View Full Version : Suspension & Brakes
- If your educated in the way of the torque arm come in!
- Vibration shelled my rear end
- choosing a TQ arm
- Tourqe arm umi or spohn
- My new stance!! Slam!!!!!
- Compressing springs -- how to?
- Back End Slams when i hit bumps
- Safest strut spring compressor?
- dropzone springs
- Stock Springs
- spongy brake pedal!!! help please
- My Wheel Hop has Got to Go!
- BMR spring users in here!
- Just Received my Koni's- Have a few questions.
- LCA relocation brackets
- moser makes good!
- Front Sway Bar End link size?
- whats the difference?
- suspension help please...
- yup got another suspension issue
- getting new suspension
- Getting ready for the track
- Do I really need an adjustable torque arm?
- I FINALLY lowered my car on Stranos....
- Got my 3 pt SFCs, tunnel mount torque arm installed
- Will these work?
- Drilled/Slotted rotors
- will corvette front brake calipers fit on a 2000 trans am?
- Master cylinder rebuild kit
- Cold or hot formed sway bars?
- Front drag shocks
- Removing Rear Isolator Question
- Squealing brakes...
- need a better ride?
- Brakes make weird sound..
- What needs to be modified to use C5 caliper abutment with the LG bracket?
- Caliper / bracket colors....just an idea
- Suspension help
- eibach lowering springs which shock???
- Question?
- Brake Pads Dragging
- What are these called???
- What setting on the yellow koni's? What position for front strut spring purch?
- Need some help
- Lca popping/clunking
- Where to start with handling mods
- The next best shocks to konis?
- Stock Suspension
- lowering with no PHB. questions???
- brake issues...
- "ASR", "ABS INOP", "BRAKE" lights all on!!!
- Stranos and konis overkill for a DD?
- K member
- 12-bolt rearend improves handling
- Torque arm question
- Caliper Bracket Sliders cause rubbing? Help! BRAKE PROBLEM!
- Alignment Question
- Need Help Please
- Suspension questions
- dumd question about brakes
- Where in the heck can you buy caliper brackets?
- Brake pad question
- rear suspension questions.
- Torque Arm or LCA/PHB next???
- where can I get PAB's?
- How well can a 4th gen be made to handle?
- Just bought a 99 Z28..suspension help.
- Help: need torque # for front sway bar bushing bolts
- The dumbest Koni question ever!
- Strange drag brakes on my Moser 9", setup questions
- Broken Strut Mount
- Best brake rotors
- GTO calipers vs Vette calipers on f-body?
- front end question
- front suspension question...
- clunking sound on harder accelerations....
- Help..Looking for a good street suspension
- Koni prices going up Sept 1.
- Will 3 chl rear brakes work on 4 chl rearend?
- Weird noise from right rear.
- Shortcut for compressing springs?
- anti pogo washers???
- Rearend wiggle
- stock rear sway bar on moser 9"
- ALL i have to say is Strano !!!
- installing a driveshaft loop. Should I use a poly trans mount?
- Bilstein SLP Kit = Firehawk Bilstein Suspension Package????
- break master cylinder help
- Drop that ASS!!!!!!!!!!!!!!!!!!!!
- Driveshaft safety loop?
- C5 brake upgrade
- What suspension does my 97 SS have?
- Has anyone ran there own brakeline w/o abs
- Bilstein shocks IN STOCK at Speed Inc.!!!
- ABS Light, Brake Light, ASR Off....HELP!!!
- springs and shocks
- who's got the best price on Brembo blanks/HPS pads?
- umi/qa1 front suspension issues
- Spring Question
- Spohn Adj T/A and Dana 60 Fit Problems
- UMI k member & a arms issue
- Bilstein's are back in stock.
- 3 point sfc's/torque arm? help?
- Anyone box their lower control arms?
- Adjusting ride height w/QA1's
- Time to Change
- Difference between Eibach springs... looking for 1" drop
- Popping from subframe connectors?
- Strano Swaybars
- Where can I find bump stops
- Does it matter which rear sway bar?
- Major Spring Problem
- Thinking of painting my wheels
- Best rear drag springs?
- Odd brake question...
- Rotor questions
- KYB rear shock install?
- What is this clicking sound
- How Much Do Hotchkis Subframe Connectors Weigh???
- What TA is right for me?
- 02 TA WS-6 want to drop it down and give it a sport rake. What options?
- QA1-R Ride hieght...where to set??
- will UMI tunnel brace TA clear with BBKs?
- so I added a 1le rear bar to my setup . . .
- rearend shited??
- Any substatution for a TA
- torque spec for upper a-arm
- No Brake Pressure
- Will a blown shock cause wheel hop?
- shorten sway bar end links when car is lowered?
- Just installed UMI 3 point subframer connectors
- how to tell if springs are bad?
- Limiting straps in the rear
- K member mounting bolt torque spec?
- QA1 (fronts) question
- xlr calipers on f body?
- Hotckis Springs..
- Sway bar End links..Not wanting to line up
- Torque arm question, yes I searched
- Adj Rubber panhard bar?
- Whats the top adjustment on a Adj TA for?
- GM 32mm sway bar
- oklahoma, free suspension components...
- WS6 springs????
- Subframe connector and LCA relocation bracket help.
- What shocks for DMS springs
- 3 inch drop
- front end clunking when brakes applied....
- UMI Performance K Member
- hotchkiss lowering springs
- lowering and alignment question
- A few questions about Bilstein Shocks and BTS kit
- Rear Spring Isolator Question
- Getting CTS-V Calipers to Fit
- Power Steering leak?!
- Opinions on shocks for multi use ready to buy this week.
- bought the $100 a peice KYB front shocks
- k-member bolts
- Ls1howto shock install directions?
- debating relocation crossmember, or chasis mounted TA
- Front Sway bar Bushings and Brackets
- Front Strut Removal? (LS1 How 2 is DOWN!)
- heater hose mod questions...
- BMR Crossmember
- "high performance ride & handling suspsension"
- Need help fast UMI TM Adj. TA clunking
- No Koni Warranty for 4/3?
- Tech II / Brakes
- Thanx ws6store for rotors!!!!!!
- UMI 2-POINT Bolt on SFC's
- What is more likely to bend first?
- lowering issues
- Rotorsonline...BAD! BAD! BAD!
- Only lower the front???? Pics?
- Ok I just put on some suspension parts???
- Bilstein Shocks
- Changing the SPRINGS...
- Phb
- Best Shocks for the $?
- what could it be?
- Front A arm Adjustment ?? UMI
- brake line swap....TCS...bleeding
- BMR K-Member install questions
- Panhard Bar Relocation Kit - Beneficial To Handling?
- lca help..
- Power Steering pump making noise & foaming?!
- Braking issues, help some help on this one.
- Modified Crossmember Brackets
- Strange Vibration, Does this sound plausible?
- PA K-Member--very nervous. Any one own one
- Brake weight reduction ideas.
- C5 Kit Hits Rim!!!
- Any Experience Road Racing a "BeCool Radiator"
- Technical shock expert needed here..
- What are these worth?
- OKLAHOMA!!!: 3.73's!!!
- Wheel speed sensor problems!
- Help WS6 rear rotors need info quick!
- What to do next? Picked up some suspesion parts
- BMR K-member broke
- OKLAHOMA:hotchkis sub-frame connectors!
- Line Lock
- Subframe Connector Help
- Konis/Strano Springs Installed
- sway bar question
- Stainless Steel Brakes, 4-pistons?
- Strut Mounts
- Still torque arm trouble need help!
- Bendix discs, any good?
- Braided power steering line question
- rotors keep warping
- not the typical lca debate
- QA1 front, AFCO rear, tall tire, M6 come on in....
- Where to buy caliper rebuild kits?
- why does my car feel so floaty?
- Where to buy Spohn LCA bushings?
- Brake Planet
- Strano springs on stock shocks
- Sam Strano! Help!
- SOM T/A drop pics
- power steering cooler/ lt1 radiator ?
- Oil dipstick hits strut tower brace
- Tokico HP Shock sale
- Rear parking brake dragging
- Sway Bar End Link Bushings
- Rear end noise when turning sharp only
- What causes "BRAKE" light to be on? ABS delete...
- Panhard Bar
- Strano spring noise?
- 60ft times
- Adjustable Rear Sway Bar
- Pinion angle confusion...Help
- Hard Rear Brake Lines
- Who repairs Q1A's
- sway bar link installation
- new wheels, time for brake upgrade
- Brake Bleeding Question
- What pinion angle for UMI torque arm on Strano-lowered Z28?
- what happened to the alignment sticky??
- abs delete question
- poly/poly or poly/rod LCA's?
- Edelbrock competition finalists!
- Wilwood brake problems
- Rear shock mounts
- Shock Options Please?
- Pics Needed of UMI TA
- Traction
- How to remove... ASAP
- Ever seen this? Broke my swaybar bracket. Pic
- Torque arm question.
