View Full Version : New LS1 Owners - Newbie Tech
  1. New guy needs HELP!!!!
  2. burnouts?????
  3. Insurance claim question?..need help big time
  4. LT's and the corvette o2 senser ?
  5. Programming Keyless Remote
  6. PCV valve boot "fell" off...
  7. quick question about LS1 swaps!
  8. How much power should i have and what should i run?
  9. How much power...
  10. Air pump sound on cold startup
  11. intake lids that fit
  12. Any Ideas Ls6 Intake????
  13. Which is better for 1/4 mile? F-body or vette
  14. How to buy a muscle car?
  15. mod or not to mod
  16. skip shift installing
  17. Why do I WANT to do the "Drill Mod"?
  18. New SS
  19. Good Deal or Bad
  20. 98 block with wrong oil pan?
  21. Quality Headers
  22. New guy w/ ? about d1sc procharger
  23. need help in a hurry
  24. How much are LS1 Swaps going for?
  25. cheap cam (such thing?)
  26. I just got a 2002 TA WS6 and i have ? about the brakes
  27. Got Spray??
  28. Help a Noob
  29. Z06/LS6 Manifolds
  30. Newbie oil question
  31. SS Camaro... Stock SLP Airlid or not?
  32. Engine code
  33. cold air intake vs. aftermarket lid?
  34. Swapping a LS6 manifold
  35. Cam/heads
  36. Whats the next generation GTO supposed to look like?
  37. Performance Shop
  38. New here, looking for a LS1
  39. Mod Thoughts... please help me
  40. 1998 Trans am GOOD DEAL OR NOT
  41. free mods
  42. Using a 350 block with a 6.0 408
  43. How to take the t-tops apart?
  44. Torque Convertor question
  45. Newbie PCM Question
  46. 2 questions
  47. 1999 T/A Firehawk, Should I get it?
  48. mega squirt or carb kit
  49. rattleing in my exhaust
  50. heads and cam
  51. Does pontiac have a oem parts site like this
  52. Lowering springs?
  53. A little input please
  54. 9040 foglights
  55. New car alarm?
  56. oil pan swap
  57. I just hit 72,000 miles
  58. Safe REV range?
  59. HOW DO YOU KNOW IF A WS6 Is BEAT uP
  60. Crank Sensor Problem
  61. How Am I Doing??
  62. Are there any pictures of STE. THÉRÈSE PLANT
  63. How Long Will An LS1 Aluminum Engine Last?
  64. need info on head gasket
  65. electronic supercharger???
  66. new and want a 427
  67. Strange bubbling noise.
  68. 1/8th mile to 1/4th mile times?
  69. Initial Acceleration
  70. New and need info
  71. Mileage questions...
  72. Title Help
  73. head gasket
  74. newbie, noticeable rear end
  75. stock gear ratio in 2001 WS6?
  76. Slp Cold Air Kit On 02 SS???
  77. New LS1 Owner!!!!! Got An 2002 TA
  78. Need Help with LT1 Temp Gauge
  79. 2005 6.0 truck harness,HELP!!!
  80. Katech information.
  81. Crate motor...
  82. Possible air leak? WTF
  83. Exhaust?
  84. need some advice
  85. Warranty modding
  86. finished spark plugs
  87. TCS question??? help
  88. strange, help!!!
  89. fog light and asr switches
  90. Is a cut out good or bad?
  91. CompCams Camhelp...HUH??!!
  92. Differences between LS1 vs LS6 vs LS2
  93. what is the size on t.b.
  94. **BigBronco's Must Have LS1 Book List**
  95. Firehawk Specs
  96. New to LS1's advice appreicated.
  97. electrical help with my lt1
  98. Buying A used T/A.
  99. Thickness on Drag Radials?
  100. 98 Firebird Randomly Doesnt Start
  101. What's wrong with my 99 SS??
  102. Losing gas mileage
  103. Camaro Production Number?
  104. driver door sagging neeed help!
  105. Question regarding possible selling of SS
  106. Are the reinforced gaskets reusable?
  107. Cam and headers?
  108. Just got my TA
  109. Who has the most PMs?
  110. Swap steering wheel?
  111. German Castrol Question...
  112. head gasket question
  113. 10% Ethanol?
  114. New 02 Ws6
  115. GM Performance wire?
  116. Plastic Alternator Splash Gaurd
  117. What if...
  118. Did a burnout tonight and...
  119. fuel injectors
  120. Newbie Tech Questions...
  121. Which Lid to buy MTI or SLP...?
  122. 35th Anniversary question
  123. Convert throttle-by-wire (ETC) to cable - which ones?
  124. What would you do?
  125. What gear ratio do I have?
  126. V8 with no power
  127. TRex Cam.... Daily Driver?
  128. 2000 ws6 fair price?
  129. quick lid install question
  130. SLP Lid Question... Installation
  131. 97/98 k1500 vortech help
  132. What is this part number? 88894255
  133. driveability after large cam install
  134. Canadian ? on U.S. spec cars
  135. LS1, The perfect Jeep Wrangler Replacement?
  136. CNC for one-off requests
  137. LS1 Engine Ticking Noise
  138. Cam Question
  139. SS or not
  140. right tail light is obviously way brighter than the left. why?
  141. Brake Woes, Help!
  142. 86 Camaro Iroc & 89 240sx Coupe
  143. slp cold air induction
  144. I'm new to chevy!
  145. newb here, cam question
  146. Not sure what to do with the car. H/C or STS... both? I can't decided. Help.
  147. ported LS2 parts or ported LS6 parts???
  148. car running lean ?
  149. Ebay
  150. A very ignorant question~!!!!!!
  151. Seals Leaking
  152. 241 head
  153. LS2 parts in an LS1
  154. water temp and oil pressure gauge
  155. Very Confused!
  156. Stock LS-1 Need advice
  157. what you think?
  158. What does it take (mods and $$) to build a RELIABLE mid 10-second LS1?
  159. Should i get this throttle body?
  160. SLP lid question
  161. What thermostat to get?
  162. belt replacement?
  163. mti intake
  164. upgrading to 17x9 WS6 rims
  165. Got my first speeding ticket!
  166. Miles
  167. anyone ever reply to need parts nuber page anymore?
  168. Ok, what size is the battery hold down bolt?
  169. Headers and Catted Y or LS6 style intake and UDP
  170. street 10 sec pos?
  171. will i need to upgrade from a 10bolt?
  172. ls1 stock crank pulley install
  173. Lid Vs SS Ram Air?
  174. new here
  175. What year LS1 is in my car?
  176. Flow # stock 2002 ls1 heads
  177. Chevy Mirror Installed on a TA / Compass and Temperature
  178. Squeaking Clutch?
  179. Heads/Cams What does everyone have, how much horsepower?
  180. Exhaust Help Needed, O2 sensors.
  181. Insurance on a 17 year old
  182. fog lights
  183. whats the difference??
  184. In 2009 I'll be able to get antique plates...
  185. Looking
  186. skip shif wiring diagram !
  187. LS1, and LS7 headers?
  188. A4 gear ratios
  189. How loud is the SLP LM?
  190. Skip Shift Eliminator
  191. "skip shift" wtf
  192. slp
  193. parking tips?
  194. New Clutch?
  195. gears
  196. New Water Pump?
  197. What are solid rollers (valveterain)
  198. pulling codes
  199. Introducing new LS1 sponsor! :)
  200. Cam and Tuning
  201. f-body prices in the future
  202. head bolts torque
  203. Weather gets cold = oil leak?
  204. slp flowpac
  205. D-1sc
  206. 93 Lt1
  207. pro-charger or heads and cam
  208. Steel Braided Brake Lines?
  209. 400 goal
  210. san diego meet similar to that of gumball rally 3000
  211. NEW RIDE (00 Triple Blk Trans Am 6spd)
  212. "Taking over payments"- How does it work
  213. Good price on LS1/Trans combo pullout
  214. help finding cust gauge face
  215. help finding cust gauge face
  216. loan help/advice?
  217. E.G.R and A.I.R...
  218. rotor problem
  219. Towing with the camaro?
  220. LID ET Gains?
  221. Just got my TA!!!! now where to start?!
  222. Best headers for slp lm2 exhaust
  223. Cleaning Engine
  224. Low oil level?
  225. Whats the difference
  226. Owner's manual, service manual?
  227. Gains from cat-back?
  228. Tranny??
  229. how do i post pictures up?
  230. overheating...sort of
  231. need some advice
  232. Engine mount install help
  233. Mods?
  234. which Car?
  235. how long do you warm up ls1 in cold
  236. Hey to all
  237. Worth it??
  238. No Power, Please Help!
  239. New car and not sure how to spend my money
  240. Exhaust touching rear bumper...?
  241. LS6 Intake Install...
  242. Lower Performance At High Miles?
  243. Opinion needed b4 purchase
  244. 02 B4c Auto
  245. Hello
  246. Bassani Headers?
  247. Value of a stock, 80-90k mile LS1.
  248. 02 TA intake
  249. Help...this doesn't look good!!!
  250. WS6 Value
