View Full Version : Gears & Axles
  1. Location Of Speedometer Sensor on Tranny?
  2. Whats the difference between the nitrous ready and heavy duty driveshafts?
  3. Gear Whine question?
  4. Is there any way to build a strong 10 bolt?
  5. Looking for ABS on my Strange 12 bolt. "Sensor not on top of pumpkin" help!!
  6. 3.5 CF driveshaft----->
  7. TC lockup switch
  8. What Tranny filter and Fluid to use?
  9. Parking brake will not
  10. Interesting topic inside here!!!
  11. ALL 1LE Trans Mount Owners, Have youhad this problem?
  12. Stiffer 1LE tranny mount part number
  13. How much hp/tq can the drivetrain handle??
  14. trans stuck in 4th for 30 miles, WHY
  15. WTF is wrong with my rearend?!
  16. Who knows......? (fitting size question)
  17. Help needed.. How do you remove the axles off the 10 bolt?
  18. Ring gear bolt torque for '99 Z28
  19. The Truth about 12 Bolt Rears please...
  20. Has anyone broken a stock 2.73 rear? If so...
  21. Speedometer not working!!
  22. Won't poly trans mount mod change pinion angle?
  23. Car pops out of reverse (normal)?
  24. lt1 tranny in a ls1 fbody
  25. Why does my TC only lock right with the A/C on?
  26. Lost close to 100rwhp through drivetrain: What could've caused it?
  27. Transmission Noise After Gear Change?
  28. 28" slick question
  29. Question on BMR chromoly K-member
  30. moser leaks out of the vent tube.. wtf?
  31. ST2800 lockup
  32. Chatter going into OD under light acceleration-HELP
  33. Strange's website???
  34. what is unlock/lock TC?!?!?!
  35. **Pro's and Con's to 4.10's or even 4.88's?
  36. gear change ?
  37. Stock tire height of a 245/50/16 GSC ?
  38. bad vibration/clunking question?
  39. Where can I buy a poly trans mount?
  40. Need gear setup specs: pinion depth and backlash etc.
  41. TP4400 vs TP4400E
  42. Ragtop99 did good
  43. transmission problem
  44. Rev-lok II question
  45. 12-bolt prices
  46. Do we have posi-traction?
  47. What year TA had a performance shift switch
  48. HELP!!Loud popping/Clunking Coming from rear of car only when Im going slow?
  49. 4.10 and moser 12 bolt on z28...
  50. how did i crack my torque arm???
  51. Does anyone know if the stock LT1 torque arm is interchangable with the LS1?
  52. Any info on the better sun shell,input shaft,and planetarys?
  53. rear end problem? please help
  54. does anyone have gears that dont whine?
  55. Synthetic or regular oil with an Auburn?
  56. Anyone have a stock Torque arm lying around?
  57. Motive Gear Question/Problem
  58. Mustang rearend on f-bodies??!!
  59. 4.10 Help
  60. rear pinion seal leaks
  61. Hitting the rev limit
  62. I gotta slight problem.
  63. How do gears affect dyno?
  64. What is a drive shaft made of?
  65. DRIVESHAFT
  66. Chewed pinion bearing...
  67. Question for ALL LS1 owners
  68. Tranny and/or read-end clunk?
  69. 3.73 Gears What's the best to buy??
  70. Poll of how many H/C cars running TA girdle...
  71. Whats this hose?
  72. Driveline slack
  73. Stock to 3.73
  74. Simple and prob dumb Q
  75. PY3400E in a N/A car?
  76. Bad Seal? Differential leak??
  77. Questions regarding an m6 to th350 swap, gears, stall,etc
  78. CENTERFORCE DF......NEED HELP QUICK!!!
  79. What is the secret too......
  80. How much leakage in the differential is normal?
  81. Which Sliks?
  82. MPG loss........3.23s to 3.73s
  83. LOOKING FOR V6 ANSWERS!
  84. Will GM Synromesh work in the 6 speeds?
  85. Drag Radials
  86. Can someone tell me how to change out the Manual Tranny Fluid
  87. 2,73 to 3.42's....what do i need??
  88. 4.33's --vrs- 4.56's
  89. How much can a stock driveshaft take
  90. Question about Transbrakes
  91. looking for some chrome ZO6 WHEELS for my C5
  92. BMR K Member... How do you choose which one? Please reply if you know
  93. 9" vs 12 Bolt......
  94. How strong is a Carbon fibre driveshaft
  95. My 3.73's are in!
  96. need help locating some tools for the trans
  97. GEARS AND CARRIER QUESTIONS
  98. axle spline ?
  99. What RPM to lock TC
  100. Is the dealer trying to screw me? Please Help!!!!!
  101. I need a 12 bolt. Strange or Moser?
  102. HELP ASAP PLEASE! Can't connect the master quick fit to the slave cylinder!
  103. 3:73's, Motive or Strange? Opinions Please.
  104. Tbyrne Performance Parts
  105. TH 350 dipsticks
  106. 4l60E removal and install instructions
  107. Will I break my rear-end if?
  108. Clunking noise when I repeatedly engage and disengage the gas pedal at low rpms?
  109. What is the Best RAM setup?
  110. Changing to 3:73's
  111. swapping from 4.10s to 3.73s
  112. Suspension upgrades?
  113. broken posi?
  114. How much fluid does a 10 bolt hold???
  115. How many broken 4.10s
  116. Is this normal?
  117. stock rear leaking?
  118. Warrenty Help
  119. Slave disconnect trouble
  120. 9" Rear End
  121. Slave cylinder help.
  122. Will I have to shift to 5th in the 1/4 with 4.30 gears?
  123. Please answer this question for me.
  124. Sintered iron and steep driveways....
  125. Royal Purple 85W40.... do I need the GM additive?
  126. Need Help Identifying Genuine GM 4.10's
  127. Moser 12-Bolt Performance Cover Bolts (one sticking out)...
  128. ANYONE HELP WITH GEARS!!
  129. Tranny moving?
  130. DS vibration
  131. code for gears
  132. posi???
  133. Pre Loading Rear
  134. Whats going on?
  135. MAJOR TRANNY PROBLEMS PLEASE HELP!!!1
  136. How rough is missing a shift on drivetrain?
  137. metco lca relo. brackets work on moser 12 bolt? weld?
  138. Is 3500 too much stall for a street car?
  139. Found someone to swap me trannies!
  140. Can't wait
  141. the best tran (AUTO)
  142. Ditching the 10 bolt for a 9" or a 12 Bolt...help
  143. Thorugh Out Bearing
  144. Hooking hard on the Street?
  145. Hydraulics shot?
  146. Switching from 3.23 to 3.73 gears
  147. t400 & 3.73's tach out in the 1/4?
  148. Help, gas pedal works when in Park but doesn't work when in Drive
  149. Shift Kit does it really help or really hurt???
  150. What gears do I need?
  151. manual shifting an automatic
  152. HELP?
  153. Anyway to do 2nd gear burnout in pre 2k cars??
  154. Wider 16" Rims
  155. 12 bolt with spool weight?
  156. Rear Gear Noise in a Convertible
  157. 12-bolt dripping some fluid....
  158. How do you check Pinion Angle?
  159. Another Ram 6130 bites the dust.....
  160. Knock Noise coming from Rear End
  161. Gears on Stock Rear End?
  162. Rearend Noisy. Is that Normal?
  163. Tranny went out.... question
  164. ET Streets on stock rear
  165. 2K silverado trans pan owners please come in
  166. What gears?
  167. What do you think.Th-400 all the bolt ons and 10 BOLT LAST WITH ET STREETS?
  168. which sway bar is better
  169. 3rd gear woes after rebuild
  170. Which one usually goes first??
  171. Beeffing Up My Tranny
  172. how much LSD additive in your 12bolt???
  173. 9 inch is in, but noisy
  174. Rear question
  175. Do SS's come with a Auburn carrier?
  176. What 12 bolt is better?
  177. Customer service @ Speed Inc.
  178. Is there a way to reduce gear whine.... cheaply?
  179. gear swap questions
  180. 4.10 gears????
  181. Will my rear handle this???
  182. SLP TC
  183. Shifting/Cluth Problems.
  184. 12 bolt Options?
  185. Motive 4.10's are actually 4.11's !!
  186. Gears
  187. $450+ dollars for second gears, 2 cones, and 2 shift forks?? WTF?!!
  188. 4.10's on a Torsion???
  189. Problems engaging 2nd gear
  190. Need some opinions...
  191. What usually breaks on a stock rear...
  192. **2001 WS6 gear ratio**
  193. Has anyone ever switched from a M6 TO a A4???
  194. How many quarts does my 10 bolt hold?
  195. what goes?
  196. Level 10 in latest HPP
  197. Are Moser 9 inch axles supposed to be different lengths?
  198. how to tell if master cylinder needs bled??
  199. Rear End Noise
  200. what type of a product...
  201. Diagnostic Codes????
  202. speedo help
  203. Nobody EVER had loud gears? I'm invisible? Just ignoring me?
  204. Is my rear end a 3 or a 4 channel ABS?
  205. SES light and ASR off all the time after TH-400 Swap.HELP!!!
  206. 10-bolt solid crush sleeve?
  207. Wanted: 10-bolt breakage reports
  208. Maybe the most newbie question ever!
  209. How do you know where to adjust the adjustable torque arm?
  210. pt 4400 in a 2001 owners please answer ?
  211. Nasty Nasty Gear Noise..HELP!!!
  212. Need some tranny help please
  213. How to take apart master cylinder?
  214. When racing, my car doesn't shift into the next gear?
  215. Question about Energy Suspension torque arm mount...
  216. What year did the LS1 cars switch to the better slave cylinder?
  217. SY 3500 Launch???
  218. What PCM connector block is C2?
  219. Driveshaft Q
  220. 3.73s...
  221. PT4400 on daily driver...
  222. Pulse Width Modulator....
  223. What would be the best TC for the 1/8?
  224. Moser 12 bolt with 1350 yoke. Driveshaft length?
  225. How to swap my TC-lockup from PWM to non-PWM ?
  226. real deal with N2O and trannies...
  227. 98 t/a
  228. Another Driveshaft Question
  229. Question on torque arms?
  230. Would a synthetic get rid of most of my gear noise ?
  231. Changed the tranny fluid last night, Uhhhh!
  232. How do we change all the tranny fluid: tranny and TC?
  233. BMR Standard tail shaft torque arm VS. Trak Pak style tq arm
  234. i think something's very wrong
  235. Getting custom EW tune....
  236. 19k GVW v. 24k
  237. New Street Twin - temporary pedal pressure loss - help?
  238. Popping out of third
  239. Shortest Shifter
  240. Motor mount ?
  241. Rear end rebuild?
  242. Driveshaft Question
  243. Tranny maintenance Qs
  244. Possible rear end problem
  245. Yoke for a ACPT Driveshaft ?
  246. RAM torque spec question?
  247. Wheel Studs - which ones?
  248. Moser 12 bolt - very loud! how do I fix?
  249. Who has the nicest rearend?
  250. Gear noise... need help
