View Full Version : Drag Racing Tech
  1. Bias ply rear, radial front... how bad?
  2. How about a $1000 recipe? Come on in.......
  3. First time at track with new setup
  4. anyone running sloid motor mounts LS1?
  5. 12 bolt guys with 3.55's and higer (lower#)
  6. Holley Fuel Pump Hook Up
  7. Guys that have removed hvac box and the ducts from behind the dash....
  8. just weighed my car
  9. Ac Box?
  10. !catback question
  11. who sells travel limiters?
  12. NHRA Allowance on Rubber Lines
  13. Race gas, answer needed ASAP
  14. Starting Racing Business?
  15. Passenger side airbag pressure
  16. Remove M6 brake pedal assembly?
  17. need help ASAP on tires!!!!!!!!!!!!
  18. Tru Trac or Torsen T2R in a 10 bolt?
  19. Pics of car going through some changes!
  20. Dropped some weight=DAMN
  21. Questions for guys running manual brakes.
  22. anyone with pics of !inner wheel well plastic
  23. Spray in bedliner instead of carpet
  24. bmr alt bracket
  25. Jegs/Summit lightweight seat mounting??
  26. Daily Driving weight reduction
  27. Auto Weld Chassis Cages?? Anybody Run one??
  28. an breather size?
  29. Cage painting
  30. who is running the Meziere race pump?
  31. launch techniques w/ 28 m/t
  32. Hood clearance issues: Victor Jr. and 90/elbow
  33. Traction with 1 new tire and 1 worn tire??
  34. 4.56 A4
  35. New Harlan 2-Step/3-Step
  36. 12 bolt w/anti roll bar and wheelie bars FS
  37. Transbrake and two step
  38. Whats the best suspension set-up for the 1/4 mile?
  39. question on !Power Steering
  40. Advantages of 12 bolt over 9"?! I searched!
  41. Comp engineering shocks...what am I doing wrong?
  42. Got my lightweight carpet/rollbar/corbeaus installed *PICS INSIDE*
  43. Pacesetter 1 3/4 to Kooks 1 7/8 results on a SI car.
  44. 26 x 10 x 15 ET Drags, Scres, Tubes???
  45. I have a stupid question....
  46. how people run low times
  47. low traction
  48. Best way to launch A4
  49. Engine setback rules location of pedals?????
  50. Manual Valve Body guys, need sanity check...
  51. 12 Bolt T/A Mounting points?
  52. what rpm do you launch at??
  53. How much HP to lift front tires?
  54. Fuzion ZRI's// Tire Pressure???
  55. How do I move my battery
  56. 1550CFM Accel TB users, have an air cleaner question?
  57. lauching witha tci 3800
  58. battery relocation
  59. track temperature?
  60. think i can hit 11's?
  61. help with hal's
  62. writing a report on safety of non-pro drag racing - any info?
  63. ??McGard Lugnuts??
  64. Anyone know the motorcycle rules fro e-town/most tracks??
  65. hvac delete
  66. best way to launch
  67. any 4th gen with manual steering, no power steering?
  68. Shiftlight setting for stock redline.
  69. drag race muffler
  70. Taking out the front sway bar?
  71. tire pressure / Nitto 555R's
  72. Pic's of my weight reduction
  73. Harlan 2 step and trans brake?
  74. wheelhop during burnout?
  75. what should i do? (suspension)
  76. Battery Relocation Is Done! Pics Inside.
  77. Tubing thickness.
  78. Aluminum spool vs Auburn Pro in Moser 12 bolt
  79. Help me set up my car for this season....
  80. Driftbox - Revolutionary Testing Device
  81. Homemade!! LOL
  82. top speed with 4.56's and 28's
  83. Slightly bigger cam worth 2/10ths?
  84. Front mounted fuel cells. Bad idea?
  85. How to remove wiper motor and hardware?
  86. Launching problem
  87. what do i need to go from 7.48-6.99 cam only 1/8thmi.
  88. pics of 325/50/15s on Bogart d10s
  89. Almost ready for the track - pics
  90. what to expect
  91. Can someone take acouple of under hood measurements for me?
  92. Whats needed to run fast on stock internals?
  93. Anyone cut this out?
  94. What brand torque arm is this?
  95. v6 springs in the rear
  96. bfg dr air pressure
  97. Whats the weight...
  98. Coil relocation and wires
  99. Trying to decide which drag tires to run on my 15x10 draglites.
  100. Parachute Handle Location
  101. How much ET and MPH is an Electric Water Pump worth?
  102. How to fit 15x10s?
  103. Low Lead 100 Octane?
  104. anyone thats installed line lock, please come in.
  105. Homemade VHT?
  106. Which TH400 scattershield fits best?
  107. Coolant overflow tank replacement?
  108. Torque arm with Moser...
  109. What Drag tire for my 16x8 rim
  110. Screws for M/T Et Radials ??
  111. madman manual rack rubbing
  112. 12 inch rim pics needed
  113. HELP: how to launch a M6 car on street tires?
  114. How much gas do you run the 1/4 mile with??
  115. Battery relocation -- Will this set-up work
  116. Bogart Welded Floyd rt's
  117. What should I be running in the 8th of a mile?
  118. Anyone else have issues with their windshield fogging up under WOT?
  119. Need performance advice???
  120. Cutting radiator support
  121. Madman--SYA bars for stock K member?
  122. What OD driveshaft for full weight car?
  123. ?TH-350 with a 2.75 frist gear?
  124. She's on a diet!!
  125. Gears?
  126. Ultimate weight reduction!!!!
  127. Negative panhard rod angle
  128. what will blow out first?
  129. cAGE
  130. better bang for the buck.
  131. NHRA approved roll-cage for a vert?
  132. 1.41 60' on MT drag radials
  133. Were do you go to get a roll bar approved?
  134. Torque Arm ?
  135. What should this combo give me in the 1/4?
  136. mti x1 cam
  137. pull dash for 8pt chage install
  138. 26X8.5X14 or 26X10X15?
  139. Strange Brakes
  140. weight of gallon of gasoline?
  141. What do you think of this launch?
  142. Opinions on Desktop Dyno or other simulation software
  143. 325-50-15 MT Drag Radial Pics!
  144. NHRA Protective clothing rules help
  145. NHRA rules on Scattershield??
  146. Suspension advice needed
  147. Guys With 325/50/15 D.r. Help...
  148. Who has LTs, then mufflers, then dumps (not duals or w/ORY)
  149. Rear Drag brakes...?
  150. Custom Torque arm mount
  151. Need help on Battery Relocation
  152. d-zus on the front???
  153. Cage Requirements (T-Tops)
  154. Sanity check on setting TA vs Pinion *
  155. Locking converter help ET or MPH?
  156. Taking it to the Track
  157. Pinion angle and 60'
  158. Cam only?
  159. ET Streets, tube or no tube?
  160. 26'' or 28'' ET Street?
  161. Got the door bars out
  162. Car number size NHRA
  163. What is the best way to launch an A4 w/ 3400 2.1 stall?
  164. 1/8 mile to 1/4 mile time estimates?
  165. New custom lightweight red interior installed!
  166. LCA offset question
  167. Trailor Time
  168. LS1Queen Beats Hubbys times..
  169. how to deturmin power lost due to elevation
  170. Drag suspension and the effects of normal driving...
  171. Asr? By Pass
  172. Gut it out !!
  173. what gear are you in at the end of the 1/4mi?
  174. Help I want 10's N/A
  175. Help me get to the 12s
  176. ABS Inop. LineLock Install?
  177. Which set of drag radials?
  178. Remove front sway bar for skinnies??
  179. ZR1 fronts to skinnies 1/8th improevment ?
  180. M/T ET Streets walk around at top end?
  181. Weight in trunk hurt 1/8 mile times?
  182. Do you have a line lock?
  183. Afco question
  184. Manual master cylinder
  185. 18 inch Drag Radials
  186. Brake Line-Lock by SLP tricky
  187. reason for high 60'???
  188. Who here races at HRP in Baytown?
  189. Opinions wanted, home made SYAB for Stock K-Member
  190. Rod Ended TAs
  191. Spring Rates Continued???
  192. Adj TQ Arm and Qa1s?
  193. Mini tub questions
  194. Where can I go to race?
  195. 10pt. cage install pointers?
  196. Shortening axles and stock rims.
  197. Hoosier QTP install question
  198. what should i expect?
  199. E/Ts on 15x8s VS 15x10s??
  200. MS3 + 4.10s = what height tire?
  201. Need some torque converter advice
  202. ANy HP guesses for me?
  203. Racing seat question
  204. 9"/12 Bolt Guys: Relo Brackets Needed?
  205. For The racers!!!
  206. setttin pinion with bmr T-ARM relocater??
  207. Where to get HALS rebuilt and how much?
  208. Launching from 3800
  209. Help for the track newb
  210. Wheels and Tires drag set up
  211. NHRA Rules Question??
  212. front wheel sensor question
  213. looks like they stuck me a sweet tire pic in GMHTP
  214. Rear brakes
  215. Launching a 380whp M6 with stock 10bolt and MT ET Street DR’s with 125 ZEX wet shot??
  216. my rollbar
  217. Anyone running Weld Aluma-stars and stock brakes?
  218. Who makes a T/A that will work with a 9" rear?
  219. Will installing Weld pro stars make any difference
  220. Am I legal now?
  221. Anybody running MT bias fronts and Drag radials in the rear?
  222. rewiring delima
  223. Weight difference Moroso DS2's vs kumho 165 80's
  224. in line transmission filter
  225. Another Drag setup?
  226. Stealth battery cutoff
  227. Roll Bar Padding
  228. Drag Wheel and tire question
  229. A/C Evap
  230. Abs delete installed and now car won't start
  231. how to start pulling the dash?
  232. Traction Advice
  233. Hard top VS T-TOP
  234. Good shock/spring combo for launching?
  235. ideal drag racing setup...what do you guys think?
  236. Battery Relo. Question
  237. launching at the track
  238. Launching an m6 on nitto 55rs?
  239. TH400 questions
  240. I need traction!!!!!
  241. Benefits of C5-R over Ls1?
  242. Anybody using Kuhmo 165 80 R15 skinnies?
  243. spohn torque arm is binding bad
  244. 1.488 On rear for the Queen
  245. Tire wheel Combos
  246. Pro Stock Certification.
  247. What is the rear spring of choice? And whos running a rear coil-over setup?
  248. 325 radials + narrowed 2.5" = what do you think?
  249. Check it out, 3-link suspension calculator!
  250. 90/90 Direct Port
