View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. need ls2 torque specs
  2. L92 stroker cam selection
  3. valve dropped, what would cause this?
  4. Arp head bolts
  5. Ragin Racin World Warhawk 427ci ECS2200 full build
  6. Does a stock lq4 have a 4" crank? or what size is it?
  7. Where Can I get some Hollow stem LS3 intake valves?
  8. ls2 pistons
  9. what kind of oil 402
  10. Va Speed. We'd like to apologize.......
  11. Any one use kellogg or Sonny Bryant Cranks
  12. LS3 @ 600-670H.p. with 7000-8000RPM possible?
  13. My old set up vs. my new to come set up:
  14. Cam is to big
  15. TSP - PRC CNCd L92's
  16. Ported LS3/L92 heads, What kind of results should I expect?
  17. Ls2, ls3, or ls7 exhaust manifolds
  18. Pics and flow #'s for TEA ported l92 heads,370 cfm!
  19. goat truck motor swap
  20. 408ci advice?
  21. L92 Options
  22. LS-3 cylinder walls...
  23. Going to L92s, few questions.
  24. LS Gen IV engines - detailed specs wanted
  25. lifters ticking. please help
  26. is a 2005 5.3 a 24x or 58x reluctor?
  27. where to get WARHAWK morel lifters ?? .... please help !!
  28. Help me get ls1->ls2 swap pcv figured out
  29. MAF sensor help!!!!!!!!
  30. How can I tell where you LS2 came from?
  31. 228r for TBSS
  32. 2003 LQ4 6.0 58X OR 24X -tooth reluctor ?
  33. anybody know the weight of a ls2 rod, piston, and wrist pin??
  34. Tall Deck Warhawk build/ tech info/ builder input
  35. balance
  36. 370 ci, Pat G cam. AI LS3 heads, FAST 102/102 sound good?
  37. Jesel lifters
  38. Ls3 deck hight
  39. LQ4 408 Build, need some help
  40. ls7 Comp Cams Trurion rocker upgrade
  41. Ls7 block or resleeved ls2 for a 427
  42. LS3 headed LS3/L92/LS2/6.0's... Hey...
  43. Has anybody Modified LS-9 ?
  44. What flow #'s #863 Caddy LSA cyl heads
  45. GM L92 wiring harness???
  46. 1.7 or 1.8 roller rockers
  47. TFS 215's on a 416???
  48. LSX Tall Deck blocks are in at SDPC
  49. New Cheatr cam " V.3" from TR
  50. can i install ls7 springs in a l92 head
  51. NEW LS-R Edelbrock head?
  52. LS7 ARP main/head studs/rod bolts
  53. How much lift on stock rockers?
  54. Ls2 advice
  55. RHS LS Race Block Capable of 500ci
  56. LS3 427C.I. Questions
  57. cammed 08 L92 into 01SS M6 where should I be (hp)
  58. Best double roller timing set?
  59. Speculation. TFS 235's or Ported LS7's???
  60. ls7 cam in a LY6
  61. Katech Performance logo T-shirt - A great stocking-stuffer for only $8
  62. IS 800FWHP N/A on pump gas possible with this combo?
  63. best oil pump for LS6 block......
  64. deck height
  65. Best aluminum dry sump 427 block?
  66. Cat delete
  67. Ticking Noise=New Cam=?s
  68. LS7 cam in LS3...
  69. Wiseco vs. Diamond
  70. What is my Compression?
  71. Ed curtis,or other pros-6.0 l92 big hp questions
  72. 4.8L crank in LS2
  73. High compression E85 L92 headed LS2/408, suggestions/experiences?
  74. 2009 Sema new LSX parts?
  75. Corvette Specials - www.PartsTaxi.com
  76. ls2 trailblazer 06 problem need help
  77. PAC 1518 springs on LS3 heads with XE-r lobes?
  78. VVT LY6/L92 (1.7) with LS7 (1.8) rockers... is it possible or even worth it?
  79. which vette to achieve 750hp goal
  80. What would cause a Patriot Gold Double spring to break?
  81. LS2 bottom end max hp?
  82. help
  83. Engine knocking after rebuild.
  84. 404ci stroker build
  85. Need some advice on a ly6
  86. Renegade cranks???
  87. HELP!! 6.2 heads&cam advise what 2 buy
  88. Aftermarket Harland Sharp LS7
  89. anyone heard of Livernois Motorsports?
  90. Will Ti LS7 rods bolt up to a stock 3.622-in crankshaft?
  91. how much power out of a ls 7 are u getting?
  92. Who is running a Morris Motorsports 427?
  93. L92 or LS3 swap into 2000 GMC truck?
  94. installing stroker short block on g8: LS2 402 or LS3 416?
  95. Which Ls3 Cam?
  96. Which cam for LS2/L92 heads
  97. CNC'd L92s by WCCH
  98. What should the cranking compression be?
  99. Getting ready for the cam swap
  100. 07 5.3 in an 05 gto technical questions
  101. combo help
  102. LS3 vs LS7 Fuel Rails
  103. Lq9
  104. What do you think?
  105. LS9 head stud kits now in stock
  106. check engine light need help with codes
  107. Agressive LS2 cam
  108. Need help with engine diagnosis... HYUNDAI FTL
  109. LS2 in CTS-V, change of roller rockers?
  110. someone tell me what the problem is with this block
  111. LS2 vs LQ9 Weight Difference???
  112. ls2 afr heads question
  113. LQ9 build ideas- forced inductions step in
  114. LS2 into my 99 Z28....opinions needed
  115. question about putting togheter 402
  116. down on topend power,need direction? help.
  117. LS Engine oil flow rate
  118. machining rear oil passage in LQ block??
  119. ls3 cnc heads
  120. Arias HEMI LS1 at SEMA show!!
  121. ls2 engine
  122. Milling L92s.....how much can I remove?
  123. L99 Oil Pump - Keep VVT - Remove DOD
  124. patriot heads on 6.6
  125. Anyone have LS3, L92 and LY6 factory cam specs?
  126. best cam for LS7?
  127. Need cam help for ls2 tbss
  128. 6.0 build help
  129. pics of-10cc dished tsp/diamond pistons
  130. virginiaspeed.com......new online calatog
  131. cam opinions/suggestions
  132. For Your Enjoyment
  133. LSX-R GM heads?
  134. Why did you buy the engine you have?
  135. discussion... LS3 vs. LS7
  136. LS7 Torque settings
  137. ETP 245cc rockers?
  138. L92 with VVT in a 98 Fbody
  139. Blower Cam for 2010 A6
  140. tick tick tick tick ? wtf ?
  141. Ferrea makes a 2.20 Hollow stem intake valve for L92 heads! Why no CNC'd heads w/them
  142. ls6 oil pump!!! quick question
  143. ls9 head gasket big boost?
  144. 427 versus 408
  145. Stock LS2 shortblock RPM/power limit
  146. LS3 head rear coolant passage...
  147. Confused - which pilot bearing do I need?
  148. Torquer V2 + L92 heads ??
  149. Where to search for a used LSx
  150. Square deck the block or not?
  151. max effort L92 cam
  152. Beryllium Copper Valve Seats
  153. Should I mill LS7 heads while they're off?
  154. oil problem and valvetrain
  155. L92 head and l9h head ??
  156. LS3 head milling...
  157. looking for some l92 answers???
  158. 2010 camaro cam install valvetrain carnage
  159. Stock LS2 Connecting Rod strength
  160. Deleting AFM
  161. 370 vs 408
  162. Should LS2 timing chain rub on dampner?
  163. LG G6XE Specs?
  164. Casting # 5364 ???? What cc
  165. Custom LSX Timing Cover
  166. Putting together my l92 short block for my camaro...critique my list of parts.
  167. What is the best block for 454
  168. Loud Ticking noise from TSP LS2 402
  169. MAF possibly dead, symptoms?
  170. wat track times expected?
  171. 2010 Camaro L99 vs LS3 valves
  172. Anyone had the heads off an LY6 yet?
  173. Need some help on a LS2 Stroker setup.
  174. Gen III to IV questions
  175. Stumped: LS2 Oil dissapearing
  176. ssr
  177. whats better
  178. jw
  179. Lifter tick on truck
  180. blower cam on high CR NA motor
  181. ls1 balancer on 402
  182. Another Morel lifter ??
  183. How much is to much piston speed?
  184. Big N/A horse power guys please step in
  185. All pro heads work with stock pistons?
  186. Hp numbers for 438 ci. L92
  187. LQ4 to LS3 Questions
  188. 234/238 in stock lq4 long block?
  189. stock 6.0 crank limits?
  190. Torque sequence
  191. LS7 Crank: Flat plane or Cross Plane??
  192. ls7 lifter question?
  193. ARP stuff...
  194. L19 head studs
  195. No vacuum at idle after cam/intake swap
  196. Dome piston for 4.030 bore L92 head
  197. Differences in LS2,LS3,LQ4,LQ9 and L92
  198. BEST Ls7 heads?
  199. 2.20 intake valve in an LS3 Head?
  200. AFR 205's or L92's on a 408?
  201. How do I know...
  202. Stock LQ9 w/ vic jr and carb-what cam???
  203. 4.25 stroke in LSX block
  204. GM LS3 Crate Engine Startup Procedure?
  205. g8 afm vvt cam swap
  206. Throttle Body size
  207. 454 ci ls3?
  208. Help with Compression Ratio!
  209. The new LSX blocks are in at SDPC
  210. block questions
  211. L92 Head?
  212. Thinking of using ERL???
  213. 5.3l (325ci) to 7.4l(454ci)
  214. A few heads and cams questions
  215. what # from this 402 combination
  216. Reduce the C.R for C6Z06 !! How ??
  217. 6.2l or 6.0??????
  218. Cam Gear
  219. price for used ls2
  220. Deciding on how to build LS2 for my project
  221. GI on my 6.0 build???
  222. LSX-LS7 Heads?
  223. what is this cam
  224. ls3 heads on to lsx454
  225. Lsx Block and Ls7 Heads
  226. More Timing Or More compression = More Power
  227. LS1 to LS3 Swap
  228. using LS3 injectors w/ ls1 harness questions
  229. ls2 block
  230. LS2 rotating assembly into a LQ4???
  231. lq4/lq9 internals and components fit to bare LS2 block?
  232. Max LS3 bore according to GM
  233. WARNING: if order Federal Mogul pistons
  234. LQ4 Build?
  235. what cars, suvs, or trucks did the LS2, LS3, L76, L92 come in
  236. Anyone running a 413?
  237. 116mph-117mph trap
  238. Mast Motorsports cam vs. comp cam for LY6
  239. Brand new erl ls series main girdle
  240. PRC LS3/L92 CNC'd heads (PICS)
  241. 6.0 aluminum block ?
  242. ls7 engine masters challenge
  243. Fu*k Trees!
  244. L76 engine
  245. 433ci out of a LS3
  246. 6.0L N20 Motor build up
  247. Entropy Aluminum Radiator
  248. buy an LS7 long block from GM or build a 427 with the ls7 block
  249. L92 heads... Spring seat pressure?
  250. 39 lb injectors big enough?
