View Full Version : Suspension & Brakes
- Front lower control arm bolt replacement.
- Shout out to FoundersPerformance
- “Brake” light after CTS brake swap
- 1999 FireBird ABS Light
- Torque Arm or Sway Bars
- Rough Rear suspension
- LT1 to 4 piston CTS-V brakes
- Koni STRT/Strano
- 8.8 guys
- Suspension help
- New approach to more angle? Daily /drift.
- Abs bleeding tool & securing brake lines
- Baer Extreme 6S front kit
- What to do for rear bump stops?
- ABS not working in abs/tc car after brake line replacement
- Before & After
- Brake discussion. An article from Brembo about fakes, retrofitting OEM stuf
- Anyone have drilled and slotted on just rears?
- Best OEM sized rotors?
- Aftermarket calipers 4th gen
- 2010 Camaro SS Strut Issue
- Rear axle brake lines on 4th Gen.
- Rear wheel on one side moves forward and scrubs while turning
- 4th gen Nurburgring
- Tunnel brace options
- Anyone tried these?
- Custom spring rates
- Eibach Springs
- 4th Gen K Member Fastener size
- Traction problem!
- Found out why the left slick was unloading so much!!!
- 02 SS 1LE slp ... lowering springs? With DA koni shocks
- First Rear Suspension upgrade
- Power Steering Pulley
- Strange SA Front Shock Want a Silver Spring
- Moog 1LE style bushings
- Koni Sport Yellow shocks
- UMI Products
- Afco da street ride quality
- Koni STR.T orange shocks are back in stock!
- Moog front hub bearings
- New calipers barely clear, problem?
- Is this part needed for bump stop?
- LT1 parking brake adjustment
- 69 firebird project
- Forgestar discount for Black Friday deal, 2020 version, ends 11/30
- Status of Koni shocks as of 11/13/20
- Parking brake shoe too wide
- Full Polyurethane Bushing Kits
- Dead spot in Steering STILL.
- wierd suspension issues??
- power steering pump knocking
- Suspension Refresh - 1998 LS1 Trans AM Convertible - 132k Miles
- What size are z28 rear shock bushings?
- Midwest Chassis Subframe Connectors Fitment Issue
- Moog problem solver endlinks...
- Brake & Rotors Options For 15s
- Best 60' on street tires
- Lowering car without Springs
- 9'' rearend hard brake lines??
- "Unbalanced Engineering" De-Coupled Torque Arm . . .
- Auto Swap Brake Pedal
- clicking from under center of car
- 99 fbody hits hard over some bumps in rear.
- Electric Brakes
- 2002 Cadillac Escalade ext brake issue!
- Front Control Arms - Stock v. UMI
- Looking for parking brake lever
- Chasing the best 60ft
- Bushings to go along with install of rack and front shocks?
- 2010 Camaro SS Brake Issue
- Quick performance 9 inch backing plates wont fit
- Can you run long tubes on a lowered car? My first TA I didn’t lower and had no issues
- Best value stock ls1 stainless steel brake lines
- wheel hop with 9 inch on fbody 2002 camaro z28 ss ls1
- Strano Spring and Koni STR.T Shocks
- QP 9” brake setup
- Sub frame connectors
- 2020 has meant a lot of shortages... but here's some good news
- MWC Short TA Install
- Suspension upgrade question on options for next year.
- MCA Suspension
- Spacers up front only or all four corners?
- Labor hours for complete suspension upgrade
- Blown SBC 48 Ford Coupe Suspension Setup & Scaling Video 1
- Leaning on wheelie
- Bembro brakes on 4th gen fbody
- Rear suspension almost finished
- Tesing brake system for leaks
- *Springs* sale 9/9-9/30/20 15% off
- need help with front suspension
- Umi lt1 k member on ls1??
- leaking abs module
- Panhard Adj Maxed Out, DSL doesn’t fit, help!
- Front end sits a lot higher after ls swap into 94 z28
- 99% possible 2 piston pbr floating caliper upgrade for the rear!
- Uneven suspension
- Aje k member
- Removing front sway bar.......negative affects?
- Best grease for suspension fittings?
- Whiteline PTFE lubed sway bar bushings - no squeak or snake oil?
- UMI Suspension parts
- Need new rack and pinion
- Ctsv 4 piston brakes under 17” C4 ZR1’s
- Best E-Brake cable?
- Rear hard line flare type
- 9 inch and umi suspension
- 17X9.5 Torq Thrust II's Big Brake upgrade recommendations.
- Rack and pinion
- Bottoming out
- Line Lock issue
- New here
- Power steering pump melted
- rear brakes 1993 trans am
- MWC 2 piece race arm
- 2016 CT6 caddy brembo upgrade (j56). Quick and easy!
- LCA Install - Do I need relocation brackets?
- 99 TA panhard/rear control arms bolts
- Rear abs sensor ohms value
- Drag Rear Spring
- Spohn LCA relocation bracket install off of car?
- What is the best K-Member for 2" primary 3" collector headders?
- Constant noise after Coilover install and UMI LCAs + PHB
- DIY 4 link suspension 69 Camaro
- Alignment specs
- Leaf Springs with Drag Racing
- DIY: How to Rebuild Brake Calipers (VIDEO)
- Brake Caliper Covers?
- Trial and error front brakes
- hotckis vs strano
- 2000 trans am rough rear suspension
- Ladder Bar Setup and Tuning
- Brake options for 9" with Torino housing ends (Big ford new)
- Koni SR-T rear bushing
- Viking coilover rebuild?
- Rear brakes
- Flynbye Performance
- 02 Camaro Vert UMI Springs
- Just a few questions.
- Slicks and Anti Squat!! Who else is running rear separation with Slicks successfully?
- Floating piston rear caliper upgrade
- Speed sensor cable
- Should new shock compress easy by hand?
- Front passenger brake dragging - replaced everything
- 2002 Camaro SS Convertible Chassis Stiffening
- Brake upgrade
- 1967 Impala SS big brake upgrade
- C5 vette column in 68 camaro
- Shocks and Springs
- 4th gen rear caliper difference
- Heim joints.
- Bilstein replacement rear shock bushings?
- Springs wearing out.....???? RECOMMENDATIONS on new springs/shocks
- Front struts recommendations and questions 94TA
- Suspension overhaul kit for comfort/ride quality on 01 WS6?
- Kmember Hardware question
- Tightening up steering feel
- Chevelle handling advice (mostly shocks)
- What is this rear caliper hardware for?
- I think my bump stops are shot
- 4 Link Angles | AntiSquat Line | Finding Center of Gravity
- Shimming front struts.
- Suspension tuning with Coilovers - Launching a drag car Detailed Talk
- spohns torque arm with true dual exhuast issues
- I have a question for a Coil Over specialist?
- 2000 Trans Am Rear Coil Spring Isolator
- Chasing stubborn wheel hop, shocks, suggestions?
- Turbo k member
- Tunnel Brace Hardware
- UMI upper & lower control arm install
- strano springs vs eibach prokit
- Koni Shocks - STR.T vs. Sport 4/3
- How do I wire a lighted toggle to my line lock
- Vibration right front
- Stoptech slotted or Baer Eradispeed rotors?
- CTS-V brake fitment issue
- Hydroboost Woes, 2 years of issues help!
- Any experience with Power Stop Z23 Evolution Sport Brake Package?
- Alignment Trouble
- thrust align after MWC torque arm
- Sticking brakes
- Budget IRS options?
- Can’t put jack stands under axle tubes?
- hard lines to which abs port?
- What do I need?
- Air ride or coilover
- steering issues
- Shocks
- Torque spec for body sway bar bracket for 99 Camaro
- Shock mount bushings
- K member
- Which Springs & Shocks
- ST 50080 35 mm Front Sway Bar
- brake line kit
- Abs module
- Buying a 4th gen Camaro, suspension feels odd - help
- eibach lowering springs front1.0 rear1.5
- UMI hardware kit
- No fluid to front brakes; line lock the issue?
- C5 Corvette Disc Brake Swap for 67-69 Camaro
- SFC gap
- Weird issue
- Silverado suspension Baja guys in here!
- 98 T/A Springs
- 2000 z28 suspension
- Rack and pinion bolt craziness
- Help identifying rear brake lines as need to replace
- Best Place to buy new Brake line
- 96 rs Rear drum to disc help
- Steering tight in spots after K-member dropped
- Steering column
- UMI/ Afco + Weight Jack Install Review
- Standalone ABS Brakes
- Rear QA1 Help
- Torque Arm install
- Shock bolts
- Time for new front end on 4th gen
- Can't Decide Between Two Suspension Kits
- Extended Wheel Studs
- 9" torque arm mount
- tubular a arms for street
- Lowering Question
- Brake pedal not returning
- what are my 4l80e torque arm options??
- Double Adjustable Shock Tuning
- Different wheel base lengths?
- Koni Shock Value Sale, live @ Strano Performance Parts, now.
- Talk me into or out of my next mod (98 Z28)
- Lowering rear only?
- Have to clearance trans tunnel for UMI Torque arm?
- Finally finished shock/spring install. Thanks Sam!
- Business during the COVID-19 crisis. We are open.
- LT1 parking brake woes
- Rotors and Pads for 02 WS6
- Viking shocks question?
- Wheel alignment
- Koni single adjustable shock ride height
- Bilstein Rear Shock Lower Nut Size
- PBR Brake Calipers
- Adjust lca or just leave it alone 1.6 60’
- Which spring
- quick disconnect brake lines?
- Question on Alignment after bushings
- Budget Friendly Struts for Drag Car Only
- Help me diagnose my brake issue : Camaro '99 A4
- Stainless Steel Brake Lines
- Downsides of Tubular K members and a arms
- New Rear LCAs and Panhard bar noise
- Brake system issues after installing zl1 calipers
- Rear ride height
