PDA
View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77
  1. Comp XR275 (222/224 566/568 112) cam. Have sound clips???
  2. 402-408-427 Motor Sponsors welcome
  3. LS7 Firebird anyone???
  4. blown 427 build?
  5. need 500rwhp+
  6. ls3 /lq9 mix and match
  7. who is happy with their LSX block?
  8. HELP !~!!!! Putting LS1 Windtray onto my 402cid Shortblock , But there is Problems
  9. PROPER WAY TO CHECK COMPRESSION to see if you need a rebuild
  10. Out with the old (carnage), In with the new.
  11. I Am Stumped!!!
  12. What is the longest stroke crankshaft I can fit in a Ls3?
  13. Aluminum engine parts appearance....anodized?
  14. New Engine Combo
  15. finally got my truck back from the shop this past monday
  16. LS376/515 Released?
  17. Best place to get an LQ9/LS2 block, L92 heads, etc?
  18. Wonder if they will be worth a damn...?
  19. what motor should i go with... Bang for the buck
  20. To good to be true?
  21. Changing my 402 setup, need input .
  22. Mod the ls1 or get the 408
  23. Max spring pocket cutter diameter for L92's.
  24. LS2/402 vs. L92/416 vs. LSX/434
  25. Forged my LS1 or 402
  26. When to use oil restricted push rods???
  27. Need Cam Advise.. 408, vic jr, 4barrel tb ect.
  28. what to clean the Head Deck with before intalling head gasket and heads ?
  29. Questions on timing chain interchange
  30. Rocker Arm Sequence
  31. DoD Oil Pan Swap
  32. Lifter Questions ..
  33. Feeding LSx block oil from the rear plug
  34. Will GM MLS Part # 12589227 work for TSP 402cid Shortblock with 4.010 bore ?
  35. I HAVE ARP HEAD BOLTS PART # 123-3610 what ARP LUBE TO USE ?
  36. ARP head stud kit for ls2 with l92 heads?
  37. l92 Valvetrain Choices?
  38. Can i install the Heads and then install the oil pan and covers After
  39. New everything + QTP headers = steering linkage does NOT work!!!
  40. lifter tray torque #'s ?
  41. Hogan's manifolds
  42. rear main seal help
  43. my baby ls3/l92/l76 is almost done
  44. ls2 cam help
  45. crankshaft relict wheels
  46. 461 Ci?
  47. Warhawk block users
  48. LS7 cam install....
  49. Will Mr Gasket Co part # 983G Crankshaft key work for an LS2 Eagle forged 4" crank
  50. 427 Engine Swap *pics*
  51. OK so spare me some trouble....
  52. LS7 head gasket pic
  53. engine swap
  54. Sneek Peak Of Prototype PRC Castings INSIDE!!
  55. I Need Help Plz
  56. 2005 GTO LS2-402, F1A 12psi, Custom ram-airbox by Katech
  57. Anyone using a gear drive instead of a timing chain?
  58. LS2 crank pulley removal
  59. A new, mild cam I need to get for my 402
  60. what fuel injectors will work with the LS2 intake Manifold ?
  61. 6 bolt heads
  62. how to preload Lifters
  63. l92 heads or tfs 235'S lets discuss for my 408
  64. Any sponsors have a stock cube built LS2 on the shelves?
  65. What size Pushrods would i need Switching from stock LS2 lifter to LS7 lifters ?
  66. Whats the downside of VVT?
  67. Forged LS2: PRC Stg 2.5, MS4 /w Fast 92/92 or PRC L92's, Custom cam /w L76??
  68. cam only car bit the dust, questions
  69. LSX block rear cover?
  70. Please help-solid roller lifters. which ones????
  71. Oil Pump Pressure Relief Valve
  72. LS2 Corvette vs LS2 Trailblazer
  73. Mast Motorsports Releases M-90 ECM Pacakges (Yes, with VVT capabilities)
  74. L92 Valvetrain adjustement questions
  75. Stock L92 Shortblock?
  76. Dynoed my 402ci l92,l76 today.
  77. I have some Fast Intake questions???
  78. LS2 heads on LS1
  79. 403 Installed, Having a hard time at Low RPM's in gear
  80. Best way to choke a 408 N/A..... unported GMPP L92 Intake FTL!
  81. Best Heads for 402 with Twins
  82. LS2 intake , but need a throttle Cable " BRACKET"
  83. Lifter questions
  84. ls2 timing chins
  85. Q: What has more HP than a Bugatti Veyron? Introducing the 1st Katech Air Attack Z06!
  86. SBC Pistons in LQ4?
  87. Is anyone using ET 6 bolt heads?
  88. LSX Head studs?
  89. Excessive oil in catch can...
  90. is this true?
  91. got the lsx 427 to the track with the new heads!
  92. best place to get a 402cid shortblock ?
  93. When switching from Stock to Aftermarket heads does it matter ?
  94. Ls1/LSX main studs?
  95. cam choice "wild" 427 LS3?
  96. Quick...LS2 timing set, is this dot to dot? Pics
  97. LS2 402 What cam to use?
  98. Guys using 4 barell TB's
  99. LME LSX 454ci fresh off the crate. (56k go take a dump)
  100. Is anyone using these ported L92 heads
  101. something a little dif *pic*
  102. Opinion: Will I need to flycut?
  103. How thick is an LS7 head gasket??
  104. valvetrain problems at track-Need help
  105. melling 295 oil pump too small?
  106. Melling Oil Pump & Double Roller in an LS2
  107. LS7 lifter pre load??
  108. Questions , Switching from 364cid to a 402cid LS2
  109. I Found Berrings in My Oil (PIC)
  110. 253/262- 640- 112 + 4
  111. L92 heads, stock 6.0 shortblock Tsp 233/239 cam 10.80's
  112. WTF called arp and they say they dont have them
  113. LS3 to replace my 2002 LS1?
  114. Valve Cover option for ET Canted valve heads?
  115. LSX Expert Needed (book Author)
  116. aluminum 5.3
  117. LS2 timing set and cam retainer questions (Pics)
  118. New Numbers
  119. Knock sensor location
  120. I had to say something......
  121. whats a good aftermarket cam on a stock motor
  122. Rocker Arm Studs and Guide Plates
  123. what heads for 416 l92
  124. cam costs...help?
  125. who carries morel
  126. 6 Bolt Block Comparison
  127. lq4 l92 heads?
  128. L92 heads take F-body to 9s on pump gas (NA)
  129. Timing Chain Loose?
  130. Cam swap
  131. want to go to 6.0L iron block need to know what will transfer
  132. 6.2L into f-body help
  133. can u put ls2 heads on a ls1 block
  134. Abnormal Oil Consumption
  135. ARP 234-5608 Main Studs - Am I missing something
  136. 403ci solid roller motor
  137. Need help on assembly
  138. pushrods
  139. Cam help with static and dynamic compression
  140. lsx swap into v6 98-02 camaro
  141. Got my AFR 205s ported/opened up for my 402
  142. ls2 swap
  143. Port and Polish Throttle Body
  144. Best Price On Rotating Assembly
  145. Speed INC Built 416CI L92 in 04 GTO
  146. EL Toro complete engine
  147. ls1 to ls2 block conversion
  148. Can I use the stock LS2 Pushrods and Timing Chain?
  149. New Service offering
  150. Diamond or Wiseco Pistons
  151. More ported L92 head pics
  152. Valvetrain Knock When Warm After Cam Swap
  153. Looking to do a cam swap, advice needed...
  154. part # for cam sensor harness??
  155. Cracked piston???
  156. Anyone have pics of the GMPP CNC ported L92 heads?
  157. Going back to stock
  158. L92 intake injector help
  159. what kind of power will this setup put down ?
  160. L92 Shortblock?
  161. Help me understand oil burning on decel??
  162. L92/LS1 valve centres?
  163. Video - Katech/Short-Throw C6
  164. check engine sing ls7
  165. 6.6 L92 cam?
  166. hp at wheels
  167. what torque specs on Stock LS2 Rocker Arms ?, and Stock lifter trays
  168. Need help deciding what cube engine to build
  169. is this the correct Part # for ls2 W/P
  170. would this cam sound stock or would it be noticble
  171. Brand new motor and broke crank
  172. Is it worth the money or should I go differently?
  173. Replacing Rod Bolts. Tips/Tricks Needed Please
  174. New motor.
  175. Mega Death Cam or MS4
  176. 427 ls2 pistons clearance
  177. Possible to make over 550rwhp
  178. L92 + Rhoads Lifters + High Lift Cam = Flat Torque Curve
  179. Need some help please! Found a motor.
  180. ECS Blower Cam
  181. ls2 cam sensor
  182. Cam Review LS2 C6 (Comp vs Crane)
  183. Is it possible to build a 400 ci motor on 5g's?
  184. Problems with ls1 i need help
  185. cam ID help
  186. Will my 6.0 internals work in an LS3 block?
  187. will these heads work?
  188. Anyone have Oil pick up Tube Clearance with bottom of pan , With the ARP Studs ?
  189. Torque #'s on the Front timing cover and rear engine Cover
  190. Is the base circle the same on a XFI cam?
  191. new head/cam for ls1 or lq9/l92/cam
  192. LS1 vs. LS2 crankshaft
  193. Cam swap
  194. Who can explain this dyno graph?
  195. Buy it or Build it?
  196. Warhawk Morel Lifters
  197. Nice Diamond Jugs *PICS
  198. GT11 + Dual Valvespring Noise?
  199. new cam specd out for the 408
  200. Livernoise Stg 3R.......whos used them?
  201. Trying to get Rear Engine Cover on , but its Trick , please HELP
  202. LS7 sodium filled exhaust valves. Any Problems?
  203. Cam Sprocket Torque #'s
  204. building an aluminum ls3 block
  205. ARP replacement crank dampner bolt info?
  206. Cam and stall Help, Best 4 my setup
  207. Scat crank flex plate bolts?
  208. About Rear main seals and Front seals on covers
  209. Removing Valve Cover
  210. Just ordered my 408 now I need a cam....
  211. Katech releases upgraded connecting rod bolt for the LS7
  212. iron block vs aluminum ls2
  213. Cleaner?
  214. 243's vs L92's on F.I. car...
  215. World Warhawk LS1X Heads
  216. Power out of a N/A 370ci
  217. PAC Spring Question (Beehive)
  218. Anyone make adjustable L92 rockers?
  219. Trickflow "as cast" heads or Dart port&polished heads from PM-Florida?
  220. New pistons should i re balance?
  221. lsx 484 cui
  222. LS6/LS2 heads on an LS1?
  223. When talking about Head CC's What is the Difference in 59CC and 64cc
  224. Oil pump questions . about if there is supposed to be an O ring from block to oil pum
  225. How large can you machine a LS 1,2,6,7 spring pocket
  226. I Need Valvetrain Advice.
  227. At what point are aftermarket main studs needed?
  228. Valvetrain Noise
  229. Rocker & spring for stock LS7?
  230. head selection dilema
  231. pushrods
  232. LS3 Coil Wire Designation
  233. Discuss: Does revving an engine in neutral hurt the engine?
  234. help with cam for 402
  235. Pontiac Valve Covers
  236. cam in a4 stock rear
  237. ARP main stud?
  238. head ?
  239. 6.2 truck motor vs ls3
  240. help needed: gm pn 17122490 lifters for ls2?
  241. L92 cylinder wall clearance/piston burn pattern question
  242. What injectors should I run?
  243. quick connecting rod question...opinions needed ASAP
  244. headgasket
  245. Some questions about LS3 heads\intake on a 2006 GTO LS2
  246. Need help with SCR and DCR calculations
  247. will stock lifter and stock rocker arm for the LS2 be ok for Patriot stge 3 heads ?`
  248. Need part #'s for front timing cover, rear main seal , rear main gasket and more !!
  249. ok so my compression is? l92 related
  250. Harland sharp L92 rockers
