View Full Version : Parts Classifieds
- Bellhousing blanket
- Performer RPM carb intake and Edelbrock ignition box
- FS: LS3 short 60 lb injectors
- Rx performance polished 1LE
- WANTED: Sunoco Hood Camaro Bolt On
- Twin on3 70mm Turbos, Twin Turbo Intercooler, Two Wastegates, BOV
- 82-02 LCA for sale and wheels come see ! !
- *for sale* lt1 t56
- *FOR SALE* LS6 Shortblock
- 1997-2004 Chevrolet Corvette Wiper Motor Assembly
- 1997-2004 Chevrolet Corvette HVAC Control Module
- New cam in box
- DBC truck throttle body (3 total)
- Moroso fabricated valve covers for LS Part#12563288
- Wtb t56 3/4 synchronizer
- Brand new 2000cc Bosch injectors EV14
- LS1 1.7 Roller Rockers
- FS: LS7 / C6 Corvette Garage Sale
- LT1 Coolant Crossover SOLD
- Diamond turbo pistons
- Efi live flashscan v2
- Ls1 valley pan cover,timing chain, lifter trays
- Qa1 coil over springs
- Wtb ls1 t56 bell housing from f body.
- MAF, Pushrods, Radiator, Stock valve train parts/Cam
- LS1 Computers
- Patriot CnC Ported Heads *NEW*
- FS: LS1 Intake and After Market Fuel Railes
- M6 & A4 Consoles
- 2010 Camaro SS TR6060 6 Speed Manual Transmission
- stock MAF and stock drive shaft
- C5 Z06 Wheel Chrome 17" X 10.5"
- TBSS Intake and stock fuel rails SOLD!
- 17x9.5 Black Chrome AFS ZR1 Replicas With Tires
- 9″ Ford Camaro/Firebird Sportsman 3.5″Aluminum Driveshaft
- 01 ls1/ls6 pistons and rods
- Oem firehawk hood(93-97)
- Brand new DeatchWerks 65lb ls3 height injectors
- 42lb green top injectors
- upgraded GM steering shafts!
- Sonnax Smart tech Imput drum, Smart shell 4l60e
- 99-02 ls1 painless harness and ECM
- For Sale: New Complete Dart 421 SBC Callies Oliver Wiseco
- Fast 90
- Stock OEM windshield and rear glass with tint and new seals FREE!!
- Stock OEM catalytic converters from my 2002 Camaro SS ~8000 miles
- Huge Garage Sale!!!! Buy now cheap
- 95 trans am part out
- C5/C6 parts for sale
- WHO NEEDS A FULL SET OF BOGART D10's WITH TIRES?
- LS1 F-body Huron speed turbo hot side pipes.
- TH400 big shot nitrous convertor by Greg Slack
- FTI TH400 turbo convertor
- Pics added*****ls1 ls2 ls3 lt4 camaro parts***************
- FTP air lid BRAND NEW. Never installed.
- SVO red top injectors
- Tial V60 wastegate
- Z06 seats
- Garage cleanout (Honeycomb, LQ4, Spohn, Tires, etc.)
- CTS-V spoiler
- D585 Coil Packs and harnesses - SOld
- >> 402ci stroker iron shortblock <<
- 750 holley ultra hp
- Wilwood 4 piston Brake calipers
- Stock Ls1 maf
- Parting Out 2001 Pontiac Trans Am Ram Air
- LS1/T56 harness and PCM
- Power Master CS130 Alternator New Sold
- FS: Manley .660 Lift Dual Springs p/n 221436-16
- Snap-On 5 gas analyzer
- Supercharged 383 lt1 650hp
- c5 rsi twin fuel setup, built tq tube,water pump, katec tensioner
- LS1 & LS3 CNC Heads - ARP Bolts - TFS Pushrods - T56 Bellhousing
- 205 lb bosch ev14 high impedance injectors like new
- TA performance cover, lnc-2000,shocks, struts and more.
- FS: LS7 Crank And Rods
- T56 for sale
- Racetronix plug and play fuel pump harness and more!
- FAST 4150 tb, and supporting parts plus GMPP Carb ls7 intake fs!
- Weld RTS
- Turbo Accessories, AN Fittings, Exhaust parts & much more! Priced to move!!!!
- FS: built LS7 short block
- extended Bosch front o2 sensors, ls1 MAF
- New in box Strange S60 3.54 gears
- ls1 parts
- Trick flow 215 cnc'd heads 59cc
- Wts 2 12" 2.5 in/out classic chambered/powerstick exhaust bullets
- Various Items For Sale
- LS1 T56 and other LS/4th gen stuff
- upper & lower control arms / Ccenter console lid
- SLP Air Lid $75
- 90mm LS2 T.B....
- Roller Rockers
- LS internal/external engine parts for sale....
- EFI Live Flashscan V2 tuning software (!)
- TSP 5/16" 7.400 pushrods
- SCT X4 handheld tuner for GM
- Gauging interest... LS6 intake f/s
- Electric LS Waterpump
- 06 gto t-56
- 10" ptc 3000-3200 stall t400
- F.A.S.T. 60lb Injectors
- WS6 Sportline Wheels,KMJ Headstuds,862 Heads w/ BTR Springs,Trans Am Foglights...etc.
- MSD 6010 Harness, new never used
- f\s brand new comp custom NA - NITROUS cam
- FS: 06 GTO oem radiator
- fs: LS2 90mm TB from an 06 gto
- Cleanout of various stock parts
- FS: used 06 GTO ebony leather seats
- ARP 134-3610 head bolts
- 99 manual pedal assembly/ 2 set of LS1 front brakes/98 convertible subframe connector
- Spohn Tubular K-member
- Corvette Y2K wheels
- Looking to trade items for a t56
- SOLD SPC Performance FasTrax Camber Caster Gauges and toe adapters
- ALL SOLD Auto meter cobalt gauge set, hurst shifter
- FS: 98-02 FBody radiator
- LS6 intake with DBW TB
- PTC turbo converter new in box
- 9.5" Revmax 3400 stall converter for 4L60E
- FAST 90 with small crack
- yella terra 1.7's & ls brake calipers
- Rebuilt lsa short block
- NIB Melling Oil Pump 10296 high volume/high pressure.
- Hoosier QTPs 26x9.50x16
- MSD Timing Twister
- Circle D Triple Disc Billet 4l80 converter.
- T56 Swap Parts and drag shocks
- lsx coil covers mildly custom
- LS1 motor SOLD, injectors, ypipe, tips, TB...NEED GONE
- Wtt dry kit for wet kit
- Comp cam 54-444-11 NIB
- Comp Cam7.425 push rods
- Grotyohann LS1 Headers & ORY 98-02 F-Body
- Comp cams LS 1.8 magnum roller rockers NIB
- Twin 255 pump setup
- Pioneer AVH-P4400BH
- LS1 Leftover Parts Sale - FRC's, Catch Can, 241 Heads, O2 Extensions, etc.
- fs:kooks true dual race system
- Honeycomb Taillights
- Pro Yank 3600 4L80 Slightly Used $800
- HP Tuners MVPI Pro
- h/c ls1long block,
- LS1 forged pistons 3.903 -11cc wiseco
- Moser bearings for 10 bolt rear
- Brand new 2010 camaro ss wheels $1100
- QTP long tube headers 1 3/4
- LS2 silver blade throttle bodies
- wiseco wrist pins
- original 02 camaro ypipe and cat o2 sensor
- 1993-2002 camaro westwing body kit
- 5.3 truck intake, coils, c5 accesories bracket
- Parting out 98 TA/updated 8/3/14
- 104mm Fast toys lid
- Zex plate kit
- Fbody m6 driveshaft
- BNIB NX single nozzle kit and Gen x2 accessory kit
- Nice Subwoofer Boxes!! CHEAP
- SLP 3.5" polished SS exhaust tips
- USED Pioneer AVH-P4400BH 7 inch Car DVD Player aux bluetooth
- LS1 Underdrive Harmonic Balancer
- LS1 / LS6 Stock Center Bolt Valve Covers
- Manual setup for c5 (held 1000hp)
- swagelok fittings 3/8" hard line to -6AN.
- SOLD! LS6 intake, p&p throttle body and fuel rails
- Siemens 60 and 80lb injectors
- S13 240SX LSX swap coil overs. BC BR racing series.
- 317 heads
- sold
- 862 heads
- List of parts for sale
- 2004 6.0 LQ4 w/ 1995 4L80
- Motor mounts, stands, T56 xmember EBC pads, collectors, MBC
- LS6 intake - Complete or Bare Intake - Other OEM engine pieces
- Radio delete/ climate control delete and gauge pod
- Stock Heads, Cam, Shocks, Spring, Misc
- corvette eradispeed rotor
- Procharger Surge Valve, Ls1 Mafs, stock cam
- new cam, .621 .617 115lsa
- Ls1 engine stands
- Built TH400
- 17" Torque Thrust rims with tires
- LS6 Intake and TB
- Ls1 parts, T56 parts, suspension parts
- LS Rockers with New Comp Cam Trunion Kit Installed
- LS3 long block
- Zoom d2 clutch kit (twin) used race version
- Zoom d2 clutch kit (twin) like new
- Convertible Top Boot / Tonneau / Cover
- Flowmaster mufflers (nib)
- F/T 4l80e 60k miles!
- Dewitts Rad, LED Tails, HIR Head Light Bulbs
- gto t56 mainshaft
- Need to pass inspection? Stock manifolds & Y pipe w/cats + other LS parts
- LS to TREMEC T-56/TR-6060 Bellhousing 89059423
- Pontiac G8 GXP Throwout Bearing/Slave Cylinder #92227219
- new dynotune dry kit 275 shipped!
- 2 BRAND NEW BORLA XR1 Bullets
- NOS Plate Kit 78mm
- Sold
- GM Performance Exhaust for 5th gen SS
- 04 duramax ppei autocal efi live tuner with Cts
- Yella Terra 1.8 rockers, Crane style valve spring compressor
- GMPP ASA cam and 7.4 hardened pushrods for sale
- 55lb FAST flow matched low impedance injectors ls1 style
- MS4 cam and .675 prc double springs
- injectors, intake stuff, fittings
- 4L60E and TCI converter for sale
- ms4 cam 7.4 hardened pushrods
- LS1 intake/DBW throttle body/injectors/fuel rails
- 1998-2002 SS Hood
- LS3 fuel injectors
- Stock LS7 fuel rails and intake mounting bolts
- FS: New Comp 7.475 .80 pushrod set
- Alky control meth kit
- Mint condition dash pad for 98-02 F body
- F body procharger intercooler kit.
- 2 Air Lids for Fbodys
- Alky control methynol kit
- LS1 Shop clean out
- Efilive v2
- 5 New Sets Wiseco pistons
- Fs 42lb injectors for LS1/LS6
- Vintage Air LS Series Chevy Front Runner Front Drive System (Part #174011)
- BRAND NEW 98-02 LS1 CAMARO & TRANS AM BREMBO BRAKE PADS - FRONT $35 shipped
- Drivers side honeycomb tail light (6/10) SOLD
- Stock z28 Snowflake wheels OBO
- Nitrous kit, MSD timing twister, Stock wheels with drag radials
- SOLD - 18"/19" Polished Corvette C6 Rims with Wheel Adaptors
- Moser 9in
- ** Sold **
- Vengeance vrx4 cam
- Procharger Big Red Blow Off Valve with Flange
- Blown06 Garage Sale (If it wasn't bad ass, I threw it away): Tons of stuff w/pics #2
- Blown06 Garage Sale (If it wasn't bad ass, I threw it away): Tons of stuff w/pics #1
- 706 Heads
- 5.3 Parts-MAKE OFFERS!
- Ls1 m6 Aluminum Driveshaft and suspension
- 15x10 Bogart D10s like new!!!
- Racetronix Fuel Pump 99+
- 5.3 short Block-Price Drop
- 1000cc ls1 injectors
- fast 85lb ls3 shorty injectors
- 5.3 flat tops BNIB $300 shipped
- 99' LS1 injectors, LS1 MAF
- Ls1 complete except wiring harness
- Full set of dynatechs, high flow cats, y pipe and 02s
- UMI valve cover spacer Kit
- 4l80e with new hd2 shift kit and converter
