View Full Version : Fueling & Injection
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. A-1000 and stock tank
  2. Slow drop in fuel pressure
  3. How is this for a fuel system?
  4. fuel injectors blown ??
  5. Help! Injector question
  6. Electric street pump - low presure
  7. New fuel setup..
  8. What fuel lines have a teflon inner liner?
  9. Edelbrock Carburetor Conversion?
  10. good source ?
  11. R.I.P. Ultra 94
  12. any have complete fuel system diagram?
  13. 408 startup, any problem using gas from last August?
  14. Cant identify these injectors help
  15. Upgrade my rails or get regulator/bypass?
  16. Help - Racetronix wiring Kit
  17. FAST fuel system
  18. whats the difference between high and low impedence
  19. cobra injector in ls1?
  20. Fuel pressure @50 wot
  21. Fuel Line disconnect at tank?
  22. Siphonning gas
  23. First fuel mod
  24. Svo Or Delphi/lucas
  25. Injectors for a LS7
  26. Single powerful inline fuel pumps
  27. Erratic a/f issue, boost car, Moto 60s, Walbro, hotwire
  28. Fuel pump noisy on long drives
  29. My racetronics pump whines alot louder now. Is that normal?
  30. injector size
  31. interchanging locking fuel cap
  32. NOS Fuel Pump *loud whine*
  33. Where can I find pictures of 99+ tank plumbing versus 98 tanks?
  34. Can't find -4an female to 1/8" npt female fitting for FP gauge, please help
  35. how far can u go on stock fuel system??
  36. Low impedance vs. High impedance Injectors
  37. How loud is a in tank Walbro 255?
  38. How much rwhp is safe on 60lb. inj.
  39. Very weird problem fuel experts inside please.
  40. nasty fuel cell!
  41. Running race gas
  42. Filter Type
  43. Aeroquip Part # 15103 for connecting to stock feed line?
  44. Fuel Pressure Regulator...Tune???
  45. some help would be appreciated
  46. comp engineering sump kit for tank which one
  47. Straight tubing to hose fittings
  48. Lost Pressure with Walbro 255
  49. best place to buy injectors
  50. Denatured Ethanol Smog Cheat?
  51. tuning stock injectors
  52. Nasty Billet Fuel Rail install guide?
  53. Racetronix...
  54. fuel setup ideas
  55. Aeromotive or Weldon Regulator - Which to Use?
  56. Fuel system 101.....dual intanks, 8an feed, stock return
  57. Are FAST 36lb Injectors High or Low Impedance??
  58. Dam Fuel line (HELP)
  59. Stock Fuel Pump vs 30lb Injecters
  60. fuel system pics
  61. rusted destroyed fuel system?
  62. 99+ tank swap help please! Doing this tomorrow!
  63. Gas Gauge issues
  64. Will 30lb/hr injectors be big enough?
  65. stock injectors after head/cam swap
  66. Is This True About Methonal??????!!!!!!
  67. Fuel question
  68. Nasty's sending unit help
  69. What fuel line manufacturers are available?
  70. Fuel Pump install, Driveability???
  71. Fuel Pressure Gauge
  72. Fuel Pressure gauge install
  73. Can anyone tell me correct pressure???
  74. how much power can you make with svo 30's
  75. Larger injectors and gas mileage
  76. racetronics wiring harness instructions?
  77. svo #30 and no tune
  78. Throwing codes P0172 & P0175
  79. one for all you techies! :)
  80. Car Running Rough!!
  81. How do you disconnect the line from the rail?
  82. Which external fuel pump
  83. 39lb injectors anybody have 'em or know of them?
  84. Anyone heard of TRE performance fuel pumps
  85. How do I add an external fuel regulator up front
  86. Fuel pressure sending unit
  87. fuel pump problems please help!!!!!!!
  88. MS3 and heads what inj.?
  89. fuel rail install
  90. should I upgrade fuel system?
  91. how many HP is dual walbro's good for?
  92. how many HP is a dual walbro good for?
  93. 28.8 injectors
  94. 3800 series Supercharged 36lb injectors?
  95. hard starts
  96. Fuel Pump Booster Wiring
  97. wats a good replacement fuel pump
  98. Running rich/lean on fuel?
  99. Purge valve question
  100. what size injectors on stock 01 vette ?
  101. Question about line sizing and HP rating
  102. In-tank pump for 70 F body tank?
  103. MSD Boost a Pump Function
  104. fuel press at 30psi walbro pump runs nonstop
  105. Need help finding "Y" fitting
  106. How to mix Xylene?
  107. fuel system for my 402
  108. Translator
  109. quick plaese!! what is the stock ls1 fuel pressure reg supoosed to be set between??
  110. Feed the front of the rails or the back???
  111. Lucas/Delphi injectors
  112. No spark/fuel (getting 12v to injectors, no ground)
  113. On my way to a better fuel system for my 04' Veet FFS
  114. Pressure Regulator Pipework?
  115. Need help with fueling!!!!!!!!!!!!!!!!
  116. Octane rating
  117. What size injectors?
  118. Ideal injector size for my set up?
  119. Need a 42# table
  120. How are the 60 pound racetronix injectors in daily driving?
  121. New Racetronix Fuel System for Sale
  122. Kenne Bell Boost a Pump
  123. Which External Fuel Pump..please vote
  124. Car is idling really bad and misfires and sputters when I step into it
  125. Fuel injector size?
  126. What years did the F-body have a steel fuel tank?
  127. Pics of my Dual Intank Walbros
  128. Impedance Converters
  129. 97/98 C5 stock fuel rail question
  130. 190 LPH fuel pump from my 5.0 question?
  131. Are all injector brands created equal?
  132. Pumping gas
  133. How important are flow-matched injectors?
  134. How do I get the Injectors off the fuel rail?
  135. big injectors - problems
  136. Upgrading fuel system?
  137. small fuel leak(s)..can a sealant be used?
  138. Injectors and Fuel pump Questoin !!!!!
  139. Gas in the OIL
  140. Inj duty Cycle %
  141. fuel system for ls2 gto anybody making any
  142. Ethanol And E85 Alternative Fuel
  143. Stainless braided fuel lines and fittings
  144. Where can I get this hose???
  145. SVO injectors... What years fit?
  146. Aeromotiver fuel rail question. Where to mount???
  147. Stock Injector flow rate '91 Z28
  148. Do I need bigger injectors?
  149. MSD Boost a pump
  150. High pressure fuel hose??
  151. is this an ls6 or ls2 intake manifold?
  152. Picture of Racetronix dual pump harness..super quality.
  153. fuel system for 402/turbo??
  154. what is needed for a 408?
  155. really bad misfire
  156. 42# injectors 1to1 regulator 8-10#s boost
  157. Question about fuel pump line inside tank.
  158. help guys, need it asap!! thanks fuel line removal, no qick disconnect piece
  159. Shitty fuel milage
  160. fuel line adapters: AN to factory style connections
  161. Fuel pump from the top?
  162. What is THE regulator to get? for 4 bar setup, and possibly for a DP as well?
  163. fuel pumps...big single what you guys running
  164. Anyone had problems getting Racetronix tech support?
  165. Question on fuel pump draw...
  166. fuel rail covers install
  167. how much injector will i need?
  168. ATL surge tank
  169. who sells the best fuel rails
  170. Dual intank write up
  171. Should I ?
  172. which injectors..............
  173. 60lb Mototrons @ 80% duty cycle, how much
  174. Racetronix/Hotwire Fuel Pressure fluctuates with nitrous
  175. fuel pressure problems
  176. upgraded fuel pump install recommendations
  177. Not accepting fuel...
  178. Fast fuel rails to stock lines....
  179. Picture of Harris Speed Works teflon fuel lines, Fast Rails, Weldon Regulator w/n.
  180. When do I need to upgrade fuel injectors?
  181. Fuel system vacuum?
  182. High Flow "Race" Fuel Filter - Needed?
  183. Boost Referenced Fuel Psi Reg.
  184. Gas pumps with ethanol stickers
  185. Difference b/w matched injectors & non-matched
  186. Trying to make sense of Racetronix injector flow numbers
  187. Injector advice -H/C + FAST 90
  188. What size injector should i go?
  189. Fuel system help
  190. Advice: When is it time to step up to a bigger fuel pump & injectors?
  191. duals and fuel lines
  192. Using E85 as a substitute to race gas on high compression/high boost motors
  193. Walbro in-line pump in the tank?
  194. Who sells the cheapest SVO 30#s?
  195. What size line, -8 or -6?
  196. Cooling Mist?
  197. injector part # 12554271 doesn't exist??? any help!
  198. 8-160#s or 12-90#s
  199. Advice: Need to purchase some 42LB injectors that are flow benched where to get them.
  200. Cheapest 42# Injectors..High Impedence?
  201. getting injectors out of fuel rails
  202. any body have atleast a 12 gallon sumped cell
  203. Installed Dual intank 255's
  204. how hard is it to install a racetronix fuel pump?
  205. ac and fuel line tool
  206. Help with FI fuel system
  207. where to get 160# injectors
  208. enough fuel?
  209. tuning for E85
  210. Fuel rail removal????
  211. Gas fumes from breaded lines???
  212. 42# injectors
  213. Installing MSD Inline booster pump
  214. Venom injectors ?
  215. what fuel psi with return fuel system
  216. losing fuel pressure
  217. Dual in-tank pumps
  218. help walbro 255 install
  219. LPH of stock 02ss fuel pump??
  220. Fuel Pressure drops to 25 psi
  221. engine surge when stopping
  222. SVO 30 or 42 lb injectors
  223. Running on pure ethanol
  224. What fuel pump for BIG Nitrous LT1???
  225. fuel system
  226. Need More??
  227. 60# injectors
  228. Fuel Injector Help!
  229. Need help choosing right injector
  230. How do I identify ls6 28.8 injectors?
  231. Should I upgrade my fuel system?
  232. ebay fuel system ?
  233. what injector size should i get???
  234. Mods and maybe new injectors?
  235. Tuning Before / After a Racetronix
  236. Please help me with my fuel system
  237. fuel pump sock?
  238. air/fuel gauge help
  239. Fuel pump install, wiring harness?
  240. little help please
  241. help with fuel pump decision....
  242. Cowl mounted FP gauge
  243. injector flow rates with a rising regulator 1:1
  244. the last fuel system you will need
  245. Truck Fuel Pressure
  246. fuel gauge not working
  247. ethanol
  248. fuel gauge weirdness
  249. Electric fuel pump?
  250. What kind of fuel pump?
