3.73 or 4.10
- Thick Gears
- round hole torque arm bushing ?
- ? on axles
- gear question
- Rear End Noise?
- driveshaft question
- 10 bolt has finally Pissed ME OFF!!! Need some advice.
- pix of Crush sleeve
- looking for a PST ALUM. driveshaft?
- thinking of beefing up the old 10 bolt
- S60 questions
- 10 bolt, 4 channel, 3.42 rear end will it work in my lt1?
- Tru Trac Carnage!!! PICS
- Driveshaft
- Anything special to do when swapping axles or is just an in/out deal?
- I desperately need a stock 10 bolt axle
- Vented bolt?
- Driveshaft... I think.
- 70 Camaro with a C4 rear end?
- How much to cut off my rear
- Torsen is SHOT!! Need Help..
- Passengers in Car with a Full Spool=them being :confused:
- 10% off all RPM Transmissions and Differentials !!
- Annoying squeek still there after rear end swap!
- 10 swap
- strange dana s60
- Repalcing gears on my car and I need HELP!!
- Posi traction problems???
- what size bolt?
- 8.5 inch 10 bolt
- Replacing rearend fluid-Couple Q's.
- a4 373 or 410 or 390
- HELP!!! Car wont roll!
- in the market for a rearend? ck this out!
- Ford to Chevy driveshaft
- Too good not to share. Youtube Link, How differentials work.
- Broken lug stud help!!!!
- 4.10's and gear whine?
- Strange 12 bolt or S60
- Locker vs. Wavetrac -- Need advice
- Need A workn 10 bolt(ILLINOIS)
- Quick Performance Ebay 9 inch
- U-Joints??
- gear choice advice...
- Midwest fab 9 with watts link and dual 3" exhaust over the axle
- How to find out if an used diff is fine?
- Grinding during light throttle cruising
- Spool Qs
- abs reluctor???
- turbo gear?
- drag radials?
- how did this break in my 10 bolt? *pic*
- Will going from 2.73's to 3.73's wake the car up?
- torsen diff.. what fluid??
- 98-02 driveshaft material question
- differential cover girdle fitment question?
- Where to buy axles for 9 inch
- my beefy 10 bolt build...(W/pix)
- where to get pinion crush sleeve
- How to get axle out from under car?
- Best 3.73 gears?
- Thinking of buying a used rear end...good idea?
- New to ls1. Help me please!
- 9'' driveshaft issues?
- Driveshaft Length???
- chrysler 8 3/4
- 9 inch center section is this a good deal
- Pinion nut torque question
- 9'' driveshaft quick question?
- 9" vs. S60
- need help replacing pinion bearings
- 3.73 gear 26 tire vs 4.1 gear 28 tire
- Rear end swap Install write up?
- Rear end hummmming....help!
- Looking for advice on Gears
- Rear End Reenforcement
- 12 bolt,3 series carrier,4 series gear
- Vibration Issues
- TA diff Cover & brack line bracket question
- Strange S 60l; 40 spline axles...
- Changing gears in a 9"
- LT1 non camed,M6,4.11/4.10 cars come in
- 12 bolt Moser
- DIfference between 3 and 4 channel axle length?
- 3.73's vs 4.10 10-bolt 'strength'
- 94-02 rear end gears
- Safety loop w/ lowered car
- Weird Vibration
- plan on building my own 9"
- Which Carrier?
- whats bad? carrier, ring & pinion or bearings?
- 00' stock rear end went out! what now? help!
- Moser 9 in rear end noise
- 10 bolt to 8.8" conversion and "Mini 4-Link" complete! Pics
- B-W 9 bolt rear...worth the hassle??
- How many drive to the track with a spool?
- gear change affect stall speed
- Questions on 9" width
- 3 channel abs
- Finally!!!!
- Attention Strange Driveshaft Owners...
- 2002 Zexel-Torsen 3.42s, which oil???
- Another question
- Help me pleaseee!
- 10 bolt mint whats it worth + questions
- Just Ordered my MW 9 rear end
- swapped rears what did i do wrong?
- c5 gears
- Why is a 9" such a mystery?
- What center section? ford 9"
- Greasing an S60??
- When did you break your stock wheel studs?
- Help, brakes won't bolt up on new MWC rear end
- Which is short axel on 9" ?
- MWC driveshaft loop won't fit
- Fab 9
- How stiff should a 12 bolt be?
- needing to put new ring and pinion in
- How streetable are 4.10s in an Auto?
- 3.73's that DON'T whine AT ALL
- is my stock 10bolt going to expload if i run dr's?
- summit gears
- What to do now?
- 3 channel rear in a 4 channel car?
- 12 bolt for 3rd gen Camaro ?
- Inner pinion bearing is bad, have to replace gears too
- Moser 9 inches
- 9 Inch or 8.8
- from what rearend is this?
- 12 bolt.. what needs reinforcing?
- 9in rearend question
- Looking for 7.5" GM/AAM 4.10 2 series gear
- Crazy question
- Need help determining a 9inch - 3 or 4ch
- ???What is the LIGHTEST rearend (street brakes, no drag brakes).....
- 12 Bolt Moser Rear Fluid Change
- T/A 10bolt cover worth it or not?
- camaro
- VERY upset with WaveTrac and Moser Eng.
- Exotic Performance Plus? WTF Mate?
- 00' 8.8 width vs stock 10 bolt
- Neapco u joint # 2-1153
- 9" rear end fluid leaking out the end of axle tubes onto brakes???
- transition from rubber to hard line on 9"
- Do higher gear lube viscosities rob power?
- Can I use a 4 channel rear in a 3 channel car
- Narrowed or stock length?
- ford 9 inch
- Which axle to choose for my 2001 camaro ss??
- what is good upgrade for stock rearend
- 1998 Ws6 with a 4 channel rear?
- Rearend Specialist In N.Illinois
- 2:73 to 4;10s
- moser 12 bolt issues
- Auburn ?
- 500 hp build. Any suggestions?
- Strong 10-bolt????
- broken u joint
- balancing driveshaft
- DR's with stock 10 bolt
- Stock Rear??
- Pic request on Thunder Racing Stud Kit
- 4.10's for Torsen?
- 48" driveshaft????
- going w/ a 9" and have some ?'s
- 10 bolt making noises when turning
- ?s for a4 owners with 4.10s
- Need strongest trans slip yoke available??
- Posi not working......
- what gears?
- Dowshifting w/ a Detroit Locker
- driveshaft to midwest 9" rear question....
- electrical plug
- 9" question
- diff help
- Finally got dead quiet 4.10's in my 10 bolt
- new gear retune?
- instructions for gear swap
- 12 bolt installer questions
- Drive shaft?
- Installed gears...now it whines: Advice?
- axle saving bearing
- What gear to go with?
- Question?
- Irs ?
- where to buy strange 12 bolt ?
- Does my drive shaft fitment look correct?
- looking for 9 inch housing and axles no center section whear do I get one?
- Carbon Fiber Driveshaft
- Ring gear trashed, 9" going in....
- Guys with BIG CAM and A4 and 4.10 gears?
- 3:43 to 3:73
- Gear guru's...check this out
- Found this
- 9" question.
- Axles swap
- installing my Moser 9... i got a few questions with pics
- gears?w
- 8.8 worth the trouble
- do s10 rear ends interchange with camaro rear ends?
- tire and gear?
- Need an important question answered before I purchase the wrong rear end
- Series 2 torsen in a series 3 carrier??
- 9" help
- Weight difference between a tru-trac and a spool
- 1 piece vs 2 piece driveshaft ?
- strange 12bolt vent??
- Welding Axle Tubes to Housing Worth it?
- Moser 9''/Jaws gear center section got loud all of a sudden
- ford 9 , with 4.11 gears question
- Moser torque specs
- gm 10bolt axle tube dia?
- Will this survive
- Clunking after 9 inch install
- Built 10 bolt
- Whining rear after just being serviced.
- Just bought a 9" and have some questions.
- Is there any difference between a MAC and TA cover?
- LS6 swap with MS4 cam with 7 5/8" 10 bolt eaton?
- Need full parts list for 9in install!
- Which is better for what im doing?
- Installing a posi unit, does anyone have a write up?
- 9" install with relation to driveshaft
- can anyone let me know what diff this is?
- Iron center section or Aluminum center
- some help or options
- long 9" 1350 yoke.
- S60, 12 bolt, 9 inch, which uses less power
- lt1 rear on an ls1?
- 9 inch noise when turning... normal?
- Going to 4.10s
- Help me piece together a rear end!
