View Full Version : Suspension & Brakes
- Founders Performance Newest Adjustable Poly/Poly Panhard Bar
- Stock Torque Arm bolt removal - unique problem
- ABS problems
- quiet torque arm needed!
- Do or die...Edelbrock torque arm
- best shock for ur money
- SLP/Bilstein ride comfort
- what 4 link/ rearend to get?
- BMR Torque Arm Relocation Crossmember adjustment questions
- Bought a Strange S60, do I need adjustable Panhard and LCAs?
- My first build thread. LPM, Koni, strano, misc
- Line Lock Fitment Issue
- blistein install
- Questions about bmr long tq arm and relocation member???????????
- Kyb/strano
- getting there with the suspension
- How to adjust Koni Lower Spring perch
- Bent aftermarket panhard bar?
- New tires, car handles worse, any ideas?
- rear axle & pinion angle question
- Suspension overkill?? Need advise!
- Convertible Tunnel Brace?
- any lowered 4th gens with BMR Trak Pak Torque Arm??
- Qa-1 rebuild, diy or send it out?
- Is the top of rear Koni stem supposed to move freely?
- Baer Rotors + Wagner Pads = Grinding
- Heater hose mod????
- Removing Control Arm Bushings
- Would a tubular LCA with Rubber Bushings allow for some articulation?
- Best lowering spring?
- sway bar and shock ???
- not all LS brake calipers are the same
- Noise with lca,phb, and torque arm.
- Looking to do the C5 Brake Upgrade, Have Questions
- New Braking Setup Advice?
- Lowered my 1998 and it sucks!!! Help!!
- New brake job turns into a PITA, rusted pins.
- brake proportion question...
- Manual brakes hard pedal cant stop!!
- need help, 1.9 60ft. with over 540 hp/tq
- 9"/12 bolt/S60
- needing a torque spec...
- UMI or BMR inside please, help
- I need a measurement from a 17" ZR1 wheel pleassee
- Question about lowering 02 camaro?
- 130k On Stock Decarbons what to do?
- cant find brake pads for wilwood calipers!
- Another abs/trac
- UMI Performance Labor Day Sale- 10% off and $9.99 shipping! 9-1 to 9-4
- Popping/rattling from rear suspension
- Sway Bar
- Bilsteins with stock SPRINGS?
- bent torque arm symptoms
- Need Help with suspension set up
- Looking for 4-piston w/ 17"..where do i go?
- help me decide what to do
- New Bmr Set up :)
- Removing ball joints from UMI LCA's
- Looking For Bump Stops...
- Handling setup ?'s wheels, tires, shocks, springs, etc...
- It's SCCA Nationals time... Closed 8/29-9/10
- BMR Tranny Crossmember
- What lowering springs are these??
- Stock lower control arms - 1998-2002
- Caliper Bolt Size/name/specs
- Flynbye..no answer or emails after order?
- BMR manuel brake
- What brake set up?
- What direction do the pigtails go?
- Looking for torque specs for the panhard rod brace
- Stock "Pan Hard Bar" Alignment Question..
- Routing Brake lines with Tubular K-Member
- which front shocks and springs?
- PA Racing Turbo Style K-member / Front Suspension SPECIAL!
- BMR suspension help
- F-Body 6-piston CTS-V brake conversion questions
- fastest 1/4 on just suspension?
- is air ride really worth it?
- Koni/Strano Stance
- E-brake, abs light
- Are lug bolts reusable?
- Warning: Check those 12 bolt torque arm bolts!!
- Help with rotors
- Poor Straight Line Tracking
- 1993-1997 GM F-Body G-Load Brace - Red
- 1982-2002 GM F-Body Rear Lower Control Arms - Red
- Slotted rotors
- Brake Question - ABS kicking in
- Jegs PHB Leveling Bracket
- Anything you order before midnight the 31st is FREE...
- Koni/Strano/UMI Installed (Showing Off)
- Having trouble installing umi torque arm. Help?
- links and bushings
- panhard bar
- Alignment Right??
- Torque arm mount issue - help
- tire rub... stiffer shocks?
- Anyone know the size of stock lca bushings???
- Brake pedal is mushy... Master Cylinder?
- Questions about strange coilovers?????
- Parking brake dis-engaging?
- High speed vibration 98 t/a
- I need new hardlines
- Front end problems?
- big brake conversion
- 67 Camaro front hub options?
- UMI - BMR - Founders (Panhard Relocation Bracket)
- BMR Relocation Bracket...
- My rear springs/shocks are crapped out. What are my adjustable and/or air options?
- Question For UMI- Brake Brackets
- Car seems REALLY loose when driving over 40...
- Need help with suspension
- Torque arm adjustable or non-adjustable?
- Torque Arm Help! *Pics*
- Founder's swivel joint vs UMI Roto joint
- Best "Budget" Shock for Drag and Street
- e brake loose after shifter install
- Koni, SLP Bilstein, and Strano springs--in stock
- best bushings with eibach prokit
- What plug extension is this for?
- pbr ??
- shocks and struts
- Getting the 60fts down.
- Paint Front Sway Bar - Will it Squeak?
- Need 13 inch rotors for 98 camaro with wilwood brakes!!!!!!
- Lowered daily driver alignment specs
- Tick master cylinder
- What did I break?
- Rear LCA's
- C6 ZO6 Brake conversion **PICS**
- Brake lights out?
- Wondering if there is any truth to this>>>
- Del-A-Lum bushings in front upper control arms?
- rear suspension help??????
- T/A wont align to specs PA tubular K member
- anyone tried these FRONT - STOPTECH Stainless Steel Brake Lines
- C6z06 6P/4P brakes
- Horrible tramlining, rear end all over the place
- Brakemotive rotors and painted calipers pics inside
- Looking for LT1 to LS1 brake conversion info.
- Rear caliper mount bolts
- sfc front mounting points slightly caved in
- That sweet Caliper look - Lets see them!!
- Best shocks/springs...Drag only car
- C5 18 tire rub?
- SLP torque arm bushing
- Best DD Suspension Set-Up
- qa1?s
- is adjustable for me?
- DIY Brake Ducts for less then 20 bucks
- Bleed brakes - 100% new system
- soon will be putting in rebuilt rack & pinion I need the PS lines o-rings?......
- vogtland lowering springs? SLP bilstein shocks.
- sjm abs delete kit help
- kyb agx are these good for a daily driver 01 z28
- Some suspension help :)
- question on brake conversion
- Post Pictures of Your BMR 1" Lower A-Arm Stance!!
- Front Brake Line Options
- Torq Arm Question / Swap
- Need new parking brakes
- Hardware question... anybody??
- Abs Inop Light
- quick question on stranos/bilsteins
- th400 swap torque arm question?
- strange sa front shocks and 300# springs question
- Strano springs stops braking nose dive?
- Squeak / Creak over bumps and rear brake howl
- Broke front driver side brake line, right out of the abs block
- Need some input on rear shock/spring or coilover setup
- pedal hard after sitting for about 6 months
- UMI: Any plans for rubber ends?
- Subframe connectors before alignment?
- C6 vs F-Bod (Handling) ??
- CTS-V brake lines...Flynbye or?
- 94 camaro eibach lowering kit
- Strano 3 way rear adjustable sway bar??
- Ground Control "Coilovers"
- ATTN: UMI Front Suspension Alignment Problems
- J&M/HotPart "Street" Lower Control Arms, Adjustable (1982-2002 F-Body)
- Video: 2001 Z28--former Strano Performance car in action
- Bottoming Out My Shocks....
- Upgraded Brakes Firebird??
- 3rd gen and 4th gen the same?
- Caliper rubs rotor
- Dropped off car at Midwest Chassis
- Making my own torque arm relocation bracket
- air lift anyone?
- Bmr steering shaft won't fit in the colum
- crazy idea - cutting rear bump stops
- Founders Suspension?
- Moog mount-Bilstein shock
- Pinion angle?
- Koni question
- Got an Alignment ?
- If I have an Adj. TQ Arm and Adj. LCA's, are LCARB's still necessary?
- Oooops
- How to fix the pogo effect
- Powder Coated Parts.
- rear drag springs??
- Powder Coating Koni shocks got a ???
- Summit drilled and slotted Rotors??
- Help me identify this sound....
- 2000-2006 suspension plus air ride aftermarket...
- Reprogram necessary with different ABS module?
- BMR springs and heater hose mod need feedback
- Rear Suspension To Preserve 10-Bolt
- Base to WS6 sway bar swap worth it?
- Pinion Angle: S60, All UMI & Strano Springs
- Need suspension opinions 2000 Z28
- My setup
- need advice on rear springs
- Torque Arm?
- Founders adjustable LCAs not long enough
- Can't bleed brakes!!!!!!
- rear end upgrade question
- Collecting parts for spring install
- Was Firestone BSing me?
- Brake Pedal Travel
- Serious Handling Issue!
- Need a new sway bar
- Ready for alignment?
- Help me decide on Driveshaft Safety Loop
- wheel bearing
- need new shocks for eibach springs
- Koni SA fronts allen wrench not working? Help Please
- changing struts and tie rods
- rhino ramps
- what drop to sit level
- Eibach pro kit
- Mix N Matched Shocks?
- c5 brake conversion for F body
- Using mt e/t streets
- Brake lockup abs, brake light on after alignment
- Replacing shocks, upper strut mount question...
- E-Brake help
- Where is Sam Strano
- Vibration at 60mph +
- What Spring with Tokico shocks???
- Where to buy brakes?
- Springy after new springs/shocks
- Best Brake Pads for Track use???
- UMI Panhard Bar Question
- Parking brake cables
- fine tuning suspension and AutoX
- Tuning konis for drag
- Wheel spacers w/ stock WS6 rims
- Kw Coilover VS. Koni 4/4 w/ strano springs.
- how much to pay for c5 brake kit?
- DIY Poor Mans Wheel Alignment
