PDA
View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77
  1. Are ALL hardened pushrods created equal?
  2. (quick response please)tb 95mm vs 92mm cable 4bolt
  3. LS2 Raptor cam info?
  4. Total budget build LS3
  5. what lifters should i buy?
  6. Are ls9 head gaskets better than ls2 head gaskets and why
  7. Quick Question about valve spring retainers
  8. anybody done a comp lsr269-13
  9. Ls7 cam ID? Pic
  10. what could have done this to my heads?
  11. Stock fuel pump mod?
  12. What intake should I run with 500+ cubic inches?
  13. Help pick heads??
  14. ls2 cam into l76
  15. Ls3 intake valve pushrod
  16. Question about my heads when changing bottom end
  17. Ls3 plug play cry conversion
  18. 2010 camaro ls-3 head casting...
  19. 6.0 pushrod
  20. Lifters upgrade?
  21. Cam bearings ?
  22. Need a head gasket for lq4 with ls3 heads
  23. Cam dowel doesn't fit
  24. VVT Phaser bolt tq settings
  25. My setup
  26. Building a big inch LS2. Need some help...
  27. My full build through AES LSX 454 ( +1000RWHP )
  28. How far can I push this setup??
  29. LS7 head gasket on LS2 block?
  30. CNC'd L92s worth the $$$?
  31. Best engine balance shop in Texas?
  32. Check push rod length after trunion upgrade?
  33. what H/C/I package for my truck
  34. Probe Pistons
  35. What modifications will i need to do to run a double roller timing chain?
  36. Will stock head gaskets be fine on my ls2?
  37. 235lbs on #7
  38. Opinions on build
  39. Looking for answers
  40. Eagle H-Beam rods and Crankshaft
  41. Best Complete Rotating Assembly?
  42. 440 CI smoking???
  43. How - To : Manley Double Roller Timing Set LS3/L92/LY6
  44. Head flow vs compression
  45. What should be my total timing
  46. Oil Catch Can
  47. u
  48. Any reason not to go with a 414 vs 402?
  49. L76 vs. Big Ugly Question...
  50. New Virginia Speed supercharger cams
  51. Lsx swap problems.. Cam position and tach..
  52. Are these Ls3 intake valves?
  53. Looking for NEW "Budget" LS3 ported heads with dual springs
  54. What rockers for bigger cam in LS3?
  55. What Timing Chain Do I Need?
  56. nos in L92
  57. LS2 Block w/ LS1 Heads
  58. Cam for carb LQ4/L92 heads
  59. AIRWOLF LS7 heads
  60. WCCH Small Bore LS7 heads
  61. Jessel Rocker Question
  62. will an ls1 crank work in an lq9?
  63. HELP, trouble starting LS3 416.
  64. LQ9 vs LS2 bottom end
  65. Recommended Spark Plug TFS 225 15#'s Boost
  66. Wanting 6.0 Aluminum Block Engine Info
  67. 600.00 water pump,is that right!!!
  68. PTV Clearance Question
  69. Ls7 exhaust manifold
  70. 6.0 build Suggestions
  71. Cost to install 427 shortblock?
  72. Attention Sponsors - I'm in need of Pistons
  73. ls1 into ls2 car
  74. 2010 Camaro LS3 into 99 LS1 TA questions
  75. Arp crank bolt keeps coming loose???
  76. Ls3 427 cam
  77. Luck with dropout engines from ebay etc?
  78. iron 415 for boost
  79. MAhle Ring end gap?
  80. g6x3 concerns
  81. WTB: LS2 Rods and Pistons
  82. ERL 454 (Dry Sleeve)
  83. LS3 question?
  84. Quick Help with cam install, #1 @ TDC, no dot
  85. Head Stud Q...
  86. Push rod ????
  87. Just want to beef up an LS2
  88. LS2 swap questions
  89. K1 Rods
  90. Scat or Manley Crankshaft?
  91. 6.0 370 500hp?? what do u think?
  92. LS3 shaft mount rocker arms?
  93. Which head bolts i need ??
  94. anybody running prc237s
  95. need help with head selection for 427
  96. LS2's Dont like to drink water.
  97. could use some help!!
  98. Question on motor size for 700 fwhp
  99. LS3/L92 heads with SBC/BBC valve Springs
  100. Help me Decide on a Rotating Assy LSX427
  101. I need more power! LS6 stage 1's and MS3 not enough for my 402ci
  102. 58x 7000rpm+ misfire?
  103. Would you cam a motor with 122k?
  104. Is this right depth rearmain seal
  105. P0016 Crankshaft position - camshaft position correlation (bank 1 sensor A)
  106. Any stock bore ls3's w/tfs or afr's out there?
  107. would i benefit by going....
  108. Need advise problems with C6 Z06
  109. Need help in determining the piston specs for my setup?
  110. Pageing Texas Speed tech.. cam questions
  111. cam help
  112. ls3 cam into l76
  113. l76 dod lifter rattle
  114. LS6 cam
  115. ls9 and l92 heads
  116. exhaust only ported l92 heads.
  117. cadillac LSA conecting rods
  118. cadillac LSA connecting rods...
  119. Lookinf or the goodson rrj-350 tool
  120. ls9 valve springe
  121. ls2 reluctor wheels
  122. John at Scoggin Dickey
  123. stock lq4,lq9,ls2,ls3 shortblock durability
  124. theoretical build
  125. SDPC ST4 cam?
  126. Cam bearing question??
  127. Ptv clearence ?
  128. 4032 or 2618 for a 450c.i. N/A setup
  129. 6.0l Boost build
  130. Who has the best price on connecting rods?
  131. Titanium vs. SS valves weight...pictured...
  132. Head Bolt Thread Size...
  133. What gaskets/hardware need to be changed?
  134. lq4 in an 84c10/ headers, alternator
  135. Mahle piston to valve clearance ?
  136. who has the best price 416-418 shipped
  137. WCCH Heads! LS3/L92 cylinder head shootout!
  138. new set up ...new cam??? chime in plz
  139. From 11.0:1 to 11.4:1 on head gasket thickness
  140. Stock aluminum ls3 or 416 or 427 cast iron
  141. New 408 buildup
  142. 3/8 pushrods in LS3
  143. Dart 250cc heads
  144. need opinion of exhaust pics...
  145. comp. ratio, l92 heads
  146. l92's on a lq9
  147. 317's on l92 short block question
  148. Compstar LSC vs. Stock LS2 rods ?
  149. Anyone got a toasted ls crank with the reluctor wheel still on it?
  150. I have some spare cash, how should I spend it?
  151. What Motor setup to do...??
  152. Morel hyd.Lifter PreLoad
  153. Cant Decide! HELP
  154. Matching up crank and reluctor wheel?
  155. 58x or 24x reluctor wheel
  156. Single bolt cam sprocket usable with LS1 PCM?
  157. displacement on demand?
  158. Comp Cams LSr question
  159. Reluctor wheel?
  160. Rods Question?
  161. LS2 Mismatched Rods?
  162. 402 REassembly
  163. 408 lq4
  164. Factory LS3 cam with Cathedral port heads
  165. New engine section
  166. Pics of LSA Heads.
  167. New GM LS7 crate engine Break In
  168. is pump gas and 12.4:1 doable on pump gas LS7?
  169. Head porting question
  170. GenIII Block into a Trailblazer SS
  171. Need Harland Rockers LS1 Torque Sqecs and Instructions
  172. Reluctor Wheel Run-Out?
  173. milling l92 heads
  174. little peices in my oil... any ideas?
  175. Help me identify this engine
  176. What lifters to get?
  177. eps 226/230 116+1 should I advance it?
  178. 08 Sierra Denali 6.2 !!!! comp 401 or 402 cam !!
  179. G6X3 cam ptv clearance
  180. COMP Cams Hi-Tech Oil Restricting Pushrod
  181. Rear cover problem
  182. Cam Theory: Carbed 6.0 LY6/ 6.2 L92 with exhaust manifolds
  183. Best cam for 4.30 gears m6?
  184. Cam help for LS3 418
  185. Low oil pressure
  186. Replacement valve guides for 243 head - Where to buy?
  187. exhaust ports
  188. VVT vs non VVT
  189. Lunati JP6125-8 Ls rods
  190. L92 headed 408 lq9 build.
  191. max lift allowable still keeping factory l92 springs
  192. Diamond or wiseco pistons
  193. LSX 376 or AES 390
  194. L92 throwing P0121 and P2138 codes
  195. L92/Lq9/other?
  196. Porting my LS3 heads
  197. Input on cam for L92 setup
  198. Best source for 427 LS3 short?
  199. newbie needs help between 2 setups
  200. LS2 cam sensor clearance with cloyes double roller
  201. Looking for a good advise and CNC shop
  202. 2007 LS2, 1 bolt cam in engine, aftermarket cam 3 hole, will it fit?????
  203. Yet another 408 thread. Thoughts?
  204. Intermittent rod knocking sound.
  205. What is this seal/gasket?
  206. New Holley LS3 intake
  207. Mast C5R Head pics!!
  208. 4.8 crank
  209. Need help identifying a what 6.0L i going to buy!
  210. What r prefered head gaskets on LQ4 FI?
  211. *** HPE Flip-Drive Now $789 + FREE SHIPPING!!! For 2011***
  212. Is the LY-6 the only 6.0 that came wit hL-92's in the trucks?
  213. What is a LY-6 worth with 170 miles?
  214. LXR PS7-LS7 12 Degree Med. Bore Heads
  215. LS2 to 406?
  216. Need some help going from Ls1 to Ls2...
  217. MAST 305cc LS7 Heads or GM LSX-LS7 head for a NA 427
  218. differences in the ls3 and ls7 blocks?
  219. dragon slayer crank or !
  220. What do you want to see from Katech in 2011?
  221. CNC port shops opinions inside.
  222. Cam bearing installation... Help please
  223. what compression will i be running. -19.2 dish pistons
  224. Putting LS3 heads on LS2. Need head gasket help.
  225. ls3 heads or 243
  226. How fo you change the reluctor wheel?
  227. 6.0 Litre, L92, Cam selection, Max Power
  228. Advise needed, 5.3 transplant what to do?
  229. Anyone got an old crankshaft laying around?
  230. Having trouble yanking engine from trans
  231. Quick Question for LS3
  232. hey guys, new here, looking for suggestions and/or feedback
  233. is 75 psi oil pressure too high?
  234. 230/240 .592/.605 113lsa Opinions???
  235. LS2 oil pump question/dilemma
  236. 224/232 .585/590 opinion
  237. What year did the LQ 4 change to Gen IV ?
  238. Eliminating Valve Float
  239. Comp 227/235 113 LSA - 54-458-11
  240. Does this quote seem right?
  241. New to LS world...
  242. LS2 Cam Specs for Daily Driver: Discuss...
  243. Forged stock bore/rod LS3 replacement pistons?
  244. Eagle rods good or bad? ls2 d1 procharged
  245. HOw much can my ls2 sleeves handle? 4.005-4.030?
  246. L92 heads on stock cubes
  247. Cam swap with DOD turned off; retaining DOD lifters?
  248. Vacuum
  249. Ls2 whats the recommended bore size with out sleeving
  250. RHS Tall Deck Build
