View Full Version : Parts Classifieds
- Brand new ARP 2000 04+ LS head studs ARP 234-4345
- LS1/6/ 3 Internals and externals!
- Comp Cam
- FS DBW Pedal/TAC/Harness
- (Sold)Nasty performance sumped aluminum fuel tank
- Two sets of Truck Coils
- Corvette C5Z Real front wheels with Hoosier R7 Slicks
- KB 89072 21V Boost a pump
- SBC BBC performance Parts
- New tick stage 3 polluter cam
- 2 new LSA oil pan sets
- **SOLD**Single (1) Weld AlumaStar 2.0 15x8" 5x4.75 4" BS 788-508278
- **SOLD**Holley Mid Rise Single Plain EFI Intake Cathedral 300-137
- ARP head studs, Pacesetter LT, SLP lid, stock injectors
- Corvette wiring harness for manual
- Ls6 Intake Manifold
- A\C parts for sale
- Tsp 1 7/8 headers and custom true dual
- Brand new nitrous parts
- Monster stage 3 with flywheel
- 245/40R20 Blizzak LM32 For Sale
- Yank 4000 rpm stall for 4L60E (F-Body, Truck, CTS-V and GTO)
- LSA custom Blower cam
- 2014 Camaro ZL1 tr6060 6 speed Tremec
- L76 6.0l short block with 2 cams 35k Sold
- Sold
- Fbody oil pan, pick-up tube and windage tray
- Complete catch can set-up
- 2 Borg Warner S300SX3-60 Turbos NEW
- SOLD - Procharger 4.5" Twins plus Big Red
- BTR Stage IV Turbo Cam (SOLD)
- sbc payr replica engine
- Nitrous bottle
- tko 5oo transmission for sbc or bbc new
- Callie's rods,Eage crank
- Stock lsa injectors-SOLD
- Fuel injector connection 127lb injectors
- Looking for ls1 fuel rail
- PCM for sale
- B@m
- Trick flow pushrods 7.400
- Sold!!!
- 20x13 19x9.5 C5 C6 Z06 ZO6 MOTORSPORT CHROME WHEELS & TIRES
- 98 z28 4l60e tranny for sale
- 2002 10 bolt with GM 410s - $200
- SLP exhaust tips
- SOLD: LS3 ID 850 Injectors
- LJMS stage 2 turbo cam *used*
- BTR Stage 4 ls7 cam / FIC 80 injectors and more
- Yukon nodular 9 inch case- sold
- RCI Performance billet sheet metal cathedral port intake
- Damaged LT1 heads great to practice porting on
- arp main studs for lq4
- Deka 60’s
- 243 heads
- Nitrous outlet 78mm kit
- 2013 L96 6.0 LS Short Block
- 2013 Gen 4 6.0 L96 LS Short Block
- 2004 lq4 6.0 tsp cam, l92 heads, Holley intake longblock
- LS3 5364 heads stage 2 ported-SOLD
- 2012-2013 LS3 L92 L99 L9H L94 6.2 short block
- TCI 4l80e
- 5th Gen Stainless Work SP headers, Vararam, ECS BAP
- Bare ETP 4.1 LS7 Heads (Damaged)
- Custom Hotside with Garrett 76mm Turbo and alternator relocation
- LS3 intake ported-SOLD
- Johnson 2110 Lifters=SOLD
- FS New OEM LS6 Light Weight Valves
- Nitrous outlet stand alone fuel tank
- Yank 2800SS converter for 6L80=SOLD
- Gauging interest-Trickflow 215 cnc'd heads
- Fuel Rails. 80lb injectors
- LS Crank Pulley Pinning Kit
- LS T56 w/Bell Spec Clutch/GM Flywheel/ARP Needs Input Buffalo NY
- 12 Bolt 4.56 Spool with Tabular Torque Arm Buffalo NY
- Weldon 2345-A
- NEW MS4 Camshaft, NEW LS1/6 Rails & Injectors, H-30 Injectors & TBSS Intake Manifold
- Throttle Body's, MAF's & SLP Lid
- WTB: fuel lines for 1999 Z28
- Fast Xfi Sportsman Efi 303000
- 415 cubic inch lsx
- O.v.p
- Fast LSXR 102 intake complete LS3
- MSD Digital Shift Light and Tach Driver
- SOLD!! MADMAN 400 to LS1 Transmission Dip Stick and Tube
- Ls2 blower engine brand new 403c.i
- Complete ls6 intake
- Holley dominator ECU new
- T56-M6 Harness-Magnafuel-Complete Part Out
- FTP 98mm Lid + Delphi 85mm maf
- For Sale CCW Classics 17"
- AFX wideband nitrous coil pack relocation shift light tach
- SOLD - Used PAC 1905 .650" Lift Dual Spring Kit with Titanium Retainers
- Billet LS fuel rails w/ Crossover
- Need LS1 Camaro / Firebird Alternator Bracket
- Billet s472 and Circle D
- SOLD!! Siemens Deka 60lb injectors
- Centerforce dual friction clutch and flywheel
- LG Motorsports coilovers (f-body)
- New 2014 2015 Camaro SS Polished Aluminum Custom Bumper Grille T-rex
- Small garage clean out
- Garage sale
- Mahle Pistons 4.030 forged
- LS3 intake manifold setup w/ rails & injectors , etc complete
- LS7 Parts
- SOLD!!!!!Eagle 4" stroker crank 425 shipped
- 18" Raceline Billet Wheels(SOLD)
- 9 inch 3.89 gears & T56 pedals
- FTI Reid case 1.69 Glide *NEW*
- SOLD tick performance turbo cam brand new stg2
- COMPETE 88mm TURBO SYSTEM W/EXTRA'S
- LS parts
- T56 Pedals 98-02 Fbody
- Lt1 chrome power steering/ billet specialties
- Mamo mms 220
- Lt1 AFR heads vortech race supercharger plus more
- stage 6 rpm 4l60
- LS6 Intake with rails and injectors.
- LS9X Clutch and Katech Aluminum Flywheel
- *ALL THINGS FBODY/LSX..OEM PERFORMANCE 12BOLT T56 INJECTORS CompCam N20 +++
- LS to SBC Valvecover Adapters
- CPP Cast Exhaust Manifolds
- FS: Fast 102mm LSXR LS7
- LS6 intake with return style rails
- Nitrous Outlet heated bottle bracket
- Boxed bmr weld on sfcs sub frame connectors
- BRAND NEW TRE 80lb Siemens Deka IV EV6 Injectors
- Comp ARC 1.72 LS3 roller rockers
- FBODY PARTS.Gauge clusters,Stock ws6 wheels ,shift plate,Trans am tail lights
- Forged C5-C6 Hickock wheels
- 1 7/8 inch kooks 3" collector mid length headers
- Yella Terra Ultralite LS3
- Trick Flow 255 LS3 heads - 6 bolt heads
- ON3 Performance Map Sensor, 2 Bar
- LS7 OEM cam - BTR Stage 4 cam SOLD
- New 243 heads, tick cam, ls6 short block, ls7 lifters, l96 engine
- SLP PowerFlo / TSP ORY
- AGP Twin turbo kit for sale or Trade
- Aeromotive A1000 Stealth In-Tank Fuel Pump
- 416ci: LS7 crank/Ti rods, LS9 heads, LS3 intake your choice of cam/pistons
- FORD 9" / DETROIT LOCKER / 35 SPLINE / 187S160A with under 500 miles on it.
- cam for 5.3 with turbo
- 4 corner steam vent
- gates F body waterpump w/tensioner low miles sold
- stock 60k mile truck rockers.
- Hidden license plate retractor
- QA1 coilover springs, used 10" 450lb
- Cnc ported 317s w/Btr springs ready to go
- OEM 61k starter 98-02 fbody
- OEM AC delco motor mount new fbody
- Holley 160 LB/HR fuel injectors
- Fbody Garage Sale
- 243 heads fresh from machine shop
- WTT: LS3 Holley hi-ram for LS1 Holley hi-ram
- Racing Seat
- FAST XFI 2.0 with XIM and Touchscreen Dash
- Ls6 dorman intake,powerbond pulley
- FS: Ford 9" 4.30 ring & pinion
- Nitrous Outlet 90mm plate
- OEM Trans Am License Plate Cover
- BMR 4-Point Bolt-on Subframe Connectors - NEW
- 243 heads- SOLD
- SOLD--LS3 Intake Complete--SOLD
- Hotchkis Rear LCA $130 shipped
- SOLD-LS3 Gold Blade Throttle Body 12605109-SOLD
- MSD Timing Twister 8625 for LS1/LS6 - for FI / Nitrous / Meth applications
- Fast intake ms3 cam ect
- BMR lower control arms
- 2005 LS2/T56 Engine and Trans Wiring Harness and ECM
- fs - lunati crank, compstar rods, 5.3 aluminum block, clear lid, pistons, gaskets
- Ms4 cam, Texas speed 228 cam
- Strange manual brake master cyl
- Stock ls1 rockers 61k *SOLD*
- 2010-2012 5th Gen Alternator w/ bracket (50k miles)
- Sold
- NOS fuel/nitrous solenoids NEW
- PROcharger BIG RED BOV (blowoffvalve) 60mm
- Mildly built 4l60e with m&p ls flexplate and tci 3400 lock up conerter
- Rare clear 98-02 F-body Lid, SLP smooth bellow, C5 billet tail light covers
- Custom spec cam for boost
- 98-02 Trans Am Side Skirts - SOLD
- LS3/L92 Rockers, F.A.S.T. TB Adapter
- For Sale: 05-06 GTO RackDoctor Refurbished Rack & Pinion BNIB
- 2010 Camaro Engine cover
- Dry sump oil Tank
- Race technologies Dash 2 with wheel and aem thermocouple plus extras
- NEW Nitrous Outlet 90 plate & bottle heater
- LM7 Parts - intake, AC, WP, PS pump, balancer, manifolds, etc.
- 02 Camaro SS oem wing and rear hatch
- Freshly built 4L60E/4L65E LS and Edge converter *price drop*
- Ls1 nitrous outlet kit
- 90mm nitrous plate
- Nick Williams Black 102mm DBC TB
- Trickflow 235s
- Mamo Ported/Shaved Atomic MSD intake with Direct Port Nitrous Outlet
- Canton Cartridge/Canister Oil Filter Housing -10 AN
- 2016 l83 5.3 with extras
- Dual 10" custom sub box
- NW 90mm Throttle Body LS1
- Autometer nitrous pressure gauge
- Brand new prothane motor mounts and trans mount
- 243 heads
- Sold
- Brand new Manley double roller LS timing chain
- 2 CX Racing GT35 t4 turbos Brand New
- Big Red Procharger B.O.V. with aluminum Flange Kit
- FIC 80lb injectors with adapters for 98- 02 f bodies
- Howards Cams 248/268 solid roller (custom turbo cam)
- Fbody turbo setup $3500 obo
- Looking for ZL1 parts
- Lunati Voodoo Cam #60510 212/218
- Howards Cams 224/230 3-bolt cam
- 99 F-body LS1/A4 wire harness
- Holley blue pump $85 shipped
- New PRNDL switch and harness for 4L60e
- Brand New Race Star 92 Drag wheel Grey Metallic 17 x 9.5
- FIC (Fuel injector connection) 850cc LSA injectors
- Edelbrock E-force Supercharger
- Holley jet carb kit
- Used 102 FAST LSX-R intake combo; NEW PRICE!!!
- 411 ECU and FBody Harness 99-02
- Dual Intank Pumps Walboro 255 and Aeromotive 340 on Hobbs Switch
- 3.73 gears for stock rear
- Cleaning up
- Manton 3/8” pushrods 7.820”
- FAST 90 Cathedral Port Intake - used, So Cal
- HP tuners pro 6 credits
- Neil Chance 9.9 Custom Weld Together EZ Spool Converter for TH400
- LS1 intake
- BTR 7.275" Chromoly Pushrods
- Sold
- 5th gen Camaro SS Fuel pump w/ 50k miles
- Custom nitrous standalone fuel system
- Sold
- 5th Gen Ls3 underdrive pulley w/ ac and serp belt
- Tsp ory/slp lm1
- LS2/LS3 coils
- SOLD SOLD 6 AN Fuel Rail Crossover and (4) 6 AN Fuel Rail Fittings
- F-body camaro alternator bracket with alternator
- SOLD SOLD : Racetronix 48 lb. LS 60 mm injectors
- SOLD SOLD: '98-'02 F-body motor mounts
- SOLD SOLD: used Melling 296 Oil Pump
- LT1 a/c delete and alternator relocation brackets
- WS6 airbox, bellow, SLP lid and K&N filter + LS1 fans
- (2) Billet 7675 T4 .96 a/r CT4 Turbochargers - Polished, Red Anodized
- 1998 camaro z28 partout
- Pushrods Trick Flow Chromoly
- Pushrods Compcams HI-Tech 8461-16
- Moroso LS Valve Covers
- GM Performance LS3 CNC-Ported Cylinder Head
