- Harbor Freight orbital wax/polisher
- "ghost" flames idea question
- what are good jack stands made out of?
- BendPak is giving away a lift
- "Just in case tool bag"
- Retractable air hose
- Hoist repair?
- looking for a good 120 volt MIG welder
- what makes a cheap tool a bad tool?
- AC block off plate
- Powerbuilt Digital Torque Adaptor
- Welding take out my PCM?
- Anyone use a Harbor Freight Freon Leak Detector?
- Balancer INSTALL tool at Autozone
- The solution tool for Door Bars
- Can I use a NEMA 10-30P with a 220v mig welder to a NEMA 10-30R 250v
- Angle finder?
- MIG welding wire thickness for 16 gauge exhaust pipe, contact tip question
- Garage cooling
- going rate on metal buildings?
- Newbe at using air grinder
- Exhaust tubing bender?
- need help finding a tool to hold the crank in place..
- Tig Welder Used or New
- cutting hole on side of exhaust pipe for wastegate pipe
- Titan 72t 3/8" Stubby Ratchet - $12.99 - GO BUY ONE!!
- GEN IV valley cover?
- Welder Questions
- DIY Sheetmetal Intake?
- Pneumatic or cordless Impact Wrench?
- I need to replace air compressor's pressure switch with something else.
- Larry Lyles' DVDs
- cherry picker
- gonna make some headers, need some advise
- Roll Cage
- 4L60E Tools
- Need bolts for engine on engine stand
- Need Jack Stands
- Shop press for axle bearings
- found a cheap simple way to fill the transmission
- Help with Electronic Polisher and pads
- I'm wanting to get into fabrication, need advice on a welder
- Wheel machining help please
- Adding outlet for welder
- Getting my MIG equipped
- cen-tech 98614 harbor freigth ?
- 2-part Adhesives
- need help with dumps
- ls1 balancer puller
- motor location 2000 camaro
- anyone know how to find someone with cam dr?
- What 2 post lift for my shop?
- Anyone else buy new tools and instantly modify them for "improvement"?
- Do any lightweight, in-car jacks exist?
- Tig welder info?
- Garage Floor Coatings
- Tool for installing valve springs on LS2
- Flycutting Tool ???
- Template for porting heads?
- FINALLY finished my garage!!!!
- Decent 3/8 click torque wrench for $50 or under?
- What is this damn thing called?
- Started to learn tig welding today.
- Torque Wrench Question
- Rusting Tools
- How are yall cleaning your shop rags?
- HarborFreight Pittsburgh 72-tooth ratchet
- Turbo hotside
- Welding cast manifold???
- My review of the Duralast 3/8 Long Handle "Snap on Copy" Ratchet
- Hawk LS Series Harmonic Balancer Installation Tool & Other Stuff
- all inch tool box
- Does anyone have a template for a Front and Mid engine plate
- Oh guys I need some advise, building related
- Craftsman make a descent torque wrench??
- Want to build a 30x40ft shop
- Show off your tool box/boxes
- Tig welding a thick mondo flange on schdle 5 piping
- Scan tool for obd2 and obd1 $2000 price range?
- Does thinner wire weld thin metal better?
- Obd 2 scan program for motor and tranmission
- Scan tool?
- Used end mills
- Custom K member
- Sunex Tools - Snap-on quality, 1/4 the price
- What 2 post lift to go with?
- Harness Bar Fabrication?
- Who like this tool? PIC
- Compressor Question
- Fabbing a 9"
- I want to get a cheap MIG welder
- what wire for stainless to mild steel
- Lincoln Power MIG 140 MIG/Fluxcore welder?
- Starting Tool Collection..Need Your Help
- question for 4 post lift users
- Torque Wrenches?
- HVAC guys - Humidifier install Qs.
- who made the flycutting valves?
- Question about "Tim" style valve spring compressor tool
- Help picking out floor jack, lowered car safe
- Hitachi drill help
- What do you guys think of this welder?
- new to snow plow setup, please help
- I need a clutch alignment tool
- Anyone own/use Snap-On CT4858ho?
- porting bits? which ones to use
- opinions on Century 140 MIG Welder by Lincoln.
- Grease gun won't stay primed?
- Dammit! Broke my 1/2" torque wrench torquing the heald bolts!
- Need info ASAP on crank pulley removal/install tool
- What 37* double flare tool and bender?
- broken extractor in iron head
- low profile 2 post lift
- Heads Off Valve Spring Compressor
- Yard remodel with new tool !
- Having problems with my nat. gas wall heater shutting off.
- Spark Plug Gapping Tools
- jack options
- wiring
- header design/weld tips
- Custom switch panel
- Making bolt hole larger?
- Garage remodel
- What thread chasing set(s) to buy?
- What tool for the job?
- Looking for a MIG NEED ADVICE
- Need advice for a jack and jack stands
- Stripped Torx bolt
- aluminum welding is kicking my aZZ
- What tool?
- I know Ive seen them but what are they called?
- battery hold down...need ideas
- hf model 67045 low profile jack?
- Need some help
- form-a-funnel
- Deleting ac airbox while keeping Heater assembly??
- carbon fiber hood
- AC in the shop
- valve spring compressor w/ head off??
- PSA: Flux Core wire on thin'ish metal is a bad idea
- Good pulley puller and installer
- Eastwood mig welders? any good?
- does anyone have a write up on removing the complete ac system in a camaro ?
- Guege bezel
- Problem with Air compressor 50gal
- Rhino Tools
- LSX engine transport stand
- how do you think this was welded?
- Mig weld steel on cast iron manifold?
- ls7 dry sump in ls1
- MaxJax residential 2 post lift on sale with free shipping at Northern Tool
- Promo. Code website
- Where can I buy a fuel pressure guage?
- Kent Moore Tools Catalog
- Moving vehicle with no rear wheels/axles on?
- Clearance Issues with swaybar and floorjack
- Valve Seal Applicator install tool?
- anyone use this summitt exhaust separator tool
- Air compressor - pressure washing tool
- Who has installed a 2-post lift on a residential slab?
- '04-'08 Chevy Silverado clutch pivot bracket upgrade.
- C5 electric power steering kit
- noob o2 sensor socket question
- Which of these welders?
- ABS/SRS Scanner
- new car jack low version junk or decent jack?
- How to properly back purge stainless
- Pittsburgh Professional (Harbor Freight) Ratchets
- Torque Wrench
- 110v TIG
- ordered me a new plasma cutter
- Quick clarification on Home Depot lifter rod tool
- Pros/Cons of using high frequency plasma cutter
- Power Invertor and Cigarette Plug Air Compressor
- Tools for an engine build
- custom roll cages
- Looking for...
- Jack for lowered car & torque wrench for *
- Preferance on stands?
- Kwiklift and non-skid tape recommendation
- Floor jack recommendations
- do i need a drill?
- without an engine lift
- torque wrench recommendation
- Wolfe Cage Door Bar Conversion?
- Digital Multimeter
- What can i use to clean my coated edelbrocks
- Do I have to disconnect anything to weld on my car?
- valve spring tools
- Ac vacuum pump keeps shutting off
- anyone tried the NEW Open End Ratcheting Wrench's?
- Best Tig Welder?
- LS Engine Transport Crate Dimensions??
- Welding Cast Iron Brake backing plates
- aluminum heads + chain = ?
- Shopping for a Torque Wrench ???
- Craftsman vs. Kobalt Tools
- Mig wire size question
- Recommend a good welding unit.
- Snap Rings on a Dana 44.
- Husky Aluminum racing jack broken?
- Sub-frame connectors
- SX2 MiniMill [Pics and Very first cuts]
- Anybody need a good Ingersoll impact? 2132g FS...
- Gm performance parts tools any good?
- Bought me a welder
- Best 10,000 pound 2-post lift for the buck?
- C5 Z06 Wolf Racecraft cages
- Scanner for OBDII, ABS, airbag etc??
- want to weld my own exhaust HELP!
- School of Automotive Machinists : New CNC Class
- Where to get a tool to pull the pins out of the coil connectors.
- torque wrench
- mig aluminum ?
- Omega/Blackhawk 29023 / ATD-7325 Floor Jack Roll Call
- SPEED INC.- LS3 Valve Spring Tool
- Cad file for Plate where gauges go
- tool j 36660 A
- can a broken starter motor boss mount be welded back on with engine in car.....
- headrest mounted camera ideas?
- Just tell me if you guys can appreciate it.
- Impact gun for exhaust
- cracked block
- Power Steering Line fitting wrench
- injector bungs
- looking for good benchtop bandsaw
- Experienced welders and Ready Welder owners in here!!!
- poweder coating..
- help with 1'' impact gun
- Anyone tried one of these?
- can anyone tell me any info on these
- wire welder
- Any experience with Floor lifts?
- Miller Plasma Cutter Spectrum 125C
- Weight Reduction for 98-02 camaro?
- Welding Crack Headers
- Flashlight woes...
- Chassis Fabrication
- Good Jack/jack stands
- Best GLUE for automotive plastics?
- Check this out
- Dial indicator stand for LS1 cylinder head?
- Good Amp Clamps?
- Balancer puller/installer
- Rear crank seal installer
- Exhaust manifold help
- Self made Hot Rod Parts
- gas analyzer
- Flex Hone
- t tops and 25.5 cage?
