View Full Version : Dynamometer Results & Comparisons
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39
  1. FM14 Results
  2. Proper Dyno protocol?
  3. New Dyno Numbers on 150 shot wet NX kit
  4. dyno my h/c car today
  5. N/A FMS 408ci Dyno & Video....577 RWHP!!!
  6. vinci accelerated lift cams
  7. Could a low dyno and bad track times be the result of an A4 2-3 shift hesitation?
  8. dyno numbers on 02 ws6
  9. Why does my bone-stock '02 automatic Z28 dyno only 280.9 rwhp @ 295.7 ft-lb.?!
  10. Shop owners, load dyno users.. which dynos do you prefer?
  11. These numbers look right?
  12. Replaced FM13 with FM15 (Ron Jeremy), lost power
  13. New dyno numbers with 90LSX,90TB Stock 346!
  14. 920+ Rwhp!
  15. GTO Dyno results with full Exhaust system?
  16. Preproduction C5/zo6 GMMG exhaust #s
  17. Bone Stock 01 SS Dyno Numbers
  18. Before and after LS6 intake
  19. Paging TSP: Any AFR Magic Stick results yet?
  20. Need to make 400hp cam only! suggestions ASAP!!!!
  21. Cartek Cam Dyno Good?
  22. Torquer Camshaft Dyno Results Within!!
  23. CAM dyno'd the car today
  24. Dyno Results
  25. Guess my numbers.
  26. New Dyno #s
  27. F13 Dyno Results- tuned by FMS
  28. Debate: high Dyno #'s or low ET's???
  29. Not happy with Dyno numbers at all!!!
  30. TSP 228R cam only results!!!
  31. NEW 400rwhp CLUB MEMBER!!!
  32. horsepowerenginering 434 dyno numbers 562/507 !!!!!!!
  33. TR224, LS6 intake, LTs, 3500 stall.....340HP/340TQ?
  34. Okay, what is this "dip" in my graph?!?
  35. Ati + Sm 370 = 687rwhp.
  36. New member of the 400 club
  37. any mustang dyno numbers?
  38. Just dynoed tuesday. Happy with results
  39. Going to do a good copmarison of Grott/QTP 1 3/4 headers vs. Grott/QTP 1 7/8 headers.
  40. DYNO # on = 224/220 .581/.581@116lsa + headers + intake
  41. Any TSP Torquer results yet?!?!
  42. HPE "S" Cam Dyno Results!!!
  43. Finally dynoed APE 370, Patriot II's, 238/244
  44. new dyno numbers...
  45. ATI new 8 rib setup Final results
  46. AFR LT4 H/C Dyno results
  47. my Stock #'s, whatcha think?
  48. FMS Cam, small head 408, 542rwhp/535rwtq
  49. AS Stage II 6.0L head dyno
  50. Highest HP AFR 205 car to date...
  51. Hows this for a correction SAE,uncorrected
  52. Dynoed 11/13/04
  53. Finally....441hp...394trq
  54. Added LS6 intake, stage 3 trans and car dynoed much lower
  55. Dynoed the car!
  56. HP From a Tune?
  57. I came up short...
  58. can i get 350 rwhp?
  59. These results normal?
  60. Dyno figures for Hooker LT's and TSP true duals
  61. ATI D1 Procharged Camaro - 538rwhp broken d/s
  62. First Time on Dyno... Odd Results ???
  63. New Dyno with slight tuning
  64. PRC 5.3's and Futral F15 cam dyno
  65. New dyno numbers are in!!!!!!!!
  66. Dynoed the SS
  67. Before/After pulley install
  68. Dyno Results
  69. Are these good numbers for a stock car
  70. z06 Before/After: TEA 1.5 swapped to AFR 205cc, lost HP
  71. Those w/stock heads, stock bottom end, N/A, T-Rex user, please post dyno graph.
  72. Dyno question???
  73. Anyone have any Head/Cam Dyno Results with the CMMG Exhaust?
  74. My first ever dyno .....
  75. Fresh 422", TEA AFR 247cc, A4 C5 Dyno results
  76. '99 M6 with boltons... low #'s?
  77. HP Numbers on the N20
  78. Dyno help w/ numbers please!
  79. Went to the Dyno yesterday
  80. AFR 205cc 346" Z06 501.3 rwhp, 454 rwtq!
  81. Sad Sad Day!
  82. A4 Dyno Tune
  83. anyone dyno a stock 00 z28
  84. got a time slip to go with the dyno #'s
  85. Any AFR results on A4 cars?
  86. My cam only results after adding the 90/90 setup
  87. Bolt Ons dyno-graph
  88. How is this 1/4 time?
  89. dyno #for my 99 SS
  90. What kind of power can i expect if i went turbo on my 408?
  91. ATI 8 PSI 8 rib, on stock head/226 cam car
  92. TR 230/224 Cam Only!!!
  93. Will I break the 400rwhp mark?
  94. DNYO Graph inside: C6 with a NX 150 HP
  95. Another AFR 205 dyno result: 490/443
  96. W/B A:F through cats... how?
  97. First Every Dyno Pull
  98. Converter Efficiency by Dyno Results
  99. Dyno related question
  100. SLP 402, AFR 205, TSP MS3, Rapid Tuning
  101. Freak dyno results?
  102. Dyno my car 4 first time (baseline runs)
  103. Best air/fuel ratio for making power and staying safe?
  104. Not and LS1 or LS2 - '04 Cobra Dyno
  105. T-ReX + 100 Shot = 528 RWHP, 580 RWTQ
  106. D-1SC stock heads and bottom end
  107. first time on Dyno
  108. Thoughts on dyno parasitic losses
  109. new dyno numbers 231/237 PPII
  110. 400rwhp and 523rwtq...
  111. Dyno results for ls6 intake...and short belt
  112. First time to the Dyno with our cam only cars
  113. First Dyno Results
  114. Any graphs with valve float?
  115. PP LS6 stage II Heads & TS 237 cam
  116. 98 Z28, M6, bolt-ons and small shot
  117. 250 shot on stock bottom end.
  118. Looking for dyno results of one cam but 112 and 114 LSA.
  119. results from Next Level Performance (Norris) dyno # VRS McDonald Motorsports
  120. TTP S3 AFR H/C Package Results on 03 Z06
  121. Dyno results for bolt on only LT1
  122. 422 results
  123. Just added alot of power, want to guess dyno numbers??
  124. Losing HP? How bad do i need the dyno?
  125. TSP 231/237= 67 rwhp gain!
  126. How much HP will these give me?
  127. Does this sound plausible?
  128. headers,ory,loudmouth only dyno#'s
  129. H/C dyno results.
  130. Post 9" Dyno Numbers
  131. 225 shot was fun! Dyno numbers on a 225 shot and new all motor best....
  132. G5X3 112 Cam Only Dyno Results: 434 rwhp and 405 ft-lbs
  133. Z06 P1SC, cam, LT's, methanol, tuning....
  134. Dyno numbers for a 98 Formula
  135. AFR 205 / G5X-3 Dyno Results....
  136. 2001 SS #'s
  137. How much RWHP will it give me?
  138. opinion on Dyno #'s
  139. My dyno #s...
  140. Speed Inc.-Single Turbo-348ci -844rwhp 813rwtq-stock pcm
  141. some nitrous numbers
  142. Old dyno of LS6 Intake hp/tq gain!
  143. TSP Magic Stick Dyno Results!!!
  144. Auto Vs. 6-Speed power lost to the wheels
  145. What are you guys seeing out of this combo?
  146. Best Headers
  147. Just added ported TB and ASP pulley
  148. WHO here on this forum, REALLY knows transmissions, converters & dyno's?
  149. TTP ATI Procharger Stock H/C ZO6 "606RWHP"
  150. Just back from 1st ever dyno - a little dissapointed...
  151. just dynoed my car today kinda low
  152. Is there anyone who Has Dynoed Holley Power shot or K&N Filter?
  153. Torque converter lock up on dyno question
  154. MTI G1 cam and Kooks LT header Dyno results...
  155. is 450 rwhp possible with these mods?
  156. good tuner in NJ/pa?
  157. first dyno results
  158. what kind of gains???
  159. New APE 408 dyno #s :) NA and with 150 shot..
  160. 346 with baby cam dyno
  161. 454 Impala SS Final Numbers
  162. Engine dyno in Dallas area???
  163. Difference between AFR on dyno vs the street
  164. Dynoed the Trex-GTP combo...peaked awefully early...
  165. dyno results for a stock 2002 ws6 m6
  166. What #'s to expect from my combo
  167. 01 Ws6 Dyno!!!
  168. 383ci 496rwhp Z06
  169. Any mustang dyno guys out there?
  170. First Time Dyno - Results good?!?
  171. HP seems a little low?
  172. Dyno Results: TSP 231/237 and Patriot 5.3 Stage II Heads
  173. 1998 Bolt On Results step by step
  174. Is This A Good Number
  175. 347 RWHP Bolt On LS1
  176. My Absolute/ G5X3 dyno...
  177. Race-Prep 434 91 Octane Pump Gas Dyno Results!!
  178. SAE corrected or actual rwhp?????
  179. Cam only dyno
  180. Just dynoed today at lunch... what do you think?
  181. Livernois C6 Head Swap Dyno Numbers
  182. Going back to dyno tomorrow for retune with LS6
  183. f10,tr228,cc228 dyno #'s..lets see what you got!!
  184. Speed inc. 427.
  185. 295 RWHP WITH LT's, Lid, Borla ????????
  186. More AFR 205 results: 481/417
  187. How Much HP Would an Exhaust Leak Rob?
  188. My first dyno runs
  189. oil pressure sensor pin outs for 98 LS1?
  190. New dyno #'s on 150 shot, still getting there.....
  191. 383dyno 360rwhp why did the car dyno so low on mustange dyno(what will it make on jet
  192. dyno tuning in san diego
  193. AFR 205, 60cc, 234/238, 90mm results
  194. First ever dyno/tune after new parts install
  195. Rwhp/trq estimates based on my setup?
  196. TTP AFR 205 H/C Combo Results
  197. APE 427 C5 Vette Dyno Results
  198. APE LS6 H/C Results
  199. My second Dyno session, still can't figure it out...
  200. APE Z06 Vette w/Magnacharger dyno results
  201. EZSS's Dyno Numbers
  202. Gained 15 rwhp with LS6 intake.
  203. Icon Autosports 408 Preliminary Results
  204. average #'s?????
  205. All my dyno sheets
  206. advise on exhaust gain/losses
  207. MTI Comp Stealth II cam Stage I trans and retune
  208. question...need to free up 15rwhp....
  209. First Dyno #'s
  210. Baseline for project Orange Krush
  211. Please post dyno #'s achieved OVER Pred/HPPIII
  212. Baseline Dyno Last Night Lid/LM/LS6 Intake
  213. Any HP gains with roller rockers
  214. Elevation Matter and dyno matter?
  215. my tr 224/224 cam dyno tune numbers
  216. Dyno Results 9/26 - 1999 Trans Am
  217. NEW #'s
  218. 365 RWTQ bolt ons
  219. Dynatech Supermaxx 1-3/4 LTs
  220. Dyno'd my car for the first time - 98 Z28
  221. Most disappointing modded ls1 I've seen
  222. good dnyo # or not with heads,cam.6.0l
  223. Full Bolt-On Dyno #s right on
  224. New Dyno Numbers
  225. Good numbers? and ABS LIGHT ON!!!
  226. SLP 234/228 cam/heads package
  227. Dyno in 3rd Gear?
  228. Dyno numbers with TSP "MS3" cam only??
  229. c1 cam only results
  230. Low Dyno Numbers With Cam
  231. New 383 TSP Magic Stick Numbers
  232. Good AFR 205 Results...
  233. NO heads or cam DYNO
  234. 89 TTA - 698rwhp
  235. Y2K Camaro cam only: FIRST DYNO!
  236. Cam Only Dyno Thread
  237. RWHP loss with heavy wheels. How much?
  238. dyno tuning ohio
  239. TR224 cam only A4 redyno dual/dual 372/365 locked (vs. magnaflow previously)
  240. How much rwhp will Fikse 17x11's cost me?
  241. Any idea what's causing this dip in my curves?
  242. Just dynoed and 02 w/Bolts/02 LS6 cam...
  243. what is your thoughts?
  244. new numbers from saturday 433/385 cam only
  245. Altitude comparison Here
  246. New car Dyno....
  247. D-Day
  248. Dynojet correction question?
  249. TEA stg 2.5 LS6 heads and G5X4 dyno and track times within.
  250. patriot stage 2 heads/comp cam/all bolt on numbers inside.....
